fortran parallel-netcdf
Tyce Mclarty
mclarty3 at llnl.gov
Mon Jul 28 19:05:30 CDT 2003
I was trying to run the fortran test in .../test/nf_test. After finding
several problem that convince me it has not run in quite a while, I think
it better to swith over and see if I can make progress running John's code,
since he is the one who really needs help here.
I'll put together a summary of what I found/corrected on nf_test soon.
Tyce
PS - Rob R., Do you still have accounts here on frost? If not would it be
useful to try to get it re-activated?
At 09:35 PM 7/25/2003 -0500, Rob Ross wrote:
>Thanks for your patience John; we'll have a look at this on Monday and see
>if we can fix things.
>Rob
>On Fri, 25 Jul 2003, John Tannahill wrote:
> > Rob and Rob,
> > I am having a good deal of difficulty getting the Fortran test code that I
> > put together to run. I have cut it down to where it just defines and
> > creates the initial file and I can't seem to get it to work. So what I did
> > is translate it back into C code and tried that. It ran just fine. I am
> > attaching both versions and the Makefile's I used to create them. I am
> > hoping that you guys can help me out. I am guessing the problem is with
> > the Fortran parallel-netcdf library, but who knows? Anyway, enough for
> > today.
> > Regards,
> > John
More information about the parallel-netcdf
