fortran parallel-netcdf
John Tannahill tannahill1 at llnl.gov
Tue Jul 29 18:22:24 CDT 2003
Rob,
Earlier today, I sent you a couple of run scripts for frost.
John
Rob Ross wrote:
> Hi all,
> Ok, I've run out of time to work on this for today, so I'm tagging and
> releasing.  John's test code builds just fine; unfortunately I've
> forgotten how to run jobs on Frost :(.
> Can someone send me a poe script that will run that stuff?  I'm a quick
> learner from examples :)!  In the mean time, I'm putting up version 0.8.7
> on the web site so you guys can try it out.
> Assuming I have time tomorrow, I'll try to get Tyce's test fixes into
> place and do some runs of John's tests on Frost (if you guys haven't
> already done that).
> Getting closer...
> Rob
> On Mon, 28 Jul 2003, Tyce Mclarty wrote:
>>John,
>>Enclosed is a tar file with your code and slightly different Makefile that
>>works for me on snow, which is just a smaller version of frost. It uses the
>>parallel netCDF library I installed in /usr/local. It should be world useable.
>>Try it and let me know if it doesn't work for you.
>>Tyce
John R. Tannahill
Lawrence Livermore Nat. Lab.
P.O. Box 808, M/S L-103
Livermore, CA  94551
925-423-3514
Fax:  925-423-4908
