Compile pnetcdf library in IBM SP at NCAR
Yu-Heng Tseng YHTseng at lbl.gov
Tue Dec 6 02:14:38 CST 2005
I couldn't compile the library in NCAR's IBM SP.
It works fine in NERSC's IBM SP machine.
I am not sure if this is compiler's or the library's problem.
When I tried to "./configure" the
it stops at the following line
checking for Fortran-equivalent to netCDF "byte"... byte
checking for Fortran-equivalent to netCDF "short"... integer*2
checking for Fortran "integer*"... no
configure: error: F77 does not support "integer*"
The "integer*" is actually "integer8" in a successful check.
Anyone has clues to solve the problem? The c compiler at NCAR
seems different from that at NERSC.
NCAR uses  VisualAge C++ Professional / C for AIX Compiler, Version 6
Thanks a lot for your help!
Yu-heng
Yu-Heng Tseng
Computational Research Division
Lawrence Berkeley National Laboratory
One Cyclotron Rd, MS: 50F-1650
Berkeley, CA94720
YHTseng at lbl.gov
510.495.2904
