fortran parallel-netcdf
Rob Ross
rross at mcs.anl.gov
Tue Jul 29 18:36:27 CDT 2003
Ah, my mailer confused me by calling them "Application/X-JAVA-VM" (?).
Oops!
I just put the newest tar files up on our web server, and I've rebuilt it
on frost just to make sure I didn't mess anything up. The "make test"
still doesn't work at the moment, but I can knock that out soon; just need
a better, more general approach to cd'ing into subdirectories in the
Makefile.
Rob
On Tue, 29 Jul 2003, John Tannahill wrote:
> Rob,
> Earlier today, I sent you a couple of run scripts for frost.
> John
> Rob Ross wrote:
> > Hi all,
> > Ok, I've run out of time to work on this for today, so I'm tagging and
> > releasing. John's test code builds just fine; unfortunately I've
> > forgotten how to run jobs on Frost :(.
> > Can someone send me a poe script that will run that stuff? I'm a quick
> > learner from examples :)! In the mean time, I'm putting up version 0.8.7
> > on the web site so you guys can try it out.
> > Assuming I have time tomorrow, I'll try to get Tyce's test fixes into
> > place and do some runs of John's tests on Frost (if you guys haven't
> > already done that).
> > Getting closer...
> > Rob
> > On Mon, 28 Jul 2003, Tyce Mclarty wrote:
> >>John,
> >>Enclosed is a tar file with your code and slightly different Makefile that
> >>works for me on snow, which is just a smaller version of frost. It uses the
> >>parallel netCDF library I installed in /usr/local. It should be world useable.
> >>Try it and let me know if it doesn't work for you.
> >>Tyce
More information about the parallel-netcdf
