[opa-nightly-tests] jam OPA_Daily_Tests_0504Wed_FAILED!!!
Quincey Koziol
koziol at hdfgroup.org
Wed May 4 11:18:17 CDT 2011
Hi Dave,
On May 4, 2011, at 9:26 AM, Dave Goodell wrote:
> Is this the same issue we were seeing before?
I don't think so.
> The output appears to have changed (we are missing the actual "make check" output for some reason...
Amani was having some compiler-related system issues yesterday, so I think we can ignore this failure.
Quincey
> -Dave
> On May 4, 2011, at 12:19 AM CDT, HDF Tester wrote:
>> *** OPA Tests on 0504Wed ***
>> Tests Summary
>> ****FAILED amani: standard****
>> PASSED freedom: standard
>> PASSED heiwa: standard
>> PASSED jam: standard
>> PASSED koala: standard
>> PASSED linew: standard
>> PASSED loyalty: standard
>> Tests Time Summary
>> amani: Ran 1(0/1/0) tests, Grand total test time = 0m 1s
>> koala: Ran 1(1/0/0) tests, Grand total test time = 0m 44s
>> jam: Ran 1(1/0/0) tests, Grand total test time = 1m 20s
>> freedom: Ran 1(1/0/0) tests, Grand total test time = 1m 25s
>> loyalty: Ran 1(1/0/0) tests, Grand total test time = 1m 28s
>> heiwa: Ran 1(1/0/0) tests, Grand total test time = 5m 35s
>> linew: Ran 1(1/0/0) tests, Grand total test time = 7m 51s
>> jam: Ran 7(0/0/0) hosts, Grand total test time = 8m 49s
>> Timekeeper log
>> Timekeeper started at Wed May 4 00:10:29 CDT 2011
>> Timekeeper sleeping for 1800 seconds
>> Tests Failures
>> Dumping logfile of amani: standard
>> Last 50 lines of /mnt/scr1/SnapTest/snapshots-opa/log/amani_0504Wed_0010
>> SVNROOT=http://svn.hdfgroup.uiuc.edu
>> USER=hdftest
>> _=/usr/bin/printenv
>> VENDOR=unknown
>> ===Done Dumping environment variables before option parsing ===
>> ===Dumping environment variables after option parsing ===
>> CCACHE_DISABLE=yes
>> CVSROOT=/mnt/hdf/cvs
>> EC2_CERT=/home/hdftest/.ec2/cert-6HKISUOM3HT2PWDQB4PLG67KTWOVVKOK.pem
>> EC2_HOME=/mnt/hdf/ec2-api-tools
>> EC2_PRIVATE_KEY=/home/hdftest/.ec2/pk-6HKISUOM3HT2PWDQB4PLG67KTWOVVKOK.pem
>> G_BROKEN_FILENAMES=1
>> GROUP=hdf
>> HDF5TestExpress=yes
>> HOME=/home/hdftest
>> HOST=amani
>> HOSTTYPE=x86_64-linux
>> JAVA_HOME=/usr/java/jdk-106/jdk
>> KRB5CCNAME=FILE:/tmp/krb5cc_27429_uxDKC14181
>> LANG=en_US.UTF-8
>> LESSOPEN=|/usr/bin/lesspipe.sh %s
>> LOGNAME=hdftest
>> LS_COLORS=
>> MACHTYPE=x86_64
>> MAIL=/var/spool/mail/hdftest
>> MAKE=gmake -j 2
>> MANPATH=/usr/local/man:/usr/share/man:/usr/kerberos/man
>> OSTYPE=linux
>> PATH=/home/hdftest/bin:/usr/hdf/bin:/home/hdftest/bin:/usr/hdf/bin:/usr/local/bin:/bin:/usr/bin:/usr/kerberos/bin:/mnt/hdf/ec2-api-tools/bin
>> PWD=/mnt/scr1/SnapTest/snapshots-opa
>> SET_PATH=yes
>> SHELL=/bin/tcsh
>> SHLVL=3
>> SSH_ASKPASS=/usr/libexec/openssh/gnome-ssh-askpass
>> SSH_CLIENT=72.36.68.169 55963 22
>> SSH_CONNECTION=72.36.68.169 55963 72.36.68.153 22
>> USER=hdftest
>> _=/usr/bin/printenv
>> VENDOR=unknown
>> ===Done Dumping environment variables after option parsing ===
>> ===== Run Tests: Wed May 4 00:10:23 CDT 2011 =====
>> Remove contents of amani.\n
>> ===== configure: Wed May 4 00:10:23 CDT 2011 =====
>> checking for a BSD-compatible install... /usr/bin/install -c
>> checking whether build environment is sane... configure: error: newly created file is older than distributed files!
>> Check your system clock
>> Failed running configure
>> ===== Exit bin/snapshot with status=1: Wed May 4 00:10:24 CDT 2011 =====
>> Dumping done
>> Runtest did not exit normally.
>> Watchers List
>> OPA Daily test features/platforms watchers and procedure
>> Procedure:
>> The watcher will investigate and report the cause of failure by 11am.
>> The developer who checked in the error code may report so by then too.
>> The watcher or the developer should get the failure fixed and report it
>> by 3pm.
>> Watcher for OPA: Neil
>> updated: 2009/05/05
>> Tests Details
>> 00:10:09 up 89 days, 14:41, 75 users, load average: 1.06, 1.26, 2.56
>> Filesystem 1K-blocks Used Available Use% Mounted on
>> /dev/sda3 31738420 3843612 26256580 13% /
>> /dev/sda1 101086 22885 72982 24% /boot
>> /dev/sda2 31738420 468876 29631316 2% /tmp
>> /dev/sda6 31738392 6475048 23625120 22% /var
>> /dev/sda7 31738392 25907416 4192752 87% /usr
>> /dev/sda8 124991068 7135584 111403784 7% /var/tmp
>> /dev/mapper/VolGroup00-home
>> 198351840 13812044 174301436 8% /home
>> /dev/sde1 565688764 391457712 145032116 73% /scr
>> /dev/sdc1 961432072 832154016 80440056 92% /mnt/scr1
>> /dev/sdd1 961432072 743528896 169065176 82% /mnt/hdf
>> tmpfs 8313848 16 8313832 1% /dev/shm
>> gumund:/data/ftp 480719072 287527200 168772672 64% /mnt/ftp
>> gumund:/data/web 480719072 287527200 168772672 64% /mnt/web
>> STANDARD_OPT=op-configure --prefix=${PWD}/opainstall
>> TEST_TYPES=standard
>> Running source repository checkout with output saved in
>> /mnt/scr1/SnapTest/snapshots-opa/log/REPO_LOG_0504Wed
>> Checking MANIFEST file ...
>> cat: /mnt/scr1/SnapTest/snapshots-opa/log/#runtest.0504Wed.17689: No such file or directory
>> rm: cannot remove `/mnt/scr1/SnapTest/snapshots-opa/log/#runtest.0504Wed.17689': No such file or directory
>> *** launching tests from jam ***
>> TESTHOST is linew
>> jam
>> amani
>> heiwa
>> koala
>> loyalty
>> freedom
>> Fork off timekeeper 30
>> Testing linew
>> ssh linew -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname linew
>> 12:10am up 53 day(s), 6:07, 8 users, load average: 2.25, 2.04, 1.59
>> / (/dev/dsk/c1t0d0s0 ):67275890 blocks 8242147 files
>> /devices (/devices ): 0 blocks 0 files
>> /system/contract (ctfs ): 0 blocks 2147483601 files
>> /proc (proc ): 0 blocks 29897 files
>> /etc/mnttab (mnttab ): 0 blocks 0 files
>> /etc/svc/volatile (swap ):19647488 blocks 1182156 files
>> /system/object (objfs ): 0 blocks 2147483490 files
>> /etc/dfs/sharetab (sharefs ): 0 blocks 2147483646 files
>> /platform/sun4u-us3/lib/libc_psr.so.1(/platform/sun4u-us3/lib/libc_psr/libc_psr_hwcap1.so.1):67275890 blocks 8242147 files
>> /platform/sun4u-us3/lib/sparcv9/libc_psr.so.1(/platform/sun4u-us3/lib/sparcv9/libc_psr/libc_psr_hwcap1.so.1):67275890 blocks 8242147 files
>> /dev/fd (fd ): 0 blocks 0 files
>> /tmp (swap ):19647488 blocks 1182156 files
>> /var/run (swap ):19647488 blocks 1182156 files
>> /scr (/dev/dsk/c1t1d0s0 ):890421180 blocks 226805930 files
>> /home (jam:/home ):369079592 blocks 50947274 files
>> /mnt/hdf (jam:/mnt/hdf ):435806352 blocks 113975632 files
>> /mnt/scr1 (jam:/mnt/scr1 ):258556056 blocks 115709861 files
>> /mnt/web (gumund:/mnt/web ):386383736 blocks 60893364 files
>> /mnt/ftp (gumund:/mnt/ftp ):386383736 blocks 60893364 files
>> TEST_TYPES=standard
>> Wed May 4 00:11:17 CDT 2011
>> *** starting standard tests in linew ***
>> Uname -a: SunOS linew 5.10 Generic_144488-07 sun4u sparc SUNW,A70
>> Running snapshot with output saved in
>> /mnt/scr1/SnapTest/snapshots-opa/log/linew_0504Wed_0011
>> *** finished standard tests for linew ***
>> Wed May 4 00:18:59 CDT 2011
>> Total time = 7m 42s
>> *** finished tests in linew ***
>> Wed May 4 00:19:00 CDT 2011
>> Testing jam
>> ssh jam -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname jam
>> 00:10:37 up 89 days, 14:42, 75 users, load average: 1.18, 1.27, 2.52
>> /dev/sda2 31738420 468996 29631196 2% /tmp
>> /dev/sda6 31738392 6475052 23625116 22% /var
>> /dev/sdc1 961432072 832154052 80440020 92% /mnt/scr1
>> TEST_TYPES=standard
>> Wed May 4 00:10:47 CDT 2011
>> *** starting standard tests in jam ***
>> Uname -a: Linux jam 2.6.18-194.3.1.el5PAE #1 SMP Thu May 13 13:48:44 EDT 2010 i686 i686 i386 GNU/Linux
>> /mnt/scr1/SnapTest/snapshots-opa/log/jam_0504Wed_0010
>> *** finished standard tests for jam ***
>> Wed May 4 00:12:07 CDT 2011
>> Total time = 1m 20s
>> *** finished tests in jam ***
>> Testing amani
>> ssh amani -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname amani
>> 00:10:13 up 14 days, 8:16, 8 users, load average: 0.01, 0.01, 0.14
>> /dev/hda6 39021196 28868700 8138352 79% /
>> /dev/hda3 12192636 4175632 7387660 37% /var
>> /dev/hda2 12192636 162584 11400708 2% /tmp
>> /dev/hda1 101086 30048 65819 32% /boot
>> /dev/sdb1 144221592 76228912 60666640 56% /scr
>> tmpfs 2057492 0 2057492 0% /dev/shm
>> jam:/home 198351840 13812032 174301440 8% /home
>> jam:/mnt/hdf 961432096 743528896 169065184 82% /mnt/hdf
>> jam:/mnt/scr1 961432096 832154080 80440032 92% /mnt/scr1
>> TEST_TYPES=standard
>> *** starting standard tests in amani ***
>> Uname -a: Linux amani 2.6.18-238.9.1.el5 #1 SMP Tue Apr 12 18:10:13 EDT 2011 x86_64 x86_64 x86_64 GNU/Linux
>> *** finished standard tests for amani ***
>> Total time = 0m 1s
>> *** finished tests in amani ***
>> ****SYSTEM ERROR amani: Abnormal exit from runtest ****
>> Wed May 4 00:19:08 CDT 2011
>> ****SYSTEM ERROR amani: runtest command failed ****
>> Testing heiwa
>> ssh heiwa -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname heiwa
>> 00:11:02 up 13 days, 12:24, 2 users, load average: 0.00, 0.00, 0.00
>> /dev/sdb8 35435232 2722436 30912756 9% /
>> tmpfs 2008144 0 2008144 0% /dev/shm
>> /dev/sdb4 198337 106660 81437 57% /boot
>> /dev/sdb6 12385456 3162608 8593704 27% /tmp
>> /dev/sdb7 12385456 4880904 6875408 42% /var
>> /dev/sda6 82573108 878148 77500392 2% /scr
>> gumund:/mnt/web 480719072 287527200 168772672 64% /mnt/web
>> gumund:/mnt/ftp 480719072 287527200 168772672 64% /mnt/ftp
>> TEST_TYPES=standard
>> Wed May 4 00:11:13 CDT 2011
>> *** starting standard tests in heiwa ***
>> Uname -a: Linux heiwa 2.6.32.16-150.fc12.ppc64 #1 SMP Sat Jul 24 05:19:27 UTC 2010 ppc64 ppc64 ppc64 GNU/Linux
>> /mnt/scr1/SnapTest/snapshots-opa/log/heiwa_0504Wed_0011
>> *** finished standard tests for heiwa ***
>> Wed May 4 00:16:47 CDT 2011
>> Total time = 5m 34s
>> *** finished tests in heiwa ***
>> Testing koala
>> ssh koala -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname koala
>> 00:11:07 up 14 days, 8:15, 3 users, load average: 0.00, 0.00, 0.00
>> /dev/sda7 22292052 10685796 10455604 51% /
>> /dev/sda5 12192608 411720 11151544 4% /tmp
>> /dev/sda3 12192636 1460592 10102700 13% /var
>> /dev/sda1 101086 30464 65403 32% /boot
>> tmpfs 6149588 0 6149588 0% /dev/shm
>> /dev/md0 48091528 6078808 39569792 14% /scr
>> jam:/mnt/scr1 961432096 832154080 80440000 92% /mnt/scr1
>> TEST_TYPES=standard
>> *** starting standard tests in koala ***
>> Uname -a: Linux koala 2.6.18-238.9.1.el5 #1 SMP Tue Apr 12 18:10:13 EDT 2011 x86_64 x86_64 x86_64 GNU/Linux
>> /mnt/scr1/SnapTest/snapshots-opa/log/koala_0504Wed_0011
>> *** finished standard tests for koala ***
>> Wed May 4 00:12:01 CDT 2011
>> Total time = 0m 44s
>> *** finished tests in koala ***
>> Testing loyalty
>> ssh loyalty -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname loyalty
>> grep: /proc/cpuinfo: No such file or directory
>> 12:11AM up 7 days, 13:49, 4 users, load averages: 0.00, 0.00, 0.00
>> Filesystem 1K-blocks Used Avail Capacity Mounted on
>> /dev/da0s1a 507630 215730 251290 46% /
>> devfs 1 1 0 100% /dev
>> /dev/da0s1g 58896528 7067104 47117702 13% /local_home
>> /dev/da0s1f 16244334 4457208 10487580 30% /usr
>> /dev/da0s1d 1012974 191166 740772 21% /var
>> /dev/da0s1e 507630 16732 450288 4% /var/tmp
>> procfs 4 4 0 100% /proc
>> jam:/home 198351840 13812044 174301436 7% /home
>> jam:/mnt/hdf 961432072 743528896 169065176 81% /mnt/hdf
>> jam:/mnt/scr1 961432072 832154084 80439988 91% /mnt/scr1
>> gumund:/data/web 480719056 287527188 168772668 63% /mnt/web
>> gumund:/data/ftp 480719056 287527188 168772668 63% /mnt/ftp
>> devfs 1 1 0 100% /var/named/dev
>> /dev/md0 126702 12 116554 0% /tmp
>> TEST_TYPES=standard
>> Wed May 4 00:11:19 CDT 2011
>> *** starting standard tests in loyalty ***
>> Uname -a: FreeBSD loyalty.hdfgroup.uiuc.edu 8.2-PRERELEASE FreeBSD 8.2-PRERELEASE #1: Tue Feb 1 20:47:02 CST 2011 sukoziol at loyalty.hdfgroup.uiuc.edu:/usr/obj/usr/src/sys/LOYALTY i386
>> /mnt/scr1/SnapTest/snapshots-opa/log/loyalty_0504Wed_0011
>> *** finished standard tests for loyalty ***
>> Wed May 4 00:12:47 CDT 2011
>> Total time = 1m 28s
>> *** finished tests in loyalty ***
>> Testing freedom
>> ssh freedom -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname freedom
>> 12:11AM up 7 days, 13:46, 3 users, load averages: 0.00, 0.00, 0.00
>> /dev/da0s1a 507630 70670 396350 15% /
>> /dev/da0s1g 45184754 8528674 33041300 21% /local_home
>> /dev/da0s1f 24372460 4960936 17461728 22% /usr
>> /dev/da0s1d 2026030 159338 1704610 9% /var
>> /dev/da0s1e 1012974 108 931830 0% /var/tmp
>> jam:/home 198351840 13812044 174301436 7% /usr/home
>> jam:/mnt/scr1 961432072 832154096 80439976 91% /mnt/scr1
>> TEST_TYPES=standard
>> Wed May 4 00:11:22 CDT 2011
>> *** starting standard tests in freedom ***
>> Uname -a: FreeBSD freedom.hdfgroup.uiuc.edu 8.2-PRERELEASE FreeBSD 8.2-PRERELEASE #0: Wed Feb 2 14:32:23 CST 2011 sukoziol at freedom.hdfgroup.uiuc.edu:/usr/obj/usr/src/sys/FREEDOM amd64
>> /mnt/scr1/SnapTest/snapshots-opa/log/freedom_0504Wed_0011
>> *** finished standard tests for freedom ***
>> Wed May 4 00:12:46 CDT 2011
>> Total time = 1m 24s
>> *** finished tests in freedom ***
>> opa-nightly-tests mailing list
>> opa-nightly-tests at lists.mcs.anl.gov
>> https://lists.mcs.anl.gov/mailman/listinfo/opa-nightly-tests
More information about the opa-nightly-tests
