[opa-nightly-tests] jam OPA_Daily_Tests_1008Thu_FAILED!!!
HDF Tester
hdftest at hdfgroup.org
Thu Oct 8 00:08:50 CDT 2015
*** OPA Tests on 1008Thu ***
Tests Summary
****FAILED emu: standard op-configure --prefix=/mnt/scr1/pre-release/opa/emu32 deploy emu32****
PASSED jam: standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam
PASSED kite: standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/kite deploy kite
PASSED koala: standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala
PASSED ostrich: standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich
PASSED ostrich: standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl
PASSED platypus: standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus
PASSED quail: standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/quail deploy quail
Tests Time Summary
emu: Ran 1(0/1/0) tests, Grand total test time = 0m 2s
koala: Ran 1(1/0/0) tests, Grand total test time = 0m 34s
platypus: Ran 1(1/0/0) tests, Grand total test time = 0m 44s
kite: Ran 1(1/0/0) tests, Grand total test time = 0m 48s
jam: Ran 1(1/0/0) tests, Grand total test time = 1m 2s
quail: Ran 1(1/0/0) tests, Grand total test time = 0m 56s
ostrich: Ran 2(2/0/0) tests, Grand total test time = 4m 43s
jam: Ran 7(0/0/0) hosts, Grand total test time = 5m 48s
Timekeeper log
Timekeeper started at Thu Oct 8 00:03:13 CDT 2015
Timekeeper sleeping for 720 seconds
Tests Failures
Dumping logfile of emu: standard op-configure --prefix=/mnt/scr1/pre-release/opa/emu32 deploy emu32
Last 50 lines of /mnt/scr1/SnapTest/snapshots-opa/log/emu_1008Thu_0003
GROUP=hdf
HDF5_ACLOCAL=/mnt/hdf/packages/AUTOTOOLS/automake/1.15/sun4v/bin/aclocal-1.15
HDF5_AUTOCONF=/mnt/hdf/packages/AUTOTOOLS/autoconf/2.69/sun4v/bin/autoconf
HDF5_AUTOHEADER=/mnt/hdf/packages/AUTOTOOLS/autoconf/2.69/sun4v/bin/autoheader
HDF5_AUTOMAKE=/mnt/hdf/packages/AUTOTOOLS/automake/1.15/sun4v/bin/automake-1.15
HDF5_LIBTOOL=/mnt/hdf/packages/AUTOTOOLS/libtool/2.4.6/sun4v/bin/libtool
HDF5_M4=/mnt/hdf/packages/AUTOTOOLS/m4/1.4.17/sun4v/bin/m4
HDF5TestExpress=yes
HOME=/home/hdftest
HOST=emu
HOSTTYPE=sun4
JAVA_HOME=/usr/lib/jvm/jre-1.6.0
LANG=en_US.UTF-8
LC_ALL=
LC_COLLATE=
LC_CTYPE=
LC_MESSAGES=
LC_MONETARY=
LC_NUMERIC=
LC_TIME=
LOGNAME=hdftest
MACHTYPE=sparc
MAIL=/var/mail/hdftest
MAKE=gmake
NLSPATH=/usr/share/locale/%L/LC_MESSAGES/%N.cat
OSTYPE=solaris
PATH=/home/hdftest/bin:/usr/hdf/bin:/home/hdftest/bin:/usr/hdf/bin:/usr/bin:/usr/sbin:/opt/solarisstudio/bin:/opt/cmake/bin:/opt/svn/bin:/mnt/hdf/ec2-api-tools/bin
PWD=/mnt/scr1/SnapTest/snapshots-opa
REMOTEHOST=
SET_PATH=yes
SHELL=/bin/tcsh
SHLVL=3
SSH_CLIENT=10.10.10.86 47541 22
SSH_CONNECTION=10.10.10.86 47541 10.10.10.84 22
SVNROOT=http://svn.hdfgroup.uiuc.edu
TZ=localtime
USER=hdftest
VENDOR=sun
===Done Dumping environment variables after option parsing ===
===== Run Tests: Thursday, October 8, 2015 12:03:06 AM CDT =====
Remove contents of emu.
diff: /home/hdftest/snapshots-opa/previous/MANIFEST: No such file or directory
===== configure: Thursday, October 8, 2015 12:03:06 AM CDT =====
checking for a BSD-compatible install... /usr/bin/ginstall -c
checking whether build environment is sane... configure: error: newly created file is older than distributed files!
Check your system clock
Failed running configure
===== Exit bin/snapshot with status=1: Thursday, October 8, 2015 12:03:07 AM CDT =====
Dumping done
Runtest did not exit normally.
Watchers List
OPA Daily test features/platforms watchers and procedure
Procedure:
The watcher will investigate and report the cause of failure by 11am.
The developer who checked in the error code may report so by then too.
The watcher or the developer should get the failure fixed and report it
by 3pm.
Watcher for OPA: Neil
updated: 2009/05/05
Tests Details
00:02:52 up 7 days, 10:58, 14 users, load average: 0.36, 0.37, 0.31
Filesystem 1K-blocks Used Available Use% Mounted on
/dev/sda3 31738420 8766472 21333720 30% /
/dev/sda1 101086 17532 78335 19% /boot
/dev/sda2 31738420 185136 29915056 1% /tmp
/dev/sda6 31738392 5427888 24672280 19% /var
/dev/sda7 31738392 18498412 11601756 62% /usr
/dev/sda8 124991068 193660 118345708 1% /var/tmp
/dev/mapper/VolGroup00-home
198351840 94425968 93687512 51% /home
/dev/sde1 565688764 432139036 104350792 81% /scr
/dev/sdc1 961432072 766715584 145878488 85% /mnt/scr1
/dev/sdd1 961432072 875573416 37020656 96% /mnt/hdf
tmpfs 8313628 0 8313628 0% /dev/shm
gumund:/data/ftp 480719104 393916032 62383872 87% /mnt/ftp
gumund:/data/web 480719104 393916032 62383872 87% /mnt/web
10.10.10.15:/volume1/hdf2
1437485440 238696192 1198686848 17% /mnt/hdf2
10.10.10.15:/volume1/hdf3
1437485440 238696192 1198686848 17% /mnt/hdf3
10.10.10.15:/volume1/readonly
1437485440 238696192 1198686848 17% /mnt/readonly
1437485440 238696192 1198686848 17% /mnt/ro-src
1437485440 238696192 1198686848 17% /mnt/rw-src
STANDARD_OPT=setenv MAKE gmake deploydir /mnt/scr1/pre-release/opa
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam
Running source repository checkout with output saved in
/mnt/scr1/SnapTest/snapshots-opa/log/REPO_LOG_1008Thu
Checking MANIFEST file ...
cat: /mnt/scr1/SnapTest/snapshots-opa/log/#runtest.1008Thu.16081: No such file or directory
rm: cannot remove `/mnt/scr1/SnapTest/snapshots-opa/log/#runtest.1008Thu.16081': No such file or directory
*** launching tests from jam ***
TESTHOST is emu
jam
koala
platypus
ostrich
quail
kite
Fork off timekeeper 12
Testing emu
ssh -o ConnectTimeout=60 emu -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname emu
12:02am up 101 day(s), 9:07, 1 user, load average: 0.36, 1.05, 2.48
/ (rpool/ROOT/solaris):429867879 blocks 429867879 files
/devices (/devices ): 0 blocks 0 files
/dev (/dev ): 0 blocks 0 files
/system/contract (ctfs ): 0 blocks 2147483588 files
/proc (proc ): 0 blocks 29923 files
/etc/mnttab (mnttab ): 0 blocks 0 files
/system/volatile (swap ):18378640 blocks 2199713 files
/system/object (objfs ): 0 blocks 2147483464 files
/etc/dfs/sharetab (sharefs ): 0 blocks 2147483646 files
/dev/fd (fd ): 0 blocks 0 files
/var (rpool/ROOT/solaris/var):429867879 blocks 429867879 files
/tmp (swap ):18378640 blocks 2199713 files
/var/share (rpool/VARSHARE ):429867879 blocks 429867879 files
/rpool (rpool ):429867879 blocks 429867879 files
/export (rpool/export ):429867879 blocks 429867879 files
/export/home (rpool/export/home ):429867879 blocks 429867879 files
/export/home/kurz (rpool/export/home/kurz):429867879 blocks 429867879 files
/home (jam.ad.hdfgroup.org:/home):207851744 blocks 50220568 files
/mnt/hdf (jam.ad.hdfgroup.org:/mnt/hdf):171717312 blocks 111657383 files
/mnt/scr1 (jam.ad.hdfgroup.org:/mnt/scr1):389432920 blocks 118009852 files
/mnt/ro-src (10.10.10.15:/volume1/readonly):2397578312 blocks 91191972 files
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/emu32 deploy emu32
Extract source and run autogen if .
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/emu32 deploy emu32 tests in emu ***
Uname -a: SunOS emu 5.11 11.1 sun4v sparc sun4v
Running snapshot with output saved in
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/emu32 deploy emu32 tests for emu ***
Total time = 0m 1s
*** finished tests in emu ***
****SYSTEM ERROR emu: Abnormal exit from runtest ****
****SYSTEM ERROR emu: runtest command failed ****
Testing jam
ssh -o ConnectTimeout=60 jam -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname jam
00:03:20 up 7 days, 10:58, 14 users, load average: 0.38, 0.37, 0.31
/dev/sda2 31738420 185244 29914948 1% /tmp
/dev/sda6 31738392 5427964 24672204 19% /var
/dev/sdc1 961432072 766715620 145878452 85% /mnt/scr1
Thu Oct 8 00:03:30 CDT 2015
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam tests in jam ***
Uname -a: Linux jam 2.6.18-308.13.1.el5PAE #1 SMP Tue Aug 21 17:50:26 EDT 2012 i686 i686 i386 GNU/Linux
/mnt/scr1/SnapTest/snapshots-opa/log/jam_1008Thu_0003
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam tests for jam ***
Thu Oct 8 00:04:32 CDT 2015
Total time = 1m 2s
*** finished tests in jam ***
Testing koala
ssh -o ConnectTimeout=60 koala -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname koala
00:03:22 up 42 days, 11:14, 0 users, load average: 0.00, 0.00, 0.00
/dev/sda7 22292052 4436472 16704928 21% /
/dev/sda5 12192608 371600 11191664 4% /tmp
/dev/sda3 12192636 989724 10573568 9% /var
/dev/sda1 101086 18614 77253 20% /boot
/dev/sdc1 41279536 26268092 12914564 68% /usr
/dev/sdb 152754284 67503480 77491344 47% /scr
tmpfs 6149552 0 6149552 0% /dev/shm
10.10.10.86:/home 198351872 94425088 93687808 51% /home
10.10.10.86:/mnt/hdf 961432576 875573248 37020672 96% /mnt/hdf
10.10.10.86:/mnt/scr1
961432576 766715904 145879040 85% /mnt/scr1
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala
Thu Oct 8 00:03:32 CDT 2015
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala tests in koala ***
Uname -a: Linux koala 2.6.18-406.el5 #1 SMP Tue Jun 2 17:25:57 EDT 2015 x86_64 x86_64 x86_64 GNU/Linux
/mnt/scr1/SnapTest/snapshots-opa/log/koala_1008Thu_0003
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala tests for koala ***
Thu Oct 8 00:04:06 CDT 2015
Total time = 0m 34s
*** finished tests in koala ***
Testing platypus
ssh -o ConnectTimeout=60 platypus -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname platypus
00:03:25 up 40 days, 13:31, 5 users, load average: 0.01, 0.17, 0.62
/dev/sda6 54205540 22753008 28692392 45% /
tmpfs 6099072 0 6099072 0% /dev/shm
/dev/sda1 194241 48551 135450 27% /boot
/dev/sda2 12850716 236292 11954968 2% /tmp
/dev/sda3 12850716 4030832 8160428 34% /var
/dev/sdd 152623212 111182308 33681444 77% /scr
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus
Thu Oct 8 00:03:35 CDT 2015
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus tests in platypus ***
Uname -a: Linux platypus 2.6.32-573.3.1.el6.x86_64 #1 SMP Thu Aug 13 22:55:16 UTC 2015 x86_64 x86_64 x86_64 GNU/Linux
/mnt/scr1/SnapTest/snapshots-opa/log/platypus_1008Thu_0003
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus tests for platypus ***
Thu Oct 8 00:04:19 CDT 2015
Total time = 0m 44s
*** finished tests in platypus ***
Testing ostrich
ssh -o ConnectTimeout=60 ostrich -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname ostrich
00:03:27 up 91 days, 10:51, 0 users, load average: 0.24, 0.83, 1.62
/dev/mapper/vg_ostrich-lv_root
140479384 19271392 114068948 15% /
tmpfs 7821632 0 7821632 0% /dev/shm
/dev/sda2 487652 92973 369079 21% /boot
/dev/sdb2 124477364 83814644 34332968 71% /scr
jam:/home 198351872 94425088 93687808 51% /home
jam:/mnt/hdf 961432576 875573248 37020672 96% /mnt/hdf
jam:/mnt/scr1 961432576 766715904 145879040 85% /mnt/scr1
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich ; standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl
Thu Oct 8 00:03:37 CDT 2015
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich tests in ostrich ***
Uname -a: Linux ostrich 2.6.32-504.8.1.el6.ppc64 #1 SMP Fri Dec 19 12:10:45 EST 2014 ppc64 ppc64 ppc64 GNU/Linux
/mnt/scr1/SnapTest/snapshots-opa/log/ostrich_1008Thu_0003
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich tests for ostrich ***
Thu Oct 8 00:05:15 CDT 2015
Total time = 1m 38s
*** starting standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl tests in ostrich ***
/mnt/scr1/SnapTest/snapshots-opa/log/ostrich_1008Thu_0005
*** finished standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl tests for ostrich ***
Thu Oct 8 00:08:20 CDT 2015
Total time = 3m 5s
*** finished tests in ostrich ***
Testing quail
ssh -o ConnectTimeout=60 quail -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname quail
0:03 up 40 days, 13:44, 0 users, load averages: 1.54 1.53 1.51
Filesystem 512-blocks Used Available Capacity iused ifree %iused Mounted on
/dev/disk0s2 488555536 182136192 305907344 38% 22831022 38238418 37% /
devfs 362 362 0 100% 627 0 100% /dev
map auto_nfs 0 0 0 100% 0 0 100% /mnt/hdf
map auto_nfs 0 0 0 100% 0 0 100% /mnt/scr1
map auto_nfs 0 0 0 100% 0 0 100% /home
jam.ad.hdfgroup.org:/mnt/hdf 1922864144 1751146832 74041312 96% 10452569 111657383 9% /mnt/hdf
jam.ad.hdfgroup.org:/home 396703680 188851936 187375024 51% 995816 50220568 2% /home
jam.ad.hdfgroup.org:/mnt/scr1 1922864144 1533431312 291756832 85% 4100111 118009841 3% /mnt/scr1
TEST_TYPES=standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/quail deploy quail
Thu Oct 8 00:03:40 CDT 2015
*** starting standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/quail deploy quail tests in quail ***
Uname -a: Darwin quail.ad.hdfgroup.org 13.4.0 Darwin Kernel Version 13.4.0: Wed Mar 18 16:20:14 PDT 2015; root:xnu-2422.115.14~1/RELEASE_X86_64 x86_64
/Users/hdftest/snapshots-opa/log/quail_1008Thu_0003
*** finished standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/quail deploy quail tests for quail ***
Thu Oct 8 00:04:35 CDT 2015
Total time = 0m 55s
*** finished tests in quail ***
Testing kite
ssh -o ConnectTimeout=60 kite -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname kite
0:03 up 40 days, 13:42, 0 users, load averages: 0.42 0.40 0.43
/dev/disk0s2 1951845952 250103136 1701230816 13% 31326890 212653852 13% /
devfs 373 373 0 100% 647 0 100% /dev
/dev/disk1s2 1952853344 1296656 1951556688 1% 162080 243944586 0% /Volumes/Milvinae
10.10.10.86:/home 396703680 188851936 187375024 51% 995816 50220568 2% /mnt/home
10.10.10.86:/mnt/scr1 1922864144 1533431368 291756776 85% 4100116 118009836 3% /mnt/scr1
10.10.10.86:/mnt/hdf 1922864144 1751146832 74041312 96% 10452569 111657383 9% /mnt/hdf
TEST_TYPES=standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/kite deploy kite
Thu Oct 8 00:03:42 CDT 2015
*** starting standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/kite deploy kite tests in kite ***
Uname -a: Darwin kite.ad.hdfgroup.org 12.6.0 Darwin Kernel Version 12.6.0: Wed Mar 18 16:23:48 PDT 2015; root:xnu-2050.48.19~1/RELEASE_X86_64 x86_64
/Users/hdftest/snapshots-opa/log/kite_1008Thu_0003
*** finished standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/kite deploy kite tests for kite ***
Thu Oct 8 00:04:30 CDT 2015
Total time = 0m 48s
*** finished tests in kite ***
More information about the opa-nightly-tests
