[opa-nightly-tests] jam OPA_Daily_Tests_0826Wed_FAILED!!!
HDF Tester
hdftest at hdfgroup.org
Wed Aug 26 23:41:32 CDT 2015
*** OPA Tests on 0826Wed ***
Tests Summary
****FAILED emu: setenvN 2 CC cc -m64 op-configure --prefix=/mnt/scr1/pre-release/opa/emu64 deploy emu64****
PASSED jam: standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam
PASSED kite: standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/kite deploy kite
PASSED koala: standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala
PASSED ostrich: standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich
PASSED ostrich: standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl
PASSED platypus: standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus
PASSED quail: standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/quail deploy quail
Tests Time Summary
emu: Ran 1(0/1/0) tests, Grand total test time = 0m 2s
koala: Ran 1(1/0/0) tests, Grand total test time = 0m 33s
platypus: Ran 1(1/0/0) tests, Grand total test time = 0m 42s
kite: Ran 1(1/0/0) tests, Grand total test time = 0m 48s
jam: Ran 1(1/0/0) tests, Grand total test time = 1m 1s
quail: Ran 1(1/0/0) tests, Grand total test time = 0m 55s
ostrich: Ran 2(2/0/0) tests, Grand total test time = 4m 48s
jam: Ran 7(0/0/0) hosts, Grand total test time = 6m 1s
Timekeeper log
Timekeeper started at Wed Aug 26 23:35:48 CDT 2015
Timekeeper sleeping for 720 seconds
Tests Failures
Dumping logfile of emu: setenvN 2 CC cc -m64 op-configure --prefix=/mnt/scr1/pre-release/opa/emu64 deploy emu64
Last 50 lines of /mnt/scr1/SnapTest/snapshots-opa/log/emu_0826Wed_2335
GROUP=hdf
HDF5_ACLOCAL=/mnt/hdf/packages/AUTOTOOLS/automake/1.15/sun4v/bin/aclocal-1.15
HDF5_AUTOCONF=/mnt/hdf/packages/AUTOTOOLS/autoconf/2.69/sun4v/bin/autoconf
HDF5_AUTOHEADER=/mnt/hdf/packages/AUTOTOOLS/autoconf/2.69/sun4v/bin/autoheader
HDF5_AUTOMAKE=/mnt/hdf/packages/AUTOTOOLS/automake/1.15/sun4v/bin/automake-1.15
HDF5_LIBTOOL=/mnt/hdf/packages/AUTOTOOLS/libtool/2.4.5/sun4v/bin/libtool
HDF5_M4=/mnt/hdf/packages/AUTOTOOLS/m4/1.4.17/sun4v/bin/m4
HDF5TestExpress=yes
HOME=/home/hdftest
HOST=emu
HOSTTYPE=sun4
JAVA_HOME=/usr/lib/jvm/jre-1.6.0
LANG=en_US.UTF-8
LC_ALL=
LC_COLLATE=
LC_CTYPE=
LC_MESSAGES=
LC_MONETARY=
LC_NUMERIC=
LC_TIME=
LOGNAME=hdftest
MACHTYPE=sparc
MAIL=/var/mail/hdftest
MAKE=gmake
NLSPATH=/usr/share/locale/%L/LC_MESSAGES/%N.cat
OSTYPE=solaris
PATH=/home/hdftest/bin:/usr/hdf/bin:/home/hdftest/bin:/usr/hdf/bin:/usr/bin:/usr/sbin:/opt/solarisstudio/bin:/opt/cmake/bin:/opt/svn/bin:/mnt/hdf/ec2-api-tools/bin
PWD=/mnt/scr1/SnapTest/snapshots-opa
REMOTEHOST=
SET_PATH=yes
SHELL=/bin/tcsh
SHLVL=3
SSH_CLIENT=10.10.10.86 45415 22
SSH_CONNECTION=10.10.10.86 45415 10.10.10.84 22
SVNROOT=http://svn.hdfgroup.uiuc.edu
TZ=localtime
USER=hdftest
VENDOR=sun
===Done Dumping environment variables after option parsing ===
===== Run Tests: Wednesday, August 26, 2015 11:35:40 PM CDT =====
Remove contents of emu.
diff: /home/hdftest/snapshots-opa/previous/MANIFEST: No such file or directory
===== configure: Wednesday, August 26, 2015 11:35:40 PM CDT =====
checking for a BSD-compatible install... /usr/bin/ginstall -c
checking whether build environment is sane... configure: error: newly created file is older than distributed files!
Check your system clock
Failed running configure
===== Exit bin/snapshot with status=1: Wednesday, August 26, 2015 11:35:41 PM CDT =====
Dumping done
Runtest did not exit normally.
Watchers List
OPA Daily test features/platforms watchers and procedure
Procedure:
The watcher will investigate and report the cause of failure by 11am.
The developer who checked in the error code may report so by then too.
The watcher or the developer should get the failure fixed and report it
by 3pm.
Watcher for OPA: Neil
updated: 2009/05/05
Tests Details
23:35:21 up 7 days, 10:31, 22 users, load average: 4.55, 3.71, 2.97
Filesystem 1K-blocks Used Available Use% Mounted on
/dev/sda3 31738420 8783220 21316972 30% /
/dev/sda1 101086 17532 78335 19% /boot
/dev/sda2 31738420 376960 29723232 2% /tmp
/dev/sda6 31738392 5516396 24583772 19% /var
/dev/sda7 31738392 18480532 11619636 62% /usr
/dev/sda8 124991068 264372 118274996 1% /var/tmp
/dev/mapper/VolGroup00-home
198351840 81686416 106427064 44% /home
/dev/sde1 565688764 426567540 109922288 80% /scr
/dev/sdc1 961432072 769090716 143503356 85% /mnt/scr1
/dev/sdd1 961432072 840071188 72522884 93% /mnt/hdf
tmpfs 8313628 0 8313628 0% /dev/shm
gumund:/data/ftp 480719104 380445312 75854592 84% /mnt/ftp
gumund:/data/web 480719104 380445312 75854592 84% /mnt/web
10.10.10.15:/volume1/hdf2
1437485440 238047232 1199335808 17% /mnt/hdf2
10.10.10.15:/volume1/hdf3
1437485440 238047232 1199335808 17% /mnt/hdf3
STANDARD_OPT=setenv MAKE gmake deploydir /mnt/scr1/pre-release/opa
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam
Running source repository checkout with output saved in
/mnt/scr1/SnapTest/snapshots-opa/log/REPO_LOG_0826Wed
Checking MANIFEST file ...
cat: /mnt/scr1/SnapTest/snapshots-opa/log/#runtest.0826Wed.3176: No such file or directory
rm: cannot remove `/mnt/scr1/SnapTest/snapshots-opa/log/#runtest.0826Wed.3176': No such file or directory
*** launching tests from jam ***
TESTHOST is emu
jam
koala
platypus
ostrich
quail
kite
Fork off timekeeper 12
Testing emu
ssh -o ConnectTimeout=60 emu -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname emu
11:35pm up 59 day(s), 8:40, 3 users, load average: 0.31, 0.79, 1.26
/ (rpool/ROOT/solaris):429883410 blocks 429883410 files
/devices (/devices ): 0 blocks 0 files
/dev (/dev ): 0 blocks 0 files
/system/contract (ctfs ): 0 blocks 2147483587 files
/proc (proc ): 0 blocks 29914 files
/etc/mnttab (mnttab ): 0 blocks 0 files
/system/volatile (swap ):22479952 blocks 2202954 files
/system/object (objfs ): 0 blocks 2147483465 files
/etc/dfs/sharetab (sharefs ): 0 blocks 2147483646 files
/dev/fd (fd ): 0 blocks 0 files
/var (rpool/ROOT/solaris/var):429883410 blocks 429883410 files
/tmp (swap ):22479952 blocks 2202954 files
/var/share (rpool/VARSHARE ):429883410 blocks 429883410 files
/rpool (rpool ):429883410 blocks 429883410 files
/export (rpool/export ):429883410 blocks 429883410 files
/export/home (rpool/export/home ):429883410 blocks 429883410 files
/export/home/kurz (rpool/export/home/kurz):429883410 blocks 429883410 files
/home (jam.ad.hdfgroup.org:/home):233330848 blocks 49860108 files
/mnt/hdf (jam.ad.hdfgroup.org:/mnt/hdf):242721768 blocks 112167005 files
/mnt/scr1 (jam.ad.hdfgroup.org:/mnt/scr1):384682656 blocks 118078007 files
TEST_TYPES=setenvN 2 CC cc -m64 op-configure --prefix=/mnt/scr1/pre-release/opa/emu64 deploy emu64
Wednesday, August 26, 2015 11:35:39 PM CDT
*** starting setenvN 2 CC cc -m64 op-configure --prefix=/mnt/scr1/pre-release/opa/emu64 deploy emu64 tests in emu ***
Uname -a: SunOS emu 5.11 11.1 sun4v sparc sun4v
Running snapshot with output saved in
*** finished setenvN 2 CC cc -m64 op-configure --prefix=/mnt/scr1/pre-release/opa/emu64 deploy emu64 tests for emu ***
Total time = 0m 2s
*** finished tests in emu ***
****SYSTEM ERROR emu: Abnormal exit from runtest ****
****SYSTEM ERROR emu: runtest command failed ****
Testing jam
ssh -o ConnectTimeout=60 jam -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname jam
23:35:55 up 7 days, 10:32, 22 users, load average: 4.77, 3.86, 3.04
/dev/sda2 31738420 377068 29723124 2% /tmp
/dev/sda6 31738392 5516400 24583768 19% /var
/dev/sdc1 961432072 769090752 143503320 85% /mnt/scr1
Wed Aug 26 23:36:06 CDT 2015
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam tests in jam ***
Uname -a: Linux jam 2.6.18-308.13.1.el5PAE #1 SMP Tue Aug 21 17:50:26 EDT 2012 i686 i686 i386 GNU/Linux
/mnt/scr1/SnapTest/snapshots-opa/log/jam_0826Wed_2336
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam tests for jam ***
Wed Aug 26 23:37:06 CDT 2015
Total time = 1m 0s
*** finished tests in jam ***
Testing koala
ssh -o ConnectTimeout=60 koala -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname koala
23:35:58 up 10:46, 1 user, load average: 0.00, 0.01, 0.00
/dev/sda7 22292052 4429488 16711912 21% /
/dev/sda5 12192608 388572 11174692 4% /tmp
/dev/sda3 12192636 1225348 10337944 11% /var
/dev/sda1 101086 18614 77253 20% /boot
/dev/sdc1 41279536 26254628 12928028 68% /usr
/dev/sdb 152754284 72616444 72378380 51% /scr
tmpfs 6149552 0 6149552 0% /dev/shm
10.10.10.86:/home 198351872 81685504 106427392 44% /home
10.10.10.86:/mnt/hdf 961432576 840071168 72523776 93% /mnt/hdf
10.10.10.86:/mnt/scr1
961432576 769090560 143503360 85% /mnt/scr1
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala
Wed Aug 26 23:36:08 CDT 2015
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala tests in koala ***
Uname -a: Linux koala 2.6.18-406.el5 #1 SMP Tue Jun 2 17:25:57 EDT 2015 x86_64 x86_64 x86_64 GNU/Linux
/mnt/scr1/SnapTest/snapshots-opa/log/koala_0826Wed_2336
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala tests for koala ***
Wed Aug 26 23:36:41 CDT 2015
Total time = 0m 33s
*** finished tests in koala ***
Testing platypus
ssh -o ConnectTimeout=60 platypus -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname platypus
23:36:10 up 41 days, 15:21, 6 users, load average: 0.00, 0.36, 1.53
/dev/sda6 54205540 20975956 30469444 41% /
tmpfs 6099128 0 6099128 0% /dev/shm
/dev/sda1 194241 48100 135901 27% /boot
/dev/sda2 12850716 180928 12010332 2% /tmp
/dev/sda3 12850716 3714036 8477224 31% /var
/dev/sdd 152623212 96380508 48483244 67% /scr
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus
Wed Aug 26 23:36:20 CDT 2015
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus tests in platypus ***
Uname -a: Linux platypus 2.6.32-504.16.2.el6.x86_64 #1 SMP Wed Apr 22 06:48:29 UTC 2015 x86_64 x86_64 x86_64 GNU/Linux
/mnt/scr1/SnapTest/snapshots-opa/log/platypus_0826Wed_2336
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus tests for platypus ***
Wed Aug 26 23:37:02 CDT 2015
Total time = 0m 42s
*** finished tests in platypus ***
Testing ostrich
ssh -o ConnectTimeout=60 ostrich -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname ostrich
23:36:22 up 49 days, 10:24, 1 user, load average: 1.26, 0.87, 1.43
/dev/mapper/vg_ostrich-lv_root
140479384 16567728 116772612 13% /
tmpfs 7821632 0 7821632 0% /dev/shm
/dev/sda2 487652 92973 369079 21% /boot
/dev/sdb2 124477364 82665196 35482416 70% /scr
jam:/home 198351872 81685504 106427392 44% /home
jam:/mnt/hdf 961432576 840071168 72523776 93% /mnt/hdf
jam:/mnt/scr1 961432576 769090560 143503360 85% /mnt/scr1
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich ; standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl
Wed Aug 26 23:36:32 CDT 2015
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich tests in ostrich ***
Uname -a: Linux ostrich 2.6.32-504.8.1.el6.ppc64 #1 SMP Fri Dec 19 12:10:45 EST 2014 ppc64 ppc64 ppc64 GNU/Linux
/mnt/scr1/SnapTest/snapshots-opa/log/ostrich_0826Wed_2336
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich tests for ostrich ***
Wed Aug 26 23:38:13 CDT 2015
Total time = 1m 41s
Wed Aug 26 23:38:14 CDT 2015
*** starting standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl tests in ostrich ***
/mnt/scr1/SnapTest/snapshots-opa/log/ostrich_0826Wed_2338
*** finished standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl tests for ostrich ***
Wed Aug 26 23:41:20 CDT 2015
Total time = 3m 7s
*** finished tests in ostrich ***
Testing quail
ssh -o ConnectTimeout=60 quail -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname quail
23:36 up 11:23, 3 users, load averages: 1.25 1.34 1.33
Filesystem 512-blocks Used Available Capacity iused ifree %iused Mounted on
/dev/disk0s2 488555536 169812752 318230784 35% 21290592 39778848 35% /
devfs 363 363 0 100% 628 0 100% /dev
map auto_nfs 0 0 0 100% 0 0 100% /home
map auto_nfs 0 0 0 100% 0 0 100% /mnt/hdf
map auto_nfs 0 0 0 100% 0 0 100% /mnt/scr1
jam.ad.hdfgroup.org:/mnt/hdf 1922864144 1680142376 145045768 93% 9942947 112167005 8% /mnt/hdf
jam.ad.hdfgroup.org:/mnt/scr1 1922864144 1538181576 287006568 85% 4031956 118077996 3% /mnt/scr1
jam.ad.hdfgroup.org:/home 396703680 163372832 212854128 44% 1356276 49860108 3% /home
TEST_TYPES=standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/quail deploy quail
Wed Aug 26 23:36:16 CDT 2015
*** starting standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/quail deploy quail tests in quail ***
Uname -a: Darwin quail.ad.hdfgroup.org 13.4.0 Darwin Kernel Version 13.4.0: Wed Mar 18 16:20:14 PDT 2015; root:xnu-2422.115.14~1/RELEASE_X86_64 x86_64
/Users/hdftest/snapshots-opa/log/quail_0826Wed_2336
*** finished standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/quail deploy quail tests for quail ***
Wed Aug 26 23:37:11 CDT 2015
Total time = 0m 55s
*** finished tests in quail ***
Testing kite
ssh -o ConnectTimeout=60 kite -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname kite
23:36 up 11:03, 0 users, load averages: 0.11 0.08 0.18
/dev/disk1s2 1951845952 220119648 1731214304 12% 27578954 216401788 11% /
devfs 372 372 0 100% 644 0 100% /dev
/dev/disk0s2 1952853344 1296640 1951556704 1% 162078 243944588 0% /Volumes/Milvinae
10.10.10.86:/mnt/hdf 1922864144 1680142376 145045768 93% 9942947 112167005 8% /mnt/hdf
10.10.10.86:/mnt/scr1 1922864144 1538181632 287006512 85% 4031961 118077991 3% /mnt/scr1
10.10.10.86:/home 396703680 163372832 212854128 44% 1356276 49860108 3% /mnt/home
TEST_TYPES=standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/kite deploy kite
Wed Aug 26 23:36:18 CDT 2015
*** starting standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/kite deploy kite tests in kite ***
Uname -a: Darwin kite.ad.hdfgroup.org 12.6.0 Darwin Kernel Version 12.6.0: Wed Mar 18 16:23:48 PDT 2015; root:xnu-2050.48.19~1/RELEASE_X86_64 x86_64
/Users/hdftest/snapshots-opa/log/kite_0826Wed_2336
*** finished standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/kite deploy kite tests for kite ***
Total time = 0m 48s
*** finished tests in kite ***
More information about the opa-nightly-tests
