[opa-nightly-tests] jam OPA_Daily_Tests_0504Wed_FAILED!!!
HDF Tester
hdftest at hdfgroup.org
Wed May 4 00:19:08 CDT 2011
*** OPA Tests on 0504Wed ***
Tests Summary
****FAILED amani: standard****
PASSED freedom: standard
PASSED heiwa: standard
PASSED jam: standard
PASSED koala: standard
PASSED linew: standard
PASSED loyalty: standard
Tests Time Summary
amani: Ran 1(0/1/0) tests, Grand total test time = 0m 1s
koala: Ran 1(1/0/0) tests, Grand total test time = 0m 44s
jam: Ran 1(1/0/0) tests, Grand total test time = 1m 20s
freedom: Ran 1(1/0/0) tests, Grand total test time = 1m 25s
loyalty: Ran 1(1/0/0) tests, Grand total test time = 1m 28s
heiwa: Ran 1(1/0/0) tests, Grand total test time = 5m 35s
linew: Ran 1(1/0/0) tests, Grand total test time = 7m 51s
jam: Ran 7(0/0/0) hosts, Grand total test time = 8m 49s
Timekeeper log
Timekeeper started at Wed May 4 00:10:29 CDT 2011
Timekeeper sleeping for 1800 seconds
Tests Failures
Dumping logfile of amani: standard
Last 50 lines of /mnt/scr1/SnapTest/snapshots-opa/log/amani_0504Wed_0010
SVNROOT=http://svn.hdfgroup.uiuc.edu
USER=hdftest
_=/usr/bin/printenv
VENDOR=unknown
===Done Dumping environment variables before option parsing ===
===Dumping environment variables after option parsing ===
CCACHE_DISABLE=yes
CVSROOT=/mnt/hdf/cvs
EC2_CERT=/home/hdftest/.ec2/cert-6HKISUOM3HT2PWDQB4PLG67KTWOVVKOK.pem
EC2_HOME=/mnt/hdf/ec2-api-tools
EC2_PRIVATE_KEY=/home/hdftest/.ec2/pk-6HKISUOM3HT2PWDQB4PLG67KTWOVVKOK.pem
G_BROKEN_FILENAMES=1
GROUP=hdf
HDF5TestExpress=yes
HOME=/home/hdftest
HOST=amani
HOSTTYPE=x86_64-linux
JAVA_HOME=/usr/java/jdk-106/jdk
KRB5CCNAME=FILE:/tmp/krb5cc_27429_uxDKC14181
LANG=en_US.UTF-8
LESSOPEN=|/usr/bin/lesspipe.sh %s
LOGNAME=hdftest
LS_COLORS=
MACHTYPE=x86_64
MAIL=/var/spool/mail/hdftest
MAKE=gmake -j 2
MANPATH=/usr/local/man:/usr/share/man:/usr/kerberos/man
OSTYPE=linux
PATH=/home/hdftest/bin:/usr/hdf/bin:/home/hdftest/bin:/usr/hdf/bin:/usr/local/bin:/bin:/usr/bin:/usr/kerberos/bin:/mnt/hdf/ec2-api-tools/bin
PWD=/mnt/scr1/SnapTest/snapshots-opa
SET_PATH=yes
SHELL=/bin/tcsh
SHLVL=3
SSH_ASKPASS=/usr/libexec/openssh/gnome-ssh-askpass
SSH_CLIENT=72.36.68.169 55963 22
SSH_CONNECTION=72.36.68.169 55963 72.36.68.153 22
USER=hdftest
_=/usr/bin/printenv
VENDOR=unknown
===Done Dumping environment variables after option parsing ===
===== Run Tests: Wed May 4 00:10:23 CDT 2011 =====
Remove contents of amani.\n
===== configure: Wed May 4 00:10:23 CDT 2011 =====
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... configure: error: newly created file is older than distributed files!
Check your system clock
Failed running configure
===== Exit bin/snapshot with status=1: Wed May 4 00:10:24 CDT 2011 =====
Dumping done
Runtest did not exit normally.
Watchers List
OPA Daily test features/platforms watchers and procedure
Procedure:
The watcher will investigate and report the cause of failure by 11am.
The developer who checked in the error code may report so by then too.
The watcher or the developer should get the failure fixed and report it
by 3pm.
Watcher for OPA: Neil
updated: 2009/05/05
Tests Details
00:10:09 up 89 days, 14:41, 75 users, load average: 1.06, 1.26, 2.56
Filesystem 1K-blocks Used Available Use% Mounted on
/dev/sda3 31738420 3843612 26256580 13% /
/dev/sda1 101086 22885 72982 24% /boot
/dev/sda2 31738420 468876 29631316 2% /tmp
/dev/sda6 31738392 6475048 23625120 22% /var
/dev/sda7 31738392 25907416 4192752 87% /usr
/dev/sda8 124991068 7135584 111403784 7% /var/tmp
/dev/mapper/VolGroup00-home
198351840 13812044 174301436 8% /home
/dev/sde1 565688764 391457712 145032116 73% /scr
/dev/sdc1 961432072 832154016 80440056 92% /mnt/scr1
/dev/sdd1 961432072 743528896 169065176 82% /mnt/hdf
tmpfs 8313848 16 8313832 1% /dev/shm
gumund:/data/ftp 480719072 287527200 168772672 64% /mnt/ftp
gumund:/data/web 480719072 287527200 168772672 64% /mnt/web
STANDARD_OPT=op-configure --prefix=${PWD}/opainstall
TEST_TYPES=standard
Running source repository checkout with output saved in
/mnt/scr1/SnapTest/snapshots-opa/log/REPO_LOG_0504Wed
Checking MANIFEST file ...
cat: /mnt/scr1/SnapTest/snapshots-opa/log/#runtest.0504Wed.17689: No such file or directory
rm: cannot remove `/mnt/scr1/SnapTest/snapshots-opa/log/#runtest.0504Wed.17689': No such file or directory
*** launching tests from jam ***
TESTHOST is linew
jam
amani
heiwa
koala
loyalty
freedom
Fork off timekeeper 30
Testing linew
ssh linew -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname linew
12:10am up 53 day(s), 6:07, 8 users, load average: 2.25, 2.04, 1.59
/ (/dev/dsk/c1t0d0s0 ):67275890 blocks 8242147 files
/devices (/devices ): 0 blocks 0 files
/system/contract (ctfs ): 0 blocks 2147483601 files
/proc (proc ): 0 blocks 29897 files
/etc/mnttab (mnttab ): 0 blocks 0 files
/etc/svc/volatile (swap ):19647488 blocks 1182156 files
/system/object (objfs ): 0 blocks 2147483490 files
/etc/dfs/sharetab (sharefs ): 0 blocks 2147483646 files
/platform/sun4u-us3/lib/libc_psr.so.1(/platform/sun4u-us3/lib/libc_psr/libc_psr_hwcap1.so.1):67275890 blocks 8242147 files
/platform/sun4u-us3/lib/sparcv9/libc_psr.so.1(/platform/sun4u-us3/lib/sparcv9/libc_psr/libc_psr_hwcap1.so.1):67275890 blocks 8242147 files
/dev/fd (fd ): 0 blocks 0 files
/tmp (swap ):19647488 blocks 1182156 files
/var/run (swap ):19647488 blocks 1182156 files
/scr (/dev/dsk/c1t1d0s0 ):890421180 blocks 226805930 files
/home (jam:/home ):369079592 blocks 50947274 files
/mnt/hdf (jam:/mnt/hdf ):435806352 blocks 113975632 files
/mnt/scr1 (jam:/mnt/scr1 ):258556056 blocks 115709861 files
/mnt/web (gumund:/mnt/web ):386383736 blocks 60893364 files
/mnt/ftp (gumund:/mnt/ftp ):386383736 blocks 60893364 files
TEST_TYPES=standard
Wed May 4 00:11:17 CDT 2011
*** starting standard tests in linew ***
Uname -a: SunOS linew 5.10 Generic_144488-07 sun4u sparc SUNW,A70
Running snapshot with output saved in
/mnt/scr1/SnapTest/snapshots-opa/log/linew_0504Wed_0011
*** finished standard tests for linew ***
Wed May 4 00:18:59 CDT 2011
Total time = 7m 42s
*** finished tests in linew ***
Wed May 4 00:19:00 CDT 2011
Testing jam
ssh jam -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname jam
00:10:37 up 89 days, 14:42, 75 users, load average: 1.18, 1.27, 2.52
/dev/sda2 31738420 468996 29631196 2% /tmp
/dev/sda6 31738392 6475052 23625116 22% /var
/dev/sdc1 961432072 832154052 80440020 92% /mnt/scr1
TEST_TYPES=standard
Wed May 4 00:10:47 CDT 2011
*** starting standard tests in jam ***
Uname -a: Linux jam 2.6.18-194.3.1.el5PAE #1 SMP Thu May 13 13:48:44 EDT 2010 i686 i686 i386 GNU/Linux
/mnt/scr1/SnapTest/snapshots-opa/log/jam_0504Wed_0010
*** finished standard tests for jam ***
Wed May 4 00:12:07 CDT 2011
Total time = 1m 20s
*** finished tests in jam ***
Testing amani
ssh amani -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname amani
00:10:13 up 14 days, 8:16, 8 users, load average: 0.01, 0.01, 0.14
/dev/hda6 39021196 28868700 8138352 79% /
/dev/hda3 12192636 4175632 7387660 37% /var
/dev/hda2 12192636 162584 11400708 2% /tmp
/dev/hda1 101086 30048 65819 32% /boot
/dev/sdb1 144221592 76228912 60666640 56% /scr
tmpfs 2057492 0 2057492 0% /dev/shm
jam:/home 198351840 13812032 174301440 8% /home
jam:/mnt/hdf 961432096 743528896 169065184 82% /mnt/hdf
jam:/mnt/scr1 961432096 832154080 80440032 92% /mnt/scr1
TEST_TYPES=standard
*** starting standard tests in amani ***
Uname -a: Linux amani 2.6.18-238.9.1.el5 #1 SMP Tue Apr 12 18:10:13 EDT 2011 x86_64 x86_64 x86_64 GNU/Linux
*** finished standard tests for amani ***
Total time = 0m 1s
*** finished tests in amani ***
****SYSTEM ERROR amani: Abnormal exit from runtest ****
****SYSTEM ERROR amani: runtest command failed ****
Testing heiwa
ssh heiwa -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname heiwa
00:11:02 up 13 days, 12:24, 2 users, load average: 0.00, 0.00, 0.00
/dev/sdb8 35435232 2722436 30912756 9% /
tmpfs 2008144 0 2008144 0% /dev/shm
/dev/sdb4 198337 106660 81437 57% /boot
/dev/sdb6 12385456 3162608 8593704 27% /tmp
/dev/sdb7 12385456 4880904 6875408 42% /var
/dev/sda6 82573108 878148 77500392 2% /scr
gumund:/mnt/web 480719072 287527200 168772672 64% /mnt/web
gumund:/mnt/ftp 480719072 287527200 168772672 64% /mnt/ftp
TEST_TYPES=standard
Wed May 4 00:11:13 CDT 2011
*** starting standard tests in heiwa ***
Uname -a: Linux heiwa 2.6.32.16-150.fc12.ppc64 #1 SMP Sat Jul 24 05:19:27 UTC 2010 ppc64 ppc64 ppc64 GNU/Linux
/mnt/scr1/SnapTest/snapshots-opa/log/heiwa_0504Wed_0011
*** finished standard tests for heiwa ***
Wed May 4 00:16:47 CDT 2011
Total time = 5m 34s
*** finished tests in heiwa ***
Testing koala
ssh koala -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname koala
00:11:07 up 14 days, 8:15, 3 users, load average: 0.00, 0.00, 0.00
/dev/sda7 22292052 10685796 10455604 51% /
/dev/sda5 12192608 411720 11151544 4% /tmp
/dev/sda3 12192636 1460592 10102700 13% /var
/dev/sda1 101086 30464 65403 32% /boot
tmpfs 6149588 0 6149588 0% /dev/shm
/dev/md0 48091528 6078808 39569792 14% /scr
jam:/mnt/scr1 961432096 832154080 80440000 92% /mnt/scr1
TEST_TYPES=standard
*** starting standard tests in koala ***
Uname -a: Linux koala 2.6.18-238.9.1.el5 #1 SMP Tue Apr 12 18:10:13 EDT 2011 x86_64 x86_64 x86_64 GNU/Linux
/mnt/scr1/SnapTest/snapshots-opa/log/koala_0504Wed_0011
*** finished standard tests for koala ***
Wed May 4 00:12:01 CDT 2011
Total time = 0m 44s
*** finished tests in koala ***
Testing loyalty
ssh loyalty -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname loyalty
grep: /proc/cpuinfo: No such file or directory
12:11AM up 7 days, 13:49, 4 users, load averages: 0.00, 0.00, 0.00
Filesystem 1K-blocks Used Avail Capacity Mounted on
/dev/da0s1a 507630 215730 251290 46% /
devfs 1 1 0 100% /dev
/dev/da0s1g 58896528 7067104 47117702 13% /local_home
/dev/da0s1f 16244334 4457208 10487580 30% /usr
/dev/da0s1d 1012974 191166 740772 21% /var
/dev/da0s1e 507630 16732 450288 4% /var/tmp
procfs 4 4 0 100% /proc
jam:/home 198351840 13812044 174301436 7% /home
jam:/mnt/hdf 961432072 743528896 169065176 81% /mnt/hdf
jam:/mnt/scr1 961432072 832154084 80439988 91% /mnt/scr1
gumund:/data/web 480719056 287527188 168772668 63% /mnt/web
gumund:/data/ftp 480719056 287527188 168772668 63% /mnt/ftp
devfs 1 1 0 100% /var/named/dev
/dev/md0 126702 12 116554 0% /tmp
TEST_TYPES=standard
Wed May 4 00:11:19 CDT 2011
*** starting standard tests in loyalty ***
Uname -a: FreeBSD loyalty.hdfgroup.uiuc.edu 8.2-PRERELEASE FreeBSD 8.2-PRERELEASE #1: Tue Feb 1 20:47:02 CST 2011 sukoziol at loyalty.hdfgroup.uiuc.edu:/usr/obj/usr/src/sys/LOYALTY i386
/mnt/scr1/SnapTest/snapshots-opa/log/loyalty_0504Wed_0011
*** finished standard tests for loyalty ***
Wed May 4 00:12:47 CDT 2011
Total time = 1m 28s
*** finished tests in loyalty ***
Testing freedom
ssh freedom -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname freedom
12:11AM up 7 days, 13:46, 3 users, load averages: 0.00, 0.00, 0.00
/dev/da0s1a 507630 70670 396350 15% /
/dev/da0s1g 45184754 8528674 33041300 21% /local_home
/dev/da0s1f 24372460 4960936 17461728 22% /usr
/dev/da0s1d 2026030 159338 1704610 9% /var
/dev/da0s1e 1012974 108 931830 0% /var/tmp
jam:/home 198351840 13812044 174301436 7% /usr/home
jam:/mnt/scr1 961432072 832154096 80439976 91% /mnt/scr1
TEST_TYPES=standard
Wed May 4 00:11:22 CDT 2011
*** starting standard tests in freedom ***
Uname -a: FreeBSD freedom.hdfgroup.uiuc.edu 8.2-PRERELEASE FreeBSD 8.2-PRERELEASE #0: Wed Feb 2 14:32:23 CST 2011 sukoziol at freedom.hdfgroup.uiuc.edu:/usr/obj/usr/src/sys/FREEDOM amd64
/mnt/scr1/SnapTest/snapshots-opa/log/freedom_0504Wed_0011
*** finished standard tests for freedom ***
Wed May 4 00:12:46 CDT 2011
Total time = 1m 24s
*** finished tests in freedom ***
More information about the opa-nightly-tests
