[opa-nightly-tests] jam OPA_Daily_Tests_1019Thu
HDF Tester
hdftest at hdfgroup.org
Thu Oct 19 23:08:45 CDT 2017
*** OPA Tests on 1019Thu ***
Tests Summary
PASSED jam: standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam
PASSED koala: standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala
PASSED moohan: standard op-configure --prefix=/mnt/scr1/pre-release/opa/moohan deploy moohan
PASSED ostrich: standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich
PASSED ostrich: standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl
PASSED platypus: standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus
PASSED quail: standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/quail deploy quail
Tests Time Summary
koala: Ran 1(1/0/0) tests, Grand total test time = 0m 32s
platypus: Ran 1(1/0/0) tests, Grand total test time = 0m 43s
jam: Ran 1(1/0/0) tests, Grand total test time = 1m 0s
quail: Ran 1(1/0/0) tests, Grand total test time = 0m 57s
moohan: Ran 1(1/0/0) tests, Grand total test time = 1m 11s
ostrich: Ran 2(2/0/0) tests, Grand total test time = 4m 47s
jam: Ran 7(0/0/0) hosts, Grand total test time = 5m 54s
Timekeeper log
Timekeeper started at Thu Oct 19 23:03:02 CDT 2017
Timekeeper sleeping for 720 seconds
Tests Failures
Runtest did not exit normally.
Watchers List
OPA Daily test features/platforms watchers and procedure
Procedure:
The watcher will investigate and report the cause of failure by 11am.
The developer who checked in the error code may report so by then too.
The watcher or the developer should get the failure fixed and report it
by 3pm.
Watcher for OPA: Neil
updated: 2009/05/05
Tests Details
23:02:41 up 458 days, 9:44, 18 users, load average: 1.12, 1.23, 1.58
Filesystem 1K-blocks Used Available Use% Mounted on
/dev/sda3 31738420 18910548 11189644 63% /
/dev/sda1 101086 17532 78335 19% /boot
/dev/sda2 31738420 233756 29866436 1% /tmp
/dev/sda6 31738392 6782340 23317828 23% /var
/dev/sda7 31738392 18542628 11557540 62% /usr
/dev/sda8 124991068 192224 118347144 1% /var/tmp
/dev/mapper/VolGroup00-home
198351840 100216284 87897196 54% /home
/dev/sdc1 961432072 834093820 78500252 92% /mnt/scr1
/dev/sdd1 961432072 860528800 52065272 95% /mnt/hdf
tmpfs 8313628 0 8313628 0% /dev/shm
gumund:/data/ftp 480719104 369961472 86338432 82% /mnt/ftp
gumund:/data/web 480719104 369961472 86338432 82% /mnt/web
10.10.10.15:/volume1/hdf2
1437485440 503923584 933459456 36% /mnt/hdf2
10.10.10.15:/volume1/readonly
1437485440 503923584 933459456 36% /mnt/readonly
1437485440 503923584 933459456 36% /mnt/ro-src
1437485440 503923584 933459456 36% /mnt/rw-src
STANDARD_OPT=setenv MAKE gmake deploydir /mnt/scr1/pre-release/opa
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam
Running source repository checkout with output saved in
/mnt/scr1/SnapTest/snapshots-opa/log/REPO_LOG_1019Thu
Checking MANIFEST file ...
cat: /mnt/scr1/SnapTest/snapshots-opa/log/#runtest.1019Thu.14616: No such file or directory
rm: cannot remove `/mnt/scr1/SnapTest/snapshots-opa/log/#runtest.1019Thu.14616': No such file or directory
*** launching tests from jam ***
TESTHOST is jam
koala
platypus
moohan
ostrich
quail
kite
Fork off timekeeper 12
Testing jam
ssh -o ConnectTimeout=60 jam -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname jam
23:03:07 up 458 days, 9:45, 18 users, load average: 1.54, 1.32, 1.60
/dev/sda2 31738420 233864 29866328 1% /tmp
/dev/sda6 31738392 6782464 23317704 23% /var
/dev/sdc1 961432072 834093848 78500224 92% /mnt/scr1
/dev/sdd1 961432072 860594200 51999872 95% /mnt/hdf
Extract source and run autogen if .
Thu Oct 19 23:03:17 CDT 2017
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam tests in jam ***
Uname -a: Linux jam 2.6.18-308.13.1.el5PAE #1 SMP Tue Aug 21 17:50:26 EDT 2012 i686 i686 i386 GNU/Linux
Running snapshot with output saved in
/mnt/scr1/SnapTest/snapshots-opa/log/jam_1019Thu_2303
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam tests for jam ***
Thu Oct 19 23:04:17 CDT 2017
Total time = 1m 0s
*** finished tests in jam ***
Testing koala
ssh -o ConnectTimeout=60 koala -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname koala
23:03:09 up 377 days, 9:22, 1 user, load average: 0.02, 0.11, 0.10
/dev/sda7 22292052 4427736 16713664 21% /
/dev/sda5 12192608 389480 11173784 4% /tmp
/dev/sda3 12192636 1015532 10547760 9% /var
/dev/sda1 101086 18614 77253 20% /boot
/dev/sdc1 41279536 26323756 12858900 68% /usr
/dev/sdb 152754284 69867128 75127696 49% /scr
tmpfs 6149552 0 6149552 0% /dev/shm
10.10.10.86:/home 198351872 100215808 87898112 54% /home
10.10.10.86:/mnt/hdf 961432576 860600320 51994624 95% /mnt/hdf
10.10.10.86:/mnt/scr1
961432576 834094080 78500864 92% /mnt/scr1
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala
Thu Oct 19 23:03:19 CDT 2017
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala tests in koala ***
Uname -a: Linux koala 2.6.18-409.el5 #1 SMP Tue Mar 15 18:13:50 EDT 2016 x86_64 x86_64 x86_64 GNU/Linux
/mnt/scr1/SnapTest/snapshots-opa/log/koala_1019Thu_2303
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala tests for koala ***
Thu Oct 19 23:03:51 CDT 2017
Total time = 0m 32s
*** finished tests in koala ***
Testing platypus
ssh -o ConnectTimeout=60 platypus -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname platypus
23:03:12 up 377 days, 9:13, 0 users, load average: 0.57, 0.88, 1.01
/dev/sda6 54205540 34305352 17140048 67% /
tmpfs 6099068 0 6099068 0% /dev/shm
/dev/sda1 194241 48310 135691 27% /boot
/dev/sda2 12850716 242076 11949184 2% /tmp
/dev/sda3 12850716 5628008 6563252 47% /var
/dev/sdd 152623212 131878972 12984780 92% /scr
10.10.10.86:/mnt/hdf 961432576 860607488 51987456 95% /mnt/hdf
961432576 834093056 78501888 92% /mnt/scr1
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus
Thu Oct 19 23:03:22 CDT 2017
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus tests in platypus ***
Uname -a: Linux platypus 2.6.32-573.22.1.el6.x86_64 #1 SMP Wed Mar 23 03:35:39 UTC 2016 x86_64 x86_64 x86_64 GNU/Linux
/mnt/scr1/SnapTest/snapshots-opa/log/platypus_1019Thu_2303
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus tests for platypus ***
Thu Oct 19 23:04:05 CDT 2017
Total time = 0m 43s
*** finished tests in platypus ***
Testing moohan
ssh -o ConnectTimeout=60 moohan -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname moohan
23:03:16 up 322 days, 8:58, 2 users, load average: 1.97, 1.19, 1.07
/dev/mapper/centos_moohan-root 52196352 9572676 42623676 19% /
devtmpfs 3923072 0 3923072 0% /dev
tmpfs 3939844 84 3939760 1% /dev/shm
tmpfs 3939844 402496 3537348 11% /run
tmpfs 3939844 0 3939844 0% /sys/fs/cgroup
/dev/md126p1 506752 312612 194140 62% /boot
/dev/mapper/centos_moohan-scr 858065536 364408604 493656932 43% /scr
/dev/mapper/centos_moohan-tmp 16371712 488640 15883072 3% /tmp
/dev/mapper/centos_moohan-var 16371712 5885596 10486116 36% /var
jam:/mnt/scr1 961432576 834094080 78500864 92% /mnt/scr1
jam:/home 198351872 100215808 87898112 54% /home
jam:/mnt/hdf 961432576 860616704 51978240 95% /mnt/hdf
10.10.10.15:/volume1/readonly 1437485440 503923584 933459456 36% /mnt/ro-src
tmpfs 787972 12 787960 1% /run/user/42
tmpfs 787972 0 787972 0% /run/user/2519
tmpfs 787972 0 787972 0% /run/user/0
tmpfs 787972 0 787972 0% /run/user/27429
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/moohan deploy moohan
Thu Oct 19 23:03:26 CDT 2017
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/moohan deploy moohan tests in moohan ***
Uname -a: Linux moohan.ad.hdfgroup.org 3.10.0-327.10.1.el7.x86_64 #1 SMP Tue Feb 16 17:03:50 UTC 2016 x86_64 x86_64 x86_64 GNU/Linux
/mnt/scr1/SnapTest/snapshots-opa/log/moohan_1019Thu_2303
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/moohan deploy moohan tests for moohan ***
Thu Oct 19 23:04:37 CDT 2017
Total time = 1m 11s
*** finished tests in moohan ***
Testing ostrich
ssh -o ConnectTimeout=60 ostrich -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname ostrich
23:03:18 up 2 days, 7:05, 1 user, load average: 0.13, 0.68, 0.77
/dev/mapper/vg_ostrich-lv_root
140479384 27287704 106052636 21% /
tmpfs 7821504 0 7821504 0% /dev/shm
/dev/sdb2 487652 107028 355024 24% /boot
/dev/sda2 124477364 80232752 37914860 68% /scr
jam:/mnt/hdf 961432576 860622848 51972096 95% /mnt/hdf
jam:/mnt/scr1 961432576 834093056 78500864 92% /mnt/scr1
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich ; standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl
Thu Oct 19 23:03:28 CDT 2017
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich tests in ostrich ***
Uname -a: Linux ostrich 2.6.32-696.13.2.el6.ppc64 #1 SMP Fri Sep 22 12:25:47 EDT 2017 ppc64 ppc64 ppc64 GNU/Linux
/mnt/scr1/SnapTest/snapshots-opa/log/ostrich_1019Thu_2303
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich tests for ostrich ***
Thu Oct 19 23:05:09 CDT 2017
Total time = 1m 41s
*** starting standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl tests in ostrich ***
/mnt/scr1/SnapTest/snapshots-opa/log/ostrich_1019Thu_2305
*** finished standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl tests for ostrich ***
Thu Oct 19 23:08:15 CDT 2017
Total time = 3m 6s
*** finished tests in ostrich ***
Testing quail
ssh -o ConnectTimeout=60 quail -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname quail
23:03 up 98 days, 13:36, 0 users, load averages: 1.41 1.67 1.60
Filesystem 512-blocks Used Available Capacity iused ifree %iused Mounted on
/dev/disk0s2 488555536 296040120 192003416 61% 37069013 24000427 61% /
devfs 362 362 0 100% 627 0 100% /dev
map auto_nfs 0 0 0 100% 0 0 100% /home
map auto_nfs 0 0 0 100% 0 0 100% /mnt/hdf
map auto_nfs 0 0 0 100% 0 0 100% /mnt/scr1
jam.ad.hdfgroup.org:/home 396703680 200432568 175794392 54% 1035541 50180843 2% /home
jam.ad.hdfgroup.org:/mnt/hdf 1922864144 1721254864 103933280 95% 11058255 111051697 9% /mnt/hdf
jam.ad.hdfgroup.org:/mnt/scr1 1922864144 1668186864 157001280 92% 4124621 117985331 3% /mnt/scr1
TEST_TYPES=standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/quail deploy quail
Thu Oct 19 23:03:31 CDT 2017
*** starting standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/quail deploy quail tests in quail ***
Uname -a: Darwin quail.ad.hdfgroup.org 13.4.0 Darwin Kernel Version 13.4.0: Mon Jan 11 18:17:34 PST 2016; root:xnu-2422.115.15~1/RELEASE_X86_64 x86_64
/Users/hdftest/snapshots-opa/log/quail_1019Thu_2303
*** finished standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/quail deploy quail tests for quail ***
Thu Oct 19 23:04:27 CDT 2017
Total time = 0m 56s
*** finished tests in quail ***
Testing kite
ssh -o ConnectTimeout=60 kite -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname kite
snapshots-opa: No such file or directory.
BASEDIR (/Users/hdftest/snapshots-) does not exist
****SYSTEM ERROR kite: BASEDIR (/Users/hdftest/snapshots-) does not exist
/mnt/scr1/SnapTest/snapshots-opa/bin/runtest: line 128: $SYSERRLOG: ambiguous redirect
****SYSTEM ERROR kite: Abnormal exit from runtest ****
****SYSTEM ERROR kite: runtest command failed ****
More information about the opa-nightly-tests
