Houston, we have a problem
Jianwei Li
jianwei at cheetah.cpdc.ece.nwu.edu
Thu Jul 31 16:56:29 CDT 2003
I think I was wrong after a careful look at the standard output.
operation header I/O time data I/O time
write 2: 1.250E-01 0.000E+00
read 2: 6.250E-02 0.000E+00
It seems that Nfmpi_Put_Vara_Float_All/Nfmpi_Get_Vara_Float_All
are not running properly in this case.
We should look in more details for problems ...
Jianwei
On Thu, 31 Jul 2003, Jianwei Li wrote:
> John,
> I had a quick run of your attached fortran code using pnetcdf0.8.8
> on SDSC's IBM-SP (called bluehorizon). The code ran pretty well
> and genterate these outputs:
> standard output:
> mype pe_coords totsiz_3d locsiz_3d kstart,jstart,istart
> 0 0 0 0 256 256 256 16 256 256 0 0 0
> 1 1 0 0 256 256 256 16 256 256 16 0 0
> 13 13 0 0 256 256 256 16 256 256 208 0 0
> 2 2 0 0 256 256 256 16 256 256 32 0 0
> 8 8 0 0 256 256 256 16 256 256 128 0 0
> 5 5 0 0 256 256 256 16 256 256 80 0 0
> 9 9 0 0 256 256 256 16 256 256 144 0 0
> 6 6 0 0 256 256 256 16 256 256 96 0 0
> 10 10 0 0 256 256 256 16 256 256 160 0 0
> 4 4 0 0 256 256 256 16 256 256 64 0 0
> 11 11 0 0 256 256 256 16 256 256 176 0 0
> 12 12 0 0 256 256 256 16 256 256 192 0 0
> 14 14 0 0 256 256 256 16 256 256 224 0 0
> 15 15 0 0 256 256 256 16 256 256 240 0 0
> 3 3 0 0 256 256 256 16 256 256 48 0 0
> 7 7 0 0 256 256 256 16 256 256 112 0 0
> write 1: 2.500E-01 6.250E-02
> write 3: 1.250E-01 6.250E-02
> write 4: 1.875E-01 0.000E+00
> write 5: 1.250E-01 0.000E+00
> read 1: 6.250E-02 0.000E+00
> diff, delmax, delmin = 1.009E+00 1.738E+00 1.701E-02
> read 3: 6.250E-02 0.000E+00
> read 4: 6.250E-02 0.000E+00
> read 5: 6.250E-02 0.000E+00
> File size: 1.342E+02 MB
> Write: INF MB/s (eff., 1073.742 MB/s)
> Read : INF MB/s (eff., 2147.484 MB/s)
> Total number PEs: 16
> 1.250E-01 0.000E+00 1073.742 6.250E-02 0.000E+00 2147.484
> netcdf file <pnf_test.nc>:
> ncdump pnf_test.nc | more
> netcdf pnf_test {
> dimensions:
> level = 256 ;
> latitude = 256 ;
> longitude = 256 ;
> variables:
> float tt(level, latitude, longitude) ;
> data:
> tt =
> 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
> 0,
> 0,
> 0,
> 0,
> 0,
> 0,
> 0,
> 0,
> 0,
> 0,
> 0,
> 0,
> I think it's a successful run, right?
> So what? Is it the Fortran Binding problem specially related to the Frost
> platform? or something else?
> btw, I build my pnetcdf lib as below and maybe you want to try this:
> setenv CC xlc
> setenv FC xlf
> setenv F90 xlf90
> setenv CXX xlC
> setenv FFLAGS '-d -O2'
> setenv MPICC mpcc_r
> setenv MPIF77 mpxlf_r
> #make
> #make install
> //what else can I do?:)
> Jianwei
> On Thu, 31 Jul 2003, John Tannahill wrote:
> > Rob,
> > I am hoping that I can catch you before you leave, so that you can
> > pass this on to someone, but if you are already gone, can anyone
> > else take a look at this?
> > I have graduated up to my original bigger test case and the C version
> > works, but the Fortran version doesn't. It's certainly possible that
> > I have screwed up the translation from C to Fortran and I will be
> > looking at that, but I wanted to pass this back to you folks, so that
> > you can take a look at it to.
> > I am using 0.8.8. Attached are two tar files that should be pretty
> > self-explanatory, but let me know if you have questions.
> > Regards,
> > John
> > John R. Tannahill
> > Lawrence Livermore Nat. Lab.
> > P.O. Box 808, M/S L-103
> > Livermore, CA 94551
> > 925-423-3514
> > Fax: 925-423-4908
More information about the parallel-netcdf
