[opa-nightly-tests] jam OPA_Daily_Tests_0827Thu_FAILED!!!
Larry Knox
lrknox at hdfgroup.org
Fri Aug 28 08:24:19 CDT 2015
Emu's clock is a bit behind that of the launch host (jam), resulting in a file created by configure with an earlier timestamp than a source file, causing configure to fail. The time clock situation has been reported on a SYSADMIN ticket.
Larry
-----Original Message-----
From: opa-nightly-tests-bounces at lists.mcs.anl.gov [mailto:opa-nightly-tests-bounces at lists.mcs.anl.gov] On Behalf Of HDF Tester
Sent: Thursday, August 27, 2015 11:16 PM
To: opa-nightly-tests at lists.mcs.anl.gov
Subject: [opa-nightly-tests] jam OPA_Daily_Tests_0827Thu_FAILED!!!
*** OPA Tests on 0827Thu ***
Tests Summary
****FAILED emu: standard op-configure --prefix=/mnt/scr1/pre-release/opa/emu32 deploy emu32****
PASSED jam: standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam PASSED kite: standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/kite deploy kite PASSED koala: standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala PASSED ostrich: standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich PASSED ostrich: standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl PASSED platypus: standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus PASSED quail: standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/quail deploy quail
Tests Time Summary
emu: Ran 1(0/1/0) tests, Grand total test time = 0m 2s
koala: Ran 1(1/0/0) tests, Grand total test time = 0m 33s
platypus: Ran 1(1/0/0) tests, Grand total test time = 0m 42s
kite: Ran 1(1/0/0) tests, Grand total test time = 0m 48s
jam: Ran 1(1/0/0) tests, Grand total test time = 1m 2s
quail: Ran 1(1/0/0) tests, Grand total test time = 0m 54s
ostrich: Ran 2(2/0/0) tests, Grand total test time = 4m 33s
jam: Ran 7(0/0/0) hosts, Grand total test time = 5m 37s
Timekeeper log
Timekeeper started at Thu Aug 27 23:10:29 CDT 2015 Timekeeper sleeping for 720 seconds
Tests Failures
Dumping logfile of emu: standard op-configure --prefix=/mnt/scr1/pre-release/opa/emu32 deploy emu32 Last 50 lines of /mnt/scr1/SnapTest/snapshots-opa/log/emu_0827Thu_2310
GROUP=hdf
HDF5_ACLOCAL=/mnt/hdf/packages/AUTOTOOLS/automake/1.15/sun4v/bin/aclocal-1.15
HDF5_AUTOCONF=/mnt/hdf/packages/AUTOTOOLS/autoconf/2.69/sun4v/bin/autoconf
HDF5_AUTOHEADER=/mnt/hdf/packages/AUTOTOOLS/autoconf/2.69/sun4v/bin/autoheader
HDF5_AUTOMAKE=/mnt/hdf/packages/AUTOTOOLS/automake/1.15/sun4v/bin/automake-1.15
HDF5_LIBTOOL=/mnt/hdf/packages/AUTOTOOLS/libtool/2.4.6/sun4v/bin/libtool
HDF5_M4=/mnt/hdf/packages/AUTOTOOLS/m4/1.4.17/sun4v/bin/m4
HDF5TestExpress=yes
HOME=/home/hdftest
HOST=emu
HOSTTYPE=sun4
JAVA_HOME=/usr/lib/jvm/jre-1.6.0
LANG=en_US.UTF-8
LC_ALL=
LC_COLLATE=
LC_CTYPE=
LC_MESSAGES=
LC_MONETARY=
LC_NUMERIC=
LC_TIME=
LOGNAME=hdftest
MACHTYPE=sparc
MAIL=/var/mail/hdftest
MAKE=gmake
NLSPATH=/usr/share/locale/%L/LC_MESSAGES/%N.cat
OSTYPE=solaris
PATH=/home/hdftest/bin:/usr/hdf/bin:/home/hdftest/bin:/usr/hdf/bin:/usr/bin:/usr/sbin:/opt/solarisstudio/bin:/opt/cmake/bin:/opt/svn/bin:/mnt/hdf/ec2-api-tools/bin
PWD=/mnt/scr1/SnapTest/snapshots-opa
REMOTEHOST=
SET_PATH=yes
SHELL=/bin/tcsh
SHLVL=3
SSH_CLIENT=10.10.10.86 51403 22
SSH_CONNECTION=10.10.10.86 51403 10.10.10.84 22 SVNROOT=http://svn.hdfgroup.uiuc.edu
TZ=localtime
USER=hdftest
VENDOR=sun
===Done Dumping environment variables after option parsing === ===== Run Tests: Thursday, August 27, 2015 11:10:20 PM CDT ===== Remove contents of emu.
diff: /home/hdftest/snapshots-opa/previous/MANIFEST: No such file or directory ===== configure: Thursday, August 27, 2015 11:10:20 PM CDT ===== checking for a BSD-compatible install... /usr/bin/ginstall -c checking whether build environment is sane... configure: error: newly created file is older than distributed files!
Check your system clock
Failed running configure
===== Exit bin/snapshot with status=1: Thursday, August 27, 2015 11:10:21 PM CDT ===== Thursday, August 27, 2015 11:10:21 PM CDT ========================= Dumping done =========================
Runtest did not exit normally.
Watchers List
OPA Daily test features/platforms watchers and procedure
Procedure:
The watcher will investigate and report the cause of failure by 11am.
The developer who checked in the error code may report so by then too.
The watcher or the developer should get the failure fixed and report it by 3pm.
Watcher for OPA: Neil
updated: 2009/05/05
Tests Details
23:10:08 up 8 days, 10:06, 15 users, load average: 0.86, 1.06, 0.76
Filesystem 1K-blocks Used Available Use% Mounted on
/dev/sda3 31738420 8960776 21139416 30% /
/dev/sda1 101086 17532 78335 19% /boot
/dev/sda2 31738420 393500 29706692 2% /tmp
/dev/sda6 31738392 5488432 24611736 19% /var
/dev/sda7 31738392 18481020 11619148 62% /usr
/dev/sda8 124991068 377280 118162088 1% /var/tmp
/dev/mapper/VolGroup00-home
198351840 96330728 91782752 52% /home
/dev/sde1 565688764 425993688 110496140 80% /scr
/dev/sdc1 961432072 767340216 145253856 85% /mnt/scr1
/dev/sdd1 961432072 853504864 59089208 94% /mnt/hdf
tmpfs 8313628 0 8313628 0% /dev/shm
gumund:/data/ftp 480719104 380445824 75854080 84% /mnt/ftp
gumund:/data/web 480719104 380445824 75854080 84% /mnt/web
10.10.10.15:/volume1/hdf2
1437485440 238047232 1199335808 17% /mnt/hdf2
10.10.10.15:/volume1/hdf3
1437485440 238047232 1199335808 17% /mnt/hdf3 STANDARD_OPT=setenv MAKE gmake deploydir /mnt/scr1/pre-release/opa TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam
Running source repository checkout with output saved in
/mnt/scr1/SnapTest/snapshots-opa/log/REPO_LOG_0827Thu
Checking MANIFEST file ...
cat: /mnt/scr1/SnapTest/snapshots-opa/log/#runtest.0827Thu.16834: No such file or directory
rm: cannot remove `/mnt/scr1/SnapTest/snapshots-opa/log/#runtest.0827Thu.16834': No such file or directory
*** launching tests from jam ***
TESTHOST is emu
jam
koala
platypus
ostrich
quail
kite
Fork off timekeeper 12
Testing emu
ssh -o ConnectTimeout=60 emu -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname emu 11:10pm up 60 day(s), 8:14, 2 users, load average: 0.01, 0.09, 0.74
/ (rpool/ROOT/solaris):425734292 blocks 425734292 files
/devices (/devices ): 0 blocks 0 files
/dev (/dev ): 0 blocks 0 files
/system/contract (ctfs ): 0 blocks 2147483588 files
/proc (proc ): 0 blocks 29924 files
/etc/mnttab (mnttab ): 0 blocks 0 files
/system/volatile (swap ):11809216 blocks 2202599 files
/system/object (objfs ): 0 blocks 2147483465 files
/etc/dfs/sharetab (sharefs ): 0 blocks 2147483646 files
/dev/fd (fd ): 0 blocks 0 files
/var (rpool/ROOT/solaris/var):425734292 blocks 425734292 files
/tmp (swap ):11809216 blocks 2202599 files
/var/share (rpool/VARSHARE ):425734292 blocks 425734292 files
/rpool (rpool ):425734292 blocks 425734292 files
/export (rpool/export ):425734292 blocks 425734292 files
/export/home (rpool/export/home ):425734292 blocks 425734292 files
/export/home/kurz (rpool/export/home/kurz):425734292 blocks 425734292 files
/home (jam.ad.hdfgroup.org:/home):204042224 blocks 50170189 files
/mnt/hdf (jam.ad.hdfgroup.org:/mnt/hdf):215854416 blocks 112073077 files
/mnt/scr1 (jam.ad.hdfgroup.org:/mnt/scr1):388183656 blocks 118083061 files
STANDARD_OPT=setenv MAKE gmake deploydir /mnt/scr1/pre-release/opa TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/emu32 deploy emu32
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/emu32 deploy emu32 tests in emu *** Uname -a: SunOS emu 5.11 11.1 sun4v sparc sun4v Running snapshot with output saved in
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/emu32 deploy emu32 tests for emu *** Thursday, August 27, 2015 11:10:21 PM CDT Total time = 0m 1s
*** finished tests in emu ***
****SYSTEM ERROR emu: Abnormal exit from runtest ****
Thu Aug 27 23:15:55 CDT 2015
****SYSTEM ERROR emu: runtest command failed ****
Testing jam
ssh -o ConnectTimeout=60 jam -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname jam
23:10:36 up 8 days, 10:07, 15 users, load average: 0.73, 1.01, 0.75
/dev/sda2 31738420 393608 29706584 2% /tmp
/dev/sdc1 961432072 767340252 145253820 85% /mnt/scr1
Thu Aug 27 23:10:46 CDT 2015
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam tests in jam *** Uname -a: Linux jam 2.6.18-308.13.1.el5PAE #1 SMP Tue Aug 21 17:50:26 EDT 2012 i686 i686 i386 GNU/Linux Running snapshot with output saved in
/mnt/scr1/SnapTest/snapshots-opa/log/jam_0827Thu_2310
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam tests for jam *** Thu Aug 27 23:11:48 CDT 2015 Total time = 1m 2s
*** finished tests in jam ***
Testing koala
ssh -o ConnectTimeout=60 koala -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname koala
23:10:38 up 1 day, 10:21, 1 user, load average: 0.33, 0.16, 0.10
/dev/sda7 22292052 4443348 16698052 22% /
/dev/sda5 12192608 496456 11066808 5% /tmp
/dev/sda3 12192636 1157280 10406012 11% /var
/dev/sda1 101086 18614 77253 20% /boot
/dev/sdc1 41279536 26268976 12913680 68% /usr
/dev/sdb 152754284 72634820 72360004 51% /scr
tmpfs 6149552 0 6149552 0% /dev/shm
10.10.10.86:/home 198351872 96330752 91783168 52% /home
10.10.10.86:/mnt/hdf 961432576 853505024 59089920 94% /mnt/hdf
10.10.10.86:/mnt/scr1
961432576 767340544 145254400 85% /mnt/scr1 STANDARD_OPT=setenv MAKE gmake deploydir /mnt/scr1/pre-release/opa TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala
Thu Aug 27 23:10:48 CDT 2015
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala tests in koala *** Uname -a: Linux koala 2.6.18-406.el5 #1 SMP Tue Jun 2 17:25:57 EDT 2015 x86_64 x86_64 x86_64 GNU/Linux Running snapshot with output saved in
/mnt/scr1/SnapTest/snapshots-opa/log/koala_0827Thu_2310
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala tests for koala *** Thu Aug 27 23:11:21 CDT 2015 Total time = 0m 33s
*** finished tests in koala ***
Testing platypus
ssh -o ConnectTimeout=60 platypus -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname platypus
23:10:57 up 42 days, 14:56, 4 users, load average: 0.14, 0.66, 0.60
/dev/sda6 54205540 20976332 30469068 41% /
tmpfs 6099128 0 6099128 0% /dev/shm
/dev/sda1 194241 48100 135901 27% /boot
/dev/sda2 12850716 153676 12037584 2% /tmp
/dev/sda3 12850716 3817244 8374016 32% /var
/dev/sdd 152623212 99296964 45566788 69% /scr
STANDARD_OPT=setenv MAKE gmake deploydir /mnt/scr1/pre-release/opa TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus
Thu Aug 27 23:11:07 CDT 2015
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus tests in platypus *** Uname -a: Linux platypus 2.6.32-504.16.2.el6.x86_64 #1 SMP Wed Apr 22 06:48:29 UTC 2015 x86_64 x86_64 x86_64 GNU/Linux Running snapshot with output saved in
/mnt/scr1/SnapTest/snapshots-opa/log/platypus_0827Thu_2311
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus tests for platypus *** Thu Aug 27 23:11:49 CDT 2015 Total time = 0m 42s
*** finished tests in platypus ***
Testing ostrich
ssh -o ConnectTimeout=60 ostrich -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname ostrich
23:11:03 up 50 days, 9:58, 1 user, load average: 2.31, 5.84, 4.39
/dev/mapper/vg_ostrich-lv_root
140479384 18184452 115155888 14% /
tmpfs 7821632 0 7821632 0% /dev/shm
/dev/sda2 487652 92973 369079 21% /boot
/dev/sdb2 124477364 83338624 34808988 71% /scr
jam:/home 198351872 96330752 91783168 52% /home
jam:/mnt/hdf 961432576 853505024 59089920 94% /mnt/hdf
jam:/mnt/scr1 961432576 767340544 145254400 85% /mnt/scr1
STANDARD_OPT=setenv MAKE gmake deploydir /mnt/scr1/pre-release/opa TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich ; standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl
Thu Aug 27 23:11:13 CDT 2015
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich tests in ostrich *** Uname -a: Linux ostrich 2.6.32-504.8.1.el6.ppc64 #1 SMP Fri Dec 19 12:10:45 EST 2014 ppc64 ppc64 ppc64 GNU/Linux Running snapshot with output saved in
/mnt/scr1/SnapTest/snapshots-opa/log/ostrich_0827Thu_2311
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich tests for ostrich *** Thu Aug 27 23:12:47 CDT 2015 Total time = 1m 34s
*** starting standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl tests in ostrich *** Uname -a: Linux ostrich 2.6.32-504.8.1.el6.ppc64 #1 SMP Fri Dec 19 12:10:45 EST 2014 ppc64 ppc64 ppc64 GNU/Linux Running snapshot with output saved in
/mnt/scr1/SnapTest/snapshots-opa/log/ostrich_0827Thu_2312
*** finished standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl tests for ostrich *** Thu Aug 27 23:15:46 CDT 2015 Total time = 2m 59s
*** finished tests in ostrich ***
Testing quail
ssh -o ConnectTimeout=60 quail -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname quail
23:10 up 1 day, 10:58, 1 user, load averages: 1.70 1.52 1.40
Filesystem 512-blocks Used Available Capacity iused ifree %iused Mounted on
/dev/disk0s2 488555536 171744720 316298816 36% 21532088 39537352 35% /
devfs 360 360 0 100% 624 0 100% /dev
map auto_nfs 0 0 0 100% 0 0 100% /home
map auto_nfs 0 0 0 100% 0 0 100% /mnt/hdf
map auto_nfs 0 0 0 100% 0 0 100% /mnt/scr1
jam.ad.hdfgroup.org:/mnt/hdf 1922864144 1707009728 118178416 94% 10036875 112073077 8% /mnt/hdf
jam.ad.hdfgroup.org:/home 396703680 192661456 183565504 52% 1046195 50170189 2% /home
jam.ad.hdfgroup.org:/mnt/scr1 1922864144 1534680576 290507568 85% 4026902 118083050 3% /mnt/scr1
STANDARD_OPT=setenv MAKE gmake deploydir /mnt/scr1/pre-release/opa TEST_TYPES=standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/quail deploy quail
Thu Aug 27 23:10:58 CDT 2015
*** starting standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/quail deploy quail tests in quail *** Uname -a: Darwin quail.ad.hdfgroup.org 13.4.0 Darwin Kernel Version 13.4.0: Wed Mar 18 16:20:14 PDT 2015; root:xnu-2422.115.14~1/RELEASE_X86_64 x86_64 Running snapshot with output saved in
/Users/hdftest/snapshots-opa/log/quail_0827Thu_2310
*** finished standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/quail deploy quail tests for quail *** Thu Aug 27 23:11:52 CDT 2015 Total time = 0m 54s
*** finished tests in quail ***
Testing kite
ssh -o ConnectTimeout=60 kite -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname kite
23:10 up 1 day, 10:38, 1 user, load averages: 0.08 0.28 0.31
/dev/disk1s2 1951845952 210345232 1740988720 11% 26357152 217623590 11% /
devfs 372 372 0 100% 645 0 100% /dev
/dev/disk0s2 1952853344 1296640 1951556704 1% 162078 243944588 0% /Volumes/Milvinae
10.10.10.86:/mnt/hdf 1922864144 1707009728 118178416 94% 10036875 112073077 8% /mnt/hdf
10.10.10.86:/mnt/scr1 1922864144 1534680632 290507512 85% 4026907 118083045 3% /mnt/scr1
10.10.10.86:/home 396703680 192661456 183565504 52% 1046195 50170189 2% /mnt/home
STANDARD_OPT=setenv MAKE gmake deploydir /mnt/scr1/pre-release/opa TEST_TYPES=standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/kite deploy kite
Thu Aug 27 23:11:00 CDT 2015
*** starting standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/kite deploy kite tests in kite *** Uname -a: Darwin kite.ad.hdfgroup.org 12.6.0 Darwin Kernel Version 12.6.0: Wed Mar 18 16:23:48 PDT 2015; root:xnu-2050.48.19~1/RELEASE_X86_64 x86_64 Running snapshot with output saved in
/Users/hdftest/snapshots-opa/log/kite_0827Thu_2311
*** finished standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/kite deploy kite tests for kite *** Thu Aug 27 23:11:48 CDT 2015 Total time = 0m 48s
*** finished tests in kite ***
opa-nightly-tests mailing list
https://lists.mcs.anl.gov/mailman/listinfo/opa-nightly-tests
More information about the opa-nightly-tests
