[opa-nightly-tests] honest3 OPA_Daily_Tests_0817Tue_FAILED!!!
Quincey Koziol koziol at hdfgroup.org
Tue Aug 17 17:19:10 CDT 2010
Hi Larry,
On Aug 17, 2010, at 5:17 PM, Larry Knox wrote:
> Hi Quincey,
> Neil took a look and it worked for him fairly easily.  Making it work on jam
> in the daily test took a fair bit of twiddling with the path to get
> acceptable versions of autotools, autoconf, and libtool.  I also ended up
> adding AC_PROG_LIBTOOL before LT_INIT(disable-shared) in configure.in.  This
> created 8 new files in confdb.
> Svn update won't change the new files, and I think all of our tests sync
> from this source, so I'm going to leave it at this for tonight and we can
> review it tomorrow after tonight's run.
	Cool, thanks,
		Quincey
> Larry
> -----Original Message-----
> From: Quincey Koziol [mailto:koziol at hdfgroup.org]
> Sent: Tuesday, August 17, 2010 8:05 AM
> To: Larry Knox; Neil Fortner
> Cc: opa-nightly-tests at lists.mcs.anl.gov
> Subject: Fwd: [opa-nightly-tests] honest3 OPA_Daily_Tests_0817Tue_FAILED!!!
> Hi Larry/Neil,
> 	Can you take care of this?
> 	Thanks,
> 		Quincey
> Begin forwarded message:
>> From: Dave Goodell <goodell at mcs.anl.gov>
>> Date: August 17, 2010 7:59:03 AM CDT
>> To: opa-nightly-tests at lists.mcs.anl.gov
>> Subject: Re: [opa-nightly-tests] honest3 OPA_Daily_Tests_0817Tue_FAILED!!!
>> Pavan updated OPA yesterday to use libtool in the build system.  The
> source trees need an "autoreconf -vif" run.
>> -Dave
>> On Aug 17, 2010, at 1:05 AM CDT, HDFTEST Community User wrote:
>>> *** OPA Tests on 0817Tue ***
>>> Tests Summary
>>> ****FAILED honest1: standard****
>>> Tests Time Summary
>>> honest1: Ran 1(0/1/0) tests, Grand total test time =  0m 4s
>>> honest3: Ran 1(0/0/0) hosts, Grand total test time =  0m 58s
>>> Timekeeper log
>>> Timekeeper started at Tue Aug 17 01:04:59 CDT 2010
>>> Timekeeper sleeping for 1800 seconds
>>> Tests Failures
>>> Dumping logfile of honest1: standard
>>> Last 50 lines of /u/ac/hdftest/snapshots-opa/log/honest1_0817Tue_0105
>>> PBS_DEFAULT=abem5.ncsa.uiuc.edu
>>> PKG_CONFIG_PATH=/usr/local/lib64/pkgconfig
>>> PLATFORM=linux-rhel4-x86_64
>>> PWD=/u/ac/hdftest/snapshots-opa
>>> SHELL=/bin/tcsh
>>> SHLVL=3
>>> SOFTENV_ALIASES=/usr/local/softenv-1.6.2-r3/etc/softenv-aliases.csh
>>> SOFTENV_LOAD=/usr/local/softenv-1.6.2-r3/etc/softenv-load.csh
>>> SSH_CLIENT=141.142.31.132 42984 22
>>> SSH_CONNECTION=141.142.31.132 42984 141.142.31.130 22
>>> TG_APPS_PREFIX=/usr/local
>>> TOTALVIEW=/usr/apps/tools/toolworks/totalview/bin/totalview
>>> TOTALVIEW_HOME=/usr/apps/tools/toolworks/totalview
>>> TVDSVRLAUNCHCMD=ssh
>>> USER=hdftest
>>> VENDOR=unknown
>>> VMI_SPECFILE=/opt/vmi-2.2.0-1-gcc/specfiles/openfabric.xml
>>> WHATAMI=linux-rhel4-x86_64
>>> _=/usr/bin/printenv
>>> ===Done Dumping environment variables after option parsing ===
>>> Configure command is configure  --prefix=${PWD}/opainstall
>>> CURRENT is /u/ac/hdftest/snapshots-opa/current
>>> ===== Run Tests: Tue Aug 17 01:05:15 CDT 2010 =====
>>> Check to see if TESTDIR /u/ac/hdftest/snapshots-opa/TestDir/honest1
> exists
>>> /bin/sh ./config.status --recheck
>>> running CONFIG_SHELL=/bin/sh /bin/sh
> /u/ac/hdftest/snapshots-opa/current/configure --prefix=${PWD}/opainstall
> --no-create --no-recursion
>>> checking for a BSD-compatible install... /usr/bin/install -c
>>> checking whether build environment is sane... yes
>>> checking for a thread-safe mkdir -p... /bin/mkdir -p
>>> checking for gawk... gawk
>>> checking whether gmake sets $(MAKE)... yes
>>> /u/ac/hdftest/snapshots-opa/current/configure: line 2342: syntax error
> near unexpected token `2.2.6'
> `LT_PREREQ(2.2.6)'
>>> gmake: *** [config.status] Error 2
>>> TESTDIR is /u/ac/hdftest/snapshots-opa/TestDir/honest1
>>> snapshot is yes
>>> ===== configure: Tue Aug 17 01:05:16 CDT 2010 =====
> `LT_PREREQ(2.2.6)'
>>> Failed running configure
>>> ===== Exit bin/snapshot with status=2: Tue Aug 17 01:05:18 CDT 2010 =====
>>> Dumping done
>>> Runtest did not exit normally.
>>> Watchers List
>>> OPA Daily test features/platforms watchers and procedure
>>> Procedure:
>>> The watcher will investigate and report the cause of failure by 11am.
>>> The developer who checked in the error code may report so by then too.
>>> The watcher or the developer should get the failure fixed and report it
>>> by 3pm.
>>> Watcher for OPA:	 	Neil
>>> updated: 2009/05/05
>>> Tests Details
>>> Testing all hosts.
>>> opa
>>> 01:04:40 up 19 days, 10:12, 28 users,  load average: 0.06, 0.10, 0.40
>>> Filesystem           1K-blocks      Used Available Use% Mounted on
>>> none                   8218016         0   8218016   0% /dev/shm
>>> abem4:/var/lib/perceus/
>>>                    74763440  42299920  28665712  60% /var/lib/perceus
>>> 10.1.69.1:/usr/src   138916864  99971520  31888736  76% /usr/src
>>> /dev/sda3             29463920     47088  29119552   1% /tmp
>>> abe-mgs01-ib at o2ib:abe-mgs02-ib at o2ib:/apps
>>>                   3385032528 620743632 2592338856  20% /usr/apps
>>> abe-mgs01-ib at o2ib:abe-mgs02-ib at o2ib:/home
>>>                   55567516032 19180819132 33609246924  37% /u
>>> abe-mgs01-ib at o2ib:abe-mgs02-ib at o2ib:/local
>>>                   3385032528 124240920 3111768192   4% /usr/local
>>> abem5:/var/spool/torque/server_logs
>>>                   961428816 201451344 711139632  23%
>>> abem5:/var/spool/torque/server_priv/accounting
>>>                    73575600  56692832  13084960  82%
>>> pop:/var/forward      70557056  65120056   1852904  98% /var/forward
>>> abe-mgs01-ib at o2ib:abe-mgs02-ib at o2ib:/scratch
>>>                   276891315456 155142158488 111900655348  59%
> /cfs/scratch
>>> abe-mgs01-ib at o2ib:abe-mgs02-ib at o2ib:/projects
>>>                   92298352896 67398023772 23493778892  75% /cfs/projects
>>> STANDARD_OPT=setenv MAKE gmake op-configure --prefix=${PWD}/opainstall
>>> TEST_TYPES=standard
>>> Running source repository checkout with output saved in
>>> /u/ac/hdftest/snapshots-opa/log/REPO_LOG_0817Tue
>>> Checking MANIFEST file ...
>>> cat: /u/ac/hdftest/snapshots-opa/log/#runtest.0817Tue.21063: No such file
> or directory
>>> rm: cannot remove
> `/u/ac/hdftest/snapshots-opa/log/#runtest.0817Tue.21063': No such file or
> directory
>>> *** launching tests from honest3 ***
>>> TESTHOST is honest1
>>>  Fork off timekeeper 30
>>> Testing honest1
>>> ssh honest1 -n cd
> /u/ac/hdftest/snapshots-opa;/u/ac/hdftest/snapshots-opa/bin/runtest -nodiff
> -norepo -configname honest1
>>> Using configname option for -configname
>>> opa
>>> 01:05:04 up 19 days, 10:13, 30 users,  load average: 0.22, 0.20, 0.41
>>> abem2:/var/lib/perceus/
>>>                    74763440  49226688  21738944  70% /var/lib/perceus
>>> /dev/sda2             63013156    360476  62019880   1% /tmp
>>>                   55567516032 19181750692 33608305220  37% /u
>>>                   3385032528 124240988 3111768244   4% /usr/local
>>>                   961428816 201451440 711139536  23%
>>>                    73575600  56693104  13084688  82%
>>> pop:/var/forward      70557056  65120128   1852832  98% /var/forward
>>>                   276891315456 155142436308 111900519492  59%
> /cfs/scratch
>>> TEST_TYPES=standard
>>> Running standard
>>> *** starting standard tests in honest1 ***
>>> Uname -a: Linux honest1.ncsa.uiuc.edu
> 2.6.18-92.1.10.el5_lustre.1.6.6smp-perfctr #7 SMP Tue Nov 10 10:41:00 CST
> 2009 x86_64 x86_64 x86_64 GNU/Linux
>>> SRCDIRNAME is honest1
>>> Running snapshot with output saved in
>>> SNAPCMD is srcdir test clean
>>> SNAPCMD_OPT is setenv MAKE gmake op-configure --prefix=${PWD}/opainstall
> zlib /usr/local/include,/usr/local/lib srcdirname honest1
>>> *** finished standard tests for honest1 ***
>>> Total time = 0m 3s
>>> *** finished tests in honest1 ***
>>> ****SYSTEM ERROR honest1: Abnormal exit from runtest ****
>>> 	Tue Aug 17 01:05:48 CDT 2010
>>> 	****SYSTEM ERROR honest1: runtest command failed ****
>>> *** finished tests in honest3 ***
>>> _______________________________________________
>>> opa-nightly-tests mailing list
>>> https://lists.mcs.anl.gov/mailman/listinfo/opa-nightly-tests
More information about the opa-nightly-tests mailing list
