[opa-nightly-tests] jam OPA_Daily_Tests_1020Fri
HDF Tester hdftest at hdfgroup.org
Fri Oct 20 22:59:28 CDT 2017
*** OPA Tests on 1020Fri ***
   Tests Summary
PASSED jam: standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam
PASSED koala: standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala
PASSED moohan: standard op-configure --prefix=/mnt/scr1/pre-release/opa/moohan deploy moohan
PASSED ostrich: standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich
PASSED ostrich: standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl
PASSED platypus: standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus
PASSED quail: standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/quail deploy quail
   Tests Time Summary
koala: Ran 1(1/0/0) tests, Grand total test time =  0m 34s
platypus: Ran 1(1/0/0) tests, Grand total test time =  0m 43s
jam: Ran 1(1/0/0) tests, Grand total test time =  1m 2s
quail: Ran 1(1/0/0) tests, Grand total test time =  0m 56s
moohan: Ran 1(1/0/0) tests, Grand total test time =  1m 17s
ostrich: Ran 2(2/0/0) tests, Grand total test time =  4m 34s
jam: Ran 7(0/0/0) hosts, Grand total test time =  5m 41s
   Timekeeper log
Timekeeper started at Fri Oct 20 22:53:58 CDT 2017
Timekeeper sleeping for 720 seconds
   Tests Failures
Runtest did not exit normally.
   Watchers List
OPA Daily test features/platforms watchers and procedure
Procedure:
The watcher will investigate and report the cause of failure by 11am.
The developer who checked in the error code may report so by then too.
The watcher or the developer should get the failure fixed and report it
by 3pm.
Watcher for OPA:	 	Neil
updated: 2009/05/05
   Tests Details
 22:53:37 up 459 days,  9:35, 14 users,  load average: 0.23, 0.23, 0.63
Filesystem           1K-blocks      Used Available Use% Mounted on
/dev/sda3             31738420  18910548  11189644  63% /
/dev/sda1               101086     17532     78335  19% /boot
/dev/sda2             31738420    231720  29868472   1% /tmp
/dev/sda6             31738392   6892836  23207332  23% /var
/dev/sda7             31738392  18542628  11557540  62% /usr
/dev/sda8            124991068    192224 118347144   1% /var/tmp
/dev/mapper/VolGroup00-home
                     198351840 100217800  87895680  54% /home
/dev/sdc1            961432072 840129844  72464228  93% /mnt/scr1
/dev/sdd1            961432072 855029080  57564992  94% /mnt/hdf
tmpfs                  8313628         0   8313628   0% /dev/shm
gumund:/data/ftp     480719104 373859968  82439936  82% /mnt/ftp
gumund:/data/web     480719104 373859968  82439936  82% /mnt/web
10.10.10.15:/volume1/hdf2
                     1437485440 503923584 933459456  36% /mnt/hdf2
10.10.10.15:/volume1/readonly
                     1437485440 503923584 933459456  36% /mnt/readonly
                     1437485440 503923584 933459456  36% /mnt/ro-src
                     1437485440 503923584 933459456  36% /mnt/rw-src
STANDARD_OPT=setenv MAKE gmake deploydir /mnt/scr1/pre-release/opa
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam
Running source repository checkout with output saved in
   /mnt/scr1/SnapTest/snapshots-opa/log/REPO_LOG_1020Fri
Checking MANIFEST file ...
cat: /mnt/scr1/SnapTest/snapshots-opa/log/#runtest.1020Fri.9744: No such file or directory
rm: cannot remove `/mnt/scr1/SnapTest/snapshots-opa/log/#runtest.1020Fri.9744': No such file or directory
*** launching tests from jam ***
TESTHOST is jam
koala
platypus
moohan
ostrich
quail
kite
    Fork off timekeeper 12
Testing jam
ssh -o ConnectTimeout=60 jam -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname jam
 22:54:02 up 459 days,  9:36, 14 users,  load average: 0.29, 0.24, 0.62
/dev/sda2             31738420    231828  29868364   1% /tmp
/dev/sda6             31738392   6892948  23207220  23% /var
/dev/sdc1            961432072 840129872  72464200  93% /mnt/scr1
Extract source and run autogen if .
Fri Oct 20 22:54:13 CDT 2017
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam tests in jam ***
Uname -a: Linux jam 2.6.18-308.13.1.el5PAE #1 SMP Tue Aug 21 17:50:26 EDT 2012 i686 i686 i386 GNU/Linux
Running snapshot with output saved in
   /mnt/scr1/SnapTest/snapshots-opa/log/jam_1020Fri_2254
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam tests for jam ***
Fri Oct 20 22:55:14 CDT 2017
Total time = 1m 1s
*** finished tests in jam ***
Testing koala
ssh -o ConnectTimeout=60 koala -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname koala
 22:54:04 up 378 days,  9:13,  1 user,  load average: 0.00, 0.16, 0.14
/dev/sda7             22292052   4427736  16713664  21% /
/dev/sda5             12192608    389432  11173832   4% /tmp
/dev/sda3             12192636   1015860  10547432   9% /var
/dev/sda1               101086     18614     77253  20% /boot
/dev/sdc1             41279536  26323756  12858900  68% /usr
/dev/sdb             152754284  69868700  75126124  49% /scr
tmpfs                  6149552         0   6149552   0% /dev/shm
10.10.10.86:/home    198351872 100216832  87896064  54% /home
10.10.10.86:/mnt/hdf 961432576 855028736  57565184  94% /mnt/hdf
10.10.10.86:/mnt/scr1
                     961432576 840129536  72464384  93% /mnt/scr1
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala
Fri Oct 20 22:54:15 CDT 2017
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala tests in koala ***
Uname -a: Linux koala 2.6.18-409.el5 #1 SMP Tue Mar 15 18:13:50 EDT 2016 x86_64 x86_64 x86_64 GNU/Linux
   /mnt/scr1/SnapTest/snapshots-opa/log/koala_1020Fri_2254
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala tests for koala ***
Fri Oct 20 22:54:48 CDT 2017
Total time = 0m 33s
*** finished tests in koala ***
Testing platypus
ssh -o ConnectTimeout=60 platypus -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname platypus
 22:54:07 up 378 days,  9:04,  0 users,  load average: 0.52, 0.91, 0.96
/dev/sda6             54205540  34305352  17140048  67% /
tmpfs                  6099068         0   6099068   0% /dev/shm
/dev/sda1               194241     48310    135691  27% /boot
/dev/sda2             12850716     94536  12096724   1% /tmp
/dev/sda3             12850716   5640124   6551136  47% /var
/dev/sdd             152623212 132986068  11877684  92% /scr
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus
Fri Oct 20 22:54:17 CDT 2017
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus tests in platypus ***
Uname -a: Linux platypus 2.6.32-573.22.1.el6.x86_64 #1 SMP Wed Mar 23 03:35:39 UTC 2016 x86_64 x86_64 x86_64 GNU/Linux
   /mnt/scr1/SnapTest/snapshots-opa/log/platypus_1020Fri_2254
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus tests for platypus ***
Fri Oct 20 22:55:00 CDT 2017
Total time = 0m 43s
*** finished tests in platypus ***
Testing moohan
ssh -o ConnectTimeout=60 moohan -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname moohan
 22:54:11 up 323 days,  8:49,  2 users,  load average: 0.89, 1.02, 0.87
/dev/mapper/centos_moohan-root   52196352   9572676  42623676  19% /
devtmpfs                          3923072         0   3923072   0% /dev
tmpfs                             3939844        84   3939760   1% /dev/shm
tmpfs                             3939844    435264   3504580  12% /run
tmpfs                             3939844         0   3939844   0% /sys/fs/cgroup
/dev/md126p1                       506752    312612    194140  62% /boot
/dev/mapper/centos_moohan-scr   858065536 365559600 492505936  43% /scr
/dev/mapper/centos_moohan-tmp    16371712    185792  16185920   2% /tmp
/dev/mapper/centos_moohan-var    16371712   6024432  10347280  37% /var
jam:/mnt/scr1                   961432576 840129536  72464384  93% /mnt/scr1
jam:/home                       198351872 100216832  87896064  54% /home
jam:/mnt/hdf                    961432576 855028736  57565184  94% /mnt/hdf
10.10.10.15:/volume1/readonly  1437485440 503923584 933459456  36% /mnt/ro-src
tmpfs                              787972        12    787960   1% /run/user/42
tmpfs                              787972         0    787972   0% /run/user/2519
tmpfs                              787972         0    787972   0% /run/user/0
tmpfs                              787972         0    787972   0% /run/user/27429
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/moohan deploy moohan
Fri Oct 20 22:54:21 CDT 2017
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/moohan deploy moohan tests in moohan ***
Uname -a: Linux moohan.ad.hdfgroup.org 3.10.0-327.10.1.el7.x86_64 #1 SMP Tue Feb 16 17:03:50 UTC 2016 x86_64 x86_64 x86_64 GNU/Linux
   /mnt/scr1/SnapTest/snapshots-opa/log/moohan_1020Fri_2254
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/moohan deploy moohan tests for moohan ***
Fri Oct 20 22:55:38 CDT 2017
Total time = 1m 17s
*** finished tests in moohan ***
Testing ostrich
ssh -o ConnectTimeout=60 ostrich -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname ostrich
 22:54:14 up 3 days,  6:56,  2 users,  load average: 0.50, 0.93, 0.72
/dev/mapper/vg_ostrich-lv_root
                      140479384  27271316 106069024  21% /
tmpfs                   7821504         0   7821504   0% /dev/shm
/dev/sdb2                487652    107028    355024  24% /boot
/dev/sda2             124477364  90329024  27818588  77% /scr
jam:/mnt/scr1         961432576 840129536  72465408  93% /mnt/scr1
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich ; standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl
Fri Oct 20 22:54:24 CDT 2017
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich tests in ostrich ***
Uname -a: Linux ostrich 2.6.32-696.13.2.el6.ppc64 #1 SMP Fri Sep 22 12:25:47 EDT 2017 ppc64 ppc64 ppc64 GNU/Linux
   /mnt/scr1/SnapTest/snapshots-opa/log/ostrich_1020Fri_2254
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich tests for ostrich ***
Fri Oct 20 22:55:56 CDT 2017
Total time = 1m 32s
*** starting standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl tests in ostrich ***
   /mnt/scr1/SnapTest/snapshots-opa/log/ostrich_1020Fri_2255
*** finished standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl tests for ostrich ***
Fri Oct 20 22:58:58 CDT 2017
Total time = 3m 2s
*** finished tests in ostrich ***
Testing quail
ssh -o ConnectTimeout=60 quail -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname quail
22:54  up 99 days, 13:27, 0 users, load averages: 1.42 1.65 1.63
Filesystem                    512-blocks       Used Available Capacity  iused     ifree %iused  Mounted on
/dev/disk0s2                   488555536  293958712 194084824    61% 36808837  24260603   60%   /
devfs                                362        362         0   100%      627         0  100%   /dev
map auto_nfs                           0          0         0   100%        0         0  100%   /home
map auto_nfs                           0          0         0   100%        0         0  100%   /mnt/hdf
map auto_nfs                           0          0         0   100%        0         0  100%   /mnt/scr1
jam.ad.hdfgroup.org:/mnt/hdf  1922864144 1710058160 115129984    94% 11058406 111051546    9%   /mnt/hdf
jam.ad.hdfgroup.org:/mnt/scr1 1922864144 1680259864 144928280    93%  4132951 117977001    3%   /mnt/scr1
jam.ad.hdfgroup.org:/home      396703680  200435600 175791360    54%  1035544  50180840    2%   /home
TEST_TYPES=standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/quail deploy quail
Fri Oct 20 22:54:27 CDT 2017
*** starting standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/quail deploy quail tests in quail ***
Uname -a: Darwin quail.ad.hdfgroup.org 13.4.0 Darwin Kernel Version 13.4.0: Mon Jan 11 18:17:34 PST 2016; root:xnu-2422.115.15~1/RELEASE_X86_64 x86_64
   /Users/hdftest/snapshots-opa/log/quail_1020Fri_2254
*** finished standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/quail deploy quail tests for quail ***
Fri Oct 20 22:55:23 CDT 2017
Total time = 0m 56s
*** finished tests in quail ***
Testing kite
ssh -o ConnectTimeout=60 kite -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname kite
snapshots-opa: No such file or directory.
BASEDIR (/Users/hdftest/snapshots-) does not exist
	Fri Oct 20 22:54:18 CDT 2017
	****SYSTEM ERROR kite: BASEDIR (/Users/hdftest/snapshots-) does not exist
/mnt/scr1/SnapTest/snapshots-opa/bin/runtest: line 128: $SYSERRLOG: ambiguous redirect
****SYSTEM ERROR kite: Abnormal exit from runtest ****
	****SYSTEM ERROR kite: runtest command failed ****
More information about the opa-nightly-tests mailing list
