deleting pnetcdf files
Rob Ross
rross at mcs.anl.gov
Fri May 7 11:10:48 CDT 2004
Hi Joachim,
You're right; we should do this. I'm adding it to the (relatively long
now) list of things that we need to get done.
Rob
Joachim Worringen wrote:
> Hi *,
> it occured to me that the pnetcdf API, like the original NetCDF API, doesn't
> provide a function to delete a file. While this is no problem for NetCDF, as
> it is based on a sequential file system which always has this as a native
> functionality, things are different for pnetcdf which is based on MPI-IO. A
> file which is created via MPI-IO is not necessarily visible in any native
> file system.
> Thus, to be safe, a file created via pnetcdf would have to be delete via
> MPI_File_delete(). However, it is somewhat cumbersome to use two different
> APIs to access a file. Therefore, I propose some sort of ncmpi_delete(char
> *fname) function. An MPI_Info object might be passed as well, although I can
> not think of any application for this when deleting a file!?
> Joachim
More information about the parallel-netcdf
