[opa-nightly-tests] jam OPA_Daily_Tests_0829Sat_FAILED!!!
HDF Tester
hdftest at hdfgroup.org
Sat Aug 29 19:26:03 CDT 2015
*** OPA Tests on 0829Sat ***
Tests Summary
****FAILED emu: standard op-configure --prefix=/mnt/scr1/pre-release/opa/emu32 deploy emu32****
PASSED jam: standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam
PASSED kite: standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/kite deploy kite
PASSED koala: standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala
PASSED ostrich: standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich
PASSED ostrich: standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl
PASSED platypus: standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus
PASSED quail: standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/quail deploy quail
Tests Time Summary
emu: Ran 1(0/1/0) tests, Grand total test time = 0m 3s
koala: Ran 1(1/0/0) tests, Grand total test time = 0m 33s
platypus: Ran 1(1/0/0) tests, Grand total test time = 0m 41s
kite: Ran 1(1/0/0) tests, Grand total test time = 0m 47s
quail: Ran 1(1/0/0) tests, Grand total test time = 0m 52s
jam: Ran 1(1/0/0) tests, Grand total test time = 1m 3s
ostrich: Ran 2(2/0/0) tests, Grand total test time = 4m 48s
jam: Ran 7(0/0/0) hosts, Grand total test time = 5m 53s
Timekeeper log
Timekeeper started at Sat Aug 29 19:20:20 CDT 2015
Timekeeper sleeping for 720 seconds
Tests Failures
Dumping logfile of emu: standard op-configure --prefix=/mnt/scr1/pre-release/opa/emu32 deploy emu32
Last 50 lines of /mnt/scr1/SnapTest/snapshots-opa/log/emu_0829Sat_1920
GROUP=hdf
HDF5_ACLOCAL=/mnt/hdf/packages/AUTOTOOLS/automake/1.15/sun4v/bin/aclocal-1.15
HDF5_AUTOCONF=/mnt/hdf/packages/AUTOTOOLS/autoconf/2.69/sun4v/bin/autoconf
HDF5_AUTOHEADER=/mnt/hdf/packages/AUTOTOOLS/autoconf/2.69/sun4v/bin/autoheader
HDF5_AUTOMAKE=/mnt/hdf/packages/AUTOTOOLS/automake/1.15/sun4v/bin/automake-1.15
HDF5_LIBTOOL=/mnt/hdf/packages/AUTOTOOLS/libtool/2.4.6/sun4v/bin/libtool
HDF5_M4=/mnt/hdf/packages/AUTOTOOLS/m4/1.4.17/sun4v/bin/m4
HDF5TestExpress=yes
HOME=/home/hdftest
HOST=emu
HOSTTYPE=sun4
JAVA_HOME=/usr/lib/jvm/jre-1.6.0
LANG=en_US.UTF-8
LC_ALL=
LC_COLLATE=
LC_CTYPE=
LC_MESSAGES=
LC_MONETARY=
LC_NUMERIC=
LC_TIME=
LOGNAME=hdftest
MACHTYPE=sparc
MAIL=/var/mail/hdftest
MAKE=gmake
NLSPATH=/usr/share/locale/%L/LC_MESSAGES/%N.cat
OSTYPE=solaris
PATH=/home/hdftest/bin:/usr/hdf/bin:/home/hdftest/bin:/usr/hdf/bin:/usr/bin:/usr/sbin:/opt/solarisstudio/bin:/opt/cmake/bin:/opt/svn/bin:/mnt/hdf/ec2-api-tools/bin
PWD=/mnt/scr1/SnapTest/snapshots-opa
REMOTEHOST=
SET_PATH=yes
SHELL=/bin/tcsh
SHLVL=3
SSH_CLIENT=10.10.10.86 50720 22
SSH_CONNECTION=10.10.10.86 50720 10.10.10.84 22
SVNROOT=http://svn.hdfgroup.uiuc.edu
TZ=localtime
USER=hdftest
VENDOR=sun
===Done Dumping environment variables after option parsing ===
===== Run Tests: Saturday, August 29, 2015 07:20:14 PM CDT =====
Remove contents of emu.
diff: /home/hdftest/snapshots-opa/previous/MANIFEST: No such file or directory
===== configure: Saturday, August 29, 2015 07:20:14 PM CDT =====
checking for a BSD-compatible install... /usr/bin/ginstall -c
checking whether build environment is sane... configure: error: newly created file is older than distributed files!
Check your system clock
Failed running configure
===== Exit bin/snapshot with status=1: Saturday, August 29, 2015 07:20:15 PM CDT =====
Dumping done
Runtest did not exit normally.
Watchers List
OPA Daily test features/platforms watchers and procedure
Procedure:
The watcher will investigate and report the cause of failure by 11am.
The developer who checked in the error code may report so by then too.
The watcher or the developer should get the failure fixed and report it
by 3pm.
Watcher for OPA: Neil
updated: 2009/05/05
Tests Details
19:19:59 up 10 days, 6:16, 22 users, load average: 1.46, 1.32, 0.88
Filesystem 1K-blocks Used Available Use% Mounted on
/dev/sda3 31738420 9164796 20935396 31% /
/dev/sda1 101086 17532 78335 19% /boot
/dev/sda2 31738420 274176 29826016 1% /tmp
/dev/sda6 31738392 5560512 24539656 19% /var
/dev/sda7 31738392 18481028 11619140 62% /usr
/dev/sda8 124991068 377284 118162084 1% /var/tmp
/dev/mapper/VolGroup00-home
198351840 96302164 91811316 52% /home
/dev/sde1 565688764 426265184 110224644 80% /scr
/dev/sdc1 961432072 766160480 146433592 84% /mnt/scr1
/dev/sdd1 961432072 855990996 56603076 94% /mnt/hdf
tmpfs 8313628 0 8313628 0% /dev/shm
10.10.10.15:/volume1/hdf2
1437485440 238047232 1199335808 17% /mnt/hdf2
10.10.10.15:/volume1/hdf3
1437485440 238047232 1199335808 17% /mnt/hdf3
gumund:/data/ftp 480719104 380699520 75600384 84% /mnt/ftp
gumund:/data/web 480719104 380699520 75600384 84% /mnt/web
STANDARD_OPT=setenv MAKE gmake deploydir /mnt/scr1/pre-release/opa
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam
Running source repository checkout with output saved in
/mnt/scr1/SnapTest/snapshots-opa/log/REPO_LOG_0829Sat
Checking MANIFEST file ...
cat: /mnt/scr1/SnapTest/snapshots-opa/log/#runtest.0829Sat.24939: No such file or directory
rm: cannot remove `/mnt/scr1/SnapTest/snapshots-opa/log/#runtest.0829Sat.24939': No such file or directory
*** launching tests from jam ***
TESTHOST is emu
jam
koala
platypus
ostrich
quail
kite
Fork off timekeeper 12
Testing emu
ssh -o ConnectTimeout=60 emu -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname emu
7:20pm up 62 day(s), 4:24, 2 users, load average: 0.01, 0.12, 0.94
/ (rpool/ROOT/solaris):431036721 blocks 431036721 files
/devices (/devices ): 0 blocks 0 files
/dev (/dev ): 0 blocks 0 files
/system/contract (ctfs ): 0 blocks 2147483588 files
/proc (proc ): 0 blocks 29924 files
/etc/mnttab (mnttab ): 0 blocks 0 files
/system/volatile (swap ):22764832 blocks 2201831 files
/system/object (objfs ): 0 blocks 2147483465 files
/etc/dfs/sharetab (sharefs ): 0 blocks 2147483646 files
/dev/fd (fd ): 0 blocks 0 files
/var (rpool/ROOT/solaris/var):431036721 blocks 431036721 files
/tmp (swap ):22764832 blocks 2201831 files
/var/share (rpool/VARSHARE ):431036721 blocks 431036721 files
/rpool (rpool ):431036721 blocks 431036721 files
/export (rpool/export ):431036721 blocks 431036721 files
/export/home (rpool/export/home ):431036721 blocks 431036721 files
/export/home/kurz (rpool/export/home/kurz):431036721 blocks 431036721 files
/home (jam.ad.hdfgroup.org:/home):204099360 blocks 50170586 files
/mnt/hdf (jam.ad.hdfgroup.org:/mnt/hdf):210883392 blocks 112039540 files
/mnt/scr1 (jam.ad.hdfgroup.org:/mnt/scr1):390543128 blocks 118065178 files
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/emu32 deploy emu32
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/emu32 deploy emu32 tests in emu ***
Uname -a: SunOS emu 5.11 11.1 sun4v sparc sun4v
Running snapshot with output saved in
Saturday, August 29, 2015 07:20:16 PM CDT
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/emu32 deploy emu32 tests for emu ***
Total time = 0m 2s
*** finished tests in emu ***
****SYSTEM ERROR emu: Abnormal exit from runtest ****
Sat Aug 29 19:26:02 CDT 2015
****SYSTEM ERROR emu: runtest command failed ****
Testing jam
ssh -o ConnectTimeout=60 jam -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname jam
19:20:27 up 10 days, 6:17, 22 users, load average: 1.41, 1.32, 0.90
/dev/sda2 31738420 274440 29825752 1% /tmp
/dev/sda6 31738392 5560588 24539580 19% /var
198351840 96302160 91811320 52% /home
/dev/sde1 565688764 426293728 110196100 80% /scr
/dev/sdc1 961432072 766160516 146433556 84% /mnt/scr1
/dev/sdd1 961432072 855990376 56603696 94% /mnt/hdf
Sat Aug 29 19:20:37 CDT 2015
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam tests in jam ***
Uname -a: Linux jam 2.6.18-308.13.1.el5PAE #1 SMP Tue Aug 21 17:50:26 EDT 2012 i686 i686 i386 GNU/Linux
/mnt/scr1/SnapTest/snapshots-opa/log/jam_0829Sat_1920
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam tests for jam ***
Sat Aug 29 19:21:40 CDT 2015
Total time = 1m 3s
*** finished tests in jam ***
Testing koala
ssh -o ConnectTimeout=60 koala -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname koala
19:20:29 up 3 days, 6:31, 1 user, load average: 0.00, 0.21, 0.34
/dev/sda7 22292052 4443584 16697816 22% /
/dev/sda5 12192608 381364 11181900 4% /tmp
/dev/sda3 12192636 1152704 10410588 10% /var
/dev/sda1 101086 18614 77253 20% /boot
/dev/sdc1 41279536 26268420 12914236 68% /usr
/dev/sdb 152754284 72695352 72299472 51% /scr
tmpfs 6149552 0 6149552 0% /dev/shm
10.10.10.86:/home 198351872 96302080 91811840 52% /home
10.10.10.86:/mnt/hdf 961432576 855990272 56604672 94% /mnt/hdf
10.10.10.86:/mnt/scr1
961432576 766160896 146434048 84% /mnt/scr1
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala
Sat Aug 29 19:20:39 CDT 2015
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala tests in koala ***
Uname -a: Linux koala 2.6.18-406.el5 #1 SMP Tue Jun 2 17:25:57 EDT 2015 x86_64 x86_64 x86_64 GNU/Linux
/mnt/scr1/SnapTest/snapshots-opa/log/koala_0829Sat_1920
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala tests for koala ***
Sat Aug 29 19:21:12 CDT 2015
Total time = 0m 33s
*** finished tests in koala ***
Testing platypus
ssh -o ConnectTimeout=60 platypus -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname platypus
19:20:46 up 1 day, 8:45, 2 users, load average: 0.09, 0.57, 0.60
/dev/sda6 54205540 21019912 30425488 41% /
tmpfs 6099072 0 6099072 0% /dev/shm
/dev/sda1 194241 48551 135450 27% /boot
/dev/sda2 12850716 115516 12075744 1% /tmp
/dev/sda3 12850716 3813540 8377720 32% /var
/dev/sdd 152623212 97831072 47032680 68% /scr
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus
Sat Aug 29 19:20:56 CDT 2015
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus tests in platypus ***
Uname -a: Linux platypus 2.6.32-573.3.1.el6.x86_64 #1 SMP Thu Aug 13 22:55:16 UTC 2015 x86_64 x86_64 x86_64 GNU/Linux
/mnt/scr1/SnapTest/snapshots-opa/log/platypus_0829Sat_1920
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus tests for platypus ***
Sat Aug 29 19:21:37 CDT 2015
Total time = 0m 41s
*** finished tests in platypus ***
Testing ostrich
ssh -o ConnectTimeout=60 ostrich -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname ostrich
19:20:58 up 52 days, 6:08, 1 user, load average: 2.78, 5.99, 4.22
/dev/mapper/vg_ostrich-lv_root
140479384 18213304 115127036 14% /
tmpfs 7821632 0 7821632 0% /dev/shm
/dev/sda2 487652 92973 369079 21% /boot
/dev/sdb2 124477364 82885812 35261800 71% /scr
jam:/home 198351872 96302080 91811840 52% /home
jam:/mnt/hdf 961432576 855990272 56604672 94% /mnt/hdf
jam:/mnt/scr1 961432576 766160896 146434048 84% /mnt/scr1
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich ; standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl
Sat Aug 29 19:21:08 CDT 2015
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich tests in ostrich ***
Uname -a: Linux ostrich 2.6.32-504.8.1.el6.ppc64 #1 SMP Fri Dec 19 12:10:45 EST 2014 ppc64 ppc64 ppc64 GNU/Linux
/mnt/scr1/SnapTest/snapshots-opa/log/ostrich_0829Sat_1921
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich tests for ostrich ***
Sat Aug 29 19:22:47 CDT 2015
Total time = 1m 39s
*** starting standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl tests in ostrich ***
/mnt/scr1/SnapTest/snapshots-opa/log/ostrich_0829Sat_1922
*** finished standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl tests for ostrich ***
Sat Aug 29 19:25:56 CDT 2015
Total time = 3m 9s
*** finished tests in ostrich ***
Testing quail
ssh -o ConnectTimeout=60 quail -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname quail
19:20 up 1 day, 8:59, 2 users, load averages: 1.35 1.32 1.51
Filesystem 512-blocks Used Available Capacity iused ifree %iused Mounted on
/dev/disk0s2 488555536 169123240 318920296 35% 21204403 39865037 35% /
devfs 363 363 0 100% 628 0 100% /dev
map auto_nfs 0 0 0 100% 0 0 100% /home
map auto_nfs 0 0 0 100% 0 0 100% /mnt/hdf
map auto_nfs 0 0 0 100% 0 0 100% /mnt/scr1
jam.ad.hdfgroup.org:/home 396703680 192604320 183622640 52% 1045798 50170586 2% /home
jam.ad.hdfgroup.org:/mnt/scr1 1922864144 1532321104 292867040 84% 4044785 118065167 3% /mnt/scr1
jam.ad.hdfgroup.org:/mnt/hdf 1922864144 1711980752 113207392 94% 10070412 112039540 8% /mnt/hdf
TEST_TYPES=standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/quail deploy quail
Sat Aug 29 19:20:50 CDT 2015
*** starting standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/quail deploy quail tests in quail ***
Uname -a: Darwin quail.ad.hdfgroup.org 13.4.0 Darwin Kernel Version 13.4.0: Wed Mar 18 16:20:14 PDT 2015; root:xnu-2422.115.14~1/RELEASE_X86_64 x86_64
/Users/hdftest/snapshots-opa/log/quail_0829Sat_1920
*** finished standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/quail deploy quail tests for quail ***
Sat Aug 29 19:21:42 CDT 2015
Total time = 0m 52s
*** finished tests in quail ***
Testing kite
ssh -o ConnectTimeout=60 kite -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname kite
19:20 up 1 day, 8:57, 1 user, load averages: 0.03 0.27 0.30
/dev/disk0s2 1951845952 223456496 1727877456 12% 27996060 215984682 11% /
devfs 372 372 0 100% 644 0 100% /dev
/dev/disk1s2 1952853344 1296656 1951556688 1% 162080 243944586 0% /Volumes/Milvinae
10.10.10.86:/mnt/hdf 1922864144 1711980752 113207392 94% 10070412 112039540 8% /mnt/hdf
10.10.10.86:/mnt/scr1 1922864144 1532321160 292866984 84% 4044790 118065162 3% /mnt/scr1
10.10.10.86:/home 396703680 192604320 183622640 52% 1045798 50170586 2% /mnt/home
TEST_TYPES=standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/kite deploy kite
Sat Aug 29 19:20:52 CDT 2015
*** starting standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/kite deploy kite tests in kite ***
Uname -a: Darwin kite.ad.hdfgroup.org 12.6.0 Darwin Kernel Version 12.6.0: Wed Mar 18 16:23:48 PDT 2015; root:xnu-2050.48.19~1/RELEASE_X86_64 x86_64
/Users/hdftest/snapshots-opa/log/kite_0829Sat_1920
*** finished standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/kite deploy kite tests for kite ***
Sat Aug 29 19:21:39 CDT 2015
Total time = 0m 47s
*** finished tests in kite ***
More information about the opa-nightly-tests
