[opa-nightly-tests] jam OPA_Daily_Tests_0503Tue_FAILED!!!
HDF Tester hdftest at hdfgroup.org
Tue May 3 00:19:07 CDT 2011
*** OPA Tests on 0503Tue ***
   Tests Summary
****FAILED amani: standard****
PASSED freedom: standard
PASSED heiwa: standard
PASSED jam: standard
PASSED koala: standard
PASSED linew: standard
PASSED loyalty: standard
   Tests Time Summary
amani: Ran 1(0/1/0) tests, Grand total test time =  0m 2s
koala: Ran 1(1/0/0) tests, Grand total test time =  0m 44s
freedom: Ran 1(1/0/0) tests, Grand total test time =  1m 7s
jam: Ran 1(1/0/0) tests, Grand total test time =  1m 22s
loyalty: Ran 1(1/0/0) tests, Grand total test time =  1m 21s
heiwa: Ran 1(1/0/0) tests, Grand total test time =  5m 36s
linew: Ran 1(1/0/0) tests, Grand total test time =  7m 50s
jam: Ran 7(0/0/0) hosts, Grand total test time =  8m 47s
   Timekeeper log
Timekeeper started at Tue May  3 00:10:30 CDT 2011
Timekeeper sleeping for 1800 seconds
   Tests Failures
Dumping logfile of amani: standard
Last 50 lines of /mnt/scr1/SnapTest/snapshots-opa/log/amani_0503Tue_0010
SVNROOT=http://svn.hdfgroup.uiuc.edu
USER=hdftest
_=/usr/bin/printenv
VENDOR=unknown
===Done Dumping environment variables before option parsing ===
===Dumping environment variables after option parsing ===
CCACHE_DISABLE=yes
CVSROOT=/mnt/hdf/cvs
EC2_CERT=/home/hdftest/.ec2/cert-6HKISUOM3HT2PWDQB4PLG67KTWOVVKOK.pem
EC2_HOME=/mnt/hdf/ec2-api-tools
EC2_PRIVATE_KEY=/home/hdftest/.ec2/pk-6HKISUOM3HT2PWDQB4PLG67KTWOVVKOK.pem
G_BROKEN_FILENAMES=1
GROUP=hdf
HDF5TestExpress=yes
HOME=/home/hdftest
HOST=amani
HOSTTYPE=x86_64-linux
JAVA_HOME=/usr/java/jdk-106/jdk
KRB5CCNAME=FILE:/tmp/krb5cc_27429_CZuET28074
LANG=en_US.UTF-8
LESSOPEN=|/usr/bin/lesspipe.sh %s
LOGNAME=hdftest
LS_COLORS=
MACHTYPE=x86_64
MAIL=/var/spool/mail/hdftest
MAKE=gmake -j 2
MANPATH=/usr/local/man:/usr/share/man:/usr/kerberos/man
OSTYPE=linux
PATH=/home/hdftest/bin:/usr/hdf/bin:/home/hdftest/bin:/usr/hdf/bin:/usr/local/bin:/bin:/usr/bin:/usr/kerberos/bin:/mnt/hdf/ec2-api-tools/bin
PWD=/mnt/scr1/SnapTest/snapshots-opa
SET_PATH=yes
SHELL=/bin/tcsh
SHLVL=3
SSH_ASKPASS=/usr/libexec/openssh/gnome-ssh-askpass
SSH_CLIENT=72.36.68.169 53533 22
SSH_CONNECTION=72.36.68.169 53533 72.36.68.153 22
USER=hdftest
_=/usr/bin/printenv
VENDOR=unknown
===Done Dumping environment variables after option parsing ===
===== Run Tests: Tue May  3 00:10:27 CDT 2011 =====
Remove contents of amani.\n
===== configure: Tue May  3 00:10:27 CDT 2011 =====
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... configure: error: newly created file is older than distributed files!
Check your system clock
Failed running configure
===== Exit bin/snapshot with status=1: Tue May  3 00:10:28 CDT 2011 =====
Dumping done
Runtest did not exit normally.
   Watchers List
OPA Daily test features/platforms watchers and procedure
Procedure:
The watcher will investigate and report the cause of failure by 11am.
The developer who checked in the error code may report so by then too.
The watcher or the developer should get the failure fixed and report it
by 3pm.
Watcher for OPA:	 	Neil
updated: 2009/05/05
   Tests Details
 00:10:10 up 88 days, 14:41, 67 users,  load average: 1.15, 1.03, 1.18
Filesystem           1K-blocks      Used Available Use% Mounted on
/dev/sda3             31738420   3842472  26257720  13% /
/dev/sda1               101086     22885     72982  24% /boot
/dev/sda2             31738420    448400  29651792   2% /tmp
/dev/sda6             31738392   6455244  23644924  22% /var
/dev/sda7             31738392  25907416   4192752  87% /usr
/dev/sda8            124991068   7132608 111406760   7% /var/tmp
/dev/mapper/VolGroup00-home
                     198351840  13805664 174307816   8% /home
/dev/sde1            565688764 391457560 145032268  73% /scr
/dev/sdc1            961432072 830432972  82161100  91% /mnt/scr1
/dev/sdd1            961432072 744150464 168443608  82% /mnt/hdf
tmpfs                  8313848        16   8313832   1% /dev/shm
gumund:/data/ftp     480719072 287854592 168445280  64% /mnt/ftp
gumund:/data/web     480719072 287854592 168445280  64% /mnt/web
STANDARD_OPT=op-configure --prefix=${PWD}/opainstall
TEST_TYPES=standard
Running source repository checkout with output saved in
   /mnt/scr1/SnapTest/snapshots-opa/log/REPO_LOG_0503Tue
Checking MANIFEST file ...
cat: /mnt/scr1/SnapTest/snapshots-opa/log/#runtest.0503Tue.8897: No such file or directory
rm: cannot remove `/mnt/scr1/SnapTest/snapshots-opa/log/#runtest.0503Tue.8897': No such file or directory
*** launching tests from jam ***
TESTHOST is linew
jam
amani
heiwa
koala
loyalty
freedom
    Fork off timekeeper 30
Testing linew
ssh linew -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname linew
 12:10am  up 52 day(s),  6:07,  8 users,  load average: 1.20, 0.98, 0.52
/                  (/dev/dsk/c1t0d0s0 ):67278404 blocks  8242149 files
/devices           (/devices          ):       0 blocks        0 files
/system/contract   (ctfs              ):       0 blocks 2147483602 files
/proc              (proc              ):       0 blocks    29913 files
/etc/mnttab        (mnttab            ):       0 blocks        0 files
/etc/svc/volatile  (swap              ):19803856 blocks  1182160 files
/system/object     (objfs             ):       0 blocks 2147483491 files
/etc/dfs/sharetab  (sharefs           ):       0 blocks 2147483646 files
/platform/sun4u-us3/lib/libc_psr.so.1(/platform/sun4u-us3/lib/libc_psr/libc_psr_hwcap1.so.1):67278404 blocks  8242149 files
/platform/sun4u-us3/lib/sparcv9/libc_psr.so.1(/platform/sun4u-us3/lib/sparcv9/libc_psr/libc_psr_hwcap1.so.1):67278404 blocks  8242149 files
/dev/fd            (fd                ):       0 blocks        0 files
/tmp               (swap              ):19803856 blocks  1182160 files
/var/run           (swap              ):19803856 blocks  1182160 files
/scr               (/dev/dsk/c1t1d0s0 ):895050650 blocks 226804635 files
/home              (jam:/home         ):369092352 blocks 50947304 files
/mnt/hdf           (jam:/mnt/hdf      ):434563216 blocks 113950382 files
/mnt/scr1          (jam:/mnt/scr1     ):261998144 blocks 115734970 files
/mnt/web           (gumund:/mnt/web   ):385728904 blocks 60885314 files
/mnt/ftp           (gumund:/mnt/ftp   ):385728904 blocks 60885314 files
TEST_TYPES=standard
Tue May  3 00:11:11 CDT 2011
*** starting standard tests in linew ***
Uname -a: SunOS linew 5.10 Generic_144488-07 sun4u sparc SUNW,A70
Running snapshot with output saved in
   /mnt/scr1/SnapTest/snapshots-opa/log/linew_0503Tue_0011
*** finished standard tests for linew ***
Tue May  3 00:18:55 CDT 2011
Total time = 7m 44s
*** finished tests in linew ***
Tue May  3 00:18:56 CDT 2011
Testing jam
ssh jam -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname jam
 00:10:37 up 88 days, 14:42, 67 users,  load average: 1.24, 1.06, 1.19
/dev/sda2             31738420    448520  29651672   2% /tmp
/dev/sda6             31738392   6455248  23644920  22% /var
/dev/sdc1            961432072 830433008  82161064  91% /mnt/scr1
TEST_TYPES=standard
Tue May  3 00:10:47 CDT 2011
*** starting standard tests in jam ***
Uname -a: Linux jam 2.6.18-194.3.1.el5PAE #1 SMP Thu May 13 13:48:44 EDT 2010 i686 i686 i386 GNU/Linux
   /mnt/scr1/SnapTest/snapshots-opa/log/jam_0503Tue_0010
*** finished standard tests for jam ***
Tue May  3 00:12:09 CDT 2011
Total time = 1m 22s
*** finished tests in jam ***
Testing amani
ssh amani -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname amani
 00:10:16 up 13 days,  8:16,  8 users,  load average: 0.00, 0.00, 0.00
/dev/hda6             39021196  28862212   8144840  78% /
/dev/hda3             12192636   4172392   7390900  37% /var
/dev/hda2             12192636    162584  11400708   2% /tmp
/dev/hda1               101086     30048     65819  32% /boot
/dev/sdb1            144221592  76637696  60257856  56% /scr
tmpfs                  2057492         0   2057492   0% /dev/shm
jam:/home            198351840  13805664 174307840   8% /home
jam:/mnt/hdf         961432096 744150464 168443616  82% /mnt/hdf
jam:/mnt/scr1        961432096 830433024  82161056  91% /mnt/scr1
TEST_TYPES=standard
Tue May  3 00:10:26 CDT 2011
*** starting standard tests in amani ***
Uname -a: Linux amani 2.6.18-238.9.1.el5 #1 SMP Tue Apr 12 18:10:13 EDT 2011 x86_64 x86_64 x86_64 GNU/Linux
*** finished standard tests for amani ***
Total time = 0m 2s
*** finished tests in amani ***
****SYSTEM ERROR amani: Abnormal exit from runtest ****
	Tue May  3 00:19:06 CDT 2011
	****SYSTEM ERROR amani: runtest command failed ****
Testing heiwa
ssh heiwa -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname heiwa
 00:11:00 up 12 days, 12:24,  3 users,  load average: 0.00, 0.00, 0.00
/dev/sdb8             35435232   2722436  30912756   9% /
tmpfs                  2008144         0   2008144   0% /dev/shm
/dev/sdb4               198337    106660     81437  57% /boot
/dev/sdb6             12385456   2954772   8801540  26% /tmp
/dev/sdb7             12385456   4881856   6874456  42% /var
/dev/sda6             82573108    878148  77500392   2% /scr
gumund:/mnt/web      480719072 287854592 168445280  64% /mnt/web
gumund:/mnt/ftp      480719072 287854592 168445280  64% /mnt/ftp
TEST_TYPES=standard
*** starting standard tests in heiwa ***
Uname -a: Linux heiwa 2.6.32.16-150.fc12.ppc64 #1 SMP Sat Jul 24 05:19:27 UTC 2010 ppc64 ppc64 ppc64 GNU/Linux
   /mnt/scr1/SnapTest/snapshots-opa/log/heiwa_0503Tue_0011
*** finished standard tests for heiwa ***
Tue May  3 00:16:46 CDT 2011
Total time = 5m 35s
*** finished tests in heiwa ***
Testing koala
ssh koala -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname koala
 00:11:05 up 13 days,  8:14,  2 users,  load average: 0.00, 0.00, 0.00
/dev/sda7             22292052  10685496  10455904  51% /
/dev/sda5             12192608    411724  11151540   4% /tmp
/dev/sda3             12192636   1424856  10138436  13% /var
/dev/sda1               101086     30464     65403  32% /boot
tmpfs                  6149588         0   6149588   0% /dev/shm
/dev/md0              48091528   6146288  39502312  14% /scr
jam:/mnt/scr1        961432096 830433056  82161056  91% /mnt/scr1
TEST_TYPES=standard
Tue May  3 00:11:15 CDT 2011
*** starting standard tests in koala ***
Uname -a: Linux koala 2.6.18-238.9.1.el5 #1 SMP Tue Apr 12 18:10:13 EDT 2011 x86_64 x86_64 x86_64 GNU/Linux
   /mnt/scr1/SnapTest/snapshots-opa/log/koala_0503Tue_0011
*** finished standard tests for koala ***
Tue May  3 00:11:59 CDT 2011
Total time = 0m 44s
*** finished tests in koala ***
Testing loyalty
ssh loyalty -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname loyalty
grep: /proc/cpuinfo: No such file or directory
12:11AM  up 6 days, 13:49, 3 users, load averages: 0.00, 0.00, 0.00
Filesystem       1K-blocks      Used     Avail Capacity  Mounted on
/dev/da0s1a         507630    215730    251290    46%    /
devfs                    1         1         0   100%    /dev
/dev/da0s1g       58896528   7067104  47117702    13%    /local_home
/dev/da0s1f       16244334   3672492  11272296    25%    /usr
/dev/da0s1d        1012974    191428    740510    21%    /var
/dev/da0s1e         507630     16732    450288     4%    /var/tmp
procfs                   4         4         0   100%    /proc
jam:/home        198351840  13805664 174307816     7%    /home
jam:/mnt/hdf     961432072 744150464 168443608    82%    /mnt/hdf
jam:/mnt/scr1    961432072 830433040  82161032    91%    /mnt/scr1
gumund:/data/web 480719056 287854604 168445252    63%    /mnt/web
gumund:/data/ftp 480719056 287854604 168445252    63%    /mnt/ftp
devfs                    1         1         0   100%    /var/named/dev
/dev/md0            126702        12    116554     0%    /tmp
TEST_TYPES=standard
Tue May  3 00:11:17 CDT 2011
*** starting standard tests in loyalty ***
Uname -a: FreeBSD loyalty.hdfgroup.uiuc.edu 8.2-PRERELEASE FreeBSD 8.2-PRERELEASE #1: Tue Feb  1 20:47:02 CST 2011     sukoziol at loyalty.hdfgroup.uiuc.edu:/usr/obj/usr/src/sys/LOYALTY  i386
   /mnt/scr1/SnapTest/snapshots-opa/log/loyalty_0503Tue_0011
*** finished standard tests for loyalty ***
Tue May  3 00:12:38 CDT 2011
Total time = 1m 21s
*** finished tests in loyalty ***
Testing freedom
ssh freedom -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname freedom
12:11AM  up 6 days, 13:46, 3 users, load averages: 0.00, 0.00, 0.00
/dev/da0s1a         507630     70670    396350    15%    /
/dev/da0s1g       45184754   8368304  33201670    20%    /local_home
/dev/da0s1f       24372460   3835876  18586788    17%    /usr
/dev/da0s1d        2026030    159670   1704278     9%    /var
/dev/da0s1e        1012974       108    931830     0%    /var/tmp
jam:/home        198351840  13805664 174307816     7%    /usr/home
jam:/mnt/scr1    961432072 830433052  82161020    91%    /mnt/scr1
TEST_TYPES=standard
Tue May  3 00:11:20 CDT 2011
*** starting standard tests in freedom ***
Uname -a: FreeBSD freedom.hdfgroup.uiuc.edu 8.2-PRERELEASE FreeBSD 8.2-PRERELEASE #0: Wed Feb  2 14:32:23 CST 2011     sukoziol at freedom.hdfgroup.uiuc.edu:/usr/obj/usr/src/sys/FREEDOM  amd64
   /mnt/scr1/SnapTest/snapshots-opa/log/freedom_0503Tue_0011
*** finished standard tests for freedom ***
Tue May  3 00:12:27 CDT 2011
Total time = 1m 7s
*** finished tests in freedom ***
More information about the opa-nightly-tests mailing list
