[opa-nightly-tests] jam OPA_Daily_Tests_0830Sun_FAILED!!!
HDF Tester
hdftest at hdfgroup.org
Sun Aug 30 20:50:10 CDT 2015
*** OPA Tests on 0830Sun ***
Tests Summary
****FAILED emu: setenvN 2 CC cc -m64 op-configure --prefix=/mnt/scr1/pre-release/opa/emu64 deploy emu64****
PASSED jam: standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam
PASSED kite: standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/kite deploy kite
PASSED koala: standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala
PASSED ostrich: standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich
PASSED ostrich: standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl
PASSED platypus: standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus
PASSED quail: standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/quail deploy quail
Tests Time Summary
emu: Ran 1(0/1/0) tests, Grand total test time = 0m 3s
koala: Ran 1(1/0/0) tests, Grand total test time = 0m 34s
platypus: Ran 1(1/0/0) tests, Grand total test time = 0m 43s
jam: Ran 1(1/0/0) tests, Grand total test time = 1m 0s
kite: Ran 1(1/0/0) tests, Grand total test time = 0m 50s
quail: Ran 1(1/0/0) tests, Grand total test time = 0m 54s
ostrich: Ran 2(2/0/0) tests, Grand total test time = 4m 45s
jam: Ran 7(0/0/0) hosts, Grand total test time = 5m 52s
Timekeeper log
Timekeeper started at Sun Aug 30 20:44:29 CDT 2015
Timekeeper sleeping for 720 seconds
Tests Failures
Dumping logfile of emu: setenvN 2 CC cc -m64 op-configure --prefix=/mnt/scr1/pre-release/opa/emu64 deploy emu64
Last 50 lines of /mnt/scr1/SnapTest/snapshots-opa/log/emu_0830Sun_2044
GROUP=hdf
HDF5_ACLOCAL=/mnt/hdf/packages/AUTOTOOLS/automake/1.15/sun4v/bin/aclocal-1.15
HDF5_AUTOCONF=/mnt/hdf/packages/AUTOTOOLS/autoconf/2.69/sun4v/bin/autoconf
HDF5_AUTOHEADER=/mnt/hdf/packages/AUTOTOOLS/autoconf/2.69/sun4v/bin/autoheader
HDF5_AUTOMAKE=/mnt/hdf/packages/AUTOTOOLS/automake/1.15/sun4v/bin/automake-1.15
HDF5_LIBTOOL=/mnt/hdf/packages/AUTOTOOLS/libtool/2.4.6/sun4v/bin/libtool
HDF5_M4=/mnt/hdf/packages/AUTOTOOLS/m4/1.4.17/sun4v/bin/m4
HDF5TestExpress=yes
HOME=/home/hdftest
HOST=emu
HOSTTYPE=sun4
JAVA_HOME=/usr/lib/jvm/jre-1.6.0
LANG=en_US.UTF-8
LC_ALL=
LC_COLLATE=
LC_CTYPE=
LC_MESSAGES=
LC_MONETARY=
LC_NUMERIC=
LC_TIME=
LOGNAME=hdftest
MACHTYPE=sparc
MAIL=/var/mail/hdftest
MAKE=gmake
NLSPATH=/usr/share/locale/%L/LC_MESSAGES/%N.cat
OSTYPE=solaris
PATH=/home/hdftest/bin:/usr/hdf/bin:/home/hdftest/bin:/usr/hdf/bin:/usr/bin:/usr/sbin:/opt/solarisstudio/bin:/opt/cmake/bin:/opt/svn/bin:/mnt/hdf/ec2-api-tools/bin
PWD=/mnt/scr1/SnapTest/snapshots-opa
REMOTEHOST=
SET_PATH=yes
SHELL=/bin/tcsh
SHLVL=3
SSH_CLIENT=10.10.10.86 57272 22
SSH_CONNECTION=10.10.10.86 57272 10.10.10.84 22
SVNROOT=http://svn.hdfgroup.uiuc.edu
TZ=localtime
USER=hdftest
VENDOR=sun
===Done Dumping environment variables after option parsing ===
===== Run Tests: Sunday, August 30, 2015 08:44:22 PM CDT =====
Remove contents of emu.
diff: /home/hdftest/snapshots-opa/previous/MANIFEST: No such file or directory
===== configure: Sunday, August 30, 2015 08:44:22 PM CDT =====
checking for a BSD-compatible install... /usr/bin/ginstall -c
checking whether build environment is sane... configure: error: newly created file is older than distributed files!
Check your system clock
Failed running configure
===== Exit bin/snapshot with status=1: Sunday, August 30, 2015 08:44:24 PM CDT =====
Dumping done
Runtest did not exit normally.
Watchers List
OPA Daily test features/platforms watchers and procedure
Procedure:
The watcher will investigate and report the cause of failure by 11am.
The developer who checked in the error code may report so by then too.
The watcher or the developer should get the failure fixed and report it
by 3pm.
Watcher for OPA: Neil
updated: 2009/05/05
Tests Details
20:44:08 up 11 days, 7:40, 17 users, load average: 5.16, 5.37, 4.11
Filesystem 1K-blocks Used Available Use% Mounted on
/dev/sda3 31738420 9160312 20939880 31% /
/dev/sda1 101086 17532 78335 19% /boot
/dev/sda2 31738420 318496 29781696 2% /tmp
/dev/sda6 31738392 5582776 24517392 19% /var
/dev/sda7 31738392 18481028 11619140 62% /usr
/dev/sda8 124991068 377284 118162084 1% /var/tmp
/dev/mapper/VolGroup00-home
198351840 96302864 91810616 52% /home
/dev/sde1 565688764 426278976 110210852 80% /scr
/dev/sdc1 961432072 772958856 139635216 85% /mnt/scr1
/dev/sdd1 961432072 856063648 56530424 94% /mnt/hdf
tmpfs 8313628 0 8313628 0% /dev/shm
10.10.10.15:/volume1/hdf2
1437485440 238047232 1199335808 17% /mnt/hdf2
10.10.10.15:/volume1/hdf3
1437485440 238047232 1199335808 17% /mnt/hdf3
gumund:/data/ftp 480719104 383402496 72897408 85% /mnt/ftp
gumund:/data/web 480719104 383402496 72897408 85% /mnt/web
STANDARD_OPT=setenv MAKE gmake deploydir /mnt/scr1/pre-release/opa
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam
Running source repository checkout with output saved in
/mnt/scr1/SnapTest/snapshots-opa/log/REPO_LOG_0830Sun
Checking MANIFEST file ...
cat: /mnt/scr1/SnapTest/snapshots-opa/log/#runtest.0830Sun.6589: No such file or directory
rm: cannot remove `/mnt/scr1/SnapTest/snapshots-opa/log/#runtest.0830Sun.6589': No such file or directory
*** launching tests from jam ***
TESTHOST is emu
jam
koala
platypus
ostrich
quail
kite
Fork off timekeeper 12
Testing emu
ssh -o ConnectTimeout=60 emu -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname emu
8:44pm up 63 day(s), 5:48, 2 users, load average: 1.00, 1.03, 1.14
/ (rpool/ROOT/solaris):428205730 blocks 428205730 files
/devices (/devices ): 0 blocks 0 files
/dev (/dev ): 0 blocks 0 files
/system/contract (ctfs ): 0 blocks 2147483588 files
/proc (proc ): 0 blocks 29914 files
/etc/mnttab (mnttab ): 0 blocks 0 files
/system/volatile (swap ):23537328 blocks 2201471 files
/system/object (objfs ): 0 blocks 2147483465 files
/etc/dfs/sharetab (sharefs ): 0 blocks 2147483646 files
/dev/fd (fd ): 0 blocks 0 files
/var (rpool/ROOT/solaris/var):428205730 blocks 428205730 files
/tmp (swap ):23537328 blocks 2201471 files
/var/share (rpool/VARSHARE ):428205730 blocks 428205730 files
/rpool (rpool ):428205730 blocks 428205730 files
/export (rpool/export ):428205730 blocks 428205730 files
/export/home (rpool/export/home ):428205730 blocks 428205730 files
/export/home/kurz (rpool/export/home/kurz):428205730 blocks 428205730 files
/home (jam.ad.hdfgroup.org:/home):204097952 blocks 50170586 files
/mnt/hdf (jam.ad.hdfgroup.org:/mnt/hdf):210736848 blocks 112039286 files
/mnt/scr1 (jam.ad.hdfgroup.org:/mnt/scr1):376905440 blocks 118033500 files
TEST_TYPES=setenvN 2 CC cc -m64 op-configure --prefix=/mnt/scr1/pre-release/opa/emu64 deploy emu64
*** starting setenvN 2 CC cc -m64 op-configure --prefix=/mnt/scr1/pre-release/opa/emu64 deploy emu64 tests in emu ***
Uname -a: SunOS emu 5.11 11.1 sun4v sparc sun4v
Running snapshot with output saved in
*** finished setenvN 2 CC cc -m64 op-configure --prefix=/mnt/scr1/pre-release/opa/emu64 deploy emu64 tests for emu ***
Total time = 0m 2s
*** finished tests in emu ***
****SYSTEM ERROR emu: Abnormal exit from runtest ****
****SYSTEM ERROR emu: runtest command failed ****
Testing jam
ssh -o ConnectTimeout=60 jam -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname jam
20:44:36 up 11 days, 7:41, 17 users, load average: 5.17, 5.35, 4.14
/dev/sda2 31738420 318640 29781552 2% /tmp
/dev/sdc1 961432072 772987156 139606916 85% /mnt/scr1
Sun Aug 30 20:44:46 CDT 2015
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam tests in jam ***
Uname -a: Linux jam 2.6.18-308.13.1.el5PAE #1 SMP Tue Aug 21 17:50:26 EDT 2012 i686 i686 i386 GNU/Linux
/mnt/scr1/SnapTest/snapshots-opa/log/jam_0830Sun_2044
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam tests for jam ***
Sun Aug 30 20:45:46 CDT 2015
Total time = 1m 0s
*** finished tests in jam ***
Testing koala
ssh -o ConnectTimeout=60 koala -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname koala
20:44:39 up 4 days, 7:55, 1 user, load average: 0.00, 0.00, 0.00
/dev/sda7 22292052 4443592 16697808 22% /
/dev/sda5 12192608 395428 11167836 4% /tmp
/dev/sda3 12192636 1069692 10493600 10% /var
/dev/sda1 101086 18614 77253 20% /boot
/dev/sdc1 41279536 26268420 12914236 68% /usr
/dev/sdb 152754284 72634956 72359868 51% /scr
tmpfs 6149552 0 6149552 0% /dev/shm
10.10.10.86:/home 198351872 96302080 91810816 52% /home
10.10.10.86:/mnt/hdf 961432576 856064000 56530944 94% /mnt/hdf
10.10.10.86:/mnt/scr1
961432576 772986880 139607040 85% /mnt/scr1
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala
Sun Aug 30 20:44:49 CDT 2015
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala tests in koala ***
Uname -a: Linux koala 2.6.18-406.el5 #1 SMP Tue Jun 2 17:25:57 EDT 2015 x86_64 x86_64 x86_64 GNU/Linux
/mnt/scr1/SnapTest/snapshots-opa/log/koala_0830Sun_2044
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala tests for koala ***
Sun Aug 30 20:45:23 CDT 2015
Total time = 0m 34s
*** finished tests in koala ***
Testing platypus
ssh -o ConnectTimeout=60 platypus -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname platypus
20:45:03 up 2 days, 10:10, 2 users, load average: 0.01, 0.37, 0.54
/dev/sda6 54205540 21019916 30425484 41% /
tmpfs 6099072 0 6099072 0% /dev/shm
/dev/sda1 194241 48551 135450 27% /boot
/dev/sda2 12850716 113988 12077272 1% /tmp
/dev/sda3 12850716 3924720 8266540 33% /var
/dev/sdd 152623212 98334592 46529160 68% /scr
961432576 772987904 139606016 85% /mnt/scr1
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus
Sun Aug 30 20:45:13 CDT 2015
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus tests in platypus ***
Uname -a: Linux platypus 2.6.32-573.3.1.el6.x86_64 #1 SMP Thu Aug 13 22:55:16 UTC 2015 x86_64 x86_64 x86_64 GNU/Linux
/mnt/scr1/SnapTest/snapshots-opa/log/platypus_0830Sun_2045
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus tests for platypus ***
Sun Aug 30 20:45:56 CDT 2015
Total time = 0m 43s
*** finished tests in platypus ***
Testing ostrich
ssh -o ConnectTimeout=60 ostrich -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname ostrich
20:45:10 up 53 days, 7:32, 1 user, load average: 2.75, 6.27, 4.69
/dev/mapper/vg_ostrich-lv_root
140479384 18155324 115185016 14% /
tmpfs 7821632 0 7821632 0% /dev/shm
/dev/sda2 487652 92973 369079 21% /boot
/dev/sdb2 124477364 83894824 34252788 72% /scr
jam:/home 198351872 96302080 91810816 52% /home
jam:/mnt/hdf 961432576 856064000 56530944 94% /mnt/hdf
jam:/mnt/scr1 961432576 772987904 139606016 85% /mnt/scr1
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich ; standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl
Sun Aug 30 20:45:20 CDT 2015
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich tests in ostrich ***
Uname -a: Linux ostrich 2.6.32-504.8.1.el6.ppc64 #1 SMP Fri Dec 19 12:10:45 EST 2014 ppc64 ppc64 ppc64 GNU/Linux
/mnt/scr1/SnapTest/snapshots-opa/log/ostrich_0830Sun_2045
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich tests for ostrich ***
Sun Aug 30 20:47:02 CDT 2015
Total time = 1m 42s
*** starting standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl tests in ostrich ***
/mnt/scr1/SnapTest/snapshots-opa/log/ostrich_0830Sun_2047
*** finished standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl tests for ostrich ***
Sun Aug 30 20:50:05 CDT 2015
Total time = 3m 3s
*** finished tests in ostrich ***
Testing quail
ssh -o ConnectTimeout=60 quail -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname quail
20:44 up 2 days, 10:23, 2 users, load averages: 1.58 1.65 1.60
Filesystem 512-blocks Used Available Capacity iused ifree %iused Mounted on
/dev/disk0s2 488555536 170673328 317370208 35% 21398164 39671276 35% /
devfs 363 363 0 100% 628 0 100% /dev
map auto_nfs 0 0 0 100% 0 0 100% /home
map auto_nfs 0 0 0 100% 0 0 100% /mnt/hdf
map auto_nfs 0 0 0 100% 0 0 100% /mnt/scr1
jam.ad.hdfgroup.org:/mnt/hdf 1922864144 1712127296 113060848 94% 10070666 112039286 8% /mnt/hdf
jam.ad.hdfgroup.org:/mnt/scr1 1922864144 1545977888 279210256 85% 4076466 118033486 3% /mnt/scr1
jam.ad.hdfgroup.org:/home 396703680 192605728 183621232 52% 1045798 50170586 2% /home
TEST_TYPES=standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/quail deploy quail
Sun Aug 30 20:45:02 CDT 2015
*** starting standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/quail deploy quail tests in quail ***
Uname -a: Darwin quail.ad.hdfgroup.org 13.4.0 Darwin Kernel Version 13.4.0: Wed Mar 18 16:20:14 PDT 2015; root:xnu-2422.115.14~1/RELEASE_X86_64 x86_64
/Users/hdftest/snapshots-opa/log/quail_0830Sun_2045
*** finished standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/quail deploy quail tests for quail ***
Total time = 0m 54s
*** finished tests in quail ***
Testing kite
ssh -o ConnectTimeout=60 kite -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname kite
20:44 up 2 days, 10:22, 1 user, load averages: 0.09 0.21 0.31
/dev/disk0s2 1951845952 225785768 1725548184 12% 28287219 215693523 12% /
devfs 372 372 0 100% 645 0 100% /dev
/dev/disk1s2 1952853344 1296656 1951556688 1% 162080 243944586 0% /Volumes/Milvinae
10.10.10.86:/mnt/hdf 1922864144 1712127296 113060848 94% 10070666 112039286 8% /mnt/hdf
10.10.10.86:/mnt/scr1 1922864144 1545990512 279197632 85% 4076468 118033484 3% /mnt/scr1
10.10.10.86:/home 396703680 192605728 183621232 52% 1045798 50170586 2% /mnt/home
TEST_TYPES=standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/kite deploy kite
Sun Aug 30 20:45:03 CDT 2015
*** starting standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/kite deploy kite tests in kite ***
Uname -a: Darwin kite.ad.hdfgroup.org 12.6.0 Darwin Kernel Version 12.6.0: Wed Mar 18 16:23:48 PDT 2015; root:xnu-2050.48.19~1/RELEASE_X86_64 x86_64
/Users/hdftest/snapshots-opa/log/kite_0830Sun_2045
*** finished standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/kite deploy kite tests for kite ***
Sun Aug 30 20:45:53 CDT 2015
Total time = 0m 50s
*** finished tests in kite ***
More information about the opa-nightly-tests
