make install error on Cray XT4
Mark Howison MHowison at lbl.gov
Fri Nov 6 10:19:20 CST 2009
Thanks Rob, that did the trick. Mark
On Fri, Nov 6, 2009 at 8:11 AM, Rob Latham <robl at mcs.anl.gov> wrote:
> On Fri, Nov 06, 2009 at 07:57:40AM -0800, Mark Howison wrote:
>> I am trying to install a pNetCDF 1.1.0 module on Franklin (Cray XT4)
>> at NERSC, but the make install is failing with
>> make[3]: Entering directory
>> `/global/common/franklin/usg/pnetcdf/parallel-netcdf-1.1.0/src/libf'
>> cp pnetcdf.inc pnetcdf.mod /usr/common/usg/pnetcdf/1.1.0/include/pnetcdf.inc
>> cp: target `/usr/common/usg/pnetcdf/1.1.0/include/pnetcdf.inc' is not
>> a directory
>> make[3]: *** [/usr/common/usg/pnetcdf/1.1.0/include/pnetcdf.inc] Error 1
>> Any ideas?
> Hi mark.  Not long after posting the release, Wei-keng found this
> problem, too.
> I've committed the fix in revision 713.  It is very simple if you want
> to apply by hand
> http://trac.mcs.anl.gov/projects/parallel-netcdf/changeset/713
> We've fixed a few defects since the release.  Probably will roll them
> up into a bugfix release soon.
> Thanks
> ==rob
> Rob Latham
> Mathematics and Computer Science Division
> Argonne National Lab, IL USA
