[opa-nightly-tests] jam OPA_Daily_Tests_0505Thu_FAILED!!!
HDF Tester
hdftest at hdfgroup.org
Thu May 5 00:18:17 CDT 2011
*** OPA Tests on 0505Thu ***
Tests Summary
****FAILED amani: standard****
PASSED freedom: standard
PASSED heiwa: standard
PASSED jam: standard
PASSED koala: standard
PASSED linew: standard
PASSED loyalty: standard
Tests Time Summary
amani: Ran 1(0/1/0) tests, Grand total test time = 0m 2s
koala: Ran 1(1/0/0) tests, Grand total test time = 0m 44s
freedom: Ran 1(1/0/0) tests, Grand total test time = 1m 7s
jam: Ran 1(1/0/0) tests, Grand total test time = 1m 21s
loyalty: Ran 1(1/0/0) tests, Grand total test time = 1m 18s
heiwa: Ran 1(1/0/0) tests, Grand total test time = 5m 30s
linew: Ran 1(1/0/0) tests, Grand total test time = 7m 0s
jam: Ran 7(0/0/0) hosts, Grand total test time = 7m 57s
Timekeeper log
Timekeeper started at Thu May 5 00:10:30 CDT 2011
Timekeeper sleeping for 1800 seconds
Tests Failures
Dumping logfile of amani: standard
Last 50 lines of /mnt/scr1/SnapTest/snapshots-opa/log/amani_0505Thu_0010
SVNROOT=http://svn.hdfgroup.uiuc.edu
USER=hdftest
_=/usr/bin/printenv
VENDOR=unknown
===Done Dumping environment variables before option parsing ===
===Dumping environment variables after option parsing ===
CCACHE_DISABLE=yes
CVSROOT=/mnt/hdf/cvs
EC2_CERT=/home/hdftest/.ec2/cert-6HKISUOM3HT2PWDQB4PLG67KTWOVVKOK.pem
EC2_HOME=/mnt/hdf/ec2-api-tools
EC2_PRIVATE_KEY=/home/hdftest/.ec2/pk-6HKISUOM3HT2PWDQB4PLG67KTWOVVKOK.pem
G_BROKEN_FILENAMES=1
GROUP=hdf
HDF5TestExpress=yes
HOME=/home/hdftest
HOST=amani
HOSTTYPE=x86_64-linux
JAVA_HOME=/usr/java/jdk-106/jdk
KRB5CCNAME=FILE:/tmp/krb5cc_27429_HlTUf23831
LANG=en_US.UTF-8
LESSOPEN=|/usr/bin/lesspipe.sh %s
LOGNAME=hdftest
LS_COLORS=
MACHTYPE=x86_64
MAIL=/var/spool/mail/hdftest
MAKE=gmake -j 2
MANPATH=/usr/local/man:/usr/share/man:/usr/kerberos/man
OSTYPE=linux
PATH=/home/hdftest/bin:/usr/hdf/bin:/home/hdftest/bin:/usr/hdf/bin:/usr/local/bin:/bin:/usr/bin:/usr/kerberos/bin:/mnt/hdf/ec2-api-tools/bin
PWD=/mnt/scr1/SnapTest/snapshots-opa
SET_PATH=yes
SHELL=/bin/tcsh
SHLVL=3
SSH_ASKPASS=/usr/libexec/openssh/gnome-ssh-askpass
SSH_CLIENT=72.36.68.169 52310 22
SSH_CONNECTION=72.36.68.169 52310 72.36.68.153 22
USER=hdftest
_=/usr/bin/printenv
VENDOR=unknown
===Done Dumping environment variables after option parsing ===
===== Run Tests: Thu May 5 00:10:21 CDT 2011 =====
Remove contents of amani.\n
===== configure: Thu May 5 00:10:21 CDT 2011 =====
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... configure: error: newly created file is older than distributed files!
Check your system clock
Failed running configure
===== Exit bin/snapshot with status=1: Thu May 5 00:10:23 CDT 2011 =====
Dumping done
Runtest did not exit normally.
Watchers List
OPA Daily test features/platforms watchers and procedure
Procedure:
The watcher will investigate and report the cause of failure by 11am.
The developer who checked in the error code may report so by then too.
The watcher or the developer should get the failure fixed and report it
by 3pm.
Watcher for OPA: Neil
updated: 2009/05/05
Tests Details
00:10:10 up 90 days, 14:41, 74 users, load average: 1.53, 1.15, 1.10
Filesystem 1K-blocks Used Available Use% Mounted on
/dev/sda3 31738420 3845596 26254596 13% /
/dev/sda1 101086 22885 72982 24% /boot
/dev/sda2 31738420 468896 29631296 2% /tmp
/dev/sda6 31738392 6486284 23613884 22% /var
/dev/sda7 31738392 25907416 4192752 87% /usr
/dev/sda8 124991068 6668048 111871320 6% /var/tmp
/dev/mapper/VolGroup00-home
198351840 13992108 174121372 8% /home
/dev/sde1 565688764 390541200 145948628 73% /scr
/dev/sdc1 961432072 831718808 80875264 92% /mnt/scr1
/dev/sdd1 961432072 744246932 168347140 82% /mnt/hdf
tmpfs 8313848 16 8313832 1% /dev/shm
gumund:/data/ftp 480719072 287527264 168772608 64% /mnt/ftp
gumund:/data/web 480719072 287527264 168772608 64% /mnt/web
STANDARD_OPT=op-configure --prefix=${PWD}/opainstall
TEST_TYPES=standard
Running source repository checkout with output saved in
/mnt/scr1/SnapTest/snapshots-opa/log/REPO_LOG_0505Thu
Checking MANIFEST file ...
cat: /mnt/scr1/SnapTest/snapshots-opa/log/#runtest.0505Thu.7124: No such file or directory
rm: cannot remove `/mnt/scr1/SnapTest/snapshots-opa/log/#runtest.0505Thu.7124': No such file or directory
*** launching tests from jam ***
TESTHOST is linew
jam
amani
heiwa
koala
loyalty
freedom
Fork off timekeeper 30
Testing linew
ssh linew -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname linew
12:11am up 54 day(s), 6:07, 6 users, load average: 2.44, 1.61, 1.17
/ (/dev/dsk/c1t0d0s0 ):67275812 blocks 8242148 files
/devices (/devices ): 0 blocks 0 files
/system/contract (ctfs ): 0 blocks 2147483603 files
/proc (proc ): 0 blocks 29899 files
/etc/mnttab (mnttab ): 0 blocks 0 files
/etc/svc/volatile (swap ):19740656 blocks 1182156 files
/system/object (objfs ): 0 blocks 2147483490 files
/etc/dfs/sharetab (sharefs ): 0 blocks 2147483646 files
/platform/sun4u-us3/lib/libc_psr.so.1(/platform/sun4u-us3/lib/libc_psr/libc_psr_hwcap1.so.1):67275812 blocks 8242148 files
/platform/sun4u-us3/lib/sparcv9/libc_psr.so.1(/platform/sun4u-us3/lib/sparcv9/libc_psr/libc_psr_hwcap1.so.1):67275812 blocks 8242148 files
/dev/fd (fd ): 0 blocks 0 files
/tmp (swap ):19740656 blocks 1182156 files
/var/run (swap ):19740656 blocks 1182156 files
/scr (/dev/dsk/c1t1d0s0 ):893546122 blocks 226804713 files
/home (jam:/home ):368719464 blocks 50945545 files
/mnt/hdf (jam:/mnt/hdf ):434370280 blocks 113975173 files
/mnt/scr1 (jam:/mnt/scr1 ):259426472 blocks 115781337 files
/mnt/web (gumund:/mnt/web ):386383584 blocks 60893363 files
/mnt/ftp (gumund:/mnt/ftp ):386383584 blocks 60893363 files
TEST_TYPES=standard
Thu May 5 00:11:18 CDT 2011
*** starting standard tests in linew ***
Uname -a: SunOS linew 5.10 Generic_144488-07 sun4u sparc SUNW,A70
Running snapshot with output saved in
/mnt/scr1/SnapTest/snapshots-opa/log/linew_0505Thu_0011
*** finished standard tests for linew ***
Thu May 5 00:18:11 CDT 2011
Total time = 6m 53s
*** finished tests in linew ***
Thu May 5 00:18:12 CDT 2011
Testing jam
ssh jam -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname jam
00:10:37 up 90 days, 14:42, 74 users, load average: 1.59, 1.20, 1.12
/dev/sda2 31738420 469016 29631176 2% /tmp
/dev/sda6 31738392 6486288 23613880 22% /var
/dev/sdc1 961432072 831718844 80875228 92% /mnt/scr1
TEST_TYPES=standard
Thu May 5 00:10:47 CDT 2011
*** starting standard tests in jam ***
Uname -a: Linux jam 2.6.18-194.3.1.el5PAE #1 SMP Thu May 13 13:48:44 EDT 2010 i686 i686 i386 GNU/Linux
/mnt/scr1/SnapTest/snapshots-opa/log/jam_0505Thu_0010
*** finished standard tests for jam ***
Thu May 5 00:12:08 CDT 2011
Total time = 1m 21s
*** finished tests in jam ***
Testing amani
ssh amani -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname amani
00:10:11 up 15 days, 8:16, 8 users, load average: 0.00, 0.00, 0.35
/dev/hda6 39021196 28873660 8133392 79% /
/dev/hda3 12192636 4171400 7391892 37% /var
/dev/hda2 12192636 162588 11400704 2% /tmp
/dev/hda1 101086 30048 65819 32% /boot
/dev/sdb1 144221592 75651068 61244484 56% /scr
tmpfs 2057492 0 2057492 0% /dev/shm
jam:/home 198351840 13992096 174121376 8% /home
jam:/mnt/hdf 961432096 744246944 168347168 82% /mnt/hdf
jam:/mnt/scr1 961432096 831718848 80875232 92% /mnt/scr1
TEST_TYPES=standard
*** starting standard tests in amani ***
Uname -a: Linux amani 2.6.18-238.9.1.el5 #1 SMP Tue Apr 12 18:10:13 EDT 2011 x86_64 x86_64 x86_64 GNU/Linux
*** finished standard tests for amani ***
Total time = 0m 2s
*** finished tests in amani ***
****SYSTEM ERROR amani: Abnormal exit from runtest ****
****SYSTEM ERROR amani: runtest command failed ****
Testing heiwa
ssh heiwa -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname heiwa
00:11:06 up 14 days, 12:25, 2 users, load average: 0.10, 0.08, 0.01
/dev/sdb8 35435232 2722700 30912492 9% /
tmpfs 2008144 0 2008144 0% /dev/shm
/dev/sdb4 198337 106660 81437 57% /boot
/dev/sdb6 12385456 2559124 9197188 22% /tmp
/dev/sdb7 12385456 4341240 7415072 37% /var
/dev/sda6 82573108 878148 77500392 2% /scr
jam:/mnt/scr1 961432096 831718880 80875232 92% /mnt/scr1
gumund:/mnt/web 480719072 287527264 168772608 64% /mnt/web
gumund:/mnt/ftp 480719072 287527264 168772608 64% /mnt/ftp
TEST_TYPES=standard
Thu May 5 00:11:16 CDT 2011
*** starting standard tests in heiwa ***
Uname -a: Linux heiwa 2.6.32.16-150.fc12.ppc64 #1 SMP Sat Jul 24 05:19:27 UTC 2010 ppc64 ppc64 ppc64 GNU/Linux
/mnt/scr1/SnapTest/snapshots-opa/log/heiwa_0505Thu_0011
*** finished standard tests for heiwa ***
Thu May 5 00:16:46 CDT 2011
Total time = 5m 30s
*** finished tests in heiwa ***
Testing koala
ssh koala -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname koala
00:11:11 up 15 days, 8:15, 3 users, load average: 0.00, 0.00, 0.00
/dev/sda7 22292052 10685796 10455604 51% /
/dev/sda5 12192608 411720 11151544 4% /tmp
/dev/sda3 12192636 1479468 10083824 13% /var
/dev/sda1 101086 30464 65403 32% /boot
tmpfs 6149588 0 6149588 0% /dev/shm
/dev/md0 48091528 5628340 40020260 13% /scr
TEST_TYPES=standard
Thu May 5 00:11:21 CDT 2011
*** starting standard tests in koala ***
Uname -a: Linux koala 2.6.18-238.9.1.el5 #1 SMP Tue Apr 12 18:10:13 EDT 2011 x86_64 x86_64 x86_64 GNU/Linux
/mnt/scr1/SnapTest/snapshots-opa/log/koala_0505Thu_0011
*** finished standard tests for koala ***
Thu May 5 00:12:05 CDT 2011
Total time = 0m 44s
*** finished tests in koala ***
Testing loyalty
ssh loyalty -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname loyalty
grep: /proc/cpuinfo: No such file or directory
12:11AM up 12:16, 0 users, load averages: 0.00, 0.00, 0.00
Filesystem 1K-blocks Used Avail Capacity Mounted on
/dev/da0s1a 507630 103646 363374 22% /
devfs 1 1 0 100% /dev
/dev/da0s1g 58896528 6701670 47483136 12% /local_home
/dev/da0s1f 16244334 4457974 10486814 30% /usr
/dev/da0s1d 1012974 191096 740842 21% /var
/dev/da0s1e 507630 16732 450288 4% /var/tmp
procfs 4 4 0 100% /proc
jam:/home 198351840 13992108 174121372 7% /home
jam:/mnt/hdf 961432072 744246932 168347140 82% /mnt/hdf
jam:/mnt/scr1 961432072 831718880 80875192 91% /mnt/scr1
gumund:/data/web 480719056 287527264 168772592 63% /mnt/web
gumund:/data/ftp 480719056 287527264 168772592 63% /mnt/ftp
devfs 1 1 0 100% /var/named/dev
/dev/md0 126702 12 116554 0% /tmp
TEST_TYPES=standard
Thu May 5 00:11:24 CDT 2011
*** starting standard tests in loyalty ***
Uname -a: FreeBSD loyalty.hdfgroup.uiuc.edu 8.2-STABLE FreeBSD 8.2-STABLE #0: Tue May 3 22:23:36 CDT 2011 sukoziol at loyalty.hdfgroup.uiuc.edu:/usr/obj/usr/src/sys/LOYALTY i386
/mnt/scr1/SnapTest/snapshots-opa/log/loyalty_0505Thu_0011
*** finished standard tests for loyalty ***
Thu May 5 00:12:41 CDT 2011
Total time = 1m 17s
*** finished tests in loyalty ***
Testing freedom
ssh freedom -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname freedom
12:11AM up 12:14, 2 users, load averages: 0.00, 0.00, 0.00
/dev/da0s1a 507630 116204 350816 25% /
/dev/da0s1g 45184754 6202198 35367776 15% /local_home
/dev/da0s1f 24372460 4962054 17460610 22% /usr
/dev/da0s1d 2026030 159386 1704562 9% /var
/dev/da0s1e 1012974 108 931830 0% /var/tmp
jam:/home 198351840 13992108 174121372 7% /usr/home
jam:/mnt/scr1 961432072 831718888 80875184 91% /mnt/scr1
TEST_TYPES=standard
Thu May 5 00:11:26 CDT 2011
*** starting standard tests in freedom ***
Uname -a: FreeBSD freedom.hdfgroup.uiuc.edu 8.2-STABLE FreeBSD 8.2-STABLE #0: Tue May 3 22:26:37 CDT 2011 sukoziol at freedom.hdfgroup.uiuc.edu:/usr/obj/usr/src/sys/FREEDOM amd64
/mnt/scr1/SnapTest/snapshots-opa/log/freedom_0505Thu_0011
*** finished standard tests for freedom ***
Thu May 5 00:12:33 CDT 2011
Total time = 1m 7s
*** finished tests in freedom ***
More information about the opa-nightly-tests
