[opa-nightly-tests] Fwd: honest3 OPA_Daily_Tests_0817Tue_FAILED!!!
Mike McGreevy mamcgree at hdfgroup.org
Thu Aug 19 12:15:41 CDT 2010
Hi Quincey,
Yes, LT_INIT is all that should be needed.
See: http://www.gnu.org/software/libtool/manual/html_node/LT_005fINIT.html
- Mike
Quincey Koziol wrote:
> Hi Mike,
> Begin forwarded message:
>> From: Dave Goodell <goodell at mcs.anl.gov>
>> Date: August 19, 2010 11:52:25 AM CDT
>> To: lrknox at hdfgroup.org
>> Cc: "'Quincey Koziol'" <koziol at hdfgroup.org>, "'Neil Fortner'" <nfortne2 at hdfgroup.org>, opa-nightly-tests at lists.mcs.anl.gov
>> Subject: Re: [opa-nightly-tests] honest3 OPA_Daily_Tests_0817Tue_FAILED!!!
>> On Aug 17, 2010, at 5:17 PM CDT, Larry Knox wrote:
>>> I also ended up
>>> adding AC_PROG_LIBTOOL before LT_INIT(disable-shared) in configure.in.
>> Was this really necessary?  My understanding is that AC_PROG_LIBTOOL is the older, deprecated name for LT_INIT.  LT_INIT alone should be OK...
> 	Do you know if this is true?
> 		Thanks,
> 			Quincey
More information about the opa-nightly-tests mailing list
