Compile pnetcdf library in IBM SP at NCAR
Jim Edwards jedwards at ucar.edu
Tue Dec 6 02:40:52 CST 2005
There is a pnetcdf version installed in the /contrib file system on the NCAR
IBM machines.  I have already reported this problem with configure to the
parallel netcdf developers.   They have provided a patched release to
address the problem.
Jim Edwards
IBM applications support
NCAR
On 12/6/05, Yu-Heng Tseng <YHTseng at lbl.gov> wrote:
> Hi,
> I couldn't compile the library in NCAR's IBM SP.
> It works fine in NERSC's IBM SP machine.
> I am not sure if this is compiler's or the library's problem.
> When I tried to "./configure" the
> it stops at the following line
> checking for Fortran-equivalent to netCDF "byte"... byte
> checking for Fortran-equivalent to netCDF "short"... integer*2
> checking for Fortran "integer*"... no
> configure: error: F77 does not support "integer*"
> The "integer*" is actually "integer8" in a successful check.
> Anyone has clues to solve the problem? The c compiler at NCAR
> seems different from that at NERSC.
> NCAR uses  VisualAge C++ Professional / C for AIX Compiler, Version 6
> Thanks a lot for your help!
> Yu-heng
> Yu-Heng Tseng
> Computational Research Division
> Lawrence Berkeley National Laboratory
> One Cyclotron Rd, MS: 50F-1650
> Berkeley, CA94720
> YHTseng at lbl.gov
> 510.495.2904
URL: <http://lists.mcs.anl.gov/pipermail/parallel-netcdf/attachments/20051206/7e7b7040/attachment.htm>
