[opa-nightly-tests] jam OPA_Daily_Tests_1021Sat
HDF Tester
hdftest at hdfgroup.org
Sat Oct 21 22:35:19 CDT 2017
*** OPA Tests on 1021Sat ***
Tests Summary
PASSED jam: standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam
PASSED koala: standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala
PASSED moohan: standard op-configure --prefix=/mnt/scr1/pre-release/opa/moohan deploy moohan
PASSED ostrich: standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich
PASSED ostrich: standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl
PASSED platypus: standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus
PASSED quail: standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/quail deploy quail
Tests Time Summary
koala: Ran 1(1/0/0) tests, Grand total test time = 0m 33s
platypus: Ran 1(1/0/0) tests, Grand total test time = 0m 42s
jam: Ran 1(1/0/0) tests, Grand total test time = 1m 2s
quail: Ran 1(1/0/0) tests, Grand total test time = 0m 56s
moohan: Ran 1(1/0/0) tests, Grand total test time = 1m 18s
ostrich: Ran 2(2/0/0) tests, Grand total test time = 4m 35s
jam: Ran 7(0/0/0) hosts, Grand total test time = 5m 44s
Timekeeper log
Timekeeper started at Sat Oct 21 22:29:46 CDT 2017
Timekeeper sleeping for 720 seconds
Tests Failures
Runtest did not exit normally.
Watchers List
OPA Daily test features/platforms watchers and procedure
Procedure:
The watcher will investigate and report the cause of failure by 11am.
The developer who checked in the error code may report so by then too.
The watcher or the developer should get the failure fixed and report it
by 3pm.
Watcher for OPA: Neil
updated: 2009/05/05
Tests Details
22:29:25 up 460 days, 9:11, 14 users, load average: 1.29, 0.84, 1.26
Filesystem 1K-blocks Used Available Use% Mounted on
/dev/sda3 31738420 18910548 11189644 63% /
/dev/sda1 101086 17532 78335 19% /boot
/dev/sda2 31738420 232140 29868052 1% /tmp
/dev/sda6 31738392 7024196 23075972 24% /var
/dev/sda7 31738392 18542628 11557540 62% /usr
/dev/sda8 124991068 192224 118347144 1% /var/tmp
/dev/mapper/VolGroup00-home
198351840 100219200 87894280 54% /home
/dev/sdc1 961432072 840181864 72412208 93% /mnt/scr1
/dev/sdd1 961432072 855029188 57564884 94% /mnt/hdf
tmpfs 8313628 0 8313628 0% /dev/shm
gumund:/data/ftp 480719104 373858688 82441216 82% /mnt/ftp
gumund:/data/web 480719104 373858688 82441216 82% /mnt/web
10.10.10.15:/volume1/hdf2
1437485440 503923584 933459456 36% /mnt/hdf2
10.10.10.15:/volume1/readonly
1437485440 503923584 933459456 36% /mnt/readonly
1437485440 503923584 933459456 36% /mnt/ro-src
1437485440 503923584 933459456 36% /mnt/rw-src
STANDARD_OPT=setenv MAKE gmake deploydir /mnt/scr1/pre-release/opa
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam
Running source repository checkout with output saved in
/mnt/scr1/SnapTest/snapshots-opa/log/REPO_LOG_1021Sat
Checking MANIFEST file ...
cat: /mnt/scr1/SnapTest/snapshots-opa/log/#runtest.1021Sat.19267: No such file or directory
rm: cannot remove `/mnt/scr1/SnapTest/snapshots-opa/log/#runtest.1021Sat.19267': No such file or directory
*** launching tests from jam ***
TESTHOST is jam
koala
platypus
moohan
ostrich
quail
kite
Fork off timekeeper 12
Testing jam
ssh -o ConnectTimeout=60 jam -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname jam
22:29:51 up 460 days, 9:11, 14 users, load average: 1.20, 0.85, 1.25
/dev/sda2 31738420 232248 29867944 1% /tmp
/dev/sda6 31738392 7024208 23075960 24% /var
/dev/sdc1 961432072 840394976 72199096 93% /mnt/scr1
Extract source and run autogen if .
Sat Oct 21 22:30:01 CDT 2017
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam tests in jam ***
Uname -a: Linux jam 2.6.18-308.13.1.el5PAE #1 SMP Tue Aug 21 17:50:26 EDT 2012 i686 i686 i386 GNU/Linux
Running snapshot with output saved in
/mnt/scr1/SnapTest/snapshots-opa/log/jam_1021Sat_2230
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam tests for jam ***
Sat Oct 21 22:31:03 CDT 2017
Total time = 1m 2s
*** finished tests in jam ***
Testing koala
ssh -o ConnectTimeout=60 koala -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname koala
22:29:55 up 379 days, 8:49, 1 user, load average: 0.02, 0.01, 0.00
/dev/sda7 22292052 4427736 16713664 21% /
/dev/sda5 12192608 386088 11177176 4% /tmp
/dev/sda3 12192636 1015468 10547824 9% /var
/dev/sda1 101086 18614 77253 20% /boot
/dev/sdc1 41279536 26323756 12858900 68% /usr
/dev/sdb 152754284 69865864 75128960 49% /scr
tmpfs 6149552 0 6149552 0% /dev/shm
10.10.10.86:/home 198351872 100218880 87895040 54% /home
10.10.10.86:/mnt/hdf 961432576 855028736 57565184 94% /mnt/hdf
10.10.10.86:/mnt/scr1
961432576 840474624 72120320 93% /mnt/scr1
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala
Sat Oct 21 22:30:06 CDT 2017
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala tests in koala ***
Uname -a: Linux koala 2.6.18-409.el5 #1 SMP Tue Mar 15 18:13:50 EDT 2016 x86_64 x86_64 x86_64 GNU/Linux
/mnt/scr1/SnapTest/snapshots-opa/log/koala_1021Sat_2230
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala tests for koala ***
Sat Oct 21 22:30:38 CDT 2017
Total time = 0m 32s
*** finished tests in koala ***
Testing platypus
ssh -o ConnectTimeout=60 platypus -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname platypus
22:29:58 up 379 days, 8:40, 0 users, load average: 0.99, 1.02, 1.12
/dev/sda6 54205540 34305352 17140048 67% /
tmpfs 6099068 0 6099068 0% /dev/shm
/dev/sda1 194241 48310 135691 27% /boot
/dev/sda2 12850716 211756 11979504 2% /tmp
/dev/sda3 12850716 5696060 6495200 47% /var
/dev/sdd 152623212 130906876 13956876 91% /scr
961432576 840488960 72105984 93% /mnt/scr1
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus
Sat Oct 21 22:30:08 CDT 2017
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus tests in platypus ***
Uname -a: Linux platypus 2.6.32-573.22.1.el6.x86_64 #1 SMP Wed Mar 23 03:35:39 UTC 2016 x86_64 x86_64 x86_64 GNU/Linux
/mnt/scr1/SnapTest/snapshots-opa/log/platypus_1021Sat_2230
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus tests for platypus ***
Sat Oct 21 22:30:50 CDT 2017
Total time = 0m 42s
*** finished tests in platypus ***
Testing moohan
ssh -o ConnectTimeout=60 moohan -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname moohan
22:30:01 up 324 days, 8:25, 2 users, load average: 1.74, 1.37, 1.09
/dev/mapper/centos_moohan-root 52196352 9572676 42623676 19% /
devtmpfs 3923072 0 3923072 0% /dev
tmpfs 3939844 84 3939760 1% /dev/shm
tmpfs 3939844 418880 3520964 11% /run
tmpfs 3939844 0 3939844 0% /sys/fs/cgroup
/dev/md126p1 506752 312612 194140 62% /boot
/dev/mapper/centos_moohan-scr 858065536 365303308 492762228 43% /scr
/dev/mapper/centos_moohan-tmp 16371712 491968 15879744 4% /tmp
/dev/mapper/centos_moohan-var 16371712 5948272 10423440 37% /var
jam:/mnt/scr1 961432576 840504320 72090624 93% /mnt/scr1
jam:/home 198351872 100218880 87895040 54% /home
jam:/mnt/hdf 961432576 855028736 57565184 94% /mnt/hdf
10.10.10.15:/volume1/readonly 1437485440 503923584 933459456 36% /mnt/ro-src
tmpfs 787972 12 787960 1% /run/user/42
tmpfs 787972 0 787972 0% /run/user/2519
tmpfs 787972 0 787972 0% /run/user/0
tmpfs 787972 0 787972 0% /run/user/27429
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/moohan deploy moohan
Sat Oct 21 22:30:11 CDT 2017
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/moohan deploy moohan tests in moohan ***
Uname -a: Linux moohan.ad.hdfgroup.org 3.10.0-327.10.1.el7.x86_64 #1 SMP Tue Feb 16 17:03:50 UTC 2016 x86_64 x86_64 x86_64 GNU/Linux
/mnt/scr1/SnapTest/snapshots-opa/log/moohan_1021Sat_2230
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/moohan deploy moohan tests for moohan ***
Sat Oct 21 22:31:29 CDT 2017
Total time = 1m 18s
*** finished tests in moohan ***
Testing ostrich
ssh -o ConnectTimeout=60 ostrich -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname ostrich
22:30:03 up 4 days, 6:32, 2 users, load average: 0.21, 0.72, 0.75
/dev/mapper/vg_ostrich-lv_root
140479384 27118192 106222148 21% /
tmpfs 7821504 0 7821504 0% /dev/shm
/dev/sdb2 487652 107028 355024 24% /boot
/dev/sda2 124477364 95973080 22174532 82% /scr
jam:/mnt/scr1 961432576 840540160 72054784 93% /mnt/scr1
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich ; standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl
Sat Oct 21 22:30:13 CDT 2017
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich tests in ostrich ***
Uname -a: Linux ostrich 2.6.32-696.13.2.el6.ppc64 #1 SMP Fri Sep 22 12:25:47 EDT 2017 ppc64 ppc64 ppc64 GNU/Linux
/mnt/scr1/SnapTest/snapshots-opa/log/ostrich_1021Sat_2230
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich tests for ostrich ***
Sat Oct 21 22:31:45 CDT 2017
Total time = 1m 32s
*** starting standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl tests in ostrich ***
/mnt/scr1/SnapTest/snapshots-opa/log/ostrich_1021Sat_2231
*** finished standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl tests for ostrich ***
Sat Oct 21 22:34:48 CDT 2017
Total time = 3m 3s
*** finished tests in ostrich ***
Testing quail
ssh -o ConnectTimeout=60 quail -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname quail
22:30 up 100 days, 13:03, 0 users, load averages: 1.50 1.49 1.60
Filesystem 512-blocks Used Available Capacity iused ifree %iused Mounted on
/dev/disk0s2 488555536 295035952 193007584 61% 36943492 24125948 60% /
devfs 361 361 0 100% 626 0 100% /dev
map auto_nfs 0 0 0 100% 0 0 100% /home
map auto_nfs 0 0 0 100% 0 0 100% /mnt/hdf
map auto_nfs 0 0 0 100% 0 0 100% /mnt/scr1
jam.ad.hdfgroup.org:/mnt/scr1 1922864144 1681081656 144106488 93% 4139528 117970424 3% /mnt/scr1
jam.ad.hdfgroup.org:/home 396703680 200438400 175788560 54% 1035553 50180831 2% /home
jam.ad.hdfgroup.org:/mnt/hdf 1922864144 1710058376 115129768 94% 11058410 111051542 9% /mnt/hdf
TEST_TYPES=standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/quail deploy quail
Sat Oct 21 22:30:16 CDT 2017
*** starting standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/quail deploy quail tests in quail ***
Uname -a: Darwin quail.ad.hdfgroup.org 13.4.0 Darwin Kernel Version 13.4.0: Mon Jan 11 18:17:34 PST 2016; root:xnu-2422.115.15~1/RELEASE_X86_64 x86_64
/Users/hdftest/snapshots-opa/log/quail_1021Sat_2230
*** finished standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/quail deploy quail tests for quail ***
Sat Oct 21 22:31:12 CDT 2017
Total time = 0m 56s
*** finished tests in quail ***
Testing kite
ssh -o ConnectTimeout=60 kite -n cd snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname kite
snapshots-opa: No such file or directory.
BASEDIR (/Users/hdftest/snapshots-) does not exist
****SYSTEM ERROR kite: BASEDIR (/Users/hdftest/snapshots-) does not exist
/mnt/scr1/SnapTest/snapshots-opa/bin/runtest: line 128: $SYSERRLOG: ambiguous redirect
****SYSTEM ERROR kite: Abnormal exit from runtest ****
****SYSTEM ERROR kite: runtest command failed ****
More information about the opa-nightly-tests
