[opa-nightly-tests] jam OPA_Daily_Tests_0721Tue_FAILED!!!
HDF Tester hdftest at hdfgroup.org
Tue Jul 21 23:07:50 CDT 2015
*** OPA Tests on 0721Tue ***
   Tests Summary
****FAILED emu: standard op-configure --prefix=/mnt/scr1/pre-release/opa/emu32 deploy emu32****
PASSED jam: standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam
PASSED kite: standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/kite deploy kite
PASSED koala: standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala
PASSED ostrich: standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich
PASSED ostrich: standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl
PASSED platypus: standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus
PASSED quail: standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/quail deploy quail
   Tests Time Summary
emu: Ran 1(0/1/0) tests, Grand total test time =  0m 3s
koala: Ran 1(1/0/0) tests, Grand total test time =  0m 32s
platypus: Ran 1(1/0/0) tests, Grand total test time =  0m 42s
kite: Ran 1(1/0/0) tests, Grand total test time =  0m 48s
jam: Ran 1(1/0/0) tests, Grand total test time =  1m 2s
quail: Ran 1(1/0/0) tests, Grand total test time =  0m 56s
ostrich: Ran 2(2/0/0) tests, Grand total test time =  4m 38s
jam: Ran 7(0/0/0) hosts, Grand total test time =  5m 43s
   Timekeeper log
Timekeeper started at Tue Jul 21 23:02:19 CDT 2015
Timekeeper sleeping for 720 seconds
   Tests Failures
Dumping logfile of emu: standard op-configure --prefix=/mnt/scr1/pre-release/opa/emu32 deploy emu32
Last 50 lines of /mnt/scr1/SnapTest/snapshots-opa/log/emu_0721Tue_2301
A__z="*SHLVL
CCACHE_DISABLE=yes
CVSROOT=/mnt/hdf/cvs
EC2_CERT=/home/hdftest/.ec2/cert-6HKISUOM3HT2PWDQB4PLG67KTWOVVKOK.pem
EC2_HOME=/mnt/hdf/ec2-api-tools
EC2_PRIVATE_KEY=/home/hdftest/.ec2/pk-6HKISUOM3HT2PWDQB4PLG67KTWOVVKOK.pem
GROUP=hdf
HDF5TestExpress=yes
HOME=/home/hdftest
HOST=emu
HOSTTYPE=sun4
JAVA_HOME=/usr/lib/jvm/jre-1.6.0
LANG=en_US.UTF-8
LC_ALL=
LC_COLLATE=
LC_CTYPE=
LC_MESSAGES=
LC_MONETARY=
LC_NUMERIC=
LC_TIME=
LOGNAME=hdftest
MACHTYPE=sparc
MAIL=/var/mail/hdftest
MAKE=gmake
NLSPATH=/usr/share/locale/%L/LC_MESSAGES/%N.cat
OSTYPE=solaris
PATH=/home/hdftest/bin:/usr/hdf/bin:/home/hdftest/bin:/usr/hdf/bin:/usr/bin:/usr/sbin:/opt/solarisstudio/bin:/opt/cmake/bin:/opt/svn/bin:/mnt/hdf/ec2-api-tools/bin
PWD=/mnt/scr1/SnapTest/snapshots-opa
REMOTEHOST=
SET_PATH=yes
SHELL=/bin/tcsh
SHLVL=3
SSH_CLIENT=10.10.10.86 43088 22
SSH_CONNECTION=10.10.10.86 43088 10.10.10.84 22
SVNROOT=http://svn.hdfgroup.uiuc.edu
TZ=localtime
USER=hdftest
VENDOR=sun
===Done Dumping environment variables after option parsing ===
===== Run Tests: Tuesday, July 21, 2015 11:01:47 PM CDT =====
Remove contents of emu.
diff: /home/hdftest/snapshots-opa/previous/MANIFEST: No such file or directory
===== configure: Tuesday, July 21, 2015 11:01:47 PM CDT =====
checking for a BSD-compatible install... /usr/bin/ginstall -c
checking whether build environment is sane... configure: error: newly created file is older than distributed files!
Check your system clock
Failed running configure
===== Exit bin/snapshot with status=1: Tuesday, July 21, 2015 11:01:49 PM CDT =====
Dumping done
Runtest did not exit normally.
   Watchers List
OPA Daily test features/platforms watchers and procedure
Procedure:
The watcher will investigate and report the cause of failure by 11am.
The developer who checked in the error code may report so by then too.
The watcher or the developer should get the failure fixed and report it
by 3pm.
Watcher for OPA:	 	Neil
updated: 2009/05/05
   Tests Details
 23:01:57 up 24 days,  3:19, 15 users,  load average: 0.34, 0.24, 0.18
Filesystem           1K-blocks      Used Available Use% Mounted on
/dev/sda3             31738420   8485692  21614500  29% /
/dev/sda1               101086     17532     78335  19% /boot
/dev/sda2             31738420    254112  29846080   1% /tmp
/dev/sda6             31738392   5311284  24788884  18% /var
/dev/sda7             31738392  18478512  11621656  62% /usr
/dev/sda8            124991068    377324 118162044   1% /var/tmp
/dev/mapper/VolGroup00-home
                     198351840  51762772 136350708  28% /home
/dev/sde1            565688764 412553568 123936260  77% /scr
/dev/sdc1            961432072 880944684  31649388  97% /mnt/scr1
/dev/sdd1            961432072 859881776  52712296  95% /mnt/hdf
tmpfs                  8313628         0   8313628   0% /dev/shm
gumund:/data/ftp     480719104 355350016 100949888  78% /mnt/ftp
gumund:/data/web     480719104 355350016 100949888  78% /mnt/web
STANDARD_OPT=setenv MAKE gmake deploydir /mnt/scr1/pre-release/opa
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam
Running source repository checkout with output saved in
   /mnt/scr1/SnapTest/snapshots-opa/log/REPO_LOG_0721Tue
Checking MANIFEST file ...
cat: /mnt/scr1/SnapTest/snapshots-opa/log/#runtest.0721Tue.3015: No such file or directory
rm: cannot remove `/mnt/scr1/SnapTest/snapshots-opa/log/#runtest.0721Tue.3015': No such file or directory
*** launching tests from jam ***
TESTHOST is emu
jam
koala
platypus
ostrich
quail
kite
    Fork off timekeeper 12
Testing emu
ssh -o ConnectTimeout=60 emu -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname emu
 11:01pm  up 23 day(s),  8:06,  1 user,  load average: 0.00, 0.01, 0.67
/                  (rpool/ROOT/solaris):450663708 blocks 450663708 files
/devices           (/devices          ):       0 blocks        0 files
/dev               (/dev              ):       0 blocks        0 files
/system/contract   (ctfs              ):       0 blocks 2147483590 files
/proc              (proc              ):       0 blocks    29930 files
/etc/mnttab        (mnttab            ):       0 blocks        0 files
/system/volatile   (swap              ):26276464 blocks  2229228 files
/system/object     (objfs             ):       0 blocks 2147483467 files
/etc/dfs/sharetab  (sharefs           ):       0 blocks 2147483646 files
/dev/fd            (fd                ):       0 blocks        0 files
/var               (rpool/ROOT/solaris/var):450663708 blocks 450663708 files
/tmp               (swap              ):26276464 blocks  2229228 files
/var/share         (rpool/VARSHARE    ):450663708 blocks 450663708 files
/rpool             (rpool             ):450663708 blocks 450663708 files
/export            (rpool/export      ):450663708 blocks 450663708 files
/export/home       (rpool/export/home ):450663708 blocks 450663708 files
/export/home/kurz  (rpool/export/home/kurz):450663708 blocks 450663708 files
/home              (jam.ad.hdfgroup.org:/home):293178120 blocks 50541122 files
/mnt/hdf           (jam.ad.hdfgroup.org:/mnt/hdf):203100592 blocks 112123570 files
/mnt/scr1          (jam.ad.hdfgroup.org:/mnt/scr1):160974720 blocks 117857090 files
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/emu32 deploy emu32
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/emu32 deploy emu32 tests in emu ***
Uname -a: SunOS emu 5.11 11.1 sun4v sparc sun4v
Running snapshot with output saved in
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/emu32 deploy emu32 tests for emu ***
Total time = 0m 2s
*** finished tests in emu ***
****SYSTEM ERROR emu: Abnormal exit from runtest ****
	****SYSTEM ERROR emu: runtest command failed ****
Testing jam
ssh -o ConnectTimeout=60 jam -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname jam
 23:02:26 up 24 days,  3:20, 15 users,  load average: 0.42, 0.27, 0.19
/dev/sda2             31738420    254220  29845972   1% /tmp
/dev/sda6             31738392   5311344  24788824  18% /var
                     198351840  51762780 136350700  28% /home
/dev/sdc1            961432072 880944720  31649352  97% /mnt/scr1
Tue Jul 21 23:02:36 CDT 2015
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam tests in jam ***
Uname -a: Linux jam 2.6.18-308.13.1.el5PAE #1 SMP Tue Aug 21 17:50:26 EDT 2012 i686 i686 i386 GNU/Linux
   /mnt/scr1/SnapTest/snapshots-opa/log/jam_0721Tue_2302
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam tests for jam ***
Tue Jul 21 23:03:38 CDT 2015
Total time = 1m 2s
*** finished tests in jam ***
Testing koala
ssh -o ConnectTimeout=60 koala -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname koala
 23:02:28 up 22 days, 14:12,  1 user,  load average: 0.03, 0.11, 0.10
/dev/sda7             22292052   4049640  17091760  20% /
/dev/sda5             12192608    385660  11177604   4% /tmp
/dev/sda3             12192636   1149712  10413580  10% /var
/dev/sda1               101086     18614     77253  20% /boot
/dev/sdc1             41279536  26230136  12952520  67% /usr
/dev/sdb             152754284  73165496  71829328  51% /scr
tmpfs                  6149552         0   6149552   0% /dev/shm
10.10.10.86:/mnt/hdf 961432576 859881472  52712448  95% /mnt/hdf
10.10.10.86:/mnt/scr1
                     961432576 880945152  31649792  97% /mnt/scr1
10.10.10.86:/home    198351872  51762176 136350720  28% /home
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala
Tue Jul 21 23:02:38 CDT 2015
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala tests in koala ***
Uname -a: Linux koala 2.6.18-402.el5 #1 SMP Tue Feb 10 17:49:04 EST 2015 x86_64 x86_64 x86_64 GNU/Linux
   /mnt/scr1/SnapTest/snapshots-opa/log/koala_0721Tue_2302
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala tests for koala ***
Tue Jul 21 23:03:10 CDT 2015
Total time = 0m 32s
*** finished tests in koala ***
Testing platypus
ssh -o ConnectTimeout=60 platypus -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname platypus
 23:03:01 up 5 days, 14:45,  0 users,  load average: 0.00, 0.10, 0.78
/dev/sda6             54205540  19693776  31751624  39% /
tmpfs                  6099128         0   6099128   0% /dev/shm
/dev/sda1               194241     48100    135901  27% /boot
/dev/sda2             12850716     93300  12097960   1% /tmp
/dev/sda3             12850716   2932628   9258632  25% /var
/dev/sdd             152623212  84791100  60072652  59% /scr
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus
Tue Jul 21 23:03:11 CDT 2015
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus tests in platypus ***
Uname -a: Linux platypus 2.6.32-504.16.2.el6.x86_64 #1 SMP Wed Apr 22 06:48:29 UTC 2015 x86_64 x86_64 x86_64 GNU/Linux
   /mnt/scr1/SnapTest/snapshots-opa/log/platypus_0721Tue_2303
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus tests for platypus ***
Tue Jul 21 23:03:53 CDT 2015
Total time = 0m 42s
*** finished tests in platypus ***
Testing ostrich
ssh -o ConnectTimeout=60 ostrich -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname ostrich
 23:02:46 up 13 days,  9:50,  0 users,  load average: 0.00, 0.00, 0.20
/dev/mapper/vg_ostrich-lv_root
                     140479384  15983972 117356368  12% /
tmpfs                  7821632         0   7821632   0% /dev/shm
/dev/sda2               487652     92973    369079  21% /boot
/dev/sdb2            124477364  83823488  34324124  71% /scr
jam:/home            198351872  51762176 136350720  28% /home
jam:/mnt/hdf         961432576 859881472  52712448  95% /mnt/hdf
jam:/mnt/scr1        961432576 880945152  31649792  97% /mnt/scr1
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich ; standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl
Tue Jul 21 23:02:56 CDT 2015
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich tests in ostrich ***
Uname -a: Linux ostrich 2.6.32-504.8.1.el6.ppc64 #1 SMP Fri Dec 19 12:10:45 EST 2014 ppc64 ppc64 ppc64 GNU/Linux
   /mnt/scr1/SnapTest/snapshots-opa/log/ostrich_0721Tue_2302
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich tests for ostrich ***
Tue Jul 21 23:04:30 CDT 2015
Total time = 1m 34s
*** starting standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl tests in ostrich ***
   /mnt/scr1/SnapTest/snapshots-opa/log/ostrich_0721Tue_2304
*** finished standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl tests for ostrich ***
Tue Jul 21 23:07:33 CDT 2015
Total time = 3m 3s
*** finished tests in ostrich ***
Tue Jul 21 23:07:34 CDT 2015
Testing quail
ssh -o ConnectTimeout=60 quail -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname quail
23:02  up 23 days,  1:04, 0 users, load averages: 1.47 1.82 2.11
Filesystem                    512-blocks       Used Available Capacity  iused     ifree %iused  Mounted on
/dev/disk0s2                   488555536  157546064 330497472    33% 19757256  41312184   32%   /
devfs                                361        361         0   100%      626         0  100%   /dev
map auto_nfs                           0          0         0   100%        0         0  100%   /mnt/hdf
map auto_nfs                           0          0         0   100%        0         0  100%   /mnt/scr1
map auto_nfs                           0          0         0   100%        0         0  100%   /home
jam.ad.hdfgroup.org:/mnt/scr1 1922864144 1761889512  63298632    97%  4252873 117857079    3%   /mnt/scr1
jam.ad.hdfgroup.org:/mnt/hdf  1922864144 1719763552 105424592    95%  9986382 112123570    8%   /mnt/hdf
jam.ad.hdfgroup.org:/home      396703680  103525560 272701400    28%   675262  50541122    1%   /home
TEST_TYPES=standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/quail deploy quail
Tue Jul 21 23:03:06 CDT 2015
*** starting standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/quail deploy quail tests in quail ***
Uname -a: Darwin quail.ad.hdfgroup.org 13.4.0 Darwin Kernel Version 13.4.0: Wed Mar 18 16:20:14 PDT 2015; root:xnu-2422.115.14~1/RELEASE_X86_64 x86_64
   /Users/hdftest/snapshots-opa/log/quail_0721Tue_2303
*** finished standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/quail deploy quail tests for quail ***
Tue Jul 21 23:04:02 CDT 2015
Total time = 0m 56s
*** finished tests in quail ***
Testing kite
ssh -o ConnectTimeout=60 kite -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname kite
23:02  up 19 days,  8:47, 0 users, load averages: 0.02 0.05 0.22
/dev/disk0s2          1951845952  214692080 1736641872    12% 26900508 217080234   11%   /
devfs                        372        372          0   100%      645         0  100%   /dev
/dev/disk1s2          1952853344    1296608 1951556736     1%   162074 243944592    0%   /Volumes/Milvinae
10.10.10.86:/mnt/hdf  1922864144 1719763552  105424592    95%  9986382 112123570    8%   /mnt/hdf
10.10.10.86:/mnt/scr1 1922864144 1761889560   63298584    97%  4252878 117857074    3%   /mnt/scr1
10.10.10.86:/home      396703680  103525560  272701400    28%   675262  50541122    1%   /mnt/home
TEST_TYPES=standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/kite deploy kite
Tue Jul 21 23:02:53 CDT 2015
*** starting standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/kite deploy kite tests in kite ***
Uname -a: Darwin kite.ad.hdfgroup.org 12.6.0 Darwin Kernel Version 12.6.0: Wed Mar 18 16:23:48 PDT 2015; root:xnu-2050.48.19~1/RELEASE_X86_64 x86_64
   /Users/hdftest/snapshots-opa/log/kite_0721Tue_2302
*** finished standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/kite deploy kite tests for kite ***
Tue Jul 21 23:03:41 CDT 2015
Total time = 0m 48s
*** finished tests in kite ***
More information about the opa-nightly-tests mailing list
