Houston, we have a problem
John Tannahill
tannahill1 at llnl.gov
Thu Jul 31 18:53:47 CDT 2003
Jianwei,
This is what I was suspecting as well.
John
Jianwei Li wrote:
> I think I was wrong after a careful look at the standard output.
> operation header I/O time data I/O time
> write 2: 1.250E-01 0.000E+00
> read 2: 6.250E-02 0.000E+00
> It seems that Nfmpi_Put_Vara_Float_All/Nfmpi_Get_Vara_Float_All
> are not running properly in this case.
> We should look in more details for problems ...
> Jianwei
> On Thu, 31 Jul 2003, Jianwei Li wrote:
>>John,
>>I had a quick run of your attached fortran code using pnetcdf0.8.8
>>on SDSC's IBM-SP (called bluehorizon). The code ran pretty well
>>and genterate these outputs:
>>standard output:
>>mype pe_coords totsiz_3d locsiz_3d kstart,jstart,istart
>> 0 0 0 0 256 256 256 16 256 256 0 0 0
>> 1 1 0 0 256 256 256 16 256 256 16 0 0
>> 13 13 0 0 256 256 256 16 256 256 208 0 0
>> 2 2 0 0 256 256 256 16 256 256 32 0 0
>> 8 8 0 0 256 256 256 16 256 256 128 0 0
>> 5 5 0 0 256 256 256 16 256 256 80 0 0
>> 9 9 0 0 256 256 256 16 256 256 144 0 0
>> 6 6 0 0 256 256 256 16 256 256 96 0 0
>> 10 10 0 0 256 256 256 16 256 256 160 0 0
>> 4 4 0 0 256 256 256 16 256 256 64 0 0
>> 11 11 0 0 256 256 256 16 256 256 176 0 0
>> 12 12 0 0 256 256 256 16 256 256 192 0 0
>> 14 14 0 0 256 256 256 16 256 256 224 0 0
>> 15 15 0 0 256 256 256 16 256 256 240 0 0
>> 3 3 0 0 256 256 256 16 256 256 48 0 0
>> 7 7 0 0 256 256 256 16 256 256 112 0 0
>>write 1: 2.500E-01 6.250E-02
>>write 3: 1.250E-01 6.250E-02
>>write 4: 1.875E-01 0.000E+00
>>write 5: 1.250E-01 0.000E+00
>> read 1: 6.250E-02 0.000E+00
>>diff, delmax, delmin = 1.009E+00 1.738E+00 1.701E-02
>> read 3: 6.250E-02 0.000E+00
>> read 4: 6.250E-02 0.000E+00
>> read 5: 6.250E-02 0.000E+00
>>File size: 1.342E+02 MB
>> Write: INF MB/s (eff., 1073.742 MB/s)
>> Read : INF MB/s (eff., 2147.484 MB/s)
>>Total number PEs: 16
>> 1.250E-01 0.000E+00 1073.742 6.250E-02 0.000E+00 2147.484
>>netcdf file <pnf_test.nc>:
>>ncdump pnf_test.nc | more
>>netcdf pnf_test {
>>dimensions:
>> level = 256 ;
>> latitude = 256 ;
>> longitude = 256 ;
>>variables:
>> float tt(level, latitude, longitude) ;
>>data:
>> tt =
>> 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
>>0,
>>0,
>>0,
>>0,
>>0,
>>0,
>>0,
>>0,
>>0,
>>0,
>>0,
>>0,
>>I think it's a successful run, right?
>>So what? Is it the Fortran Binding problem specially related to the Frost
>>platform? or something else?
>>btw, I build my pnetcdf lib as below and maybe you want to try this:
>>setenv CC xlc
>>setenv FC xlf
>>setenv F90 xlf90
>>setenv CXX xlC
>>setenv FFLAGS '-d -O2'
>>setenv MPICC mpcc_r
>>setenv MPIF77 mpxlf_r
>>#make
>>#make install
>>//what else can I do?:)
>>Jianwei
>>On Thu, 31 Jul 2003, John Tannahill wrote:
>>>Rob,
>>>I am hoping that I can catch you before you leave, so that you can
>>>pass this on to someone, but if you are already gone, can anyone
>>>else take a look at this?
>>>I have graduated up to my original bigger test case and the C version
>>>works, but the Fortran version doesn't. It's certainly possible that
>>>I have screwed up the translation from C to Fortran and I will be
>>>looking at that, but I wanted to pass this back to you folks, so that
>>>you can take a look at it to.
>>>I am using 0.8.8. Attached are two tar files that should be pretty
>>>self-explanatory, but let me know if you have questions.
>>>Regards,
>>>John
>>>John R. Tannahill
>>>Lawrence Livermore Nat. Lab.
>>>P.O. Box 808, M/S L-103
>>>Livermore, CA 94551
>>>925-423-3514
>>>Fax: 925-423-4908
John R. Tannahill
Livermore, CA 94551
925-423-3514
Fax: 925-423-4908
More information about the parallel-netcdf
