[opa-nightly-tests] Fwd: honest3 OPA_Daily_Tests_0817Tue_FAILED!!!
Quincey Koziol
koziol at hdfgroup.org
Thu Aug 19 12:11:48 CDT 2010
Hi Mike,
Begin forwarded message:
> From: Dave Goodell <goodell at mcs.anl.gov>
> Date: August 19, 2010 11:52:25 AM CDT
> To: lrknox at hdfgroup.org
> Cc: "'Quincey Koziol'" <koziol at hdfgroup.org>, "'Neil Fortner'" <nfortne2 at hdfgroup.org>, opa-nightly-tests at lists.mcs.anl.gov
> Subject: Re: [opa-nightly-tests] honest3 OPA_Daily_Tests_0817Tue_FAILED!!!
> On Aug 17, 2010, at 5:17 PM CDT, Larry Knox wrote:
>> I also ended up
>> adding AC_PROG_LIBTOOL before LT_INIT(disable-shared) in configure.in.
> Was this really necessary? My understanding is that AC_PROG_LIBTOOL is the older, deprecated name for LT_INIT. LT_INIT alone should be OK...
Do you know if this is true?
Quincey
More information about the opa-nightly-tests
