make install error on Cray XT4
Rob Latham robl at mcs.anl.gov
Fri Nov 6 10:11:29 CST 2009
On Fri, Nov 06, 2009 at 07:57:40AM -0800, Mark Howison wrote:
> I am trying to install a pNetCDF 1.1.0 module on Franklin (Cray XT4)
> at NERSC, but the make install is failing with
> make[3]: Entering directory
> `/global/common/franklin/usg/pnetcdf/parallel-netcdf-1.1.0/src/libf'
> cp pnetcdf.inc pnetcdf.mod /usr/common/usg/pnetcdf/1.1.0/include/pnetcdf.inc
> cp: target `/usr/common/usg/pnetcdf/1.1.0/include/pnetcdf.inc' is not
> a directory
> make[3]: *** [/usr/common/usg/pnetcdf/1.1.0/include/pnetcdf.inc] Error 1
> Any ideas?
Hi mark.  Not long after posting the release, Wei-keng found this
problem, too.
I've committed the fix in revision 713.  It is very simple if you want
to apply by hand
http://trac.mcs.anl.gov/projects/parallel-netcdf/changeset/713
We've fixed a few defects since the release.  Probably will roll them
up into a bugfix release soon.
Thanks
==rob
Rob Latham
Mathematics and Computer Science Division
Argonne National Lab, IL USA
