fortran parallel-netcdf
Rob Ross
rross at mcs.anl.gov
Wed Jul 30 10:52:38 CDT 2003
On Wed, 30 Jul 2003, John Tannahill wrote:
> Bummer on frost being down this morning as I will be out this afternoon.
> I think I will try to install 0.8.7 on NERSC's SP.
Cool. I'll probably try to hop on this afternoon and check out these
latest changes before doing 0.8.8. I need to find a machine here with a
decent Fortran compiler too...I think that Chiba City (Linux cluster) has
one.
> Is it possible that my first attempt at getting the tar file was done
> while you were in the process of copying it in? Anyway, my second
> attempt got the missing files. Seems like tar files can get a little
> flaky at times too, in that I know I have put some together that somehow
> missed a file or two?
I copied it over there twice; the first time was missing some files. You
were too quick :). I'll do a better job of ordering operations next time.
> I will keep you informed to the various tests and timings I try to run
> in the coming days. I would be happy to pass them on to you if you
> want to include any of them in your test directory. Might be good to
> have an actual "application test" or two versus just "feature tests".
Absolutely! This would be great.
Rob
More information about the parallel-netcdf
