fortran parallel-netcdf
John Tannahill
tannahill1 at llnl.gov
Wed Jul 30 10:34:29 CDT 2003
Rob,
Bummer on frost being down this morning as I will be out this afternoon.
I think I will try to install 0.8.7 on NERSC's SP.
Is it possible that my first attempt at getting the tar file was done
while you were in the process of copying it in? Anyway, my second
attempt got the missing files. Seems like tar files can get a little
flaky at times too, in that I know I have put some together that somehow
missed a file or two?
I will keep you informed to the various tests and timings I try to run
in the coming days. I would be happy to pass them on to you if you
want to include any of them in your test directory. Might be good to
have an actual "application test" or two versus just "feature tests".
John
Rob Ross wrote:
> Excellent! I feel like I'm batting cleanup; everyone's earlier work got
> everything really close for me :).
> I think I did something a little off when building the tar files; there
> should have been a configure script in there somewhere. I'll make sure to
> get that straight before the next cut.
> I'm going to spend some time on the test subdir on Wed.; hopefully I can
> get the make issues there straightened out and get Tyce's fixes into
> place. With the Frost account going, it's a lot easier for me to see if
> things are working :). The environments (Linux and AIX) are terribly
> different; hopefully the improvements we're making to build on these two
> will help out on the NEC platform too.
> Let us know how the larger test runs go, ok? Also, do you think some of
> these tests would be good additions to the test subdir?
> Regards,
> Rob
> On Tue, 29 Jul 2003, John Tannahill wrote:
>>Rob,
>>Great news! Both of the test cases I sent this morning (C & Fortran)
>>now compile, link, and appear to run correctly!
>>I grabbed your 0.8.7 tar file and installed it on frost in my local
>>area, following your directions in the latest README file. The one
>>difference was that I executed autoconf just prior to the call to
>>./configure. Installation went smoothly.
>>I will try out the larger versions of the test codes tomorrow and
>>see what happens, but things look promising!
>>Thanks for all of your efforts!
>>Regards,
>>John
John R. Tannahill
Lawrence Livermore Nat. Lab.
P.O. Box 808, M/S L-103
Livermore, CA 94551
925-423-3514
Fax: 925-423-4908
More information about the parallel-netcdf
