Houston, we have a problem
Jianwei Li
jianwei at cheetah.cpdc.ece.nwu.edu
Thu Jul 31 15:45:54 CDT 2003
John,
I had a quick run of your attached fortran code using pnetcdf0.8.8
on SDSC's IBM-SP (called bluehorizon). The code ran pretty well
and genterate these outputs:
standard output:
mype pe_coords totsiz_3d locsiz_3d kstart,jstart,istart
0 0 0 0 256 256 256 16 256 256 0 0 0
1 1 0 0 256 256 256 16 256 256 16 0 0
13 13 0 0 256 256 256 16 256 256 208 0 0
2 2 0 0 256 256 256 16 256 256 32 0 0
8 8 0 0 256 256 256 16 256 256 128 0 0
5 5 0 0 256 256 256 16 256 256 80 0 0
9 9 0 0 256 256 256 16 256 256 144 0 0
6 6 0 0 256 256 256 16 256 256 96 0 0
10 10 0 0 256 256 256 16 256 256 160 0 0
4 4 0 0 256 256 256 16 256 256 64 0 0
11 11 0 0 256 256 256 16 256 256 176 0 0
12 12 0 0 256 256 256 16 256 256 192 0 0
14 14 0 0 256 256 256 16 256 256 224 0 0
15 15 0 0 256 256 256 16 256 256 240 0 0
3 3 0 0 256 256 256 16 256 256 48 0 0
7 7 0 0 256 256 256 16 256 256 112 0 0
write 1: 2.500E-01 6.250E-02
write 2: 1.250E-01 0.000E+00
write 3: 1.250E-01 6.250E-02
write 4: 1.875E-01 0.000E+00
write 5: 1.250E-01 0.000E+00
read 1: 6.250E-02 0.000E+00
diff, delmax, delmin = 1.009E+00 1.738E+00 1.701E-02
read 2: 6.250E-02 0.000E+00
read 3: 6.250E-02 0.000E+00
read 4: 6.250E-02 0.000E+00
read 5: 6.250E-02 0.000E+00
File size: 1.342E+02 MB
Write: INF MB/s (eff., 1073.742 MB/s)
Read : INF MB/s (eff., 2147.484 MB/s)
Total number PEs: 16
1.250E-01 0.000E+00 1073.742 6.250E-02 0.000E+00 2147.484
netcdf file <pnf_test.nc>:
ncdump pnf_test.nc | more
netcdf pnf_test {
dimensions:
level = 256 ;
latitude = 256 ;
longitude = 256 ;
variables:
float tt(level, latitude, longitude) ;
data:
tt =
0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
0,
0,
0,
0,
0,
0,
0,
0,
0,
0,
0,
0,
I think it's a successful run, right?
So what? Is it the Fortran Binding problem specially related to the Frost
platform? or something else?
btw, I build my pnetcdf lib as below and maybe you want to try this:
setenv CC xlc
setenv FC xlf
setenv F90 xlf90
setenv CXX xlC
setenv FFLAGS '-d -O2'
setenv MPICC mpcc_r
setenv MPIF77 mpxlf_r
#make
#make install
//what else can I do?:)
Jianwei
On Thu, 31 Jul 2003, John Tannahill wrote:
> Rob,
> I am hoping that I can catch you before you leave, so that you can
> pass this on to someone, but if you are already gone, can anyone
> else take a look at this?
> I have graduated up to my original bigger test case and the C version
> works, but the Fortran version doesn't. It's certainly possible that
> I have screwed up the translation from C to Fortran and I will be
> looking at that, but I wanted to pass this back to you folks, so that
> you can take a look at it to.
> I am using 0.8.8. Attached are two tar files that should be pretty
> self-explanatory, but let me know if you have questions.
> Regards,
> John
> John R. Tannahill
> Lawrence Livermore Nat. Lab.
> P.O. Box 808, M/S L-103
> Livermore, CA 94551
> 925-423-3514
> Fax: 925-423-4908
More information about the parallel-netcdf
