initial timings
John Tannahill
tannahill1 at llnl.gov
Fri Aug 22 18:48:20 CDT 2003
Some initial timing results for parallel netCDF =>
File size: 216 MB
Processors: 16 (5x3+1; lonxlat+master)
Platform: NERSC IBM-SP (seaborg)
2D domain decomposition (lon/lat)
600x600x150 (lonxlatxlev)
real*4 array for I/O
Fortran code
Method 1: Use serial netCDF.
Slaves all read their own data.
For output:
Slaves send their data to the Master (MPI)
(all at once, no buffering; so file size restricted)
Master collects and outputs the data
(all at once)
Method 2: Use ANL's parallel-netcdf, beta version 0.8.9.
Slaves all read their own data, but use parallel-netcdf calls.
For output:
Slaves all output their own data
(all at once)
Read results =>
Method 2 appears to be about 33% faster than Method 1.
Write results =>
Method 2 appears to be about 6-7 times faster than Method 1.
Note that these preliminary results are based on the parameters given
above. Next week, I hope to look at different machines, different
file sizes (although I am memory limited on the Master as to how big
I can go), different numbers of processors, etc.
Anyway, things look promising.
John
John R. Tannahill
Lawrence Livermore Nat. Lab.
P.O. Box 808, M/S L-103
Livermore, CA 94551
925-423-3514
Fax: 925-423-4908
More information about the parallel-netcdf
