fortran parallel-netcdf
John Tannahill tannahill1 at llnl.gov
Mon Jul 28 15:25:15 CDT 2003
Robs,
Have you been able to reproduce my problem?  Can I be of any help on this
end?  I am in kind of a holding pattern until this is resolved.
John
Rob Ross wrote:
> Thanks for your patience John; we'll have a look at this on Monday and see
> if we can fix things.
> Rob
> On Fri, 25 Jul 2003, John Tannahill wrote:
>>Rob and Rob,
>>I am having a good deal of difficulty getting the Fortran test code that I
>>put together to run.  I have cut it down to where it just defines and
>>creates the initial file and I can't seem to get it to work.  So what I did
>>is translate it back into C code and tried that.  It ran just fine.  I am
>>attaching both versions and the Makefile's I used to create them.  I am
>>hoping that you guys can help me out.  I am guessing the problem is with
>>the Fortran parallel-netcdf library, but who knows?  Anyway, enough for
>>today.
>>Regards,
>>John
John R. Tannahill
Lawrence Livermore Nat. Lab.
P.O. Box 808, M/S L-103
Livermore, CA  94551
925-423-3514
Fax:  925-423-4908
