[opa-nightly-tests] jam OPA_Daily_Tests_0825Tue_FAILED!!!
HDF Tester hdftest at hdfgroup.org
Tue Aug 25 23:44:53 CDT 2015
*** OPA Tests on 0825Tue ***
   Tests Summary
****FAILED emu: standard op-configure --prefix=/mnt/scr1/pre-release/opa/emu32 deploy emu32****
****FAILED quail: standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/quail deploy quail****
PASSED jam: standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam
PASSED kite: standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/kite deploy kite
PASSED koala: standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala
PASSED ostrich: standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich
PASSED ostrich: standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl
PASSED platypus: standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus
   Tests Time Summary
emu: Ran 1(0/1/0) tests, Grand total test time =  0m 5s
quail: Ran 1(0/1/0) tests, Grand total test time =  0m 3s
koala: Ran 1(1/0/0) tests, Grand total test time =  0m 38s
platypus: Ran 1(1/0/0) tests, Grand total test time =  0m 46s
jam: Ran 1(1/0/0) tests, Grand total test time =  1m 2s
kite: Ran 1(1/0/0) tests, Grand total test time =  0m 54s
ostrich: Ran 2(2/0/0) tests, Grand total test time =  4m 59s
jam: Ran 7(0/0/0) hosts, Grand total test time =  6m 7s
   Timekeeper log
Timekeeper started at Tue Aug 25 23:38:58 CDT 2015
Timekeeper sleeping for 720 seconds
   Tests Failures
Dumping logfile of emu: standard op-configure --prefix=/mnt/scr1/pre-release/opa/emu32 deploy emu32
Last 50 lines of /mnt/scr1/SnapTest/snapshots-opa/log/emu_0825Tue_2338
GROUP=hdf
HDF5_ACLOCAL=/mnt/hdf/packages/AUTOTOOLS/automake/1.15/sun4v/bin/aclocal-1.15
HDF5_AUTOCONF=/mnt/hdf/packages/AUTOTOOLS/autoconf/2.69/sun4v/bin/autoconf
HDF5_AUTOHEADER=/mnt/hdf/packages/AUTOTOOLS/autoconf/2.69/sun4v/bin/autoheader
HDF5_AUTOMAKE=/mnt/hdf/packages/AUTOTOOLS/automake/1.15/sun4v/bin/automake-1.15
HDF5_LIBTOOL=/mnt/hdf/packages/AUTOTOOLS/libtool/2.4.5/sun4v/bin/libtool
HDF5_M4=/mnt/hdf/packages/AUTOTOOLS/m4/1.4.17/sun4v/bin/m4
HDF5TestExpress=yes
HOME=/home/hdftest
HOST=emu
HOSTTYPE=sun4
JAVA_HOME=/usr/lib/jvm/jre-1.6.0
LANG=en_US.UTF-8
LC_ALL=
LC_COLLATE=
LC_CTYPE=
LC_MESSAGES=
LC_MONETARY=
LC_NUMERIC=
LC_TIME=
LOGNAME=hdftest
MACHTYPE=sparc
MAIL=/var/mail/hdftest
MAKE=gmake
NLSPATH=/usr/share/locale/%L/LC_MESSAGES/%N.cat
OSTYPE=solaris
PATH=/home/hdftest/bin:/usr/hdf/bin:/home/hdftest/bin:/usr/hdf/bin:/usr/bin:/usr/sbin:/opt/solarisstudio/bin:/opt/cmake/bin:/opt/svn/bin:/mnt/hdf/ec2-api-tools/bin
PWD=/mnt/scr1/SnapTest/snapshots-opa
REMOTEHOST=
SET_PATH=yes
SHELL=/bin/tcsh
SHLVL=3
SSH_CLIENT=10.10.10.86 36008 22
SSH_CONNECTION=10.10.10.86 36008 10.10.10.84 22
SVNROOT=http://svn.hdfgroup.uiuc.edu
TZ=localtime
USER=hdftest
VENDOR=sun
===Done Dumping environment variables after option parsing ===
===== Run Tests: Tuesday, August 25, 2015 11:38:50 PM CDT =====
Remove contents of emu.
diff: /home/hdftest/snapshots-opa/previous/MANIFEST: No such file or directory
===== configure: Tuesday, August 25, 2015 11:38:50 PM CDT =====
checking for a BSD-compatible install... /usr/bin/ginstall -c
checking whether build environment is sane... configure: error: newly created file is older than distributed files!
Check your system clock
Failed running configure
===== Exit bin/snapshot with status=1: Tuesday, August 25, 2015 11:38:52 PM CDT =====
Dumping done
Dumping logfile of quail: standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/quail deploy quail
Last 50 lines of /Users/hdftest/snapshots-opa/log/quail_0825Tue_2338
TMPDIR=/var/folders/z6/3ppqwg7d6391tvvxflm75638000ts5/T/
USER=hdftest
VENDOR=apple
_=/usr/bin/printenv
===Done Dumping environment variables before option parsing ===
===Dumping environment variables after option parsing ===
CCACHE_DISABLE=yes
GROUP=HDF\hdf
HDF5TestExpress=yes
HDF5_ACLOCAL=/mnt/hdf/packages/AUTOTOOLS/automake/1.15/Darwin/bin/aclocal-1.15
HDF5_AUTOCONF=/mnt/hdf/packages/AUTOTOOLS/autoconf/2.69/Darwin/bin/autoconf
HDF5_AUTOHEADER=/mnt/hdf/packages/AUTOTOOLS/autoconf/2.69/Darwin/bin/autoheader
HDF5_AUTOMAKE=/mnt/hdf/packages/AUTOTOOLS/automake/1.15/Darwin/bin/automake-1.15
HDF5_LIBTOOL=/mnt/hdf/packages/AUTOTOOLS/libtool/2.4.5/Darwin/bin/libtool
HOME=/Users/hdftest
HOST=quail.ad.hdfgroup.org
HOSTTYPE=intel-mac
LANG=en_US.UTF-8
LOGNAME=hdftest
MACHTYPE=x86_64
MAKE=gnumake
OSTYPE=darwin
PATH=/usr/hdf/bin:/usr/bin:/bin:/usr/sbin:/sbin:/usr/local/bin:/opt/X11/bin
PWD=/Users/hdftest/snapshots-opa
REMOTEHOST=
SET_PATH=yes
SHELL=/bin/tcsh
SHLVL=3
SSH_CLIENT=10.10.10.86 50744 22
SSH_CONNECTION=10.10.10.86 50744 10.10.10.105 22
USER=hdftest
VENDOR=apple
_=/usr/bin/printenv
===== Run Tests: Tue Aug 25 23:38:45 CDT 2015 =====
Remove contents of quail.
/usr/bin/diff: /Users/hdftest/snapshots-opa/previous/MANIFEST: No such file or directory
/usr/bin/diff: /Users/hdftest/snapshots-opa/current/MANIFEST: No such file or directory
===== configure: Tue Aug 25 23:38:45 CDT 2015 =====
checking for a BSD-compatible install... /usr/bin/install -c
===== Exit bin/snapshot with status=1: Tue Aug 25 23:38:47 CDT 2015 =====
Dumping done
Runtest did not exit normally.
   Watchers List
OPA Daily test features/platforms watchers and procedure
Procedure:
The watcher will investigate and report the cause of failure by 11am.
The developer who checked in the error code may report so by then too.
The watcher or the developer should get the failure fixed and report it
by 3pm.
Watcher for OPA:	 	Neil
updated: 2009/05/05
   Tests Details
 23:38:36 up 6 days, 10:35, 18 users,  load average: 1.41, 0.94, 0.81
Filesystem           1K-blocks      Used Available Use% Mounted on
/dev/sda3             31738420   8768836  21331356  30% /
/dev/sda1               101086     17532     78335  19% /boot
/dev/sda2             31738420    320056  29780136   2% /tmp
/dev/sda6             31738392   5486420  24613748  19% /var
/dev/sda7             31738392  18480532  11619636  62% /usr
/dev/sda8            124991068    264372 118274996   1% /var/tmp
/dev/mapper/VolGroup00-home
                     198351840  59063340 129050140  32% /home
/dev/sde1            565688764 424966532 111523296  80% /scr
/dev/sdc1            961432072 876038340  36555732  96% /mnt/scr1
/dev/sdd1            961432072 848860456  63733616  94% /mnt/hdf
tmpfs                  8313628         0   8313628   0% /dev/shm
gumund:/data/ftp     480719104 380445312  75854592  84% /mnt/ftp
gumund:/data/web     480719104 380445312  75854592  84% /mnt/web
10.10.10.15:/volume1/hdf2
                     1437485440 127517056 1309865984   9% /mnt/hdf2
10.10.10.15:/volume1/hdf3
                     1437485440 127517056 1309865984   9% /mnt/hdf3
STANDARD_OPT=setenv MAKE gmake deploydir /mnt/scr1/pre-release/opa
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam
Running source repository checkout with output saved in
   /mnt/scr1/SnapTest/snapshots-opa/log/REPO_LOG_0825Tue
Checking MANIFEST file ...
cat: /mnt/scr1/SnapTest/snapshots-opa/log/#runtest.0825Tue.16314: No such file or directory
rm: cannot remove `/mnt/scr1/SnapTest/snapshots-opa/log/#runtest.0825Tue.16314': No such file or directory
*** launching tests from jam ***
TESTHOST is emu
jam
koala
platypus
ostrich
quail
kite
    Fork off timekeeper 12
Testing emu
ssh -o ConnectTimeout=60 emu -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname emu
 11:38pm  up 58 day(s),  8:43,  2 users,  load average: 0.01, 0.01, 0.18
/                  (rpool/ROOT/solaris):429759431 blocks 429759431 files
/devices           (/devices          ):       0 blocks        0 files
/dev               (/dev              ):       0 blocks        0 files
/system/contract   (ctfs              ):       0 blocks 2147483588 files
/proc              (proc              ):       0 blocks    29921 files
/etc/mnttab        (mnttab            ):       0 blocks        0 files
/system/volatile   (swap              ):11389648 blocks  2203373 files
/system/object     (objfs             ):       0 blocks 2147483465 files
/etc/dfs/sharetab  (sharefs           ):       0 blocks 2147483646 files
/dev/fd            (fd                ):       0 blocks        0 files
/var               (rpool/ROOT/solaris/var):429759431 blocks 429759431 files
/tmp               (swap              ):11389648 blocks  2203373 files
/var/share         (rpool/VARSHARE    ):429759431 blocks 429759431 files
/rpool             (rpool             ):429759431 blocks 429759431 files
/export            (rpool/export      ):429759431 blocks 429759431 files
/export/home       (rpool/export/home ):429759431 blocks 429759431 files
/export/home/kurz  (rpool/export/home/kurz):429759431 blocks 429759431 files
/home              (jam.ad.hdfgroup.org:/home):278577000 blocks 50518648 files
/mnt/hdf           (jam.ad.hdfgroup.org:/mnt/hdf):225143232 blocks 111961245 files
/mnt/scr1          (jam.ad.hdfgroup.org:/mnt/scr1):170787408 blocks 118076697 files
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/emu32 deploy emu32
Tuesday, August 25, 2015 11:38:49 PM CDT
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/emu32 deploy emu32 tests in emu ***
Uname -a: SunOS emu 5.11 11.1 sun4v sparc sun4v
Running snapshot with output saved in
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/emu32 deploy emu32 tests for emu ***
Total time = 0m 3s
*** finished tests in emu ***
****SYSTEM ERROR emu: Abnormal exit from runtest ****
	****SYSTEM ERROR emu: runtest command failed ****
Testing jam
ssh -o ConnectTimeout=60 jam -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname jam
 23:39:05 up 6 days, 10:35, 18 users,  load average: 1.35, 0.96, 0.82
/dev/sda2             31738420    320164  29780028   2% /tmp
/dev/sda6             31738392   5486516  24613652  19% /var
/dev/sdc1            961432072 876038376  36555696  96% /mnt/scr1
Tue Aug 25 23:39:16 CDT 2015
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam tests in jam ***
Uname -a: Linux jam 2.6.18-308.13.1.el5PAE #1 SMP Tue Aug 21 17:50:26 EDT 2012 i686 i686 i386 GNU/Linux
   /mnt/scr1/SnapTest/snapshots-opa/log/jam_0825Tue_2339
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/jam deploy jam tests for jam ***
Tue Aug 25 23:40:17 CDT 2015
Total time = 1m 1s
*** finished tests in jam ***
Testing koala
ssh -o ConnectTimeout=60 koala -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname koala
 23:39:08 up 57 days, 14:48,  1 user,  load average: 0.00, 0.18, 0.82
/dev/sda7             22292052   4428184  16713216  21% /
/dev/sda5             12192608    406840  11156424   4% /tmp
/dev/sda3             12192636   1135440  10427852  10% /var
/dev/sda1               101086     18614     77253  20% /boot
/dev/sdc1             41279536  26230136  12952520  67% /usr
/dev/sdb             152754284  72606700  72388124  51% /scr
tmpfs                  6149552         0   6149552   0% /dev/shm
10.10.10.86:/mnt/hdf 961432576 848860160  63733760  94% /mnt/hdf
10.10.10.86:/mnt/scr1
                     961432576 876038144  36555776  96% /mnt/scr1
10.10.10.86:/home    198351872  59063296 129050624  32% /home
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala
Tue Aug 25 23:39:18 CDT 2015
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala tests in koala ***
Uname -a: Linux koala 2.6.18-402.el5 #1 SMP Tue Feb 10 17:49:04 EST 2015 x86_64 x86_64 x86_64 GNU/Linux
   /mnt/scr1/SnapTest/snapshots-opa/log/koala_0825Tue_2339
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/koala deploy koala tests for koala ***
Tue Aug 25 23:39:56 CDT 2015
Total time = 0m 38s
*** finished tests in koala ***
Testing platypus
ssh -o ConnectTimeout=60 platypus -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname platypus
 23:39:14 up 40 days, 15:24,  1 user,  load average: 0.00, 0.08, 0.30
/dev/sda6             54205540  20969680  30475720  41% /
tmpfs                  6099128         0   6099128   0% /dev/shm
/dev/sda1               194241     48100    135901  27% /boot
/dev/sda2             12850716    154120  12037140   2% /tmp
/dev/sda3             12850716   3643804   8547456  30% /var
/dev/sdd             152623212  98444940  46418812  68% /scr
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus
Tue Aug 25 23:39:24 CDT 2015
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus tests in platypus ***
Uname -a: Linux platypus 2.6.32-504.16.2.el6.x86_64 #1 SMP Wed Apr 22 06:48:29 UTC 2015 x86_64 x86_64 x86_64 GNU/Linux
   /mnt/scr1/SnapTest/snapshots-opa/log/platypus_0825Tue_2339
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/platypus deploy platypus tests for platypus ***
Tue Aug 25 23:40:10 CDT 2015
Total time = 0m 46s
*** finished tests in platypus ***
Testing ostrich
ssh -o ConnectTimeout=60 ostrich -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname ostrich
 23:39:31 up 48 days, 10:27,  0 users,  load average: 11.34, 10.99, 10.68
/dev/mapper/vg_ostrich-lv_root
                     140479384  16557880 116782460  13% /
tmpfs                  7821632         0   7821632   0% /dev/shm
/dev/sda2               487652     92973    369079  21% /boot
/dev/sdb2            124477364  82820940  35326672  71% /scr
jam:/home            198351872  59063296 129050624  32% /home
jam:/mnt/hdf         961432576 848860160  63733760  94% /mnt/hdf
jam:/mnt/scr1        961432576 876038144  36555776  96% /mnt/scr1
TEST_TYPES=standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich ; standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl
Tue Aug 25 23:39:41 CDT 2015
*** starting standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich tests in ostrich ***
Uname -a: Linux ostrich 2.6.32-504.8.1.el6.ppc64 #1 SMP Fri Dec 19 12:10:45 EST 2014 ppc64 ppc64 ppc64 GNU/Linux
   /mnt/scr1/SnapTest/snapshots-opa/log/ostrich_0825Tue_2339
*** finished standard op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrich tests for ostrich ***
Tue Aug 25 23:41:30 CDT 2015
Total time = 1m 49s
*** starting standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl tests in ostrich ***
   /mnt/scr1/SnapTest/snapshots-opa/log/ostrich_0825Tue_2341
*** finished standard setenv CC /opt/xl/current/xlc op-configure --prefix=/mnt/scr1/pre-release/opa/ostrich deploy ostrichxl tests for ostrich ***
Tue Aug 25 23:44:40 CDT 2015
Total time = 3m 10s
*** finished tests in ostrich ***
Testing quail
ssh -o ConnectTimeout=60 quail -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname quail
23:38  up 7 days, 12:21, 1 user, load averages: 1.31 1.29 1.31
Filesystem                    512-blocks       Used Available Capacity  iused     ifree %iused  Mounted on
/dev/disk0s2                   488555536  167886096 320157440    35% 21049760  40019680   34%   /
devfs                                369        369         0   100%      639         0  100%   /dev
map auto_nfs                           0          0         0   100%        0         0  100%   /home
map auto_nfs                           0          0         0   100%        0         0  100%   /mnt/hdf
map auto_nfs                           0          0         0   100%        0         0  100%   /mnt/scr1
jam.ad.hdfgroup.org:/home      396703680  118126680 258100280    32%   697736  50518648    1%   /home
jam.ad.hdfgroup.org:/mnt/hdf  1922864144 1697720912 127467232    94% 10148707 111961245    8%   /mnt/hdf
jam.ad.hdfgroup.org:/mnt/scr1 1922864144 1752076848  73111296    96%  4033267 118076685    3%   /mnt/scr1
TEST_TYPES=standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/quail deploy quail
*** starting standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/quail deploy quail tests in quail ***
Uname -a: Darwin quail.ad.hdfgroup.org 13.4.0 Darwin Kernel Version 13.4.0: Wed Mar 18 16:20:14 PDT 2015; root:xnu-2422.115.14~1/RELEASE_X86_64 x86_64
*** finished standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/quail deploy quail tests for quail ***
Total time = 0m 2s
*** finished tests in quail ***
****SYSTEM ERROR quail: Abnormal exit from runtest ****
	****SYSTEM ERROR quail: runtest command failed ****
Testing kite
ssh -o ConnectTimeout=60 kite -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname kite
23:38  up 21 days,  7:37, 0 users, load averages: 0.03 0.07 0.15
/dev/disk0s2          1951845952  216812448 1734521504    12% 27165554 216815188   11%   /
devfs                        372        372          0   100%      645         0  100%   /dev
/dev/disk1s2          1952853344    1296624 1951556720     1%   162076 243944590    0%   /Volumes/Milvinae
10.10.10.86:/home      396703680  118126680  258100280    32%   697736  50518648    1%   /mnt/home
10.10.10.86:/mnt/hdf  1922864144 1697720912  127467232    94% 10148707 111961245    8%   /mnt/hdf
10.10.10.86:/mnt/scr1 1922864144 1752076896   73111248    96%  4033272 118076680    3%   /mnt/scr1
TEST_TYPES=standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/kite deploy kite
Tue Aug 25 23:39:04 CDT 2015
*** starting standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/kite deploy kite tests in kite ***
Uname -a: Darwin kite.ad.hdfgroup.org 12.6.0 Darwin Kernel Version 12.6.0: Wed Mar 18 16:23:48 PDT 2015; root:xnu-2050.48.19~1/RELEASE_X86_64 x86_64
   /Users/hdftest/snapshots-opa/log/kite_0825Tue_2339
*** finished standard setenv MAKE gnumake op-configure --prefix=/mnt/scr1/pre-release/opa/kite deploy kite tests for kite ***
Tue Aug 25 23:39:57 CDT 2015
Total time = 0m 53s
*** finished tests in kite ***
More information about the opa-nightly-tests mailing list
