Houston, we have a problem
John Tannahill
tannahill1 at llnl.gov
Thu Jul 31 18:48:01 CDT 2003
Jianwei,
You may be running at bit better, but still are having problems I
think. The values in the netCDF output file should not be 0 and the
diff, delmax, delmin should. The read/write timings look suspicious
and you get a couple of INF's (so do I). My screen output is about
the same. The main issue I think is that the netCDF data does not
appear to be written out.
John
Jianwei Li wrote:
> John,
> I had a quick run of your attached fortran code using pnetcdf0.8.8
> on SDSC's IBM-SP (called bluehorizon). The code ran pretty well
> and genterate these outputs:
> standard output:
> mype pe_coords totsiz_3d locsiz_3d kstart,jstart,istart
> 0 0 0 0 256 256 256 16 256 256 0 0 0
> 1 1 0 0 256 256 256 16 256 256 16 0 0
> 13 13 0 0 256 256 256 16 256 256 208 0 0
> 2 2 0 0 256 256 256 16 256 256 32 0 0
> 8 8 0 0 256 256 256 16 256 256 128 0 0
> 5 5 0 0 256 256 256 16 256 256 80 0 0
> 9 9 0 0 256 256 256 16 256 256 144 0 0
> 6 6 0 0 256 256 256 16 256 256 96 0 0
> 10 10 0 0 256 256 256 16 256 256 160 0 0
> 4 4 0 0 256 256 256 16 256 256 64 0 0
> 11 11 0 0 256 256 256 16 256 256 176 0 0
> 12 12 0 0 256 256 256 16 256 256 192 0 0
> 14 14 0 0 256 256 256 16 256 256 224 0 0
> 15 15 0 0 256 256 256 16 256 256 240 0 0
> 3 3 0 0 256 256 256 16 256 256 48 0 0
> 7 7 0 0 256 256 256 16 256 256 112 0 0
> write 1: 2.500E-01 6.250E-02
> write 2: 1.250E-01 0.000E+00
> write 3: 1.250E-01 6.250E-02
> write 4: 1.875E-01 0.000E+00
> write 5: 1.250E-01 0.000E+00
> read 1: 6.250E-02 0.000E+00
> diff, delmax, delmin = 1.009E+00 1.738E+00 1.701E-02
> read 2: 6.250E-02 0.000E+00
> read 3: 6.250E-02 0.000E+00
> read 4: 6.250E-02 0.000E+00
> read 5: 6.250E-02 0.000E+00
> File size: 1.342E+02 MB
> Write: INF MB/s (eff., 1073.742 MB/s)
> Read : INF MB/s (eff., 2147.484 MB/s)
> Total number PEs: 16
> 1.250E-01 0.000E+00 1073.742 6.250E-02 0.000E+00 2147.484
> netcdf file <pnf_test.nc>:
> ncdump pnf_test.nc | more
> netcdf pnf_test {
> dimensions:
> level = 256 ;
> latitude = 256 ;
> longitude = 256 ;
> variables:
> float tt(level, latitude, longitude) ;
> data:
> tt =
> 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
> 0,
> 0,
> 0,
> 0,
> 0,
> 0,
> 0,
> 0,
> 0,
> 0,
> 0,
> 0,
> I think it's a successful run, right?
> So what? Is it the Fortran Binding problem specially related to the Frost
> platform? or something else?
> btw, I build my pnetcdf lib as below and maybe you want to try this:
> setenv CC xlc
> setenv FC xlf
> setenv F90 xlf90
> setenv CXX xlC
> setenv FFLAGS '-d -O2'
> setenv MPICC mpcc_r
> setenv MPIF77 mpxlf_r
> #make
> #make install
> //what else can I do?:)
> Jianwei
> On Thu, 31 Jul 2003, John Tannahill wrote:
>>Rob,
>>I am hoping that I can catch you before you leave, so that you can
>>pass this on to someone, but if you are already gone, can anyone
>>else take a look at this?
>>I have graduated up to my original bigger test case and the C version
>>works, but the Fortran version doesn't. It's certainly possible that
>>I have screwed up the translation from C to Fortran and I will be
>>looking at that, but I wanted to pass this back to you folks, so that
>>you can take a look at it to.
>>I am using 0.8.8. Attached are two tar files that should be pretty
>>self-explanatory, but let me know if you have questions.
>>Regards,
>>John
>>John R. Tannahill
>>Lawrence Livermore Nat. Lab.
>>P.O. Box 808, M/S L-103
>>Livermore, CA 94551
>>925-423-3514
>>Fax: 925-423-4908
John R. Tannahill
Livermore, CA 94551
925-423-3514
Fax: 925-423-4908
More information about the parallel-netcdf
