[opa-nightly-tests] honest3 OPA_Daily_Tests_0817Tue_FAILED!!!
Larry Knox
lrknox at hdfgroup.org
Tue Aug 17 17:17:44 CDT 2010
Hi Quincey,
Neil took a look and it worked for him fairly easily. Making it work on jam
in the daily test took a fair bit of twiddling with the path to get
acceptable versions of autotools, autoconf, and libtool. I also ended up
adding AC_PROG_LIBTOOL before LT_INIT(disable-shared) in configure.in. This
created 8 new files in confdb.
Svn update won't change the new files, and I think all of our tests sync
from this source, so I'm going to leave it at this for tonight and we can
review it tomorrow after tonight's run.
Larry
-----Original Message-----
From: Quincey Koziol [mailto:koziol at hdfgroup.org]
Sent: Tuesday, August 17, 2010 8:05 AM
To: Larry Knox; Neil Fortner
Cc: opa-nightly-tests at lists.mcs.anl.gov
Subject: Fwd: [opa-nightly-tests] honest3 OPA_Daily_Tests_0817Tue_FAILED!!!
Hi Larry/Neil,
Can you take care of this?
Quincey
Begin forwarded message:
> From: Dave Goodell <goodell at mcs.anl.gov>
> Date: August 17, 2010 7:59:03 AM CDT
> To: opa-nightly-tests at lists.mcs.anl.gov
> Subject: Re: [opa-nightly-tests] honest3 OPA_Daily_Tests_0817Tue_FAILED!!!
> Pavan updated OPA yesterday to use libtool in the build system. The
source trees need an "autoreconf -vif" run.
> -Dave
> On Aug 17, 2010, at 1:05 AM CDT, HDFTEST Community User wrote:
>> *** OPA Tests on 0817Tue ***
>> Tests Summary
>> ****FAILED honest1: standard****
>> Tests Time Summary
>> honest1: Ran 1(0/1/0) tests, Grand total test time = 0m 4s
>> honest3: Ran 1(0/0/0) hosts, Grand total test time = 0m 58s
>> Timekeeper log
>> Timekeeper started at Tue Aug 17 01:04:59 CDT 2010
>> Timekeeper sleeping for 1800 seconds
>> Tests Failures
>> Dumping logfile of honest1: standard
>> Last 50 lines of /u/ac/hdftest/snapshots-opa/log/honest1_0817Tue_0105
>> PBS_DEFAULT=abem5.ncsa.uiuc.edu
>> PKG_CONFIG_PATH=/usr/local/lib64/pkgconfig
>> PLATFORM=linux-rhel4-x86_64
>> PWD=/u/ac/hdftest/snapshots-opa
>> SHELL=/bin/tcsh
>> SHLVL=3
>> SOFTENV_ALIASES=/usr/local/softenv-1.6.2-r3/etc/softenv-aliases.csh
>> SOFTENV_LOAD=/usr/local/softenv-1.6.2-r3/etc/softenv-load.csh
>> SSH_CLIENT=141.142.31.132 42984 22
>> SSH_CONNECTION=141.142.31.132 42984 141.142.31.130 22
>> TG_APPS_PREFIX=/usr/local
>> TOTALVIEW=/usr/apps/tools/toolworks/totalview/bin/totalview
>> TOTALVIEW_HOME=/usr/apps/tools/toolworks/totalview
>> TVDSVRLAUNCHCMD=ssh
>> USER=hdftest
>> VENDOR=unknown
>> VMI_SPECFILE=/opt/vmi-2.2.0-1-gcc/specfiles/openfabric.xml
>> WHATAMI=linux-rhel4-x86_64
>> _=/usr/bin/printenv
>> ===Done Dumping environment variables after option parsing ===
>> Configure command is configure --prefix=${PWD}/opainstall
>> CURRENT is /u/ac/hdftest/snapshots-opa/current
>> ===== Run Tests: Tue Aug 17 01:05:15 CDT 2010 =====
>> Check to see if TESTDIR /u/ac/hdftest/snapshots-opa/TestDir/honest1
exists
>> /bin/sh ./config.status --recheck
>> running CONFIG_SHELL=/bin/sh /bin/sh
/u/ac/hdftest/snapshots-opa/current/configure --prefix=${PWD}/opainstall
--no-create --no-recursion
>> checking for a BSD-compatible install... /usr/bin/install -c
>> checking whether build environment is sane... yes
>> checking for a thread-safe mkdir -p... /bin/mkdir -p
>> checking for gawk... gawk
>> checking whether gmake sets $(MAKE)... yes
>> /u/ac/hdftest/snapshots-opa/current/configure: line 2342: syntax error
near unexpected token `2.2.6'
`LT_PREREQ(2.2.6)'
>> gmake: *** [config.status] Error 2
>> TESTDIR is /u/ac/hdftest/snapshots-opa/TestDir/honest1
>> snapshot is yes
>> ===== configure: Tue Aug 17 01:05:16 CDT 2010 =====
`LT_PREREQ(2.2.6)'
>> Failed running configure
>> ===== Exit bin/snapshot with status=2: Tue Aug 17 01:05:18 CDT 2010 =====
>> Dumping done
>> Runtest did not exit normally.
>> Watchers List
>> OPA Daily test features/platforms watchers and procedure
>> Procedure:
>> The watcher will investigate and report the cause of failure by 11am.
>> The developer who checked in the error code may report so by then too.
>> The watcher or the developer should get the failure fixed and report it
>> by 3pm.
>> Watcher for OPA: Neil
>> updated: 2009/05/05
>> Tests Details
>> Testing all hosts.
>> opa
>> 01:04:40 up 19 days, 10:12, 28 users, load average: 0.06, 0.10, 0.40
>> Filesystem 1K-blocks Used Available Use% Mounted on
>> none 8218016 0 8218016 0% /dev/shm
>> abem4:/var/lib/perceus/
>> 74763440 42299920 28665712 60% /var/lib/perceus
>> 10.1.69.1:/usr/src 138916864 99971520 31888736 76% /usr/src
>> /dev/sda3 29463920 47088 29119552 1% /tmp
>> abe-mgs01-ib at o2ib:abe-mgs02-ib at o2ib:/apps
>> 3385032528 620743632 2592338856 20% /usr/apps
>> abe-mgs01-ib at o2ib:abe-mgs02-ib at o2ib:/home
>> 55567516032 19180819132 33609246924 37% /u
>> abe-mgs01-ib at o2ib:abe-mgs02-ib at o2ib:/local
>> 3385032528 124240920 3111768192 4% /usr/local
>> abem5:/var/spool/torque/server_logs
>> 961428816 201451344 711139632 23%
>> abem5:/var/spool/torque/server_priv/accounting
>> 73575600 56692832 13084960 82%
>> pop:/var/forward 70557056 65120056 1852904 98% /var/forward
>> abe-mgs01-ib at o2ib:abe-mgs02-ib at o2ib:/scratch
>> 276891315456 155142158488 111900655348 59%
/cfs/scratch
>> abe-mgs01-ib at o2ib:abe-mgs02-ib at o2ib:/projects
>> 92298352896 67398023772 23493778892 75% /cfs/projects
>> STANDARD_OPT=setenv MAKE gmake op-configure --prefix=${PWD}/opainstall
>> TEST_TYPES=standard
>> Running source repository checkout with output saved in
>> /u/ac/hdftest/snapshots-opa/log/REPO_LOG_0817Tue
>> Checking MANIFEST file ...
>> cat: /u/ac/hdftest/snapshots-opa/log/#runtest.0817Tue.21063: No such file
or directory
>> rm: cannot remove
`/u/ac/hdftest/snapshots-opa/log/#runtest.0817Tue.21063': No such file or
directory
>> *** launching tests from honest3 ***
>> TESTHOST is honest1
>> Fork off timekeeper 30
>> Testing honest1
>> ssh honest1 -n cd
/u/ac/hdftest/snapshots-opa;/u/ac/hdftest/snapshots-opa/bin/runtest -nodiff
-norepo -configname honest1
>> Using configname option for -configname
>> opa
>> 01:05:04 up 19 days, 10:13, 30 users, load average: 0.22, 0.20, 0.41
>> abem2:/var/lib/perceus/
>> 74763440 49226688 21738944 70% /var/lib/perceus
>> /dev/sda2 63013156 360476 62019880 1% /tmp
>> 55567516032 19181750692 33608305220 37% /u
>> 3385032528 124240988 3111768244 4% /usr/local
>> 961428816 201451440 711139536 23%
>> 73575600 56693104 13084688 82%
>> pop:/var/forward 70557056 65120128 1852832 98% /var/forward
>> 276891315456 155142436308 111900519492 59%
/cfs/scratch
>> TEST_TYPES=standard
>> Running standard
>> *** starting standard tests in honest1 ***
>> Uname -a: Linux honest1.ncsa.uiuc.edu
2.6.18-92.1.10.el5_lustre.1.6.6smp-perfctr #7 SMP Tue Nov 10 10:41:00 CST
2009 x86_64 x86_64 x86_64 GNU/Linux
>> SRCDIRNAME is honest1
>> Running snapshot with output saved in
>> SNAPCMD is srcdir test clean
>> SNAPCMD_OPT is setenv MAKE gmake op-configure --prefix=${PWD}/opainstall
zlib /usr/local/include,/usr/local/lib srcdirname honest1
>> *** finished standard tests for honest1 ***
>> Total time = 0m 3s
>> *** finished tests in honest1 ***
>> ****SYSTEM ERROR honest1: Abnormal exit from runtest ****
>> Tue Aug 17 01:05:48 CDT 2010
>> ****SYSTEM ERROR honest1: runtest command failed ****
>> *** finished tests in honest3 ***
>> opa-nightly-tests mailing list
>> https://lists.mcs.anl.gov/mailman/listinfo/opa-nightly-tests
More information about the opa-nightly-tests
