[opa-nightly-tests] jam OPA_Daily_Tests_0827Thu_FAILED!!!
HDF Tester hdftest at hdfgroup.org
Thu Aug 27 23:15:55 CDT 2015
*** OPA Tests on 0827Thu ***
   Tests Summary
****FAILED emu: standard op-configure --prefix=/mnt/scr1/pre-release/opa/emu32 deploy emu32****
PASSED jam: standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam
PASSED kite: standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/kite deploy kite
PASSED koala: standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala
PASSED ostrich: standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich
PASSED ostrich: standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl
PASSED platypus: standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus
PASSED quail: standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/quail deploy quail
   Tests Time Summary
emu: Ran 1(0/1/0) tests, Grand total test time =  0m 2s
koala: Ran 1(1/0/0) tests, Grand total test time =  0m 33s
platypus: Ran 1(1/0/0) tests, Grand total test time =  0m 42s
kite: Ran 1(1/0/0) tests, Grand total test time =  0m 48s
jam: Ran 1(1/0/0) tests, Grand total test time =  1m 2s
quail: Ran 1(1/0/0) tests, Grand total test time =  0m 54s
ostrich: Ran 2(2/0/0) tests, Grand total test time =  4m 33s
jam: Ran 7(0/0/0) hosts, Grand total test time =  5m 37s
   Timekeeper log
Timekeeper started at Thu Aug 27 23:10:29 CDT 2015
Timekeeper sleeping for 720 seconds
   Tests Failures
Dumping logfile of emu: standard op-configure --prefix=/mnt/scr1/pre-release/opa/emu32 deploy emu32
Last 50 lines of /mnt/scr1/SnapTest/snapshots-opa/log/emu_0827Thu_2310
GROUP=hdf
HDF5_ACLOCAL=/mnt/hdf/packages/AUTOTOOLS/automake/1.15/sun4v/bin/aclocal-1.15
HDF5_AUTOCONF=/mnt/hdf/packages/AUTOTOOLS/autoconf/2.69/sun4v/bin/autoconf
HDF5_AUTOHEADER=/mnt/hdf/packages/AUTOTOOLS/autoconf/2.69/sun4v/bin/autoheader
HDF5_AUTOMAKE=/mnt/hdf/packages/AUTOTOOLS/automake/1.15/sun4v/bin/automake-1.15
HDF5_LIBTOOL=/mnt/hdf/packages/AUTOTOOLS/libtool/2.4.6/sun4v/bin/libtool
HDF5_M4=/mnt/hdf/packages/AUTOTOOLS/m4/1.4.17/sun4v/bin/m4
HDF5TestExpress=yes
HOME=/home/hdftest
HOST=emu
HOSTTYPE=sun4
JAVA_HOME=/usr/lib/jvm/jre-1.6.0
LANG=en_US.UTF-8
LC_ALL=
LC_COLLATE=
LC_CTYPE=
LC_MESSAGES=
LC_MONETARY=
LC_NUMERIC=
LC_TIME=
LOGNAME=hdftest
MACHTYPE=sparc
MAIL=/var/mail/hdftest
MAKE=gmake
NLSPATH=/usr/share/locale/%L/LC_MESSAGES/%N.cat
OSTYPE=solaris
PATH=/home/hdftest/bin:/usr/hdf/bin:/home/hdftest/bin:/usr/hdf/bin:/usr/bin:/usr/sbin:/opt/solarisstudio/bin:/opt/cmake/bin:/opt/svn/bin:/mnt/hdf/ec2-api-tools/bin
PWD=/mnt/scr1/SnapTest/snapshots-opa
REMOTEHOST=
SET_PATH=yes
SHELL=/bin/tcsh
SHLVL=3
SSH_CLIENT=10.10.10.86 51403 22
SSH_CONNECTION=10.10.10.86 51403 10.10.10.84 22
SVNROOT=http://svn.hdfgroup.uiuc.edu
TZ=localtime
USER=hdftest
VENDOR=sun
===Done Dumping environment variables after option parsing ===
===== Run Tests: Thursday, August 27, 2015 11:10:20 PM CDT =====
Remove contents of emu.
diff: /home/hdftest/snapshots-opa/previous/MANIFEST: No such file or directory
===== configure: Thursday, August 27, 2015 11:10:20 PM CDT =====
checking for a BSD-compatible install... /usr/bin/ginstall -c
checking whether build environment is sane... configure: error: newly created file is older than distributed files!
Check your system clock
Failed running configure
===== Exit bin/snapshot with status=1: Thursday, August 27, 2015 11:10:21 PM CDT =====
Dumping done
Runtest did not exit normally.
   Watchers List
OPA Daily test features/platforms watchers and procedure
Procedure:
The watcher will investigate and report the cause of failure by 11am.
The developer who checked in the error code may report so by then too.
The watcher or the developer should get the failure fixed and report it
by 3pm.
Watcher for OPA:	 	Neil
updated: 2009/05/05
   Tests Details
 23:10:08 up 8 days, 10:06, 15 users,  load average: 0.86, 1.06, 0.76
Filesystem           1K-blocks      Used Available Use% Mounted on
/dev/sda3             31738420   8960776  21139416  30% /
/dev/sda1               101086     17532     78335  19% /boot
/dev/sda2             31738420    393500  29706692   2% /tmp
/dev/sda6             31738392   5488432  24611736  19% /var
/dev/sda7             31738392  18481020  11619148  62% /usr
/dev/sda8            124991068    377280 118162088   1% /var/tmp
/dev/mapper/VolGroup00-home
                     198351840  96330728  91782752  52% /home
/dev/sde1            565688764 425993688 110496140  80% /scr
/dev/sdc1            961432072 767340216 145253856  85% /mnt/scr1
/dev/sdd1            961432072 853504864  59089208  94% /mnt/hdf
tmpfs                  8313628         0   8313628   0% /dev/shm
gumund:/data/ftp     480719104 380445824  75854080  84% /mnt/ftp
gumund:/data/web     480719104 380445824  75854080  84% /mnt/web
10.10.10.15:/volume1/hdf2
                     1437485440 238047232 1199335808  17% /mnt/hdf2
10.10.10.15:/volume1/hdf3
                     1437485440 238047232 1199335808  17% /mnt/hdf3
STANDARD_OPT=setenv MAKE gmake deploydir /mnt/scr1/pre-release/opa
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam
Running source repository checkout with output saved in
   /mnt/scr1/SnapTest/snapshots-opa/log/REPO_LOG_0827Thu
Checking MANIFEST file ...
cat: /mnt/scr1/SnapTest/snapshots-opa/log/#runtest.0827Thu.16834: No such file or directory
rm: cannot remove `/mnt/scr1/SnapTest/snapshots-opa/log/#runtest.0827Thu.16834': No such file or directory
*** launching tests from jam ***
TESTHOST is emu
jam
koala
platypus
ostrich
quail
kite
    Fork off timekeeper 12
Testing emu
ssh -o ConnectTimeout=60 emu -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname emu
 11:10pm  up 60 day(s),  8:14,  2 users,  load average: 0.01, 0.09, 0.74
/                  (rpool/ROOT/solaris):425734292 blocks 425734292 files
/devices           (/devices          ):       0 blocks        0 files
/dev               (/dev              ):       0 blocks        0 files
/system/contract   (ctfs              ):       0 blocks 2147483588 files
/proc              (proc              ):       0 blocks    29924 files
/etc/mnttab        (mnttab            ):       0 blocks        0 files
/system/volatile   (swap              ):11809216 blocks  2202599 files
/system/object     (objfs             ):       0 blocks 2147483465 files
/etc/dfs/sharetab  (sharefs           ):       0 blocks 2147483646 files
/dev/fd            (fd                ):       0 blocks        0 files
/var               (rpool/ROOT/solaris/var):425734292 blocks 425734292 files
/tmp               (swap              ):11809216 blocks  2202599 files
/var/share         (rpool/VARSHARE    ):425734292 blocks 425734292 files
/rpool             (rpool             ):425734292 blocks 425734292 files
/export            (rpool/export      ):425734292 blocks 425734292 files
/export/home       (rpool/export/home ):425734292 blocks 425734292 files
/export/home/kurz  (rpool/export/home/kurz):425734292 blocks 425734292 files
/home              (jam.ad.hdfgroup.org:/home):204042224 blocks 50170189 files
/mnt/hdf           (jam.ad.hdfgroup.org:/mnt/hdf):215854416 blocks 112073077 files
/mnt/scr1          (jam.ad.hdfgroup.org:/mnt/scr1):388183656 blocks 118083061 files
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/emu32 deploy emu32
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/emu32 deploy emu32 tests in emu ***
Uname -a: SunOS emu 5.11 11.1 sun4v sparc sun4v
Running snapshot with output saved in
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/emu32 deploy emu32 tests for emu ***
Total time = 0m 1s
*** finished tests in emu ***
****SYSTEM ERROR emu: Abnormal exit from runtest ****
	****SYSTEM ERROR emu: runtest command failed ****
Testing jam
ssh -o ConnectTimeout=60 jam -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname jam
 23:10:36 up 8 days, 10:07, 15 users,  load average: 0.73, 1.01, 0.75
/dev/sda2             31738420    393608  29706584   2% /tmp
/dev/sdc1            961432072 767340252 145253820  85% /mnt/scr1
Thu Aug 27 23:10:46 CDT 2015
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam tests in jam ***
Uname -a: Linux jam 2.6.18-308.13.1.el5PAE #1 SMP Tue Aug 21 17:50:26 EDT 2012 i686 i686 i386 GNU/Linux
   /mnt/scr1/SnapTest/snapshots-opa/log/jam_0827Thu_2310
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam tests for jam ***
Thu Aug 27 23:11:48 CDT 2015
Total time = 1m 2s
*** finished tests in jam ***
Testing koala
ssh -o ConnectTimeout=60 koala -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname koala
 23:10:38 up 1 day, 10:21,  1 user,  load average: 0.33, 0.16, 0.10
/dev/sda7             22292052   4443348  16698052  22% /
/dev/sda5             12192608    496456  11066808   5% /tmp
/dev/sda3             12192636   1157280  10406012  11% /var
/dev/sda1               101086     18614     77253  20% /boot
/dev/sdc1             41279536  26268976  12913680  68% /usr
/dev/sdb             152754284  72634820  72360004  51% /scr
tmpfs                  6149552         0   6149552   0% /dev/shm
10.10.10.86:/home    198351872  96330752  91783168  52% /home
10.10.10.86:/mnt/hdf 961432576 853505024  59089920  94% /mnt/hdf
10.10.10.86:/mnt/scr1
                     961432576 767340544 145254400  85% /mnt/scr1
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala
Thu Aug 27 23:10:48 CDT 2015
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala tests in koala ***
Uname -a: Linux koala 2.6.18-406.el5 #1 SMP Tue Jun 2 17:25:57 EDT 2015 x86_64 x86_64 x86_64 GNU/Linux
   /mnt/scr1/SnapTest/snapshots-opa/log/koala_0827Thu_2310
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala tests for koala ***
Thu Aug 27 23:11:21 CDT 2015
Total time = 0m 33s
*** finished tests in koala ***
Testing platypus
ssh -o ConnectTimeout=60 platypus -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname platypus
 23:10:57 up 42 days, 14:56,  4 users,  load average: 0.14, 0.66, 0.60
/dev/sda6             54205540  20976332  30469068  41% /
tmpfs                  6099128         0   6099128   0% /dev/shm
/dev/sda1               194241     48100    135901  27% /boot
/dev/sda2             12850716    153676  12037584   2% /tmp
/dev/sda3             12850716   3817244   8374016  32% /var
/dev/sdd             152623212  99296964  45566788  69% /scr
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus
Thu Aug 27 23:11:07 CDT 2015
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus tests in platypus ***
Uname -a: Linux platypus 2.6.32-504.16.2.el6.x86_64 #1 SMP Wed Apr 22 06:48:29 UTC 2015 x86_64 x86_64 x86_64 GNU/Linux
   /mnt/scr1/SnapTest/snapshots-opa/log/platypus_0827Thu_2311
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus tests for platypus ***
Thu Aug 27 23:11:49 CDT 2015
Total time = 0m 42s
*** finished tests in platypus ***
Testing ostrich
ssh -o ConnectTimeout=60 ostrich -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname ostrich
 23:11:03 up 50 days,  9:58,  1 user,  load average: 2.31, 5.84, 4.39
/dev/mapper/vg_ostrich-lv_root
                     140479384  18184452 115155888  14% /
tmpfs                  7821632         0   7821632   0% /dev/shm
/dev/sda2               487652     92973    369079  21% /boot
/dev/sdb2            124477364  83338624  34808988  71% /scr
jam:/home            198351872  96330752  91783168  52% /home
jam:/mnt/hdf         961432576 853505024  59089920  94% /mnt/hdf
jam:/mnt/scr1        961432576 767340544 145254400  85% /mnt/scr1
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich ; standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl
Thu Aug 27 23:11:13 CDT 2015
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich tests in ostrich ***
Uname -a: Linux ostrich 2.6.32-504.8.1.el6.ppc64 #1 SMP Fri Dec 19 12:10:45 EST 2014 ppc64 ppc64 ppc64 GNU/Linux
   /mnt/scr1/SnapTest/snapshots-opa/log/ostrich_0827Thu_2311
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich tests for ostrich ***
Thu Aug 27 23:12:47 CDT 2015
Total time = 1m 34s
*** starting standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl tests in ostrich ***
   /mnt/scr1/SnapTest/snapshots-opa/log/ostrich_0827Thu_2312
*** finished standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl tests for ostrich ***
Thu Aug 27 23:15:46 CDT 2015
Total time = 2m 59s
*** finished tests in ostrich ***
Testing quail
ssh -o ConnectTimeout=60 quail -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname quail
23:10  up 1 day, 10:58, 1 user, load averages: 1.70 1.52 1.40
Filesystem                    512-blocks       Used Available Capacity  iused     ifree %iused  Mounted on
/dev/disk0s2                   488555536  171744720 316298816    36% 21532088  39537352   35%   /
devfs                                360        360         0   100%      624         0  100%   /dev
map auto_nfs                           0          0         0   100%        0         0  100%   /home
map auto_nfs                           0          0         0   100%        0         0  100%   /mnt/hdf
map auto_nfs                           0          0         0   100%        0         0  100%   /mnt/scr1
jam.ad.hdfgroup.org:/mnt/hdf  1922864144 1707009728 118178416    94% 10036875 112073077    8%   /mnt/hdf
jam.ad.hdfgroup.org:/home      396703680  192661456 183565504    52%  1046195  50170189    2%   /home
jam.ad.hdfgroup.org:/mnt/scr1 1922864144 1534680576 290507568    85%  4026902 118083050    3%   /mnt/scr1
TEST_TYPES=standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/quail deploy quail
Thu Aug 27 23:10:58 CDT 2015
*** starting standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/quail deploy quail tests in quail ***
Uname -a: Darwin quail.ad.hdfgroup.org 13.4.0 Darwin Kernel Version 13.4.0: Wed Mar 18 16:20:14 PDT 2015; root:xnu-2422.115.14~1/RELEASE_X86_64 x86_64
   /Users/hdftest/snapshots-opa/log/quail_0827Thu_2310
*** finished standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/quail deploy quail tests for quail ***
Thu Aug 27 23:11:52 CDT 2015
Total time = 0m 54s
*** finished tests in quail ***
Testing kite
ssh -o ConnectTimeout=60 kite -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname kite
23:10  up 1 day, 10:38, 1 user, load averages: 0.08 0.28 0.31
/dev/disk1s2          1951845952  210345232 1740988720    11% 26357152 217623590   11%   /
devfs                        372        372          0   100%      645         0  100%   /dev
/dev/disk0s2          1952853344    1296640 1951556704     1%   162078 243944588    0%   /Volumes/Milvinae
10.10.10.86:/mnt/hdf  1922864144 1707009728  118178416    94% 10036875 112073077    8%   /mnt/hdf
10.10.10.86:/mnt/scr1 1922864144 1534680632  290507512    85%  4026907 118083045    3%   /mnt/scr1
10.10.10.86:/home      396703680  192661456  183565504    52%  1046195  50170189    2%   /mnt/home
TEST_TYPES=standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/kite deploy kite
Thu Aug 27 23:11:00 CDT 2015
*** starting standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/kite deploy kite tests in kite ***
Uname -a: Darwin kite.ad.hdfgroup.org 12.6.0 Darwin Kernel Version 12.6.0: Wed Mar 18 16:23:48 PDT 2015; root:xnu-2050.48.19~1/RELEASE_X86_64 x86_64
   /Users/hdftest/snapshots-opa/log/kite_0827Thu_2311
*** finished standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/kite deploy kite tests for kite ***
Total time = 0m 48s
*** finished tests in kite ***
More information about the opa-nightly-tests mailing list
