question
William Gropp
gropp at mcs.anl.gov
Thu Jul 24 07:07:17 CDT 2003
At 11:00 PM 7/22/2003 -0500, Robert Latham wrote:
>On Tue, Jul 22, 2003 at 01:34:11PM -0700, John Tannahill wrote:
> > I am steadily making progress. I have installed parallel-netcdf on
> > an IBM-SP at NERSC (seaborg). I have put together a C test code and
> > gotten it to work.
>fantastic. thanks for the success report!
> > I now have created a Fortran90 version of the
> > test code, but have not gotten it to link and run yet. Does the
> > default install put together a parallel-netcdf interface for C only?
>The default install *should* try to build the fortran interface, but
>it is not nearly as well tested as the c interface.
> > Do I need to change something and rebuild it to get a Fortran90
> > interface?
>i don't know f90 very well... if we have to do anything special for a
>f90 interface that we wouldn't have to do for an f77 interface, then
>maybe that's the problem?
We haven't built a specific f90 version; we should build a pnetcdf module
to at least provide the interface definitions. But the F77 version should
work, as long as the name mapping from the C to Fortran is correct. We
should also document the override for that in the case where the automatic
code fails.
> > Then do I just change the ncmpi_ calls to nfmpi_, and add
> > an ierror argument at the end?
>that's how it works in theory :>
> > Anywhere I could have looked to get answers to these questions
> > myself?
>nope :> you and troy baer are the only end users who have tried out
>our fortran interface. I'll see what i can find out tomorrow, and
>i'll be sure to let you know.
>Thanks for exercising the fortran side of things for us. Sorry you
>are running into so much difficulty, but we'll try to get you
>straight as soon as we can.
We'll add Fortran-specific documentation as well. Thanks for being on the
bleeding edge.
Bill
More information about the parallel-netcdf
