[opa-nightly-tests] Fwd: honest3 OPA_Daily_Tests_0817Tue_FAILED!!!
Larry Knox lrknox at hdfgroup.org
Thu Aug 19 14:44:58 CDT 2010
Ok, I tried again, starting from scratch.
The installed version of autoreconf on jam is 2.59.  Running "autoreconf
-vif" in the opa source directory returns an error message:  Autoconf
version 2.62 or higher is required.  Using 2.62 returns the same message, so
I used 2.65, the version we currently use for hdf5 (we'll soon move to 2.67,
but I think 2.65 should be fine).  When I used autoconf 2.65 before, the
installed versions of m4, automake, and libtool were also too old, so I used
all the current versions that hdf5 uses (from hdf5_1_8/bin/reconfigure):
# HDF5 currently uses the following versions of the autotools:
AUTOCONF_VERSION="autoconf (GNU Autoconf) 2.65"
AUTOMAKE_VERSION="automake (GNU automake) 1.11.1"
AUTOHEADER_VERSION="autoheader (GNU Autoconf) 2.65"
ACLOCAL_VERSION="aclocal (GNU automake) 1.11.1"
LIBTOOL_VERSION="(GNU libtool) 2.2.6b-mcg"
PATH=/mnt/hdf/packages/m4/m4-1.4.7/bin:/mnt/hdf/packages/m4/m4-1.4.7/share:$
PATH
I still got the message about adding AC_PROG_LIBTOOL to configure.in, but
consulting Mike learned that I needed to run "libtoolize" before "autoreconf
-vif".
This works and the tests pass.  However, the following files are generated
by running "libtoolize":
?       confdb/ltsugar.m4
?       confdb/libtool.m4
?       confdb/ltversion.m4
?       confdb/lt~obsolete.m4
?       confdb/config.guess
?       confdb/ltoptions.m4
?       confdb/config.sub
?       confdb/ltmain.sh
These all seem to be necessary for the updated configure.  Do we check them
in, or does someone know a way around to avoid that?
Larry
-----Original Message-----
From: Mike McGreevy [mailto:mamcgree at hdfgroup.org]
Sent: Thursday, August 19, 2010 12:16 PM
To: Quincey Koziol
Cc: Larry Knox; Neil Fortner; opa-nightly-tests at lists.mcs.anl.gov
Subject: Re: Fwd: [opa-nightly-tests] honest3
Hi Quincey,
Yes, LT_INIT is all that should be needed.
See: http://www.gnu.org/software/libtool/manual/html_node/LT_005fINIT.html
- Mike
Quincey Koziol wrote:
> Hi Mike,
> Begin forwarded message:
>> From: Dave Goodell <goodell at mcs.anl.gov>
>> Date: August 19, 2010 11:52:25 AM CDT
>> To: lrknox at hdfgroup.org
>> Cc: "'Quincey Koziol'" <koziol at hdfgroup.org>, "'Neil Fortner'"
<nfortne2 at hdfgroup.org>, opa-nightly-tests at lists.mcs.anl.gov
>> Subject: Re: [opa-nightly-tests] honest3
>> On Aug 17, 2010, at 5:17 PM CDT, Larry Knox wrote:
>>> I also ended up
>>> adding AC_PROG_LIBTOOL before LT_INIT(disable-shared) in configure.in.
>> Was this really necessary?  My understanding is that AC_PROG_LIBTOOL is
the older, deprecated name for LT_INIT.  LT_INIT alone should be OK...
> 	Do you know if this is true?
> 		Thanks,
> 			Quincey
More information about the opa-nightly-tests mailing list
