[opa-nightly-tests] jam OPA_Daily_Tests_0719Sun_FAILED!!!
HDF Tester
hdftest at hdfgroup.org
Sun Jul 19 21:06:25 CDT 2015
*** OPA Tests on 0719Sun ***
Tests Summary
****FAILED emu: setenvN 2 CC cc -m64 op-configure --prefix=/mnt/scr1/pre-release/opa/emu64 deploy emu64****
PASSED jam: standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam
PASSED kite: standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/kite deploy kite
PASSED koala: standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala
PASSED ostrich: standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich
PASSED ostrich: standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl
PASSED platypus: standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus
PASSED quail: standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/quail deploy quail
Tests Time Summary
emu: Ran 1(0/1/0) tests, Grand total test time = 0m 2s
koala: Ran 1(1/0/0) tests, Grand total test time = 0m 33s
platypus: Ran 1(1/0/0) tests, Grand total test time = 0m 45s
kite: Ran 1(1/0/0) tests, Grand total test time = 0m 47s
jam: Ran 1(1/0/0) tests, Grand total test time = 1m 2s
quail: Ran 1(1/0/0) tests, Grand total test time = 0m 56s
ostrich: Ran 2(2/0/0) tests, Grand total test time = 4m 41s
jam: Ran 7(0/0/0) hosts, Grand total test time = 5m 45s
Timekeeper log
Timekeeper started at Sun Jul 19 21:00:51 CDT 2015
Timekeeper sleeping for 720 seconds
Tests Failures
Dumping logfile of emu: setenvN 2 CC cc -m64 op-configure --prefix=/mnt/scr1/pre-release/opa/emu64 deploy emu64
Last 50 lines of /mnt/scr1/SnapTest/snapshots-opa/log/emu_0719Sun_2100
CC= cc -m64
CCACHE_DISABLE=yes
CVSROOT=/mnt/hdf/cvs
EC2_CERT=/home/hdftest/.ec2/cert-6HKISUOM3HT2PWDQB4PLG67KTWOVVKOK.pem
EC2_HOME=/mnt/hdf/ec2-api-tools
EC2_PRIVATE_KEY=/home/hdftest/.ec2/pk-6HKISUOM3HT2PWDQB4PLG67KTWOVVKOK.pem
GROUP=hdf
HDF5TestExpress=yes
HOME=/home/hdftest
HOST=emu
HOSTTYPE=sun4
JAVA_HOME=/usr/lib/jvm/jre-1.6.0
LANG=en_US.UTF-8
LC_ALL=
LC_COLLATE=
LC_CTYPE=
LC_MESSAGES=
LC_MONETARY=
LC_NUMERIC=
LC_TIME=
LOGNAME=hdftest
MACHTYPE=sparc
MAIL=/var/mail/hdftest
MAKE=gmake
NLSPATH=/usr/share/locale/%L/LC_MESSAGES/%N.cat
OSTYPE=solaris
PATH=/home/hdftest/bin:/usr/hdf/bin:/home/hdftest/bin:/usr/hdf/bin:/usr/bin:/usr/sbin:/opt/solarisstudio/bin:/opt/cmake/bin:/opt/svn/bin:/mnt/hdf/ec2-api-tools/bin
PWD=/mnt/scr1/SnapTest/snapshots-opa
REMOTEHOST=
SET_PATH=yes
SHELL=/bin/tcsh
SHLVL=3
SSH_CLIENT=10.10.10.86 33941 22
SSH_CONNECTION=10.10.10.86 33941 10.10.10.84 22
SVNROOT=http://svn.hdfgroup.uiuc.edu
TZ=localtime
USER=hdftest
VENDOR=sun
===Done Dumping environment variables after option parsing ===
===== Run Tests: Sunday, July 19, 2015 09:00:16 PM CDT =====
Remove contents of emu.
diff: /home/hdftest/snapshots-opa/previous/MANIFEST: No such file or directory
===== configure: Sunday, July 19, 2015 09:00:16 PM CDT =====
checking for a BSD-compatible install... /usr/bin/ginstall -c
checking whether build environment is sane... configure: error: newly created file is older than distributed files!
Check your system clock
Failed running configure
===== Exit bin/snapshot with status=1: Sunday, July 19, 2015 09:00:17 PM CDT =====
Dumping done
Runtest did not exit normally.
Watchers List
OPA Daily test features/platforms watchers and procedure
Procedure:
The watcher will investigate and report the cause of failure by 11am.
The developer who checked in the error code may report so by then too.
The watcher or the developer should get the failure fixed and report it
by 3pm.
Watcher for OPA: Neil
updated: 2009/05/05
Tests Details
21:00:30 up 22 days, 1:18, 6 users, load average: 0.37, 0.13, 0.20
Filesystem 1K-blocks Used Available Use% Mounted on
/dev/sda3 31738420 8488484 21611708 29% /
/dev/sda1 101086 17532 78335 19% /boot
/dev/sda2 31738420 246824 29853368 1% /tmp
/dev/sda6 31738392 5411372 24688796 18% /var
/dev/sda7 31738392 18478512 11621656 62% /usr
/dev/sda8 124991068 377320 118162048 1% /var/tmp
/dev/mapper/VolGroup00-home
198351840 51760588 136352892 28% /home
/dev/sde1 565688764 412395796 124094032 77% /scr
/dev/sdc1 961432072 876099584 36494488 97% /mnt/scr1
/dev/sdd1 961432072 859468504 53125568 95% /mnt/hdf
tmpfs 8313628 0 8313628 0% /dev/shm
gumund:/data/ftp 480719104 355349888 100950016 78% /mnt/ftp
gumund:/data/web 480719104 355349888 100950016 78% /mnt/web
STANDARD_OPT=setenv MAKE gmake deploydir /mnt/scr1/pre-release/opa
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam
Running source repository checkout with output saved in
/mnt/scr1/SnapTest/snapshots-opa/log/REPO_LOG_0719Sun
Checking MANIFEST file ...
cat: /mnt/scr1/SnapTest/snapshots-opa/log/#runtest.0719Sun.18235: No such file or directory
rm: cannot remove `/mnt/scr1/SnapTest/snapshots-opa/log/#runtest.0719Sun.18235': No such file or directory
*** launching tests from jam ***
TESTHOST is emu
jam
koala
platypus
ostrich
quail
kite
Fork off timekeeper 12
Testing emu
ssh -o ConnectTimeout=60 emu -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname emu
9:00pm up 21 day(s), 6:04, 1 user, load average: 0.00, 0.01, 0.59
/ (rpool/ROOT/solaris):467251309 blocks 467251309 files
/devices (/devices ): 0 blocks 0 files
/dev (/dev ): 0 blocks 0 files
/system/contract (ctfs ): 0 blocks 2147483591 files
/proc (proc ): 0 blocks 29932 files
/etc/mnttab (mnttab ): 0 blocks 0 files
/system/volatile (swap ):20468800 blocks 2229229 files
/system/object (objfs ): 0 blocks 2147483467 files
/etc/dfs/sharetab (sharefs ): 0 blocks 2147483646 files
/dev/fd (fd ): 0 blocks 0 files
/var (rpool/ROOT/solaris/var):467251309 blocks 467251309 files
/tmp (swap ):20468800 blocks 2229229 files
/var/share (rpool/VARSHARE ):467251309 blocks 467251309 files
/rpool (rpool ):467251309 blocks 467251309 files
/export (rpool/export ):467251309 blocks 467251309 files
/export/home (rpool/export/home ):467251309 blocks 467251309 files
/export/home/kurz (rpool/export/home/kurz):467251309 blocks 467251309 files
/home (jam.ad.hdfgroup.org:/home):293182504 blocks 50541124 files
/mnt/hdf (jam.ad.hdfgroup.org:/mnt/hdf):203927136 blocks 112137522 files
/mnt/scr1 (jam.ad.hdfgroup.org:/mnt/scr1):170664920 blocks 117936934 files
TEST_TYPES=setenvN 2 CC cc -m64 op-configure --prefix=/mnt/scr1/pre-release/opa/emu64 deploy emu64
*** starting setenvN 2 CC cc -m64 op-configure --prefix=/mnt/scr1/pre-release/opa/emu64 deploy emu64 tests in emu ***
Uname -a: SunOS emu 5.11 11.1 sun4v sparc sun4v
Running snapshot with output saved in
*** finished setenvN 2 CC cc -m64 op-configure --prefix=/mnt/scr1/pre-release/opa/emu64 deploy emu64 tests for emu ***
Total time = 0m 1s
*** finished tests in emu ***
****SYSTEM ERROR emu: Abnormal exit from runtest ****
****SYSTEM ERROR emu: runtest command failed ****
Testing jam
ssh -o ConnectTimeout=60 jam -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname jam
21:00:58 up 22 days, 1:18, 6 users, load average: 0.82, 0.26, 0.24
/dev/sda2 31738420 246932 29853260 1% /tmp
/dev/sda6 31738392 5411296 24688872 18% /var
/dev/sdc1 961432072 876099620 36494452 97% /mnt/scr1
Sun Jul 19 21:01:08 CDT 2015
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam tests in jam ***
Uname -a: Linux jam 2.6.18-308.13.1.el5PAE #1 SMP Tue Aug 21 17:50:26 EDT 2012 i686 i686 i386 GNU/Linux
/mnt/scr1/SnapTest/snapshots-opa/log/jam_0719Sun_2101
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam tests for jam ***
Sun Jul 19 21:02:10 CDT 2015
Total time = 1m 2s
*** finished tests in jam ***
Testing koala
ssh -o ConnectTimeout=60 koala -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname koala
21:01:00 up 20 days, 12:11, 1 user, load average: 0.67, 0.90, 0.62
/dev/sda7 22292052 4049644 17091756 20% /
/dev/sda5 12192608 385688 11177576 4% /tmp
/dev/sda3 12192636 1190996 10372296 11% /var
/dev/sda1 101086 18614 77253 20% /boot
/dev/sdc1 41279536 26230136 12952520 67% /usr
/dev/sdb 152754284 73211828 71782996 51% /scr
tmpfs 6149552 0 6149552 0% /dev/shm
10.10.10.86:/mnt/hdf 961432576 859468800 53126144 95% /mnt/hdf
10.10.10.86:/mnt/scr1
961432576 876099584 36495360 97% /mnt/scr1
10.10.10.86:/home 198351872 51760128 136353792 28% /home
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala
Sun Jul 19 21:01:10 CDT 2015
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala tests in koala ***
Uname -a: Linux koala 2.6.18-402.el5 #1 SMP Tue Feb 10 17:49:04 EST 2015 x86_64 x86_64 x86_64 GNU/Linux
/mnt/scr1/SnapTest/snapshots-opa/log/koala_0719Sun_2101
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala tests for koala ***
Sun Jul 19 21:01:43 CDT 2015
Total time = 0m 33s
*** finished tests in koala ***
Testing platypus
ssh -o ConnectTimeout=60 platypus -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname platypus
21:01:20 up 3 days, 12:43, 0 users, load average: 0.37, 1.49, 1.90
/dev/sda6 54205540 19693768 31751632 39% /
tmpfs 6099128 0 6099128 0% /dev/shm
/dev/sda1 194241 48100 135901 27% /boot
/dev/sda2 12850716 289484 11901776 3% /tmp
/dev/sda3 12850716 3040916 9150344 25% /var
/dev/sdd 152623212 83295356 61568396 58% /scr
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus
Sun Jul 19 21:01:30 CDT 2015
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus tests in platypus ***
Uname -a: Linux platypus 2.6.32-504.16.2.el6.x86_64 #1 SMP Wed Apr 22 06:48:29 UTC 2015 x86_64 x86_64 x86_64 GNU/Linux
/mnt/scr1/SnapTest/snapshots-opa/log/platypus_0719Sun_2101
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus tests for platypus ***
Sun Jul 19 21:02:14 CDT 2015
Total time = 0m 44s
*** finished tests in platypus ***
Sun Jul 19 21:02:15 CDT 2015
Testing ostrich
ssh -o ConnectTimeout=60 ostrich -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname ostrich
21:01:14 up 11 days, 7:48, 0 users, load average: 0.00, 0.00, 0.17
/dev/mapper/vg_ostrich-lv_root
140479384 16015128 117325212 13% /
tmpfs 7821632 0 7821632 0% /dev/shm
/dev/sda2 487652 92973 369079 21% /boot
/dev/sdb2 124477364 83684480 34463132 71% /scr
jam:/home 198351872 51760128 136353792 28% /home
jam:/mnt/hdf 961432576 859468800 53126144 95% /mnt/hdf
jam:/mnt/scr1 961432576 876099584 36495360 97% /mnt/scr1
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich ; standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl
Sun Jul 19 21:01:25 CDT 2015
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich tests in ostrich ***
Uname -a: Linux ostrich 2.6.32-504.8.1.el6.ppc64 #1 SMP Fri Dec 19 12:10:45 EST 2014 ppc64 ppc64 ppc64 GNU/Linux
/mnt/scr1/SnapTest/snapshots-opa/log/ostrich_0719Sun_2101
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich tests for ostrich ***
Sun Jul 19 21:02:57 CDT 2015
Total time = 1m 32s
*** starting standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl tests in ostrich ***
/mnt/scr1/SnapTest/snapshots-opa/log/ostrich_0719Sun_2102
*** finished standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl tests for ostrich ***
Sun Jul 19 21:06:05 CDT 2015
Total time = 3m 8s
*** finished tests in ostrich ***
Testing quail
ssh -o ConnectTimeout=60 quail -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname quail
21:01 up 20 days, 23:03, 0 users, load averages: 1.04 1.44 1.83
Filesystem 512-blocks Used Available Capacity iused ifree %iused Mounted on
/dev/disk0s2 488555536 157132008 330911528 33% 19705499 41363941 32% /
devfs 361 361 0 100% 626 0 100% /dev
map auto_nfs 0 0 0 100% 0 0 100% /mnt/hdf
map auto_nfs 0 0 0 100% 0 0 100% /mnt/scr1
map auto_nfs 0 0 0 100% 0 0 100% /home
jam.ad.hdfgroup.org:/mnt/scr1 1922864144 1752199312 72988832 97% 4173029 117936923 3% /mnt/scr1
jam.ad.hdfgroup.org:/mnt/hdf 1922864144 1718937008 106251136 95% 9972430 112137522 8% /mnt/hdf
jam.ad.hdfgroup.org:/home 396703680 103521176 272705784 28% 675260 50541124 1% /home
TEST_TYPES=standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/quail deploy quail
Sun Jul 19 21:01:33 CDT 2015
*** starting standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/quail deploy quail tests in quail ***
Uname -a: Darwin quail.ad.hdfgroup.org 13.4.0 Darwin Kernel Version 13.4.0: Wed Mar 18 16:20:14 PDT 2015; root:xnu-2422.115.14~1/RELEASE_X86_64 x86_64
/Users/hdftest/snapshots-opa/log/quail_0719Sun_2101
*** finished standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/quail deploy quail tests for quail ***
Sun Jul 19 21:02:29 CDT 2015
Total time = 0m 56s
*** finished tests in quail ***
Testing kite
ssh -o ConnectTimeout=60 kite -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname kite
21:01 up 17 days, 6:46, 0 users, load averages: 0.16 0.08 0.21
/dev/disk0s2 1951845952 215007248 1736326704 12% 26939904 217040838 11% /
devfs 372 372 0 100% 645 0 100% /dev
/dev/disk1s2 1952853344 1296608 1951556736 1% 162074 243944592 0% /Volumes/Milvinae
10.10.10.86:/mnt/hdf 1922864144 1718937008 106251136 95% 9972430 112137522 8% /mnt/hdf
10.10.10.86:/mnt/scr1 1922864144 1752199360 72988784 97% 4173034 117936918 3% /mnt/scr1
10.10.10.86:/home 396703680 103521176 272705784 28% 675260 50541124 1% /mnt/home
TEST_TYPES=standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/kite deploy kite
Sun Jul 19 21:01:21 CDT 2015
*** starting standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/kite deploy kite tests in kite ***
Uname -a: Darwin kite.ad.hdfgroup.org 12.6.0 Darwin Kernel Version 12.6.0: Wed Mar 18 16:23:48 PDT 2015; root:xnu-2050.48.19~1/RELEASE_X86_64 x86_64
/Users/hdftest/snapshots-opa/log/kite_0719Sun_2101
*** finished standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/kite deploy kite tests for kite ***
Sun Jul 19 21:02:08 CDT 2015
Total time = 0m 47s
*** finished tests in kite ***
More information about the opa-nightly-tests
