NC_FILL (no plans to implement)
Jianwei Li
jianwei at cheetah.cpdc.ece.nwu.edu
Tue Jul 22 15:12:27 CDT 2003
I think it's also a performance issue.
There may be some overhead using NC_FILL, depending on the density of
defined-value data in the file.
If pre-fill is performed when allocating the variables file space
and data is to be written later, NC_FILL is an obvious waist of
resources and I/O bandwidth.
Otherwise, it would be complecated for a multi-process program to
achieve this NC_FILL feature:)
Maybe we can implement it in the first approach as an optional feature
so that users have a chance if they really need to use it? Or we
can just go without it?
Jianwei
On Tue, 22 Jul 2003, Russ Rew wrote:
> Hi,
> >From the announcement to netcdfgroup, the "features not yet
> implemented" includes
> - NC_FILL (no plan to implement)
> Is this because preserving fill value semantics makes it harder to do
> parallel I/O? HDF5 supports fill-values for parallel I/O using
> MPI-IO, so I'm not sure why it's explicitly ruled out, or whether we
> should consider cutting it from our proposed feature list for the
> netCDF-4 on HDF5 project.
> --Russ
> _____________________________________________________________________
> Russ Rew UCAR Unidata Program
> russ at unidata.ucar.edu http://my.unidata.ucar.edu
More information about the parallel-netcdf
