[opa-nightly-tests] jam OPA_Daily_Tests_0506Fri_FAILED!!!
HDF Tester hdftest at hdfgroup.org
Fri May 6 00:19:28 CDT 2011
*** OPA Tests on 0506Fri ***
   Tests Summary
****FAILED amani: standard****
PASSED freedom: standard
PASSED heiwa: standard
PASSED jam: standard
PASSED koala: standard
PASSED linew: standard
PASSED loyalty: standard
   Tests Time Summary
amani: Ran 1(0/1/0) tests, Grand total test time =  0m 1s
koala: Ran 1(1/0/0) tests, Grand total test time =  0m 46s
freedom: Ran 1(1/0/0) tests, Grand total test time =  1m 5s
jam: Ran 1(1/0/0) tests, Grand total test time =  1m 23s
loyalty: Ran 1(1/0/0) tests, Grand total test time =  1m 18s
heiwa: Ran 1(1/0/0) tests, Grand total test time =  5m 32s
linew: Ran 1(1/0/0) tests, Grand total test time =  8m 8s
jam: Ran 7(0/0/0) hosts, Grand total test time =  9m 7s
   Timekeeper log
Timekeeper started at Fri May  6 00:10:33 CDT 2011
Timekeeper sleeping for 1800 seconds
   Tests Failures
Dumping logfile of amani: standard
Last 50 lines of /mnt/scr1/SnapTest/snapshots-opa/log/amani_0506Fri_0010
SVNROOT=http://svn.hdfgroup.uiuc.edu
USER=hdftest
_=/usr/bin/printenv
VENDOR=unknown
===Done Dumping environment variables before option parsing ===
===Dumping environment variables after option parsing ===
CCACHE_DISABLE=yes
CVSROOT=/mnt/hdf/cvs
EC2_CERT=/home/hdftest/.ec2/cert-6HKISUOM3HT2PWDQB4PLG67KTWOVVKOK.pem
EC2_HOME=/mnt/hdf/ec2-api-tools
EC2_PRIVATE_KEY=/home/hdftest/.ec2/pk-6HKISUOM3HT2PWDQB4PLG67KTWOVVKOK.pem
G_BROKEN_FILENAMES=1
GROUP=hdf
HDF5TestExpress=yes
HOME=/home/hdftest
HOST=amani
HOSTTYPE=x86_64-linux
JAVA_HOME=/usr/java/jdk-106/jdk
KRB5CCNAME=FILE:/tmp/krb5cc_27429_jjTjIS3222
LANG=en_US.UTF-8
LESSOPEN=|/usr/bin/lesspipe.sh %s
LOGNAME=hdftest
LS_COLORS=
MACHTYPE=x86_64
MAIL=/var/spool/mail/hdftest
MAKE=gmake -j 2
MANPATH=/usr/local/man:/usr/share/man:/usr/kerberos/man
OSTYPE=linux
PATH=/home/hdftest/bin:/usr/hdf/bin:/home/hdftest/bin:/usr/hdf/bin:/usr/local/bin:/bin:/usr/bin:/usr/kerberos/bin:/mnt/hdf/ec2-api-tools/bin
PWD=/mnt/scr1/SnapTest/snapshots-opa
SET_PATH=yes
SHELL=/bin/tcsh
SHLVL=3
SSH_ASKPASS=/usr/libexec/openssh/gnome-ssh-askpass
SSH_CLIENT=72.36.68.169 43589 22
SSH_CONNECTION=72.36.68.169 43589 72.36.68.153 22
USER=hdftest
_=/usr/bin/printenv
VENDOR=unknown
===Done Dumping environment variables after option parsing ===
===== Run Tests: Fri May  6 00:10:20 CDT 2011 =====
Remove contents of amani.\n
===== configure: Fri May  6 00:10:20 CDT 2011 =====
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... configure: error: newly created file is older than distributed files!
Check your system clock
Failed running configure
===== Exit bin/snapshot with status=1: Fri May  6 00:10:21 CDT 2011 =====
Dumping done
Runtest did not exit normally.
   Watchers List
OPA Daily test features/platforms watchers and procedure
Procedure:
The watcher will investigate and report the cause of failure by 11am.
The developer who checked in the error code may report so by then too.
The watcher or the developer should get the failure fixed and report it
by 3pm.
Watcher for OPA:	 	Neil
updated: 2009/05/05
   Tests Details
 00:10:11 up 91 days, 14:41, 77 users,  load average: 2.34, 2.47, 2.47
Filesystem           1K-blocks      Used Available Use% Mounted on
/dev/sda3             31738420   3852544  26247648  13% /
/dev/sda1               101086     22885     72982  24% /boot
/dev/sda2             31738420    468952  29631240   2% /tmp
/dev/sda6             31738392   6488364  23611804  22% /var
/dev/sda7             31738392  25907416   4192752  87% /usr
/dev/sda8            124991068   6670540 111868828   6% /var/tmp
/dev/mapper/VolGroup00-home
                     198351840  14499272 173614208   8% /home
/dev/sde1            565688764 391279560 145210268  73% /scr
/dev/sdc1            961432072 838683996  73910076  92% /mnt/scr1
/dev/sdd1            961432072 744781888 167812184  82% /mnt/hdf
tmpfs                  8313848        16   8313832   1% /dev/shm
gumund:/data/ftp     480719072 287530304 168769568  64% /mnt/ftp
gumund:/data/web     480719072 287530304 168769568  64% /mnt/web
STANDARD_OPT=op-configure --prefix=${PWD}/opainstall
TEST_TYPES=standard
Running source repository checkout with output saved in
   /mnt/scr1/SnapTest/snapshots-opa/log/REPO_LOG_0506Fri
Checking MANIFEST file ...
cat: /mnt/scr1/SnapTest/snapshots-opa/log/#runtest.0506Fri.2980: No such file or directory
rm: cannot remove `/mnt/scr1/SnapTest/snapshots-opa/log/#runtest.0506Fri.2980': No such file or directory
*** launching tests from jam ***
TESTHOST is linew
jam
amani
heiwa
koala
loyalty
freedom
    Fork off timekeeper 30
Testing linew
ssh linew -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname linew
 12:11am  up 55 day(s),  6:07,  7 users,  load average: 1.22, 1.10, 0.80
/                  (/dev/dsk/c1t0d0s0 ):67275684 blocks  8242148 files
/devices           (/devices          ):       0 blocks        0 files
/system/contract   (ctfs              ):       0 blocks 2147483603 files
/proc              (proc              ):       0 blocks    29916 files
/etc/mnttab        (mnttab            ):       0 blocks        0 files
/etc/svc/volatile  (swap              ):18973152 blocks  1166951 files
/system/object     (objfs             ):       0 blocks 2147483490 files
/etc/dfs/sharetab  (sharefs           ):       0 blocks 2147483646 files
/platform/sun4u-us3/lib/libc_psr.so.1(/platform/sun4u-us3/lib/libc_psr/libc_psr_hwcap1.so.1):67275684 blocks  8242148 files
/platform/sun4u-us3/lib/sparcv9/libc_psr.so.1(/platform/sun4u-us3/lib/sparcv9/libc_psr/libc_psr_hwcap1.so.1):67275684 blocks  8242148 files
/dev/fd            (fd                ):       0 blocks        0 files
/tmp               (swap              ):18973152 blocks  1166951 files
/var/run           (swap              ):18973152 blocks  1166951 files
/scr               (/dev/dsk/c1t1d0s0 ):891415044 blocks 226803080 files
/home              (jam:/home         ):367705136 blocks 50938573 files
/mnt/hdf           (jam:/mnt/hdf      ):433300368 blocks 113964551 files
/mnt/scr1          (jam:/mnt/scr1     ):244432144 blocks 115774108 files
/mnt/web           (gumund:/mnt/web   ):386377496 blocks 60893345 files
/mnt/ftp           (gumund:/mnt/ftp   ):386377496 blocks 60893345 files
TEST_TYPES=standard
Fri May  6 00:11:23 CDT 2011
*** starting standard tests in linew ***
Uname -a: SunOS linew 5.10 Generic_144488-07 sun4u sparc SUNW,A70
Running snapshot with output saved in
   /mnt/scr1/SnapTest/snapshots-opa/log/linew_0506Fri_0011
*** finished standard tests for linew ***
Fri May  6 00:19:24 CDT 2011
Total time = 8m 2s
*** finished tests in linew ***
Fri May  6 00:19:25 CDT 2011
Testing jam
ssh jam -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname jam
 00:10:40 up 91 days, 14:42, 77 users,  load average: 2.43, 2.48, 2.48
/dev/sda2             31738420    469076  29631116   2% /tmp
/dev/sda6             31738392   6488368  23611800  22% /var
/dev/sdc1            961432072 839237276  73356796  92% /mnt/scr1
TEST_TYPES=standard
Fri May  6 00:10:50 CDT 2011
*** starting standard tests in jam ***
Uname -a: Linux jam 2.6.18-194.3.1.el5PAE #1 SMP Thu May 13 13:48:44 EDT 2010 i686 i686 i386 GNU/Linux
   /mnt/scr1/SnapTest/snapshots-opa/log/jam_0506Fri_0010
*** finished standard tests for jam ***
Fri May  6 00:12:13 CDT 2011
Total time = 1m 23s
*** finished tests in jam ***
Testing amani
ssh amani -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname amani
 00:10:10 up 16 days,  8:16,  8 users,  load average: 0.00, 0.02, 0.04
/dev/hda6             39021196  28879316   8127736  79% /
/dev/hda3             12192636   4158100   7405192  36% /var
/dev/hda2             12192636    162588  11400704   2% /tmp
/dev/hda1               101086     30048     65819  32% /boot
/dev/sdb1            144221592  75863752  61031800  56% /scr
tmpfs                  2057492         0   2057492   0% /dev/shm
jam:/home            198351840  14499264 173614208   8% /home
jam:/mnt/hdf         961432096 744781888 167812192  82% /mnt/hdf
jam:/mnt/scr1        961432096 839278944  73315168  92% /mnt/scr1
TEST_TYPES=standard
*** starting standard tests in amani ***
Uname -a: Linux amani 2.6.18-238.9.1.el5 #1 SMP Tue Apr 12 18:10:13 EDT 2011 x86_64 x86_64 x86_64 GNU/Linux
*** finished standard tests for amani ***
Total time = 0m 1s
*** finished tests in amani ***
****SYSTEM ERROR amani: Abnormal exit from runtest ****
	****SYSTEM ERROR amani: runtest command failed ****
Testing heiwa
ssh heiwa -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname heiwa
 00:11:10 up 15 days, 12:25,  5 users,  load average: 20.24, 20.36, 20.30
/dev/sdb8             35435232   2728844  30906348   9% /
tmpfs                  2008144         0   2008144   0% /dev/shm
/dev/sdb4               198337    106660     81437  57% /boot
/dev/sdb6             12385456   3303848   8452464  29% /tmp
/dev/sdb7             12385456   4337840   7418472  37% /var
/dev/sda6             82573108   1946460  76432080   3% /scr
jam:/mnt/scr1        961432096 839336224  73257888  92% /mnt/scr1
gumund:/mnt/web      480719072 287530304 168769568  64% /mnt/web
gumund:/mnt/ftp      480719072 287530304 168769568  64% /mnt/ftp
TEST_TYPES=standard
Fri May  6 00:11:21 CDT 2011
*** starting standard tests in heiwa ***
Uname -a: Linux heiwa 2.6.32.16-150.fc12.ppc64 #1 SMP Sat Jul 24 05:19:27 UTC 2010 ppc64 ppc64 ppc64 GNU/Linux
   /mnt/scr1/SnapTest/snapshots-opa/log/heiwa_0506Fri_0011
*** finished standard tests for heiwa ***
Fri May  6 00:16:51 CDT 2011
Total time = 5m 30s
*** finished tests in heiwa ***
Fri May  6 00:16:52 CDT 2011
Testing koala
ssh koala -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname koala
 00:11:15 up 16 days,  8:15,  3 users,  load average: 0.00, 0.00, 0.00
/dev/sda7             22292052  10686424  10454976  51% /
/dev/sda5             12192608    411720  11151544   4% /tmp
/dev/sda3             12192636   1502516  10060776  13% /var
/dev/sda1               101086     30464     65403  32% /boot
tmpfs                  6149588         0   6149588   0% /dev/shm
/dev/md0              48091528   6246692  39401908  14% /scr
jam:/mnt/scr1        961432096 839373248  73220832  92% /mnt/scr1
TEST_TYPES=standard
Fri May  6 00:11:25 CDT 2011
*** starting standard tests in koala ***
Uname -a: Linux koala 2.6.18-238.9.1.el5 #1 SMP Tue Apr 12 18:10:13 EDT 2011 x86_64 x86_64 x86_64 GNU/Linux
   /mnt/scr1/SnapTest/snapshots-opa/log/koala_0506Fri_0011
*** finished standard tests for koala ***
Fri May  6 00:12:11 CDT 2011
Total time = 0m 46s
*** finished tests in koala ***
Testing loyalty
ssh loyalty -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname loyalty
grep: /proc/cpuinfo: No such file or directory
12:11AM  up 1 day, 12:16, 1 user, load averages: 0.00, 0.00, 0.00
Filesystem       1K-blocks      Used     Avail Capacity  Mounted on
/dev/da0s1a         507630    103646    363374    22%    /
devfs                    1         1         0   100%    /dev
/dev/da0s1g       58896528   6901430  47283376    13%    /local_home
/dev/da0s1f       16244334   4473868  10470920    30%    /usr
/dev/da0s1d        1012974    191252    740686    21%    /var
/dev/da0s1e         507630     16736    450284     4%    /var/tmp
procfs                   4         4         0   100%    /proc
jam:/home        198351840  14499272 173614208     8%    /home
jam:/mnt/hdf     961432072 744781888 167812184    82%    /mnt/hdf
jam:/mnt/scr1    961432072 839420784  73173288    92%    /mnt/scr1
gumund:/data/web 480719056 287530308 168769548    63%    /mnt/web
gumund:/data/ftp 480719056 287530308 168769548    63%    /mnt/ftp
devfs                    1         1         0   100%    /var/named/dev
/dev/md0            126702      5754    110812     5%    /tmp
TEST_TYPES=standard
Fri May  6 00:11:28 CDT 2011
*** starting standard tests in loyalty ***
Uname -a: FreeBSD loyalty.hdfgroup.uiuc.edu 8.2-STABLE FreeBSD 8.2-STABLE #0: Tue May  3 22:23:36 CDT 2011     sukoziol at loyalty.hdfgroup.uiuc.edu:/usr/obj/usr/src/sys/LOYALTY  i386
   /mnt/scr1/SnapTest/snapshots-opa/log/loyalty_0506Fri_0011
*** finished standard tests for loyalty ***
Fri May  6 00:12:46 CDT 2011
Total time = 1m 18s
*** finished tests in loyalty ***
Testing freedom
ssh freedom -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname freedom
12:11AM  up 1 day, 12:14, 3 users, load averages: 0.00, 0.00, 0.00
/dev/da0s1a         507630    116204    350816    25%    /
/dev/da0s1g       45184754   5664680  35905294    14%    /local_home
/dev/da0s1f       24372460   4988122  17434542    22%    /usr
/dev/da0s1d        2026030    191144   1672804    10%    /var
/dev/da0s1e        1012974       112    931826     0%    /var/tmp
jam:/home        198351840  14499272 173614208     8%    /usr/home
jam:/mnt/scr1    961432072 839464736  73129336    92%    /mnt/scr1
/dev/md0            126702      5834    110732     5%    /tmp
TEST_TYPES=standard
Fri May  6 00:11:30 CDT 2011
*** starting standard tests in freedom ***
Uname -a: FreeBSD freedom.hdfgroup.uiuc.edu 8.2-STABLE FreeBSD 8.2-STABLE #0: Tue May  3 22:26:37 CDT 2011     sukoziol at freedom.hdfgroup.uiuc.edu:/usr/obj/usr/src/sys/FREEDOM  amd64
   /mnt/scr1/SnapTest/snapshots-opa/log/freedom_0506Fri_0011
*** finished standard tests for freedom ***
Fri May  6 00:12:35 CDT 2011
Total time = 1m 5s
*** finished tests in freedom ***
More information about the opa-nightly-tests mailing list
