[opa-nightly-tests] jam OPA_Daily_Tests_1011Sun_FAILED!!!
HDF Tester hdftest at hdfgroup.org
Sun Oct 11 21:21:28 CDT 2015
*** OPA Tests on 1011Sun ***
   Tests Summary
****FAILED emu: setenvN 2 CC cc -m64 op-configure --prefix=/mnt/scr1/pre-release/opa/emu64 deploy emu64****
PASSED jam: standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam
PASSED kite: standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/kite deploy kite
PASSED koala: standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala
PASSED ostrich: standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich
PASSED ostrich: standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl
PASSED platypus: standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus
PASSED quail: standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/quail deploy quail
   Tests Time Summary
emu: Ran 1(0/1/0) tests, Grand total test time =  0m 2s
koala: Ran 1(1/0/0) tests, Grand total test time =  0m 34s
platypus: Ran 1(1/0/0) tests, Grand total test time =  0m 42s
kite: Ran 1(1/0/0) tests, Grand total test time =  0m 48s
jam: Ran 1(1/0/0) tests, Grand total test time =  1m 2s
quail: Ran 1(1/0/0) tests, Grand total test time =  0m 55s
ostrich: Ran 2(2/0/0) tests, Grand total test time =  4m 41s
jam: Ran 7(0/0/0) hosts, Grand total test time =  5m 47s
   Timekeeper log
Timekeeper started at Sun Oct 11 21:15:53 CDT 2015
Timekeeper sleeping for 720 seconds
   Tests Failures
Dumping logfile of emu: setenvN 2 CC cc -m64 op-configure --prefix=/mnt/scr1/pre-release/opa/emu64 deploy emu64
Last 50 lines of /mnt/scr1/SnapTest/snapshots-opa/log/emu_1011Sun_2115
GROUP=hdf
HDF5_ACLOCAL=/mnt/hdf/packages/AUTOTOOLS/automake/1.15/sun4v/bin/aclocal-1.15
HDF5_AUTOCONF=/mnt/hdf/packages/AUTOTOOLS/autoconf/2.69/sun4v/bin/autoconf
HDF5_AUTOHEADER=/mnt/hdf/packages/AUTOTOOLS/autoconf/2.69/sun4v/bin/autoheader
HDF5_AUTOMAKE=/mnt/hdf/packages/AUTOTOOLS/automake/1.15/sun4v/bin/automake-1.15
HDF5_LIBTOOL=/mnt/hdf/packages/AUTOTOOLS/libtool/2.4.6/sun4v/bin/libtool
HDF5_M4=/mnt/hdf/packages/AUTOTOOLS/m4/1.4.17/sun4v/bin/m4
HDF5TestExpress=yes
HOME=/home/hdftest
HOST=emu
HOSTTYPE=sun4
JAVA_HOME=/usr/lib/jvm/jre-1.6.0
LANG=en_US.UTF-8
LC_ALL=
LC_COLLATE=
LC_CTYPE=
LC_MESSAGES=
LC_MONETARY=
LC_NUMERIC=
LC_TIME=
LOGNAME=hdftest
MACHTYPE=sparc
MAIL=/var/mail/hdftest
MAKE=gmake
NLSPATH=/usr/share/locale/%L/LC_MESSAGES/%N.cat
OSTYPE=solaris
PATH=/home/hdftest/bin:/usr/hdf/bin:/home/hdftest/bin:/usr/hdf/bin:/usr/bin:/usr/sbin:/opt/solarisstudio/bin:/opt/cmake/bin:/opt/svn/bin:/mnt/hdf/ec2-api-tools/bin
PWD=/mnt/scr1/SnapTest/snapshots-opa
REMOTEHOST=
SET_PATH=yes
SHELL=/bin/tcsh
SHLVL=3
SSH_CLIENT=10.10.10.86 36774 22
SSH_CONNECTION=10.10.10.86 36774 10.10.10.84 22
SVNROOT=http://svn.hdfgroup.uiuc.edu
TZ=localtime
USER=hdftest
VENDOR=sun
===Done Dumping environment variables after option parsing ===
===== Run Tests: Sunday, October 11, 2015 09:15:49 PM CDT =====
Remove contents of emu.
diff: /home/hdftest/snapshots-opa/previous/MANIFEST: No such file or directory
===== configure: Sunday, October 11, 2015 09:15:49 PM CDT =====
checking for a BSD-compatible install... /usr/bin/ginstall -c
checking whether build environment is sane... configure: error: newly created file is older than distributed files!
Check your system clock
Failed running configure
===== Exit bin/snapshot with status=1: Sunday, October 11, 2015 09:15:50 PM CDT =====
Dumping done
Runtest did not exit normally.
   Watchers List
OPA Daily test features/platforms watchers and procedure
Procedure:
The watcher will investigate and report the cause of failure by 11am.
The developer who checked in the error code may report so by then too.
The watcher or the developer should get the failure fixed and report it
by 3pm.
Watcher for OPA:	 	Neil
updated: 2009/05/05
   Tests Details
 21:15:31 up 11 days,  8:10, 18 users,  load average: 0.79, 0.53, 0.45
Filesystem           1K-blocks      Used Available Use% Mounted on
/dev/sda3             31738420   8764228  21335964  30% /
/dev/sda1               101086     17532     78335  19% /boot
/dev/sda2             31738420    218004  29882188   1% /tmp
/dev/sda6             31738392   5484592  24615576  19% /var
/dev/sda7             31738392  18498412  11601756  62% /usr
/dev/sda8            124991068    193660 118345708   1% /var/tmp
/dev/mapper/VolGroup00-home
                     198351840  94999500  93113980  51% /home
/dev/sde1            565688764 435316448 101173380  82% /scr
/dev/sdc1            961432072 768140632 144453440  85% /mnt/scr1
/dev/sdd1            961432072 878210344  34383728  97% /mnt/hdf
tmpfs                  8313628         0   8313628   0% /dev/shm
gumund:/data/ftp     480719104 394823168  61476736  87% /mnt/ftp
gumund:/data/web     480719104 394823168  61476736  87% /mnt/web
10.10.10.15:/volume1/hdf2
                     1437485440 238696192 1198686848  17% /mnt/hdf2
10.10.10.15:/volume1/hdf3
                     1437485440 238696192 1198686848  17% /mnt/hdf3
10.10.10.15:/volume1/readonly
                     1437485440 238696192 1198686848  17% /mnt/readonly
                     1437485440 238696192 1198686848  17% /mnt/ro-src
                     1437485440 238696192 1198686848  17% /mnt/rw-src
STANDARD_OPT=setenv MAKE gmake deploydir /mnt/scr1/pre-release/opa
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam
Running source repository checkout with output saved in
   /mnt/scr1/SnapTest/snapshots-opa/log/REPO_LOG_1011Sun
Checking MANIFEST file ...
cat: /mnt/scr1/SnapTest/snapshots-opa/log/#runtest.1011Sun.25514: No such file or directory
rm: cannot remove `/mnt/scr1/SnapTest/snapshots-opa/log/#runtest.1011Sun.25514': No such file or directory
*** launching tests from jam ***
TESTHOST is emu
jam
koala
platypus
ostrich
quail
kite
    Fork off timekeeper 12
Testing emu
ssh -o ConnectTimeout=60 emu -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname emu
  9:15pm  up 105 day(s),  6:20,  1 user,  load average: 0.01, 0.05, 0.47
/                  (rpool/ROOT/solaris):428747972 blocks 428747972 files
/devices           (/devices          ):       0 blocks        0 files
/dev               (/dev              ):       0 blocks        0 files
/system/contract   (ctfs              ):       0 blocks 2147483588 files
/proc              (proc              ):       0 blocks    29924 files
/etc/mnttab        (mnttab            ):       0 blocks        0 files
/system/volatile   (swap              ):12624928 blocks  2198338 files
/system/object     (objfs             ):       0 blocks 2147483464 files
/etc/dfs/sharetab  (sharefs           ):       0 blocks 2147483646 files
/dev/fd            (fd                ):       0 blocks        0 files
/var               (rpool/ROOT/solaris/var):428747972 blocks 428747972 files
/tmp               (swap              ):12624928 blocks  2198338 files
/var/share         (rpool/VARSHARE    ):428747972 blocks 428747972 files
/rpool             (rpool             ):428747972 blocks 428747972 files
/export            (rpool/export      ):428747972 blocks 428747972 files
/export/home       (rpool/export/home ):428747972 blocks 428747972 files
/export/home/kurz  (rpool/export/home/kurz):428747972 blocks 428747972 files
/home              (jam.ad.hdfgroup.org:/home):206704680 blocks 50201595 files
/mnt/hdf           (jam.ad.hdfgroup.org:/mnt/hdf):166443456 blocks 111629717 files
/mnt/scr1          (jam.ad.hdfgroup.org:/mnt/scr1):386582824 blocks 117983955 files
/mnt/ro-src        (10.10.10.15:/volume1/readonly):2397578312 blocks 91191972 files
TEST_TYPES=setenvN 2 CC cc -m64 op-configure --prefix=/mnt/scr1/pre-release/opa/emu64 deploy emu64
Extract source and run autogen if .
*** starting setenvN 2 CC cc -m64 op-configure --prefix=/mnt/scr1/pre-release/opa/emu64 deploy emu64 tests in emu ***
Uname -a: SunOS emu 5.11 11.1 sun4v sparc sun4v
Running snapshot with output saved in
*** finished setenvN 2 CC cc -m64 op-configure --prefix=/mnt/scr1/pre-release/opa/emu64 deploy emu64 tests for emu ***
Total time = 0m 2s
*** finished tests in emu ***
****SYSTEM ERROR emu: Abnormal exit from runtest ****
	****SYSTEM ERROR emu: runtest command failed ****
Testing jam
ssh -o ConnectTimeout=60 jam -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname jam
 21:16:00 up 11 days,  8:11, 18 users,  load average: 1.30, 0.67, 0.50
/dev/sda2             31738420    218848  29881344   1% /tmp
/dev/sda6             31738392   5484588  24615580  19% /var
/dev/sde1            565688764 435323860 101165968  82% /scr
/dev/sdc1            961432072 768140668 144453404  85% /mnt/scr1
/dev/sdd1            961432072 878210336  34383736  97% /mnt/hdf
Sun Oct 11 21:16:10 CDT 2015
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam tests in jam ***
Uname -a: Linux jam 2.6.18-308.13.1.el5PAE #1 SMP Tue Aug 21 17:50:26 EDT 2012 i686 i686 i386 GNU/Linux
   /mnt/scr1/SnapTest/snapshots-opa/log/jam_1011Sun_2116
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam tests for jam ***
Sun Oct 11 21:17:12 CDT 2015
Total time = 1m 2s
*** finished tests in jam ***
Testing koala
ssh -o ConnectTimeout=60 koala -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname koala
 21:16:02 up 46 days,  8:26,  0 users,  load average: 1.00, 0.75, 0.55
/dev/sda7             22292052   4436476  16704924  21% /
/dev/sda5             12192608    383700  11179564   4% /tmp
/dev/sda3             12192636    983904  10579388   9% /var
/dev/sda1               101086     18614     77253  20% /boot
/dev/sdc1             41279536  26268092  12914564  68% /usr
/dev/sdb             152754284  67643312  77351512  47% /scr
tmpfs                  6149552         0   6149552   0% /dev/shm
10.10.10.86:/home    198351872  94998528  93114368  51% /home
10.10.10.86:/mnt/hdf 961432576 878210048  34383872  97% /mnt/hdf
10.10.10.86:/mnt/scr1
                     961432576 768140288 144453632  85% /mnt/scr1
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala
Sun Oct 11 21:16:13 CDT 2015
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala tests in koala ***
Uname -a: Linux koala 2.6.18-406.el5 #1 SMP Tue Jun 2 17:25:57 EDT 2015 x86_64 x86_64 x86_64 GNU/Linux
   /mnt/scr1/SnapTest/snapshots-opa/log/koala_1011Sun_2116
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala tests for koala ***
Sun Oct 11 21:16:46 CDT 2015
Total time = 0m 33s
*** finished tests in koala ***
Testing platypus
ssh -o ConnectTimeout=60 platypus -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname platypus
 21:16:05 up 44 days, 10:44,  3 users,  load average: 0.07, 0.48, 0.60
/dev/sda6             54205540  22777068  28668332  45% /
tmpfs                  6099072         0   6099072   0% /dev/shm
/dev/sda1               194241     48551    135450  27% /boot
/dev/sda2             12850716    336464  11854796   3% /tmp
/dev/sda3             12850716   4174312   8016948  35% /var
/dev/sdd             152623212 111572156  33291596  78% /scr
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus
Sun Oct 11 21:16:15 CDT 2015
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus tests in platypus ***
Uname -a: Linux platypus 2.6.32-573.3.1.el6.x86_64 #1 SMP Thu Aug 13 22:55:16 UTC 2015 x86_64 x86_64 x86_64 GNU/Linux
   /mnt/scr1/SnapTest/snapshots-opa/log/platypus_1011Sun_2116
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus tests for platypus ***
Sun Oct 11 21:16:57 CDT 2015
Total time = 0m 42s
*** finished tests in platypus ***
Testing ostrich
ssh -o ConnectTimeout=60 ostrich -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname ostrich
 21:16:07 up 95 days,  8:04,  0 users,  load average: 2.41, 5.94, 4.31
/dev/mapper/vg_ostrich-lv_root
                      140479384  19539080  113801260  15% /
tmpfs                   7821632         0    7821632   0% /dev/shm
/dev/sda2                487652     92973     369079  21% /boot
/dev/sdb2             124477364  83824560   34323052  71% /scr
jam:/home             198351872  94998528   93114368  51% /home
jam:/mnt/hdf          961432576 878210048   34383872  97% /mnt/hdf
jam:/mnt/scr1         961432576 768140288  144453632  85% /mnt/scr1
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich ; standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl
Sun Oct 11 21:16:18 CDT 2015
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich tests in ostrich ***
Uname -a: Linux ostrich 2.6.32-504.8.1.el6.ppc64 #1 SMP Fri Dec 19 12:10:45 EST 2014 ppc64 ppc64 ppc64 GNU/Linux
   /mnt/scr1/SnapTest/snapshots-opa/log/ostrich_1011Sun_2116
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich tests for ostrich ***
Sun Oct 11 21:17:55 CDT 2015
Total time = 1m 37s
*** starting standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl tests in ostrich ***
   /mnt/scr1/SnapTest/snapshots-opa/log/ostrich_1011Sun_2117
*** finished standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl tests for ostrich ***
Sun Oct 11 21:20:58 CDT 2015
Total time = 3m 3s
*** finished tests in ostrich ***
Testing quail
ssh -o ConnectTimeout=60 quail -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname quail
21:16  up 44 days, 10:57, 0 users, load averages: 1.60 1.55 1.53
Filesystem                    512-blocks       Used Available Capacity  iused     ifree %iused  Mounted on
/dev/disk0s2                   488555536  180476416 307567120    37% 22623550  38445890   37%   /
devfs                                361        361         0   100%      626         0  100%   /dev
map auto_nfs                           0          0         0   100%        0         0  100%   /mnt/hdf
map auto_nfs                           0          0         0   100%        0         0  100%   /mnt/scr1
map auto_nfs                           0          0         0   100%        0         0  100%   /home
jam.ad.hdfgroup.org:/mnt/scr1 1922864144 1536281408 288906736    85%  4126008 117983944    3%   /mnt/scr1
jam.ad.hdfgroup.org:/home      396703680  189999000 186227960    51%  1014789  50201595    2%   /home
jam.ad.hdfgroup.org:/mnt/hdf  1922864144 1756420720  68767424    97% 10480236 111629716    9%   /mnt/hdf
TEST_TYPES=standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/quail deploy quail
Sun Oct 11 21:16:20 CDT 2015
*** starting standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/quail deploy quail tests in quail ***
Uname -a: Darwin quail.ad.hdfgroup.org 13.4.0 Darwin Kernel Version 13.4.0: Wed Mar 18 16:20:14 PDT 2015; root:xnu-2422.115.14~1/RELEASE_X86_64 x86_64
   /Users/hdftest/snapshots-opa/log/quail_1011Sun_2116
*** finished standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/quail deploy quail tests for quail ***
Sun Oct 11 21:17:15 CDT 2015
Total time = 0m 55s
*** finished tests in quail ***
Testing kite
ssh -o ConnectTimeout=60 kite -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname kite
21:16  up 44 days, 10:55, 0 users, load averages: 0.09 0.32 0.33
/dev/disk0s2          1951845952  249604200 1701729752    13% 31264523 212716219   13%   /
devfs                        373        373          0   100%      646         0  100%   /dev
/dev/disk1s2          1952853344    1296656 1951556688     1%   162080 243944586    0%   /Volumes/Milvinae
10.10.10.86:/home      396703680  189999000  186227960    51%  1014789  50201595    2%   /mnt/home
10.10.10.86:/mnt/scr1 1922864144 1536281464  288906680    85%  4126013 117983939    3%   /mnt/scr1
10.10.10.86:/mnt/hdf  1922864144 1756420720   68767424    97% 10480236 111629716    9%   /mnt/hdf
TEST_TYPES=standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/kite deploy kite
Sun Oct 11 21:16:23 CDT 2015
*** starting standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/kite deploy kite tests in kite ***
Uname -a: Darwin kite.ad.hdfgroup.org 12.6.0 Darwin Kernel Version 12.6.0: Wed Mar 18 16:23:48 PDT 2015; root:xnu-2050.48.19~1/RELEASE_X86_64 x86_64
   /Users/hdftest/snapshots-opa/log/kite_1011Sun_2116
*** finished standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/kite deploy kite tests for kite ***
Sun Oct 11 21:17:11 CDT 2015
Total time = 0m 48s
*** finished tests in kite ***
More information about the opa-nightly-tests mailing list
