parallel netCDF
Rob Ross
rross at mcs.anl.gov
Fri Aug 22 16:37:43 CDT 2003
On Fri, 22 Aug 2003, John Tannahill wrote:
> A quick follow-on and something else you may have already taken
> care of. I have finally gotten my latest Fortran test code to
> run correctly. The last thing I had to do is subtract 1 from
> each of the netCDF start points. Again, I think a C versus
> Fortran issue. Believe this needs to be fixed as well, but
> like I say, something you may already be aware of.
> Anxiously awaiting the next release,
> John
Ah, good to see that this is in fact the sort of problem that is going on.
Rob
More information about the parallel-netcdf
