fortran parallel-netcdf
Tyce Mclarty
mclarty3 at llnl.gov
Wed Jul 30 10:13:57 CDT 2003
Just a warning: frost will be down for dedicated system time Wed AM 8-noon.
At 12:52 AM 7/30/2003 -0500, Rob Ross wrote:
>Excellent! I feel like I'm batting cleanup; everyone's earlier work got
>everything really close for me :).
>I think I did something a little off when building the tar files; there
>should have been a configure script in there somewhere. I'll make sure to
>get that straight before the next cut.
>I'm going to spend some time on the test subdir on Wed.; hopefully I can
>get the make issues there straightened out and get Tyce's fixes into
>place. With the Frost account going, it's a lot easier for me to see if
>things are working :). The environments (Linux and AIX) are terribly
>different; hopefully the improvements we're making to build on these two
>will help out on the NEC platform too.
>Let us know how the larger test runs go, ok? Also, do you think some of
>these tests would be good additions to the test subdir?
>Regards,
>Rob
>On Tue, 29 Jul 2003, John Tannahill wrote:
> > Rob,
> > Great news! Both of the test cases I sent this morning (C & Fortran)
> > now compile, link, and appear to run correctly!
> > I grabbed your 0.8.7 tar file and installed it on frost in my local
> > area, following your directions in the latest README file. The one
> > difference was that I executed autoconf just prior to the call to
> > ./configure. Installation went smoothly.
> > I will try out the larger versions of the test codes tomorrow and
> > see what happens, but things look promising!
> > Thanks for all of your efforts!
> > Regards,
> > John
More information about the parallel-netcdf
