[opa-nightly-tests] jam OPA_Daily_Tests_1006Tue_FAILED!!!
HDF Tester
hdftest at hdfgroup.org
Wed Oct 7 00:00:37 CDT 2015
*** OPA Tests on 1006Tue ***
Tests Summary
****FAILED emu: standard op-configure --prefix=/mnt/scr1/pre-release/opa/emu32 deploy emu32****
PASSED jam: standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam
PASSED kite: standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/kite deploy kite
PASSED koala: standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala
PASSED ostrich: standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich
PASSED ostrich: standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl
PASSED platypus: standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus
PASSED quail: standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/quail deploy quail
Tests Time Summary
emu: Ran 1(0/1/0) tests, Grand total test time = 0m 2s
koala: Ran 1(1/0/0) tests, Grand total test time = 0m 32s
platypus: Ran 1(1/0/0) tests, Grand total test time = 0m 49s
kite: Ran 1(1/0/0) tests, Grand total test time = 0m 45s
jam: Ran 1(1/0/0) tests, Grand total test time = 1m 2s
quail: Ran 1(1/0/0) tests, Grand total test time = 0m 55s
ostrich: Ran 2(2/0/0) tests, Grand total test time = 4m 47s
jam: Ran 7(0/0/0) hosts, Grand total test time = 5m 53s
Timekeeper log
Timekeeper started at Tue Oct 6 23:54:55 CDT 2015
Timekeeper sleeping for 720 seconds
Tests Failures
Dumping logfile of emu: standard op-configure --prefix=/mnt/scr1/pre-release/opa/emu32 deploy emu32
Last 50 lines of /mnt/scr1/SnapTest/snapshots-opa/log/emu_1006Tue_2354
GROUP=hdf
HDF5_ACLOCAL=/mnt/hdf/packages/AUTOTOOLS/automake/1.15/sun4v/bin/aclocal-1.15
HDF5_AUTOCONF=/mnt/hdf/packages/AUTOTOOLS/autoconf/2.69/sun4v/bin/autoconf
HDF5_AUTOHEADER=/mnt/hdf/packages/AUTOTOOLS/autoconf/2.69/sun4v/bin/autoheader
HDF5_AUTOMAKE=/mnt/hdf/packages/AUTOTOOLS/automake/1.15/sun4v/bin/automake-1.15
HDF5_LIBTOOL=/mnt/hdf/packages/AUTOTOOLS/libtool/2.4.6/sun4v/bin/libtool
HDF5_M4=/mnt/hdf/packages/AUTOTOOLS/m4/1.4.17/sun4v/bin/m4
HDF5TestExpress=yes
HOME=/home/hdftest
HOST=emu
HOSTTYPE=sun4
JAVA_HOME=/usr/lib/jvm/jre-1.6.0
LANG=en_US.UTF-8
LC_ALL=
LC_COLLATE=
LC_CTYPE=
LC_MESSAGES=
LC_MONETARY=
LC_NUMERIC=
LC_TIME=
LOGNAME=hdftest
MACHTYPE=sparc
MAIL=/var/mail/hdftest
MAKE=gmake
NLSPATH=/usr/share/locale/%L/LC_MESSAGES/%N.cat
OSTYPE=solaris
PATH=/home/hdftest/bin:/usr/hdf/bin:/home/hdftest/bin:/usr/hdf/bin:/usr/bin:/usr/sbin:/opt/solarisstudio/bin:/opt/cmake/bin:/opt/svn/bin:/mnt/hdf/ec2-api-tools/bin
PWD=/mnt/scr1/SnapTest/snapshots-opa
REMOTEHOST=
SET_PATH=yes
SHELL=/bin/tcsh
SHLVL=3
SSH_CLIENT=10.10.10.86 45867 22
SSH_CONNECTION=10.10.10.86 45867 10.10.10.84 22
SVNROOT=http://svn.hdfgroup.uiuc.edu
TZ=localtime
USER=hdftest
VENDOR=sun
===Done Dumping environment variables after option parsing ===
===== Run Tests: Tuesday, October 6, 2015 11:54:46 PM CDT =====
Remove contents of emu.
diff: /home/hdftest/snapshots-opa/previous/MANIFEST: No such file or directory
===== configure: Tuesday, October 6, 2015 11:54:46 PM CDT =====
checking for a BSD-compatible install... /usr/bin/ginstall -c
checking whether build environment is sane... configure: error: newly created file is older than distributed files!
Check your system clock
Failed running configure
===== Exit bin/snapshot with status=1: Tuesday, October 6, 2015 11:54:48 PM CDT =====
Dumping done
Runtest did not exit normally.
Watchers List
OPA Daily test features/platforms watchers and procedure
Procedure:
The watcher will investigate and report the cause of failure by 11am.
The developer who checked in the error code may report so by then too.
The watcher or the developer should get the failure fixed and report it
by 3pm.
Watcher for OPA: Neil
updated: 2009/05/05
Tests Details
23:54:34 up 6 days, 10:49, 23 users, load average: 0.51, 0.29, 0.22
Filesystem 1K-blocks Used Available Use% Mounted on
/dev/sda3 31738420 8769460 21330732 30% /
/dev/sda1 101086 17532 78335 19% /boot
/dev/sda2 31738420 315736 29784456 2% /tmp
/dev/sda6 31738392 5475368 24624800 19% /var
/dev/sda7 31738392 18498412 11601756 62% /usr
/dev/sda8 124991068 193660 118345708 1% /var/tmp
/dev/mapper/VolGroup00-home
198351840 94423512 93689968 51% /home
/dev/sde1 565688764 431689424 104800404 81% /scr
/dev/sdc1 961432072 767148600 145445472 85% /mnt/scr1
/dev/sdd1 961432072 874136164 38457908 96% /mnt/hdf
tmpfs 8313628 0 8313628 0% /dev/shm
gumund:/data/ftp 480719104 393916032 62383872 87% /mnt/ftp
gumund:/data/web 480719104 393916032 62383872 87% /mnt/web
10.10.10.15:/volume1/hdf2
1437485440 238696192 1198686848 17% /mnt/hdf2
10.10.10.15:/volume1/hdf3
1437485440 238696192 1198686848 17% /mnt/hdf3
10.10.10.15:/volume1/readonly
1437485440 238696192 1198686848 17% /mnt/readonly
1437485440 238696192 1198686848 17% /mnt/ro-src
1437485440 238696192 1198686848 17% /mnt/rw-src
STANDARD_OPT=setenv MAKE gmake deploydir /mnt/scr1/pre-release/opa
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam
Running source repository checkout with output saved in
/mnt/scr1/SnapTest/snapshots-opa/log/REPO_LOG_1006Tue
Checking MANIFEST file ...
cat: /mnt/scr1/SnapTest/snapshots-opa/log/#runtest.1006Tue.24947: No such file or directory
rm: cannot remove `/mnt/scr1/SnapTest/snapshots-opa/log/#runtest.1006Tue.24947': No such file or directory
*** launching tests from jam ***
TESTHOST is emu
jam
koala
platypus
ostrich
quail
kite
Fork off timekeeper 12
Testing emu
ssh -o ConnectTimeout=60 emu -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname emu
11:54pm up 100 day(s), 8:59, 1 user, load average: 0.36, 0.80, 1.36
/ (rpool/ROOT/solaris):425448108 blocks 425448108 files
/devices (/devices ): 0 blocks 0 files
/dev (/dev ): 0 blocks 0 files
/system/contract (ctfs ): 0 blocks 2147483587 files
/proc (proc ): 0 blocks 29918 files
/etc/mnttab (mnttab ): 0 blocks 0 files
/system/volatile (swap ): 5407408 blocks 2200053 files
/system/object (objfs ): 0 blocks 2147483464 files
/etc/dfs/sharetab (sharefs ): 0 blocks 2147483646 files
/dev/fd (fd ): 0 blocks 0 files
/var (rpool/ROOT/solaris/var):425448108 blocks 425448108 files
/tmp (swap ): 5407408 blocks 2200053 files
/var/share (rpool/VARSHARE ):425448108 blocks 425448108 files
/rpool (rpool ):425448108 blocks 425448108 files
/export (rpool/export ):425448108 blocks 425448108 files
/export/home (rpool/export/home ):425448108 blocks 425448108 files
/export/home/kurz (rpool/export/home/kurz):425448108 blocks 425448108 files
/home (jam.ad.hdfgroup.org:/home):207856656 blocks 50220571 files
/mnt/hdf (jam.ad.hdfgroup.org:/mnt/hdf):174591816 blocks 111667606 files
/mnt/scr1 (jam.ad.hdfgroup.org:/mnt/scr1):388566552 blocks 118010611 files
/mnt/ro-src (10.10.10.15:/volume1/readonly):2397578312 blocks 91191972 files
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/emu32 deploy emu32
Extract source and run autogen if .
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/emu32 deploy emu32 tests in emu ***
Uname -a: SunOS emu 5.11 11.1 sun4v sparc sun4v
Running snapshot with output saved in
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/emu32 deploy emu32 tests for emu ***
Total time = 0m 2s
*** finished tests in emu ***
****SYSTEM ERROR emu: Abnormal exit from runtest ****
****SYSTEM ERROR emu: runtest command failed ****
Testing jam
ssh -o ConnectTimeout=60 jam -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname jam
23:55:02 up 6 days, 10:50, 23 users, load average: 0.51, 0.31, 0.22
/dev/sda2 31738420 315848 29784344 2% /tmp
/dev/sda6 31738392 5475440 24624728 19% /var
/dev/sdc1 961432072 767148804 145445268 85% /mnt/scr1
Tue Oct 6 23:55:12 CDT 2015
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam tests in jam ***
Uname -a: Linux jam 2.6.18-308.13.1.el5PAE #1 SMP Tue Aug 21 17:50:26 EDT 2012 i686 i686 i386 GNU/Linux
/mnt/scr1/SnapTest/snapshots-opa/log/jam_1006Tue_2355
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam tests for jam ***
Tue Oct 6 23:56:14 CDT 2015
Total time = 1m 2s
*** finished tests in jam ***
Testing koala
ssh -o ConnectTimeout=60 koala -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname koala
23:55:04 up 41 days, 11:05, 0 users, load average: 0.00, 0.00, 0.00
/dev/sda7 22292052 4436472 16704928 21% /
/dev/sda5 12192608 383524 11179740 4% /tmp
/dev/sda3 12192636 1000348 10562944 9% /var
/dev/sda1 101086 18614 77253 20% /boot
/dev/sdc1 41279536 26268092 12914564 68% /usr
/dev/sdb 152754284 67502964 77491860 47% /scr
tmpfs 6149552 0 6149552 0% /dev/shm
10.10.10.86:/home 198351872 94423040 93690880 51% /home
10.10.10.86:/mnt/hdf 961432576 874136576 38458368 96% /mnt/hdf
10.10.10.86:/mnt/scr1
961432576 767149056 145445888 85% /mnt/scr1
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala
Tue Oct 6 23:55:14 CDT 2015
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala tests in koala ***
Uname -a: Linux koala 2.6.18-406.el5 #1 SMP Tue Jun 2 17:25:57 EDT 2015 x86_64 x86_64 x86_64 GNU/Linux
/mnt/scr1/SnapTest/snapshots-opa/log/koala_1006Tue_2355
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala tests for koala ***
Tue Oct 6 23:55:46 CDT 2015
Total time = 0m 32s
*** finished tests in koala ***
Testing platypus
ssh -o ConnectTimeout=60 platypus -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname platypus
23:55:09 up 39 days, 13:23, 5 users, load average: 3.03, 3.13, 2.89
/dev/sda6 54205540 22747800 28697600 45% /
tmpfs 6099072 0 6099072 0% /dev/shm
/dev/sda1 194241 48551 135450 27% /boot
/dev/sda2 12850716 356772 11834488 3% /tmp
/dev/sda3 12850716 4086352 8104908 34% /var
/dev/sdd 152623212 112624384 32239368 78% /scr
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus
Tue Oct 6 23:55:19 CDT 2015
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus tests in platypus ***
Uname -a: Linux platypus 2.6.32-573.3.1.el6.x86_64 #1 SMP Thu Aug 13 22:55:16 UTC 2015 x86_64 x86_64 x86_64 GNU/Linux
/mnt/scr1/SnapTest/snapshots-opa/log/platypus_1006Tue_2355
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus tests for platypus ***
Tue Oct 6 23:56:08 CDT 2015
Total time = 0m 49s
*** finished tests in platypus ***
Testing ostrich
ssh -o ConnectTimeout=60 ostrich -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname ostrich
23:55:10 up 90 days, 10:43, 0 users, load average: 0.72, 0.97, 1.37
/dev/mapper/vg_ostrich-lv_root
140479384 19317068 114023272 15% /
tmpfs 7821632 0 7821632 0% /dev/shm
/dev/sda2 487652 92973 369079 21% /boot
/dev/sdb2 124477364 84535220 33612392 72% /scr
jam:/home 198351872 94423040 93690880 51% /home
jam:/mnt/hdf 961432576 874136576 38458368 96% /mnt/hdf
jam:/mnt/scr1 961432576 767149056 145445888 85% /mnt/scr1
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich ; standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl
Tue Oct 6 23:55:20 CDT 2015
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich tests in ostrich ***
Uname -a: Linux ostrich 2.6.32-504.8.1.el6.ppc64 #1 SMP Fri Dec 19 12:10:45 EST 2014 ppc64 ppc64 ppc64 GNU/Linux
/mnt/scr1/SnapTest/snapshots-opa/log/ostrich_1006Tue_2355
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich tests for ostrich ***
Tue Oct 6 23:57:00 CDT 2015
Total time = 1m 40s
*** starting standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl tests in ostrich ***
/mnt/scr1/SnapTest/snapshots-opa/log/ostrich_1006Tue_2357
*** finished standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl tests for ostrich ***
Wed Oct 7 00:00:07 CDT 2015
Total time = 3m 7s
*** finished tests in ostrich ***
Testing quail
ssh -o ConnectTimeout=60 quail -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname quail
23:55 up 39 days, 13:35, 0 users, load averages: 1.56 1.62 1.58
Filesystem 512-blocks Used Available Capacity iused ifree %iused Mounted on
/dev/disk0s2 488555536 181987240 306056296 38% 22812403 38257037 37% /
devfs 362 362 0 100% 627 0 100% /dev
map auto_nfs 0 0 0 100% 0 0 100% /mnt/hdf
map auto_nfs 0 0 0 100% 0 0 100% /mnt/scr1
map auto_nfs 0 0 0 100% 0 0 100% /home
jam.ad.hdfgroup.org:/mnt/scr1 1922864144 1534297688 290890456 85% 4099352 118010600 3% /mnt/scr1
jam.ad.hdfgroup.org:/mnt/hdf 1922864144 1748272328 76915816 96% 10442346 111667606 9% /mnt/hdf
jam.ad.hdfgroup.org:/home 396703680 188847024 187379936 51% 995813 50220571 2% /home
TEST_TYPES=standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/quail deploy quail
Tue Oct 6 23:55:23 CDT 2015
*** starting standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/quail deploy quail tests in quail ***
Uname -a: Darwin quail.ad.hdfgroup.org 13.4.0 Darwin Kernel Version 13.4.0: Wed Mar 18 16:20:14 PDT 2015; root:xnu-2422.115.14~1/RELEASE_X86_64 x86_64
/Users/hdftest/snapshots-opa/log/quail_1006Tue_2355
*** finished standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/quail deploy quail tests for quail ***
Tue Oct 6 23:56:18 CDT 2015
Total time = 0m 55s
*** finished tests in quail ***
Testing kite
ssh -o ConnectTimeout=60 kite -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname kite
23:55 up 39 days, 13:34, 0 users, load averages: 0.08 0.10 0.20
/dev/disk0s2 1951845952 250660848 1700673104 13% 31396604 212584138 13% /
devfs 373 373 0 100% 646 0 100% /dev
/dev/disk1s2 1952853344 1296656 1951556688 1% 162080 243944586 0% /Volumes/Milvinae
10.10.10.86:/home 396703680 188847024 187379936 51% 995813 50220571 2% /mnt/home
10.10.10.86:/mnt/scr1 1922864144 1534297736 290890408 85% 4099357 118010595 3% /mnt/scr1
10.10.10.86:/mnt/hdf 1922864144 1748272328 76915816 96% 10442346 111667606 9% /mnt/hdf
TEST_TYPES=standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/kite deploy kite
Tue Oct 6 23:55:25 CDT 2015
*** starting standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/kite deploy kite tests in kite ***
Uname -a: Darwin kite.ad.hdfgroup.org 12.6.0 Darwin Kernel Version 12.6.0: Wed Mar 18 16:23:48 PDT 2015; root:xnu-2050.48.19~1/RELEASE_X86_64 x86_64
/Users/hdftest/snapshots-opa/log/kite_1006Tue_2355
*** finished standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/kite deploy kite tests for kite ***
Tue Oct 6 23:56:10 CDT 2015
Total time = 0m 45s
*** finished tests in kite ***
More information about the opa-nightly-tests
