[opa-nightly-tests] jam OPA_Daily_Tests_0828Fri_FAILED!!!
HDF Tester
hdftest at hdfgroup.org
Fri Aug 28 23:48:33 CDT 2015
*** OPA Tests on 0828Fri ***
Tests Summary
****FAILED emu: setenvN 2 CC cc -m64 op-configure --prefix=/mnt/scr1/pre-release/opa/emu64 deploy emu64****
PASSED jam: standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam
PASSED kite: standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/kite deploy kite
PASSED koala: standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala
PASSED ostrich: standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich
PASSED ostrich: standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl
PASSED platypus: standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus
PASSED quail: standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/quail deploy quail
Tests Time Summary
emu: Ran 1(0/1/0) tests, Grand total test time = 0m 2s
koala: Ran 1(1/0/0) tests, Grand total test time = 0m 32s
platypus: Ran 1(1/0/0) tests, Grand total test time = 0m 40s
kite: Ran 1(1/0/0) tests, Grand total test time = 0m 46s
jam: Ran 1(1/0/0) tests, Grand total test time = 1m 1s
quail: Ran 1(1/0/0) tests, Grand total test time = 0m 55s
ostrich: Ran 2(2/0/0) tests, Grand total test time = 4m 47s
jam: Ran 7(0/0/0) hosts, Grand total test time = 5m 53s
Timekeeper log
Timekeeper started at Fri Aug 28 23:42:52 CDT 2015
Timekeeper sleeping for 720 seconds
Tests Failures
Dumping logfile of emu: setenvN 2 CC cc -m64 op-configure --prefix=/mnt/scr1/pre-release/opa/emu64 deploy emu64
Last 50 lines of /mnt/scr1/SnapTest/snapshots-opa/log/emu_0828Fri_2342
GROUP=hdf
HDF5_ACLOCAL=/mnt/hdf/packages/AUTOTOOLS/automake/1.15/sun4v/bin/aclocal-1.15
HDF5_AUTOCONF=/mnt/hdf/packages/AUTOTOOLS/autoconf/2.69/sun4v/bin/autoconf
HDF5_AUTOHEADER=/mnt/hdf/packages/AUTOTOOLS/autoconf/2.69/sun4v/bin/autoheader
HDF5_AUTOMAKE=/mnt/hdf/packages/AUTOTOOLS/automake/1.15/sun4v/bin/automake-1.15
HDF5_LIBTOOL=/mnt/hdf/packages/AUTOTOOLS/libtool/2.4.6/sun4v/bin/libtool
HDF5_M4=/mnt/hdf/packages/AUTOTOOLS/m4/1.4.17/sun4v/bin/m4
HDF5TestExpress=yes
HOME=/home/hdftest
HOST=emu
HOSTTYPE=sun4
JAVA_HOME=/usr/lib/jvm/jre-1.6.0
LANG=en_US.UTF-8
LC_ALL=
LC_COLLATE=
LC_CTYPE=
LC_MESSAGES=
LC_MONETARY=
LC_NUMERIC=
LC_TIME=
LOGNAME=hdftest
MACHTYPE=sparc
MAIL=/var/mail/hdftest
MAKE=gmake
NLSPATH=/usr/share/locale/%L/LC_MESSAGES/%N.cat
OSTYPE=solaris
PATH=/home/hdftest/bin:/usr/hdf/bin:/home/hdftest/bin:/usr/hdf/bin:/usr/bin:/usr/sbin:/opt/solarisstudio/bin:/opt/cmake/bin:/opt/svn/bin:/mnt/hdf/ec2-api-tools/bin
PWD=/mnt/scr1/SnapTest/snapshots-opa
REMOTEHOST=
SET_PATH=yes
SHELL=/bin/tcsh
SHLVL=3
SSH_CLIENT=10.10.10.86 49617 22
SSH_CONNECTION=10.10.10.86 49617 10.10.10.84 22
SVNROOT=http://svn.hdfgroup.uiuc.edu
TZ=localtime
USER=hdftest
VENDOR=sun
===Done Dumping environment variables after option parsing ===
===== Run Tests: Friday, August 28, 2015 11:42:44 PM CDT =====
Remove contents of emu.
diff: /home/hdftest/snapshots-opa/previous/MANIFEST: No such file or directory
===== configure: Friday, August 28, 2015 11:42:44 PM CDT =====
checking for a BSD-compatible install... /usr/bin/ginstall -c
checking whether build environment is sane... configure: error: newly created file is older than distributed files!
Check your system clock
Failed running configure
===== Exit bin/snapshot with status=1: Friday, August 28, 2015 11:42:46 PM CDT =====
Dumping done
Runtest did not exit normally.
Watchers List
OPA Daily test features/platforms watchers and procedure
Procedure:
The watcher will investigate and report the cause of failure by 11am.
The developer who checked in the error code may report so by then too.
The watcher or the developer should get the failure fixed and report it
by 3pm.
Watcher for OPA: Neil
updated: 2009/05/05
Tests Details
23:42:30 up 9 days, 10:39, 14 users, load average: 0.96, 0.94, 0.80
Filesystem 1K-blocks Used Available Use% Mounted on
/dev/sda3 31738420 9164744 20935448 31% /
/dev/sda1 101086 17532 78335 19% /boot
/dev/sda2 31738420 406960 29693232 2% /tmp
/dev/sda6 31738392 5584104 24516064 19% /var
/dev/sda7 31738392 18481028 11619140 62% /usr
/dev/sda8 124991068 377284 118162084 1% /var/tmp
/dev/mapper/VolGroup00-home
198351840 96300708 91812772 52% /home
/dev/sde1 565688764 426278748 110211080 80% /scr
/dev/sdc1 961432072 765215984 147378088 84% /mnt/scr1
/dev/sdd1 961432072 855930420 56663652 94% /mnt/hdf
tmpfs 8313628 0 8313628 0% /dev/shm
10.10.10.15:/volume1/hdf2
1437485440 238047232 1199335808 17% /mnt/hdf2
10.10.10.15:/volume1/hdf3
1437485440 238047232 1199335808 17% /mnt/hdf3
gumund:/data/ftp 480719104 380699520 75600384 84% /mnt/ftp
gumund:/data/web 480719104 380699520 75600384 84% /mnt/web
STANDARD_OPT=setenv MAKE gmake deploydir /mnt/scr1/pre-release/opa
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam
Running source repository checkout with output saved in
/mnt/scr1/SnapTest/snapshots-opa/log/REPO_LOG_0828Fri
Checking MANIFEST file ...
cat: /mnt/scr1/SnapTest/snapshots-opa/log/#runtest.0828Fri.27947: No such file or directory
rm: cannot remove `/mnt/scr1/SnapTest/snapshots-opa/log/#runtest.0828Fri.27947': No such file or directory
*** launching tests from jam ***
TESTHOST is emu
jam
koala
platypus
ostrich
quail
kite
Fork off timekeeper 12
Testing emu
ssh -o ConnectTimeout=60 emu -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname emu
11:42pm up 61 day(s), 8:47, 2 users, load average: 0.01, 0.08, 0.52
/ (rpool/ROOT/solaris):432242315 blocks 432242315 files
/devices (/devices ): 0 blocks 0 files
/dev (/dev ): 0 blocks 0 files
/system/contract (ctfs ): 0 blocks 2147483588 files
/proc (proc ): 0 blocks 29923 files
/etc/mnttab (mnttab ): 0 blocks 0 files
/system/volatile (swap ):12544432 blocks 2202201 files
/system/object (objfs ): 0 blocks 2147483465 files
/etc/dfs/sharetab (sharefs ): 0 blocks 2147483646 files
/dev/fd (fd ): 0 blocks 0 files
/var (rpool/ROOT/solaris/var):432242315 blocks 432242315 files
/tmp (swap ):12544432 blocks 2202201 files
/var/share (rpool/VARSHARE ):432242315 blocks 432242315 files
/rpool (rpool ):432242315 blocks 432242315 files
/export (rpool/export ):432242315 blocks 432242315 files
/export/home (rpool/export/home ):432242315 blocks 432242315 files
/export/home/kurz (rpool/export/home/kurz):432242315 blocks 432242315 files
/home (jam.ad.hdfgroup.org:/home):204102264 blocks 50170587 files
/mnt/hdf (jam.ad.hdfgroup.org:/mnt/hdf):211003304 blocks 112039890 files
/mnt/scr1 (jam.ad.hdfgroup.org:/mnt/scr1):392432120 blocks 118082279 files
TEST_TYPES=setenvN 2 CC cc -m64 op-configure --prefix=/mnt/scr1/pre-release/opa/emu64 deploy emu64
*** starting setenvN 2 CC cc -m64 op-configure --prefix=/mnt/scr1/pre-release/opa/emu64 deploy emu64 tests in emu ***
Uname -a: SunOS emu 5.11 11.1 sun4v sparc sun4v
Running snapshot with output saved in
*** finished setenvN 2 CC cc -m64 op-configure --prefix=/mnt/scr1/pre-release/opa/emu64 deploy emu64 tests for emu ***
Total time = 0m 2s
*** finished tests in emu ***
****SYSTEM ERROR emu: Abnormal exit from runtest ****
****SYSTEM ERROR emu: runtest command failed ****
Testing jam
ssh -o ConnectTimeout=60 jam -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname jam
23:42:59 up 9 days, 10:39, 14 users, load average: 0.85, 0.91, 0.79
/dev/sda2 31738420 407068 29693124 2% /tmp
/dev/sda6 31738392 5584116 24516052 19% /var
/dev/sdc1 961432072 765216020 147378052 84% /mnt/scr1
Fri Aug 28 23:43:09 CDT 2015
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam tests in jam ***
Uname -a: Linux jam 2.6.18-308.13.1.el5PAE #1 SMP Tue Aug 21 17:50:26 EDT 2012 i686 i686 i386 GNU/Linux
/mnt/scr1/SnapTest/snapshots-opa/log/jam_0828Fri_2343
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam tests for jam ***
Fri Aug 28 23:44:10 CDT 2015
Total time = 1m 1s
*** finished tests in jam ***
Testing koala
ssh -o ConnectTimeout=60 koala -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname koala
23:43:01 up 2 days, 10:53, 1 user, load average: 0.07, 0.02, 0.00
/dev/sda7 22292052 4443572 16697828 22% /
/dev/sda5 12192608 400624 11162640 4% /tmp
/dev/sda3 12192636 1157680 10405612 11% /var
/dev/sda1 101086 18614 77253 20% /boot
/dev/sdc1 41279536 26268420 12914236 68% /usr
/dev/sdb 152754284 72619388 72375436 51% /scr
tmpfs 6149552 0 6149552 0% /dev/shm
10.10.10.86:/home 198351872 96300032 91812864 52% /home
10.10.10.86:/mnt/hdf 961432576 855930880 56664064 94% /mnt/hdf
10.10.10.86:/mnt/scr1
961432576 765215744 147378176 84% /mnt/scr1
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala
Fri Aug 28 23:43:11 CDT 2015
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala tests in koala ***
Uname -a: Linux koala 2.6.18-406.el5 #1 SMP Tue Jun 2 17:25:57 EDT 2015 x86_64 x86_64 x86_64 GNU/Linux
/mnt/scr1/SnapTest/snapshots-opa/log/koala_0828Fri_2343
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala tests for koala ***
Fri Aug 28 23:43:43 CDT 2015
Total time = 0m 32s
*** finished tests in koala ***
Testing platypus
ssh -o ConnectTimeout=60 platypus -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname platypus
23:43:13 up 13:08, 2 users, load average: 0.04, 0.51, 0.69
/dev/sda6 54205540 21014108 30431292 41% /
tmpfs 6099072 0 6099072 0% /dev/shm
/dev/sda1 194241 48551 135450 27% /boot
/dev/sda2 12850716 136876 12054384 2% /tmp
/dev/sda3 12850716 3913376 8277884 33% /var
/dev/sdd 152623212 98053452 46810300 68% /scr
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus
Fri Aug 28 23:43:23 CDT 2015
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus tests in platypus ***
Uname -a: Linux platypus 2.6.32-573.3.1.el6.x86_64 #1 SMP Thu Aug 13 22:55:16 UTC 2015 x86_64 x86_64 x86_64 GNU/Linux
/mnt/scr1/SnapTest/snapshots-opa/log/platypus_0828Fri_2343
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus tests for platypus ***
Fri Aug 28 23:44:03 CDT 2015
Total time = 0m 40s
*** finished tests in platypus ***
Testing ostrich
ssh -o ConnectTimeout=60 ostrich -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname ostrich
23:43:28 up 51 days, 10:31, 1 user, load average: 2.15, 5.87, 4.54
/dev/mapper/vg_ostrich-lv_root
140479384 18185660 115154680 14% /
tmpfs 7821632 0 7821632 0% /dev/shm
/dev/sda2 487652 92973 369079 21% /boot
/dev/sdb2 124477364 83074460 35073152 71% /scr
jam:/home 198351872 96300032 91812864 52% /home
jam:/mnt/hdf 961432576 855930880 56664064 94% /mnt/hdf
jam:/mnt/scr1 961432576 765215744 147378176 84% /mnt/scr1
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich ; standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl
Fri Aug 28 23:43:38 CDT 2015
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich tests in ostrich ***
Uname -a: Linux ostrich 2.6.32-504.8.1.el6.ppc64 #1 SMP Fri Dec 19 12:10:45 EST 2014 ppc64 ppc64 ppc64 GNU/Linux
/mnt/scr1/SnapTest/snapshots-opa/log/ostrich_0828Fri_2343
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich tests for ostrich ***
Fri Aug 28 23:45:19 CDT 2015
Total time = 1m 41s
*** starting standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl tests in ostrich ***
/mnt/scr1/SnapTest/snapshots-opa/log/ostrich_0828Fri_2345
*** finished standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl tests for ostrich ***
Fri Aug 28 23:48:25 CDT 2015
Total time = 3m 6s
*** finished tests in ostrich ***
Testing quail
ssh -o ConnectTimeout=60 quail -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname quail
23:43 up 13:22, 2 users, load averages: 1.66 1.61 1.57
Filesystem 512-blocks Used Available Capacity iused ifree %iused Mounted on
/dev/disk0s2 488555536 168474792 319568744 35% 21123347 39946093 35% /
devfs 363 363 0 100% 628 0 100% /dev
map auto_nfs 0 0 0 100% 0 0 100% /home
map auto_nfs 0 0 0 100% 0 0 100% /mnt/hdf
map auto_nfs 0 0 0 100% 0 0 100% /mnt/scr1
jam.ad.hdfgroup.org:/mnt/scr1 1922864144 1530432112 294756032 84% 4027684 118082268 3% /mnt/scr1
jam.ad.hdfgroup.org:/mnt/hdf 1922864144 1711860840 113327304 94% 10070062 112039890 8% /mnt/hdf
jam.ad.hdfgroup.org:/home 396703680 192601416 183625544 52% 1045797 50170587 2% /home
TEST_TYPES=standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/quail deploy quail
Fri Aug 28 23:43:19 CDT 2015
*** starting standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/quail deploy quail tests in quail ***
Uname -a: Darwin quail.ad.hdfgroup.org 13.4.0 Darwin Kernel Version 13.4.0: Wed Mar 18 16:20:14 PDT 2015; root:xnu-2422.115.14~1/RELEASE_X86_64 x86_64
/Users/hdftest/snapshots-opa/log/quail_0828Fri_2343
*** finished standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/quail deploy quail tests for quail ***
Fri Aug 28 23:44:14 CDT 2015
Total time = 0m 55s
*** finished tests in quail ***
Testing kite
ssh -o ConnectTimeout=60 kite -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname kite
23:43 up 13:20, 1 user, load averages: 0.05 0.22 0.27
/dev/disk0s2 1951845952 223893048 1727440904 12% 28050629 215930113 11% /
devfs 372 372 0 100% 644 0 100% /dev
/dev/disk1s2 1952853344 1296656 1951556688 1% 162080 243944586 0% /Volumes/Milvinae
10.10.10.86:/mnt/hdf 1922864144 1711860840 113327304 94% 10070062 112039890 8% /mnt/hdf
10.10.10.86:/mnt/scr1 1922864144 1530432168 294755976 84% 4027689 118082263 3% /mnt/scr1
10.10.10.86:/home 396703680 192601416 183625544 52% 1045797 50170587 2% /mnt/home
TEST_TYPES=standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/kite deploy kite
Fri Aug 28 23:43:21 CDT 2015
*** starting standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/kite deploy kite tests in kite ***
Uname -a: Darwin kite.ad.hdfgroup.org 12.6.0 Darwin Kernel Version 12.6.0: Wed Mar 18 16:23:48 PDT 2015; root:xnu-2050.48.19~1/RELEASE_X86_64 x86_64
/Users/hdftest/snapshots-opa/log/kite_0828Fri_2343
*** finished standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/kite deploy kite tests for kite ***
Fri Aug 28 23:44:07 CDT 2015
Total time = 0m 46s
*** finished tests in kite ***
More information about the opa-nightly-tests
