fortran parallel-netcdf
John Tannahill
tannahill1 at llnl.gov
Mon Jul 28 13:33:32 CDT 2003
Rob,
I don't think I installed the library with the "--with-fortan=yes" flag.
Could this be the cause of my problems?
John
Rob Ross wrote:
> Thanks for your patience John; we'll have a look at this on Monday and see
> if we can fix things.
> Rob
> On Fri, 25 Jul 2003, John Tannahill wrote:
>>Rob and Rob,
>>I am having a good deal of difficulty getting the Fortran test code that I
>>put together to run. I have cut it down to where it just defines and
>>creates the initial file and I can't seem to get it to work. So what I did
>>is translate it back into C code and tried that. It ran just fine. I am
>>attaching both versions and the Makefile's I used to create them. I am
>>hoping that you guys can help me out. I am guessing the problem is with
>>the Fortran parallel-netcdf library, but who knows? Anyway, enough for
>>today.
>>Regards,
>>John
John R. Tannahill
Lawrence Livermore Nat. Lab.
P.O. Box 808, M/S L-103
Livermore, CA 94551
925-423-3514
Fax: 925-423-4908
More information about the parallel-netcdf
