[opa-nightly-tests] jam OPA_Daily_Tests_0504Wed_FAILED!!!
Dave Goodell
goodell at mcs.anl.gov
Wed May 4 09:26:34 CDT 2011
Is this the same issue we were seeing before? The output appears to have changed (we are missing the actual "make check" output for some reason...
-Dave
On May 4, 2011, at 12:19 AM CDT, HDF Tester wrote:
> *** OPA Tests on 0504Wed ***
> Tests Summary
> ****FAILED amani: standard****
> PASSED freedom: standard
> PASSED heiwa: standard
> PASSED jam: standard
> PASSED koala: standard
> PASSED linew: standard
> PASSED loyalty: standard
> Tests Time Summary
> amani: Ran 1(0/1/0) tests, Grand total test time = 0m 1s
> koala: Ran 1(1/0/0) tests, Grand total test time = 0m 44s
> jam: Ran 1(1/0/0) tests, Grand total test time = 1m 20s
> freedom: Ran 1(1/0/0) tests, Grand total test time = 1m 25s
> loyalty: Ran 1(1/0/0) tests, Grand total test time = 1m 28s
> heiwa: Ran 1(1/0/0) tests, Grand total test time = 5m 35s
> linew: Ran 1(1/0/0) tests, Grand total test time = 7m 51s
> jam: Ran 7(0/0/0) hosts, Grand total test time = 8m 49s
> Timekeeper log
> Timekeeper started at Wed May 4 00:10:29 CDT 2011
> Timekeeper sleeping for 1800 seconds
> Tests Failures
> Dumping logfile of amani: standard
> Last 50 lines of /mnt/scr1/SnapTest/snapshots-opa/log/amani_0504Wed_0010
> SVNROOT=http://svn.hdfgroup.uiuc.edu
> USER=hdftest
> _=/usr/bin/printenv
> VENDOR=unknown
> ===Done Dumping environment variables before option parsing ===
> ===Dumping environment variables after option parsing ===
> CCACHE_DISABLE=yes
> CVSROOT=/mnt/hdf/cvs
> EC2_CERT=/home/hdftest/.ec2/cert-6HKISUOM3HT2PWDQB4PLG67KTWOVVKOK.pem
> EC2_HOME=/mnt/hdf/ec2-api-tools
> EC2_PRIVATE_KEY=/home/hdftest/.ec2/pk-6HKISUOM3HT2PWDQB4PLG67KTWOVVKOK.pem
> G_BROKEN_FILENAMES=1
> GROUP=hdf
> HDF5TestExpress=yes
> HOME=/home/hdftest
> HOST=amani
> HOSTTYPE=x86_64-linux
> JAVA_HOME=/usr/java/jdk-106/jdk
> KRB5CCNAME=FILE:/tmp/krb5cc_27429_uxDKC14181
> LANG=en_US.UTF-8
> LESSOPEN=|/usr/bin/lesspipe.sh %s
> LOGNAME=hdftest
> LS_COLORS=
> MACHTYPE=x86_64
> MAIL=/var/spool/mail/hdftest
> MAKE=gmake -j 2
> MANPATH=/usr/local/man:/usr/share/man:/usr/kerberos/man
> OSTYPE=linux
> PATH=/home/hdftest/bin:/usr/hdf/bin:/home/hdftest/bin:/usr/hdf/bin:/usr/local/bin:/bin:/usr/bin:/usr/kerberos/bin:/mnt/hdf/ec2-api-tools/bin
> PWD=/mnt/scr1/SnapTest/snapshots-opa
> SET_PATH=yes
> SHELL=/bin/tcsh
> SHLVL=3
> SSH_ASKPASS=/usr/libexec/openssh/gnome-ssh-askpass
> SSH_CLIENT=72.36.68.169 55963 22
> SSH_CONNECTION=72.36.68.169 55963 72.36.68.153 22
> USER=hdftest
> _=/usr/bin/printenv
> VENDOR=unknown
> ===Done Dumping environment variables after option parsing ===
> ===== Run Tests: Wed May 4 00:10:23 CDT 2011 =====
> Remove contents of amani.\n
> ===== configure: Wed May 4 00:10:23 CDT 2011 =====
> checking for a BSD-compatible install... /usr/bin/install -c
> checking whether build environment is sane... configure: error: newly created file is older than distributed files!
> Check your system clock
> Failed running configure
> ===== Exit bin/snapshot with status=1: Wed May 4 00:10:24 CDT 2011 =====
> Dumping done
> Runtest did not exit normally.
> Watchers List
> OPA Daily test features/platforms watchers and procedure
> Procedure:
> The watcher will investigate and report the cause of failure by 11am.
> The developer who checked in the error code may report so by then too.
> The watcher or the developer should get the failure fixed and report it
> by 3pm.
> Watcher for OPA: Neil
> updated: 2009/05/05
> Tests Details
> 00:10:09 up 89 days, 14:41, 75 users, load average: 1.06, 1.26, 2.56
> Filesystem 1K-blocks Used Available Use% Mounted on
> /dev/sda3 31738420 3843612 26256580 13% /
> /dev/sda1 101086 22885 72982 24% /boot
> /dev/sda2 31738420 468876 29631316 2% /tmp
> /dev/sda6 31738392 6475048 23625120 22% /var
> /dev/sda7 31738392 25907416 4192752 87% /usr
> /dev/sda8 124991068 7135584 111403784 7% /var/tmp
> /dev/mapper/VolGroup00-home
> 198351840 13812044 174301436 8% /home
> /dev/sde1 565688764 391457712 145032116 73% /scr
> /dev/sdc1 961432072 832154016 80440056 92% /mnt/scr1
> /dev/sdd1 961432072 743528896 169065176 82% /mnt/hdf
> tmpfs 8313848 16 8313832 1% /dev/shm
> gumund:/data/ftp 480719072 287527200 168772672 64% /mnt/ftp
> gumund:/data/web 480719072 287527200 168772672 64% /mnt/web
> STANDARD_OPT=op-configure --prefix=${PWD}/opainstall
> TEST_TYPES=standard
> Running source repository checkout with output saved in
> /mnt/scr1/SnapTest/snapshots-opa/log/REPO_LOG_0504Wed
> Checking MANIFEST file ...
> cat: /mnt/scr1/SnapTest/snapshots-opa/log/#runtest.0504Wed.17689: No such file or directory
> rm: cannot remove `/mnt/scr1/SnapTest/snapshots-opa/log/#runtest.0504Wed.17689': No such file or directory
> *** launching tests from jam ***
> TESTHOST is linew
> jam
> amani
> heiwa
> koala
> loyalty
> freedom
> Fork off timekeeper 30
> Testing linew
> ssh linew -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname linew
> 12:10am up 53 day(s), 6:07, 8 users, load average: 2.25, 2.04, 1.59
> / (/dev/dsk/c1t0d0s0 ):67275890 blocks 8242147 files
> /devices (/devices ): 0 blocks 0 files
> /system/contract (ctfs ): 0 blocks 2147483601 files
> /proc (proc ): 0 blocks 29897 files
> /etc/mnttab (mnttab ): 0 blocks 0 files
> /etc/svc/volatile (swap ):19647488 blocks 1182156 files
> /system/object (objfs ): 0 blocks 2147483490 files
> /etc/dfs/sharetab (sharefs ): 0 blocks 2147483646 files
> /platform/sun4u-us3/lib/libc_psr.so.1(/platform/sun4u-us3/lib/libc_psr/libc_psr_hwcap1.so.1):67275890 blocks 8242147 files
> /platform/sun4u-us3/lib/sparcv9/libc_psr.so.1(/platform/sun4u-us3/lib/sparcv9/libc_psr/libc_psr_hwcap1.so.1):67275890 blocks 8242147 files
> /dev/fd (fd ): 0 blocks 0 files
> /tmp (swap ):19647488 blocks 1182156 files
> /var/run (swap ):19647488 blocks 1182156 files
> /scr (/dev/dsk/c1t1d0s0 ):890421180 blocks 226805930 files
> /home (jam:/home ):369079592 blocks 50947274 files
> /mnt/hdf (jam:/mnt/hdf ):435806352 blocks 113975632 files
> /mnt/scr1 (jam:/mnt/scr1 ):258556056 blocks 115709861 files
> /mnt/web (gumund:/mnt/web ):386383736 blocks 60893364 files
> /mnt/ftp (gumund:/mnt/ftp ):386383736 blocks 60893364 files
> TEST_TYPES=standard
> Wed May 4 00:11:17 CDT 2011
> *** starting standard tests in linew ***
> Uname -a: SunOS linew 5.10 Generic_144488-07 sun4u sparc SUNW,A70
> Running snapshot with output saved in
> /mnt/scr1/SnapTest/snapshots-opa/log/linew_0504Wed_0011
> *** finished standard tests for linew ***
> Wed May 4 00:18:59 CDT 2011
> Total time = 7m 42s
> *** finished tests in linew ***
> Wed May 4 00:19:00 CDT 2011
> Testing jam
> ssh jam -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname jam
> 00:10:37 up 89 days, 14:42, 75 users, load average: 1.18, 1.27, 2.52
> /dev/sda2 31738420 468996 29631196 2% /tmp
> /dev/sda6 31738392 6475052 23625116 22% /var
> /dev/sdc1 961432072 832154052 80440020 92% /mnt/scr1
> TEST_TYPES=standard
> Wed May 4 00:10:47 CDT 2011
> *** starting standard tests in jam ***
> Uname -a: Linux jam 2.6.18-194.3.1.el5PAE #1 SMP Thu May 13 13:48:44 EDT 2010 i686 i686 i386 GNU/Linux
> /mnt/scr1/SnapTest/snapshots-opa/log/jam_0504Wed_0010
> *** finished standard tests for jam ***
> Wed May 4 00:12:07 CDT 2011
> Total time = 1m 20s
> *** finished tests in jam ***
> Testing amani
> ssh amani -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname amani
> 00:10:13 up 14 days, 8:16, 8 users, load average: 0.01, 0.01, 0.14
> /dev/hda6 39021196 28868700 8138352 79% /
> /dev/hda3 12192636 4175632 7387660 37% /var
> /dev/hda2 12192636 162584 11400708 2% /tmp
> /dev/hda1 101086 30048 65819 32% /boot
> /dev/sdb1 144221592 76228912 60666640 56% /scr
> tmpfs 2057492 0 2057492 0% /dev/shm
> jam:/home 198351840 13812032 174301440 8% /home
> jam:/mnt/hdf 961432096 743528896 169065184 82% /mnt/hdf
> jam:/mnt/scr1 961432096 832154080 80440032 92% /mnt/scr1
> TEST_TYPES=standard
> *** starting standard tests in amani ***
> Uname -a: Linux amani 2.6.18-238.9.1.el5 #1 SMP Tue Apr 12 18:10:13 EDT 2011 x86_64 x86_64 x86_64 GNU/Linux
> *** finished standard tests for amani ***
> Total time = 0m 1s
> *** finished tests in amani ***
> ****SYSTEM ERROR amani: Abnormal exit from runtest ****
> Wed May 4 00:19:08 CDT 2011
> ****SYSTEM ERROR amani: runtest command failed ****
> Testing heiwa
> ssh heiwa -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname heiwa
> 00:11:02 up 13 days, 12:24, 2 users, load average: 0.00, 0.00, 0.00
> /dev/sdb8 35435232 2722436 30912756 9% /
> tmpfs 2008144 0 2008144 0% /dev/shm
> /dev/sdb4 198337 106660 81437 57% /boot
> /dev/sdb6 12385456 3162608 8593704 27% /tmp
> /dev/sdb7 12385456 4880904 6875408 42% /var
> /dev/sda6 82573108 878148 77500392 2% /scr
> gumund:/mnt/web 480719072 287527200 168772672 64% /mnt/web
> gumund:/mnt/ftp 480719072 287527200 168772672 64% /mnt/ftp
> TEST_TYPES=standard
> Wed May 4 00:11:13 CDT 2011
> *** starting standard tests in heiwa ***
> Uname -a: Linux heiwa 2.6.32.16-150.fc12.ppc64 #1 SMP Sat Jul 24 05:19:27 UTC 2010 ppc64 ppc64 ppc64 GNU/Linux
> /mnt/scr1/SnapTest/snapshots-opa/log/heiwa_0504Wed_0011
> *** finished standard tests for heiwa ***
> Wed May 4 00:16:47 CDT 2011
> Total time = 5m 34s
> *** finished tests in heiwa ***
> Testing koala
> ssh koala -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname koala
> 00:11:07 up 14 days, 8:15, 3 users, load average: 0.00, 0.00, 0.00
> /dev/sda7 22292052 10685796 10455604 51% /
> /dev/sda5 12192608 411720 11151544 4% /tmp
> /dev/sda3 12192636 1460592 10102700 13% /var
> /dev/sda1 101086 30464 65403 32% /boot
> tmpfs 6149588 0 6149588 0% /dev/shm
> /dev/md0 48091528 6078808 39569792 14% /scr
> jam:/mnt/scr1 961432096 832154080 80440000 92% /mnt/scr1
> TEST_TYPES=standard
> *** starting standard tests in koala ***
> Uname -a: Linux koala 2.6.18-238.9.1.el5 #1 SMP Tue Apr 12 18:10:13 EDT 2011 x86_64 x86_64 x86_64 GNU/Linux
> /mnt/scr1/SnapTest/snapshots-opa/log/koala_0504Wed_0011
> *** finished standard tests for koala ***
> Wed May 4 00:12:01 CDT 2011
> Total time = 0m 44s
> *** finished tests in koala ***
> Testing loyalty
> ssh loyalty -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname loyalty
> grep: /proc/cpuinfo: No such file or directory
> 12:11AM up 7 days, 13:49, 4 users, load averages: 0.00, 0.00, 0.00
> Filesystem 1K-blocks Used Avail Capacity Mounted on
> /dev/da0s1a 507630 215730 251290 46% /
> devfs 1 1 0 100% /dev
> /dev/da0s1g 58896528 7067104 47117702 13% /local_home
> /dev/da0s1f 16244334 4457208 10487580 30% /usr
> /dev/da0s1d 1012974 191166 740772 21% /var
> /dev/da0s1e 507630 16732 450288 4% /var/tmp
> procfs 4 4 0 100% /proc
> jam:/home 198351840 13812044 174301436 7% /home
> jam:/mnt/hdf 961432072 743528896 169065176 81% /mnt/hdf
> jam:/mnt/scr1 961432072 832154084 80439988 91% /mnt/scr1
> gumund:/data/web 480719056 287527188 168772668 63% /mnt/web
> gumund:/data/ftp 480719056 287527188 168772668 63% /mnt/ftp
> devfs 1 1 0 100% /var/named/dev
> /dev/md0 126702 12 116554 0% /tmp
> TEST_TYPES=standard
> Wed May 4 00:11:19 CDT 2011
> *** starting standard tests in loyalty ***
> Uname -a: FreeBSD loyalty.hdfgroup.uiuc.edu 8.2-PRERELEASE FreeBSD 8.2-PRERELEASE #1: Tue Feb 1 20:47:02 CST 2011 sukoziol at loyalty.hdfgroup.uiuc.edu:/usr/obj/usr/src/sys/LOYALTY i386
> /mnt/scr1/SnapTest/snapshots-opa/log/loyalty_0504Wed_0011
> *** finished standard tests for loyalty ***
> Wed May 4 00:12:47 CDT 2011
> Total time = 1m 28s
> *** finished tests in loyalty ***
> Testing freedom
> ssh freedom -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname freedom
> 12:11AM up 7 days, 13:46, 3 users, load averages: 0.00, 0.00, 0.00
> /dev/da0s1a 507630 70670 396350 15% /
> /dev/da0s1g 45184754 8528674 33041300 21% /local_home
> /dev/da0s1f 24372460 4960936 17461728 22% /usr
> /dev/da0s1d 2026030 159338 1704610 9% /var
> /dev/da0s1e 1012974 108 931830 0% /var/tmp
> jam:/home 198351840 13812044 174301436 7% /usr/home
> jam:/mnt/scr1 961432072 832154096 80439976 91% /mnt/scr1
> TEST_TYPES=standard
> Wed May 4 00:11:22 CDT 2011
> *** starting standard tests in freedom ***
> Uname -a: FreeBSD freedom.hdfgroup.uiuc.edu 8.2-PRERELEASE FreeBSD 8.2-PRERELEASE #0: Wed Feb 2 14:32:23 CST 2011 sukoziol at freedom.hdfgroup.uiuc.edu:/usr/obj/usr/src/sys/FREEDOM amd64
> /mnt/scr1/SnapTest/snapshots-opa/log/freedom_0504Wed_0011
> *** finished standard tests for freedom ***
> Wed May 4 00:12:46 CDT 2011
> Total time = 1m 24s
> *** finished tests in freedom ***
> opa-nightly-tests mailing list
> opa-nightly-tests at lists.mcs.anl.gov
> https://lists.mcs.anl.gov/mailman/listinfo/opa-nightly-tests
More information about the opa-nightly-tests
