[opa-nightly-tests] jam OPA_Daily_Tests_1010Sat_FAILED!!!
HDF Tester hdftest at hdfgroup.org
Sat Oct 10 00:08:48 CDT 2015
*** OPA Tests on 1010Sat ***
   Tests Summary
****FAILED emu: standard op-configure --prefix=/mnt/scr1/pre-release/opa/emu32 deploy emu32****
PASSED jam: standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam
PASSED kite: standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/kite deploy kite
PASSED koala: standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala
PASSED ostrich: standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich
PASSED ostrich: standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl
PASSED platypus: standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus
PASSED quail: standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/quail deploy quail
   Tests Time Summary
emu: Ran 1(0/1/0) tests, Grand total test time =  0m 3s
koala: Ran 1(1/0/0) tests, Grand total test time =  0m 33s
platypus: Ran 1(1/0/0) tests, Grand total test time =  0m 38s
kite: Ran 1(1/0/0) tests, Grand total test time =  0m 48s
jam: Ran 1(1/0/0) tests, Grand total test time =  1m 1s
quail: Ran 1(1/0/0) tests, Grand total test time =  0m 53s
ostrich: Ran 2(2/0/0) tests, Grand total test time =  4m 45s
jam: Ran 7(0/0/0) hosts, Grand total test time =  5m 50s
   Timekeeper log
Timekeeper started at Sat Oct 10 00:03:09 CDT 2015
Timekeeper sleeping for 720 seconds
   Tests Failures
Dumping logfile of emu: standard op-configure --prefix=/mnt/scr1/pre-release/opa/emu32 deploy emu32
Last 50 lines of /mnt/scr1/SnapTest/snapshots-opa/log/emu_1010Sat_0003
GROUP=hdf
HDF5_ACLOCAL=/mnt/hdf/packages/AUTOTOOLS/automake/1.15/sun4v/bin/aclocal-1.15
HDF5_AUTOCONF=/mnt/hdf/packages/AUTOTOOLS/autoconf/2.69/sun4v/bin/autoconf
HDF5_AUTOHEADER=/mnt/hdf/packages/AUTOTOOLS/autoconf/2.69/sun4v/bin/autoheader
HDF5_AUTOMAKE=/mnt/hdf/packages/AUTOTOOLS/automake/1.15/sun4v/bin/automake-1.15
HDF5_LIBTOOL=/mnt/hdf/packages/AUTOTOOLS/libtool/2.4.6/sun4v/bin/libtool
HDF5_M4=/mnt/hdf/packages/AUTOTOOLS/m4/1.4.17/sun4v/bin/m4
HDF5TestExpress=yes
HOME=/home/hdftest
HOST=emu
HOSTTYPE=sun4
JAVA_HOME=/usr/lib/jvm/jre-1.6.0
LANG=en_US.UTF-8
LC_ALL=
LC_COLLATE=
LC_CTYPE=
LC_MESSAGES=
LC_MONETARY=
LC_NUMERIC=
LC_TIME=
LOGNAME=hdftest
MACHTYPE=sparc
MAIL=/var/mail/hdftest
MAKE=gmake
NLSPATH=/usr/share/locale/%L/LC_MESSAGES/%N.cat
OSTYPE=solaris
PATH=/home/hdftest/bin:/usr/hdf/bin:/home/hdftest/bin:/usr/hdf/bin:/usr/bin:/usr/sbin:/opt/solarisstudio/bin:/opt/cmake/bin:/opt/svn/bin:/mnt/hdf/ec2-api-tools/bin
PWD=/mnt/scr1/SnapTest/snapshots-opa
REMOTEHOST=
SET_PATH=yes
SHELL=/bin/tcsh
SHLVL=3
SSH_CLIENT=10.10.10.86 34364 22
SSH_CONNECTION=10.10.10.86 34364 10.10.10.84 22
SVNROOT=http://svn.hdfgroup.uiuc.edu
TZ=localtime
USER=hdftest
VENDOR=sun
===Done Dumping environment variables after option parsing ===
===== Run Tests: Saturday, October 10, 2015 12:03:03 AM CDT =====
Remove contents of emu.
diff: /home/hdftest/snapshots-opa/previous/MANIFEST: No such file or directory
===== configure: Saturday, October 10, 2015 12:03:03 AM CDT =====
checking for a BSD-compatible install... /usr/bin/ginstall -c
checking whether build environment is sane... configure: error: newly created file is older than distributed files!
Check your system clock
Failed running configure
===== Exit bin/snapshot with status=1: Saturday, October 10, 2015 12:03:05 AM CDT =====
Dumping done
Runtest did not exit normally.
   Watchers List
OPA Daily test features/platforms watchers and procedure
Procedure:
The watcher will investigate and report the cause of failure by 11am.
The developer who checked in the error code may report so by then too.
The watcher or the developer should get the failure fixed and report it
by 3pm.
Watcher for OPA:	 	Neil
updated: 2009/05/05
   Tests Details
 00:02:48 up 9 days, 10:58, 19 users,  load average: 0.46, 0.39, 0.30
Filesystem           1K-blocks      Used Available Use% Mounted on
/dev/sda3             31738420   8765876  21334316  30% /
/dev/sda1               101086     17532     78335  19% /boot
/dev/sda2             31738420    185172  29915020   1% /tmp
/dev/sda6             31738392   5388000  24712168  18% /var
/dev/sda7             31738392  18498412  11601756  62% /usr
/dev/sda8            124991068    193660 118345708   1% /var/tmp
/dev/mapper/VolGroup00-home
                     198351840  94998468  93115012  51% /home
/dev/sde1            565688764 435861992 100627836  82% /scr
/dev/sdc1            961432072 768900392 143693680  85% /mnt/scr1
/dev/sdd1            961432072 875550896  37043176  96% /mnt/hdf
tmpfs                  8313628         0   8313628   0% /dev/shm
gumund:/data/ftp     480719104 394141184  62158720  87% /mnt/ftp
gumund:/data/web     480719104 394141184  62158720  87% /mnt/web
10.10.10.15:/volume1/hdf2
                     1437485440 238696192 1198686848  17% /mnt/hdf2
10.10.10.15:/volume1/hdf3
                     1437485440 238696192 1198686848  17% /mnt/hdf3
10.10.10.15:/volume1/readonly
                     1437485440 238696192 1198686848  17% /mnt/readonly
                     1437485440 238696192 1198686848  17% /mnt/ro-src
                     1437485440 238696192 1198686848  17% /mnt/rw-src
STANDARD_OPT=setenv MAKE gmake deploydir /mnt/scr1/pre-release/opa
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam
Running source repository checkout with output saved in
   /mnt/scr1/SnapTest/snapshots-opa/log/REPO_LOG_1010Sat
Checking MANIFEST file ...
cat: /mnt/scr1/SnapTest/snapshots-opa/log/#runtest.1010Sat.18796: No such file or directory
rm: cannot remove `/mnt/scr1/SnapTest/snapshots-opa/log/#runtest.1010Sat.18796': No such file or directory
*** launching tests from jam ***
TESTHOST is emu
jam
koala
platypus
ostrich
quail
kite
    Fork off timekeeper 12
Testing emu
ssh -o ConnectTimeout=60 emu -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname emu
 12:02am  up 103 day(s),  9:07,  1 user,  load average: 0.36, 0.90, 1.55
/                  (rpool/ROOT/solaris):426405026 blocks 426405026 files
/devices           (/devices          ):       0 blocks        0 files
/dev               (/dev              ):       0 blocks        0 files
/system/contract   (ctfs              ):       0 blocks 2147483588 files
/proc              (proc              ):       0 blocks    29924 files
/etc/mnttab        (mnttab            ):       0 blocks        0 files
/system/volatile   (swap              ):12945488 blocks  2199035 files
/system/object     (objfs             ):       0 blocks 2147483464 files
/etc/dfs/sharetab  (sharefs           ):       0 blocks 2147483646 files
/dev/fd            (fd                ):       0 blocks        0 files
/var               (rpool/ROOT/solaris/var):426405026 blocks 426405026 files
/tmp               (swap              ):12945488 blocks  2199035 files
/var/share         (rpool/VARSHARE    ):426405026 blocks 426405026 files
/rpool             (rpool             ):426405026 blocks 426405026 files
/export            (rpool/export      ):426405026 blocks 426405026 files
/export/home       (rpool/export/home ):426405026 blocks 426405026 files
/export/home/kurz  (rpool/export/home/kurz):426405026 blocks 426405026 files
/home              (jam.ad.hdfgroup.org:/home):206706744 blocks 50201592 files
/mnt/hdf           (jam.ad.hdfgroup.org:/mnt/hdf):171762352 blocks 111640129 files
/mnt/scr1          (jam.ad.hdfgroup.org:/mnt/scr1):385063304 blocks 117978969 files
/mnt/ro-src        (10.10.10.15:/volume1/readonly):2397578312 blocks 91191972 files
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/emu32 deploy emu32
Extract source and run autogen if .
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/emu32 deploy emu32 tests in emu ***
Uname -a: SunOS emu 5.11 11.1 sun4v sparc sun4v
Running snapshot with output saved in
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/emu32 deploy emu32 tests for emu ***
Total time = 0m 2s
*** finished tests in emu ***
****SYSTEM ERROR emu: Abnormal exit from runtest ****
	****SYSTEM ERROR emu: runtest command failed ****
Testing jam
ssh -o ConnectTimeout=60 jam -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname jam
 00:03:16 up 9 days, 10:58, 19 users,  load average: 0.41, 0.38, 0.30
/dev/sda2             31738420    185280  29914912   1% /tmp
/dev/sda6             31738392   5388088  24712080  18% /var
/dev/sdc1            961432072 768900428 143693644  85% /mnt/scr1
Sat Oct 10 00:03:26 CDT 2015
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam tests in jam ***
Uname -a: Linux jam 2.6.18-308.13.1.el5PAE #1 SMP Tue Aug 21 17:50:26 EDT 2012 i686 i686 i386 GNU/Linux
   /mnt/scr1/SnapTest/snapshots-opa/log/jam_1010Sat_0003
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam tests for jam ***
Sat Oct 10 00:04:27 CDT 2015
Total time = 1m 1s
*** finished tests in jam ***
Testing koala
ssh -o ConnectTimeout=60 koala -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname koala
 00:03:18 up 44 days, 11:13,  0 users,  load average: 0.00, 0.00, 0.00
/dev/sda7             22292052   4436480  16704920  21% /
/dev/sda5             12192608    371696  11191568   4% /tmp
/dev/sda3             12192636    975540  10587752   9% /var
/dev/sda1               101086     18614     77253  20% /boot
/dev/sdc1             41279536  26268092  12914564  68% /usr
/dev/sdb             152754284  67391732  77603092  47% /scr
tmpfs                  6149552         0   6149552   0% /dev/shm
10.10.10.86:/home    198351872  94997504  93115392  51% /home
10.10.10.86:/mnt/hdf 961432576 875550720  37043200  96% /mnt/hdf
10.10.10.86:/mnt/scr1
                     961432576 768900096 143693824  85% /mnt/scr1
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala
Sat Oct 10 00:03:28 CDT 2015
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala tests in koala ***
Uname -a: Linux koala 2.6.18-406.el5 #1 SMP Tue Jun 2 17:25:57 EDT 2015 x86_64 x86_64 x86_64 GNU/Linux
   /mnt/scr1/SnapTest/snapshots-opa/log/koala_1010Sat_0003
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala tests for koala ***
Sat Oct 10 00:04:01 CDT 2015
Total time = 0m 33s
*** finished tests in koala ***
Testing platypus
ssh -o ConnectTimeout=60 platypus -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname platypus
 00:03:21 up 42 days, 13:31,  5 users,  load average: 0.07, 0.33, 1.24
/dev/sda6             54205540  22764464  28680936  45% /
tmpfs                  6099072         0   6099072   0% /dev/shm
/dev/sda1               194241     48551    135450  27% /boot
/dev/sda2             12850716    236308  11954952   2% /tmp
/dev/sda3             12850716   4038328   8152932  34% /var
/dev/sdd             152623212 112110956  32752796  78% /scr
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus
Sat Oct 10 00:03:31 CDT 2015
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus tests in platypus ***
Uname -a: Linux platypus 2.6.32-573.3.1.el6.x86_64 #1 SMP Thu Aug 13 22:55:16 UTC 2015 x86_64 x86_64 x86_64 GNU/Linux
   /mnt/scr1/SnapTest/snapshots-opa/log/platypus_1010Sat_0003
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus tests for platypus ***
Sat Oct 10 00:04:09 CDT 2015
Total time = 0m 38s
*** finished tests in platypus ***
Testing ostrich
ssh -o ConnectTimeout=60 ostrich -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname ostrich
 00:03:23 up 93 days, 10:51,  0 users,  load average: 0.38, 0.91, 1.60
/dev/mapper/vg_ostrich-lv_root
                      140479384  19326928  114013412  15% /
tmpfs                   7821632         0    7821632   0% /dev/shm
/dev/sda2                487652     92973     369079  21% /boot
/dev/sdb2             124477364  83919448   34228164  72% /scr
jam:/home             198351872  94997504   93115392  51% /home
jam:/mnt/hdf          961432576 875550720   37043200  96% /mnt/hdf
jam:/mnt/scr1         961432576 768900096  143693824  85% /mnt/scr1
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich ; standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl
Sat Oct 10 00:03:33 CDT 2015
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich tests in ostrich ***
Uname -a: Linux ostrich 2.6.32-504.8.1.el6.ppc64 #1 SMP Fri Dec 19 12:10:45 EST 2014 ppc64 ppc64 ppc64 GNU/Linux
   /mnt/scr1/SnapTest/snapshots-opa/log/ostrich_1010Sat_0003
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich tests for ostrich ***
Sat Oct 10 00:05:12 CDT 2015
Total time = 1m 39s
*** starting standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl tests in ostrich ***
   /mnt/scr1/SnapTest/snapshots-opa/log/ostrich_1010Sat_0005
*** finished standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl tests for ostrich ***
Sat Oct 10 00:08:18 CDT 2015
Total time = 3m 6s
*** finished tests in ostrich ***
Testing quail
ssh -o ConnectTimeout=60 quail -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname quail
 0:03  up 42 days, 13:44, 0 users, load averages: 1.49 1.54 1.56
Filesystem                    512-blocks       Used Available Capacity  iused     ifree %iused  Mounted on
/dev/disk0s2                   488555536  179491272 308552264    37% 22500407  38569033   37%   /
devfs                                362        362         0   100%      627         0  100%   /dev
map auto_nfs                           0          0         0   100%        0         0  100%   /mnt/hdf
map auto_nfs                           0          0         0   100%        0         0  100%   /mnt/scr1
map auto_nfs                           0          0         0   100%        0         0  100%   /home
jam.ad.hdfgroup.org:/mnt/hdf  1922864144 1751101792  74086352    96% 10469823 111640129    9%   /mnt/hdf
jam.ad.hdfgroup.org:/home      396703680  189996936 186230024    51%  1014792  50201592    2%   /home
jam.ad.hdfgroup.org:/mnt/scr1 1922864144 1537800928 287387216    85%  4130994 117978958    3%   /mnt/scr1
TEST_TYPES=standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/quail deploy quail
Sat Oct 10 00:03:36 CDT 2015
*** starting standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/quail deploy quail tests in quail ***
Uname -a: Darwin quail.ad.hdfgroup.org 13.4.0 Darwin Kernel Version 13.4.0: Wed Mar 18 16:20:14 PDT 2015; root:xnu-2422.115.14~1/RELEASE_X86_64 x86_64
   /Users/hdftest/snapshots-opa/log/quail_1010Sat_0003
*** finished standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/quail deploy quail tests for quail ***
Sat Oct 10 00:04:28 CDT 2015
Total time = 0m 52s
*** finished tests in quail ***
Testing kite
ssh -o ConnectTimeout=60 kite -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname kite
 0:03  up 42 days, 13:42, 0 users, load averages: 0.23 0.29 0.43
/dev/disk0s2          1951845952  249022856 1702311096    13% 31191855 212788887   13%   /
devfs                        373        373          0   100%      647         0  100%   /dev
/dev/disk1s2          1952853344    1296656 1951556688     1%   162080 243944586    0%   /Volumes/Milvinae
10.10.10.86:/home      396703680  189996936  186230024    51%  1014792  50201592    2%   /mnt/home
10.10.10.86:/mnt/scr1 1922864144 1537800984  287387160    85%  4130999 117978953    3%   /mnt/scr1
10.10.10.86:/mnt/hdf  1922864144 1751101792   74086352    96% 10469823 111640129    9%   /mnt/hdf
TEST_TYPES=standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/kite deploy kite
Sat Oct 10 00:03:38 CDT 2015
*** starting standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/kite deploy kite tests in kite ***
Uname -a: Darwin kite.ad.hdfgroup.org 12.6.0 Darwin Kernel Version 12.6.0: Wed Mar 18 16:23:48 PDT 2015; root:xnu-2050.48.19~1/RELEASE_X86_64 x86_64
   /Users/hdftest/snapshots-opa/log/kite_1010Sat_0003
*** finished standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/kite deploy kite tests for kite ***
Sat Oct 10 00:04:26 CDT 2015
Total time = 0m 48s
*** finished tests in kite ***
More information about the opa-nightly-tests mailing list
