[opa-nightly-tests] jam OPA_Daily_Tests_0720Mon_FAILED!!!
HDF Tester
hdftest at hdfgroup.org
Mon Jul 20 19:04:07 CDT 2015
*** OPA Tests on 0720Mon ***
Tests Summary
****FAILED emu: setenvN 2 CC cc -m64 op-configure --prefix=/mnt/scr1/pre-release/opa/emu64 deploy emu64****
PASSED jam: standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam
PASSED kite: standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/kite deploy kite
PASSED koala: standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala
PASSED ostrich: standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich
PASSED ostrich: standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl
PASSED platypus: standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus
PASSED quail: standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/quail deploy quail
Tests Time Summary
emu: Ran 1(0/1/0) tests, Grand total test time = 0m 2s
koala: Ran 1(1/0/0) tests, Grand total test time = 0m 32s
platypus: Ran 1(1/0/0) tests, Grand total test time = 0m 41s
kite: Ran 1(1/0/0) tests, Grand total test time = 0m 48s
jam: Ran 1(1/0/0) tests, Grand total test time = 1m 3s
quail: Ran 1(1/0/0) tests, Grand total test time = 0m 55s
ostrich: Ran 2(2/0/0) tests, Grand total test time = 4m 51s
jam: Ran 7(0/0/0) hosts, Grand total test time = 5m 58s
Timekeeper log
Timekeeper started at Mon Jul 20 18:58:20 CDT 2015
Timekeeper sleeping for 720 seconds
Tests Failures
Dumping logfile of emu: setenvN 2 CC cc -m64 op-configure --prefix=/mnt/scr1/pre-release/opa/emu64 deploy emu64
Last 50 lines of /mnt/scr1/SnapTest/snapshots-opa/log/emu_0720Mon_1857
CC= cc -m64
CCACHE_DISABLE=yes
CVSROOT=/mnt/hdf/cvs
EC2_CERT=/home/hdftest/.ec2/cert-6HKISUOM3HT2PWDQB4PLG67KTWOVVKOK.pem
EC2_HOME=/mnt/hdf/ec2-api-tools
EC2_PRIVATE_KEY=/home/hdftest/.ec2/pk-6HKISUOM3HT2PWDQB4PLG67KTWOVVKOK.pem
GROUP=hdf
HDF5TestExpress=yes
HOME=/home/hdftest
HOST=emu
HOSTTYPE=sun4
JAVA_HOME=/usr/lib/jvm/jre-1.6.0
LANG=en_US.UTF-8
LC_ALL=
LC_COLLATE=
LC_CTYPE=
LC_MESSAGES=
LC_MONETARY=
LC_NUMERIC=
LC_TIME=
LOGNAME=hdftest
MACHTYPE=sparc
MAIL=/var/mail/hdftest
MAKE=gmake
NLSPATH=/usr/share/locale/%L/LC_MESSAGES/%N.cat
OSTYPE=solaris
PATH=/home/hdftest/bin:/usr/hdf/bin:/home/hdftest/bin:/usr/hdf/bin:/usr/bin:/usr/sbin:/opt/solarisstudio/bin:/opt/cmake/bin:/opt/svn/bin:/mnt/hdf/ec2-api-tools/bin
PWD=/mnt/scr1/SnapTest/snapshots-opa
REMOTEHOST=
SET_PATH=yes
SHELL=/bin/tcsh
SHLVL=3
SSH_CLIENT=10.10.10.86 48586 22
SSH_CONNECTION=10.10.10.86 48586 10.10.10.84 22
SVNROOT=http://svn.hdfgroup.uiuc.edu
TZ=localtime
USER=hdftest
VENDOR=sun
===Done Dumping environment variables after option parsing ===
===== Run Tests: Monday, July 20, 2015 06:57:47 PM CDT =====
Remove contents of emu.
diff: /home/hdftest/snapshots-opa/previous/MANIFEST: No such file or directory
===== configure: Monday, July 20, 2015 06:57:48 PM CDT =====
checking for a BSD-compatible install... /usr/bin/ginstall -c
checking whether build environment is sane... configure: error: newly created file is older than distributed files!
Check your system clock
Failed running configure
===== Exit bin/snapshot with status=1: Monday, July 20, 2015 06:57:49 PM CDT =====
Dumping done
Runtest did not exit normally.
Watchers List
OPA Daily test features/platforms watchers and procedure
Procedure:
The watcher will investigate and report the cause of failure by 11am.
The developer who checked in the error code may report so by then too.
The watcher or the developer should get the failure fixed and report it
by 3pm.
Watcher for OPA: Neil
updated: 2009/05/05
Tests Details
18:57:59 up 22 days, 23:15, 8 users, load average: 0.02, 0.04, 0.08
Filesystem 1K-blocks Used Available Use% Mounted on
/dev/sda3 31738420 8486416 21613776 29% /
/dev/sda1 101086 17532 78335 19% /boot
/dev/sda2 31738420 268804 29831388 1% /tmp
/dev/sda6 31738392 5339632 24760536 18% /var
/dev/sda7 31738392 18478512 11621656 62% /usr
/dev/sda8 124991068 377324 118162044 1% /var/tmp
/dev/mapper/VolGroup00-home
198351840 51761488 136351992 28% /home
/dev/sde1 565688764 412380452 124109376 77% /scr
/dev/sdc1 961432072 880338136 32255936 97% /mnt/scr1
/dev/sdd1 961432072 859588548 53005524 95% /mnt/hdf
tmpfs 8313628 0 8313628 0% /dev/shm
gumund:/data/ftp 480719104 355349888 100950016 78% /mnt/ftp
gumund:/data/web 480719104 355349888 100950016 78% /mnt/web
STANDARD_OPT=setenv MAKE gmake deploydir /mnt/scr1/pre-release/opa
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam
Running source repository checkout with output saved in
/mnt/scr1/SnapTest/snapshots-opa/log/REPO_LOG_0720Mon
Checking MANIFEST file ...
cat: /mnt/scr1/SnapTest/snapshots-opa/log/#runtest.0720Mon.23943: No such file or directory
rm: cannot remove `/mnt/scr1/SnapTest/snapshots-opa/log/#runtest.0720Mon.23943': No such file or directory
*** launching tests from jam ***
TESTHOST is emu
jam
koala
platypus
ostrich
quail
kite
Fork off timekeeper 12
Testing emu
ssh -o ConnectTimeout=60 emu -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname emu
6:57pm up 22 day(s), 4:02, 2 users, load average: 0.00, 0.01, 0.68
/ (rpool/ROOT/solaris):462852342 blocks 462852342 files
/devices (/devices ): 0 blocks 0 files
/dev (/dev ): 0 blocks 0 files
/system/contract (ctfs ): 0 blocks 2147483589 files
/proc (proc ): 0 blocks 29923 files
/etc/mnttab (mnttab ): 0 blocks 0 files
/system/volatile (swap ):24992400 blocks 2229225 files
/system/object (objfs ): 0 blocks 2147483467 files
/etc/dfs/sharetab (sharefs ): 0 blocks 2147483646 files
/dev/fd (fd ): 0 blocks 0 files
/var (rpool/ROOT/solaris/var):462852342 blocks 462852342 files
/tmp (swap ):24992400 blocks 2229225 files
/var/share (rpool/VARSHARE ):462852342 blocks 462852342 files
/rpool (rpool ):462852342 blocks 462852342 files
/export (rpool/export ):462852342 blocks 462852342 files
/export/home (rpool/export/home ):462852342 blocks 462852342 files
/export/home/kurz (rpool/export/home/kurz):462852342 blocks 462852342 files
/home (jam.ad.hdfgroup.org:/home):293180704 blocks 50541134 files
/mnt/hdf (jam.ad.hdfgroup.org:/mnt/hdf):203687048 blocks 112130499 files
/mnt/scr1 (jam.ad.hdfgroup.org:/mnt/scr1):162187816 blocks 117894576 files
TEST_TYPES=setenvN 2 CC cc -m64 op-configure --prefix=/mnt/scr1/pre-release/opa/emu64 deploy emu64
*** starting setenvN 2 CC cc -m64 op-configure --prefix=/mnt/scr1/pre-release/opa/emu64 deploy emu64 tests in emu ***
Uname -a: SunOS emu 5.11 11.1 sun4v sparc sun4v
Running snapshot with output saved in
*** finished setenvN 2 CC cc -m64 op-configure --prefix=/mnt/scr1/pre-release/opa/emu64 deploy emu64 tests for emu ***
Total time = 0m 2s
*** finished tests in emu ***
****SYSTEM ERROR emu: Abnormal exit from runtest ****
****SYSTEM ERROR emu: runtest command failed ****
Testing jam
ssh -o ConnectTimeout=60 jam -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname jam
18:58:28 up 22 days, 23:16, 8 users, load average: 0.40, 0.13, 0.11
/dev/sda2 31738420 268908 29831284 1% /tmp
/dev/sda6 31738392 5339724 24760444 18% /var
/dev/sdc1 961432072 880338172 32255900 97% /mnt/scr1
Mon Jul 20 18:58:38 CDT 2015
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam tests in jam ***
Uname -a: Linux jam 2.6.18-308.13.1.el5PAE #1 SMP Tue Aug 21 17:50:26 EDT 2012 i686 i686 i386 GNU/Linux
/mnt/scr1/SnapTest/snapshots-opa/log/jam_0720Mon_1858
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam tests for jam ***
Mon Jul 20 18:59:41 CDT 2015
Total time = 1m 3s
*** finished tests in jam ***
Testing koala
ssh -o ConnectTimeout=60 koala -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname koala
18:58:30 up 21 days, 10:08, 1 user, load average: 0.01, 0.37, 0.33
/dev/sda7 22292052 4049640 17091760 20% /
/dev/sda5 12192608 396212 11167052 4% /tmp
/dev/sda3 12192636 1170644 10392648 11% /var
/dev/sda1 101086 18614 77253 20% /boot
/dev/sdc1 41279536 26230136 12952520 67% /usr
/dev/sdb 152754284 73214816 71780008 51% /scr
tmpfs 6149552 0 6149552 0% /dev/shm
10.10.10.86:/mnt/hdf 961432576 859588608 53006336 95% /mnt/hdf
10.10.10.86:/mnt/scr1
961432576 880337920 32256000 97% /mnt/scr1
10.10.10.86:/home 198351872 51761152 136352768 28% /home
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala
Mon Jul 20 18:58:40 CDT 2015
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala tests in koala ***
Uname -a: Linux koala 2.6.18-402.el5 #1 SMP Tue Feb 10 17:49:04 EST 2015 x86_64 x86_64 x86_64 GNU/Linux
/mnt/scr1/SnapTest/snapshots-opa/log/koala_0720Mon_1858
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala tests for koala ***
Mon Jul 20 18:59:12 CDT 2015
Total time = 0m 32s
*** finished tests in koala ***
Testing platypus
ssh -o ConnectTimeout=60 platypus -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname platypus
18:58:56 up 4 days, 10:41, 0 users, load average: 0.00, 0.06, 0.66
/dev/sda6 54205540 19693768 31751632 39% /
tmpfs 6099128 0 6099128 0% /dev/shm
/dev/sda1 194241 48100 135901 27% /boot
/dev/sda2 12850716 148228 12043032 2% /tmp
/dev/sda3 12850716 2923252 9268008 24% /var
/dev/sdd 152623212 84062636 60801116 59% /scr
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus
Mon Jul 20 18:59:06 CDT 2015
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus tests in platypus ***
Uname -a: Linux platypus 2.6.32-504.16.2.el6.x86_64 #1 SMP Wed Apr 22 06:48:29 UTC 2015 x86_64 x86_64 x86_64 GNU/Linux
/mnt/scr1/SnapTest/snapshots-opa/log/platypus_0720Mon_1859
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus tests for platypus ***
Mon Jul 20 18:59:47 CDT 2015
Total time = 0m 41s
*** finished tests in platypus ***
Testing ostrich
ssh -o ConnectTimeout=60 ostrich -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname ostrich
18:58:47 up 12 days, 5:46, 0 users, load average: 0.00, 0.00, 0.21
/dev/mapper/vg_ostrich-lv_root
140479384 16107884 117232456 13% /
tmpfs 7821632 0 7821632 0% /dev/shm
/dev/sda2 487652 92973 369079 21% /boot
/dev/sdb2 124477364 83684480 34463132 71% /scr
jam:/home 198351872 51761152 136352768 28% /home
jam:/mnt/hdf 961432576 859588608 53006336 95% /mnt/hdf
jam:/mnt/scr1 961432576 880337920 32256000 97% /mnt/scr1
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich ; standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl
Mon Jul 20 18:58:57 CDT 2015
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich tests in ostrich ***
Uname -a: Linux ostrich 2.6.32-504.8.1.el6.ppc64 #1 SMP Fri Dec 19 12:10:45 EST 2014 ppc64 ppc64 ppc64 GNU/Linux
/mnt/scr1/SnapTest/snapshots-opa/log/ostrich_0720Mon_1858
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich tests for ostrich ***
Mon Jul 20 19:00:37 CDT 2015
Total time = 1m 40s
*** starting standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl tests in ostrich ***
/mnt/scr1/SnapTest/snapshots-opa/log/ostrich_0720Mon_1900
*** finished standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl tests for ostrich ***
Mon Jul 20 19:03:48 CDT 2015
Total time = 3m 11s
*** finished tests in ostrich ***
Testing quail
ssh -o ConnectTimeout=60 quail -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname quail
18:58 up 21 days, 21 hrs, 0 users, load averages: 1.34 1.73 2.04
Filesystem 512-blocks Used Available Capacity iused ifree %iused Mounted on
/dev/disk0s2 488555536 157161016 330882520 33% 19709125 41360315 32% /
devfs 361 361 0 100% 626 0 100% /dev
map auto_nfs 0 0 0 100% 0 0 100% /mnt/hdf
map auto_nfs 0 0 0 100% 0 0 100% /mnt/scr1
map auto_nfs 0 0 0 100% 0 0 100% /home
jam.ad.hdfgroup.org:/mnt/scr1 1922864144 1760676416 64511728 97% 4215387 117894565 3% /mnt/scr1
jam.ad.hdfgroup.org:/mnt/hdf 1922864144 1719177096 106011048 95% 9979453 112130499 8% /mnt/hdf
jam.ad.hdfgroup.org:/home 396703680 103522976 272703984 28% 675250 50541134 1% /home
TEST_TYPES=standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/quail deploy quail
*** starting standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/quail deploy quail tests in quail ***
Uname -a: Darwin quail.ad.hdfgroup.org 13.4.0 Darwin Kernel Version 13.4.0: Wed Mar 18 16:20:14 PDT 2015; root:xnu-2422.115.14~1/RELEASE_X86_64 x86_64
/Users/hdftest/snapshots-opa/log/quail_0720Mon_1859
*** finished standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/quail deploy quail tests for quail ***
Mon Jul 20 19:00:01 CDT 2015
Total time = 0m 55s
*** finished tests in quail ***
Testing kite
ssh -o ConnectTimeout=60 kite -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname kite
18:58 up 18 days, 4:43, 0 users, load averages: 0.00 0.07 0.25
/dev/disk0s2 1951845952 213949936 1737384016 11% 26807740 217173002 11% /
devfs 372 372 0 100% 645 0 100% /dev
/dev/disk1s2 1952853344 1296608 1951556736 1% 162074 243944592 0% /Volumes/Milvinae
10.10.10.86:/mnt/hdf 1922864144 1719177096 106011048 95% 9979453 112130499 8% /mnt/hdf
10.10.10.86:/mnt/scr1 1922864144 1760676472 64511672 97% 4215393 117894559 3% /mnt/scr1
10.10.10.86:/home 396703680 103522976 272703984 28% 675250 50541134 1% /mnt/home
TEST_TYPES=standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/kite deploy kite
Mon Jul 20 18:58:54 CDT 2015
*** starting standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/kite deploy kite tests in kite ***
Uname -a: Darwin kite.ad.hdfgroup.org 12.6.0 Darwin Kernel Version 12.6.0: Wed Mar 18 16:23:48 PDT 2015; root:xnu-2050.48.19~1/RELEASE_X86_64 x86_64
/Users/hdftest/snapshots-opa/log/kite_0720Mon_1858
*** finished standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/kite deploy kite tests for kite ***
Total time = 0m 47s
*** finished tests in kite ***
More information about the opa-nightly-tests
