fortran parallel-netcdf
Rob Ross rross at mcs.anl.gov
Fri Jul 25 21:35:17 CDT 2003
Thanks for your patience John; we'll have a look at this on Monday and see
if we can fix things.
Rob
On Fri, 25 Jul 2003, John Tannahill wrote:
> Rob and Rob,
> I am having a good deal of difficulty getting the Fortran test code that I
> put together to run.  I have cut it down to where it just defines and
> creates the initial file and I can't seem to get it to work.  So what I did
> is translate it back into C code and tried that.  It ran just fine.  I am
> attaching both versions and the Makefile's I used to create them.  I am
> hoping that you guys can help me out.  I am guessing the problem is with
> the Fortran parallel-netcdf library, but who knows?  Anyway, enough for
> today.
> Regards,
> John
